- 16-Security Command Reference
- 01-ACL commands
- 02-APR commands
- 03-ARP attack protection commands
- 04-ASPF commands
- 05-IP source guard commands
- 06-IPsec commands
- 07-ND attack defense commands
- 08-Password control commands
- 09-PKI commands
- 10-SSH commands
- 11-SSL commands
- 12-SSL VPN commands
- 13-URL filtering commands
- 14-User profile commands
- 15-Bandwidth management commands
- 16-Public key management commands
- 17-Attack detection and prevention commands
- 18-Session management commands
- 19-Connection limit commands
- 20-Crypto engine commands
- 21-Time range commands
- 22-Protocol packet rate limit commands
- 23-DPI engine commands
| 05-IP source guard commands | 43.08 KB |
ip verify source
Use ip verify source to enable the IPSG feature for IPv4.
Use undo ip verify source to disable the IPSG feature for IPv4.
ip verify source
The IPSG feature is disabled for IPv4.
Service template view
This feature uses WLAN snooping entries to filter IPv4 packets received by an AP. It drops packets that do not match the entries. A WLAN snooping entry is an IP-MAC binding.
In an IPv4 network, IPSG uses only the WLAN snooping entries obtained through DHCP packets.
# Enable the IPSG feature for IPv4.
[Sysname] wlan service-template security
[Sysname-wlan-st-security] ip verify source
ip verify unknown-ip
Use ip verify unknown-ip to configure the processing method for packets from unknown source IPv4 addresses received by APs.
Use undo ip verify unknown-ip to restore the default.
ip verify unknown-ip { deauthenticate | drop }
An AP drops packets from unknown source IPv4 addresses and sends deauthentication frames to the sources.
deauthenticate: Drops packets from unknown source IPv4 addresses and sends deauthentication frames to the sources.
drop: Drops packets from unknown source IPv4 addresses only.
Unknown source IPv4 addresses refer to the following addresses:
· IPv4 addresses learned from ARP packets that are intercepted by APs.
· IPv4 addresses that have not been learned by APs.
This command is configurable only when the service template is disabled.
This command takes effect only when the IPSG feature is enabled for IPv4.
# Configure APs to drop packets from unknown source IPv4 addresses.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] ip verify unknown-ip drop
ipv6 verify source
Use ipv6 verify source to enable the IPSG feature for IPv6.
Use undo ipv6 verify source to disable the IPSG feature for IPv6.
ipv6 verify source
The IPSG feature is disabled for IPv6.
This feature uses WLAN snooping entries to filter IPv6 packets received by an AP. It drops packets that do not match the entries. A WLAN snooping entry is an IP-MAC binding.
# Enable the IPSG feature for IPv6.
[Sysname-wlan-st-security] ipv6 verify source
