10-High Availability Configuration Guide
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R3606)-6W10010-High Availability Configuration Guide
06-Smart Link configuration
06-Smart Link configuration 221.11 KB
Configuring Smart Link
About Smart Link
Application scenario
Smart Link provides link redundancy and subsecond convergence time in a dual uplink network. As shown in Figure 1, Smart Link is configured on Device C and Device D. The secondary link takes over quickly when the primary link fails.
Figure 1 Dual uplink network diagram
A Smart Link network has the following devices:
·     Smart Link devices—A Smart Link device has two uplinks. A Smart Link device must be configured with a smart link group and a transmit control VLAN to transmit flush messages. Device C and Device D in Figure 1 are Smart Link devices.
·     Associated devices—An associated device is an uplink device to which Smart Link devices are connected. An associated device supports Smart Link, and receives flush messages sent from the specified control VLAN. When a primary/secondary link switchover occurs, the associated device updates the MAC address entries and ARP/ND entries according to received flush messages. Device A, Device B, and Device E in Figure 1 are associated devices.
Terminology
Smart link group
A smart link group consists of only two member ports: the primary and the secondary ports. Only one port is active for forwarding at a time, and the other port is blocked and in standby state. When link failure occurs on the active port due to port shutdown or the presence of unidirectional link, the standby port becomes active and takes over. The original active port transits to the blocked state.
As shown in Figure 1, Port C1 and Port C2 of Device C form a smart link group. Port C1 is active, and Port C2 is standby. Port D1 and Port D2 of Device D form another smart link group. Port D1 is active, and Port D2 is standby.
Primary/secondary port
Primary port and secondary port are two port types in a smart link group. When both ports in a smart link group are up, the primary port preferentially transits to the forwarding state. The secondary port stays in standby state. When the primary port fails, the secondary port takes over to forward traffic.
As shown in Figure 1, Port C1 of Device C and Port D1 of Device D are primary ports. Port C2 of Device C and Port D2 of Device D are secondary ports.
Primary/secondary link
The link that connects the primary port in a smart link group is the primary link. The link that connects the secondary port is the secondary link.
Flush message
When link switchover occurs, the smart link group uses flush messages to notify other devices to refresh their MAC address entries and ARP/ND entries. Flush messages are common multicast data packets, and will be dropped by a blocked receiving port.
Protected VLAN
A smart link group controls the forwarding state of protected VLANs. Each smart link group on a port controls a different protected VLAN. The state of the port in a protected VLAN is determined by the state of the port in the smart link group.
Transmit control VLAN
The transmit control VLAN is used for transmitting flush messages. When link switchover occurs, the devices (such as Device C and Device D in Figure 1) send flush messages within the transmit control VLAN.
Receive control VLAN
The receive control VLAN is used for receiving and processing flush messages. When link switchover occurs, the devices (such as Device A, Device B, and Device E in Figure 1) receive and process flush messages in the receive control VLAN. In addition, they refresh their MAC address entries and ARP/ND entries.
How Smart Link works
Link backup
As shown in Figure 1, the link on Port C1 of Device C is the primary link. The link on Port C2 of Device C is the secondary link. Port C1 is in forwarding state, and Port C2 is in standby state. When the primary link fails, Port C2 takes over to forward traffic and Port C1 is blocked and placed in standby state.
When a port switches to the forwarding state, the system outputs log information to notify the user of the port state change.
Topology change
Link switchover might outdate the MAC address entries and ARP/ND entries on all devices. A flush update mechanism is provided to ensure correct packet transmission. With this mechanism, a Smart Link-enabled device updates its information by transmitting flush messages over the backup link to its upstream devices. This mechanism requires the upstream devices to be capable of recognizing Smart Link flush messages to update their MAC address forwarding entries and ARP/ND entries.
Preemption mode
As shown in Figure 1, the link on Port C1 of Device C is the primary link. The link on Port C2 of Device C is the secondary link. When the primary link fails, Port C1 is automatically blocked and placed in standby state, and Port C2 takes over to forward traffic. When the primary link recovers, one of the following actions occurs:
·     If the smart link group is not configured with a preemption mode, Port C1 stays blocked to keep traffic forwarding stable. Port C1 does not take over to forward traffic until the next link switchover.
·     If the smart link group is configured with a preemption mode and the preemption conditions are met, Port C1 takes over to forward traffic as soon as its link recovers. Port C2 is automatically blocked and placed in standby state.
Load sharing
A ring network might carry traffic of multiple VLANs. Smart Link can forward traffic from different VLANs in different smart link groups for load sharing.
To implement load sharing, you can assign a port to multiple smart link groups. Configure each group with a different protected VLAN. Make sure the state of the port is different in these smart link groups, so traffic from different VLANs can be forwarded along different paths.
You can configure protected VLANs for a smart link group by referencing Multiple Spanning Tree Instances (MSTIs). For more information about MSTIs, see Layer 2—LAN Switching Configuration Guide.
Collaboration between Smart Link and Monitor Link for port status detection
Smart Link cannot detect when faults occur on the uplink of the upstream devices or when faults are cleared. You can configure the Monitor Link function to monitor the status of the uplink ports of the upstream devices. Monitor Link adapts the up/down state of downlink ports to uplink ports, and triggers Smart Link to perform link switchover on the downstream device. For more information about Monitor Link, see "Configuring Monitor Link."
Collaboration between Smart Link and Track for link status detection
Smart Link cannot detect unidirectional links, misconnected fibers, or packet loss on intermediate devices or network paths of the uplink. It cannot detect when faults are cleared either. To detect link status, smart link group member ports must use link detection protocols. When a fault is detected or cleared, the link detection protocols inform Smart Link to switch over the links.
Smart Link collaborates with link detection protocols through track entries. It supports only the Continuity Check (CC) function of Connectivity Fault Detection (CFD) to implement link detection. CFD notifies the smart link group member ports of fault detection events by using detection VLANs and detection ports. A port responds to a continuity check event only when the control VLAN of the smart link group to which it belongs matches the detection VLAN. For more information about track entries and the CC function of CFD, see "Configuring Track" and "Configuring CFD."
Restrictions and guidelines: Smart Link configuration
If you configure a port as both an aggregation group member and a smart link group member, only the aggregation group configuration takes effect. The port is not shown in the output from the display smart-link group command. The smart link group configuration takes effect after the port leaves the aggregation group.
Smart Link tasks at a glance
To configure Smart Link, perform the following tasks:
1.     Configuring a Smart Link device
a.     Configuring protected VLANs for a smart link group
b.     Configuring member ports for a smart link group
c.     (Optional.) Configuring a preemption mode for a smart link group
d.     (Optional.) Enabling the sending of flush messages
e.     (Optional.) Configuring collaboration between Smart Link and Track
2.     Enabling an associated device to receive flush messages
Prerequisites for Smart Link device configuration
Before configuring a Smart Link device, complete the following tasks:
·     To prevent loops, shut down a port before configuring it as a smart link group member. You can bring up the port only after completing the smart link group configuration.
·     Disable the spanning tree feature, RRPP, and ERPS on the ports you want to add to the smart link group.
Before you configure protected VLANs, you must configure an MST region and the VLAN-to-instance mapping table. For more information about MST regions, see spanning tree configuration in Layer 2—LAN Switching Configration Guide.
2.     Create a smart link group and enter smart link group view.
smart-link group group-id
3.     Configure protected VLANs for the smart link group.
You can configure member ports for a smart link group either in smart link group view or in interface view. The configurations made in these two views have the same effect.
In smart link group view
3.     Configure member ports for a smart link group.
port interface-type interface-number { primary | secondary }
By default, no member port is configured for a smart link group.
In interface view
2.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
port smart-link group group-id { primary | secondary }
By default, an interface is not a smart link group member.
2.     Enter smart link group view.
3.     Configure a preemption mode for the smart link group.
preemption mode { role | speed [ threshold threshold-value ] }
By default, preemption is disabled.
4.     Configure the preemption delay.
preemption delay delay
By default, the preemption delay is 1 second.
The preemption delay configuration takes effect only after a preemption mode is configured.
·     The control VLAN configured for a smart link group must be different from the control VLAN configured for any other smart link group.
·     Make sure the configured control VLAN already exists, and assign the smart link group member ports to the control VLAN.
·     The control VLAN of a smart link group must also be one of its protected VLANs. Do not remove the control VLAN. Otherwise, flush messages cannot be sent correctly.
3.     Enable flush update.
flush enable [ control-vlan vlan-id ]
By default, flush update is enabled, and VLAN 1 is the control VLAN.
Smart Link collaborates with the CC function of CFD through track entries to implement link detection.
Before you configure collaboration between Smart Link and Track on a port, you must assign the port to the smart link group.
3.     Configure collaboration between Smart Link and Track on the port.
port smart-link group group-id track track-entry-number
By default, smart link group member ports do not collaborate with track entries.
·     You do not need to enable all ports on the associated devices to receive flush messages. Enable the feature only on all control VLANs of ports on the primary and secondary links between the Smart Link device and the destination device.
·     If no control VLAN is specified for processing flush messages, the device forwards the received flush messages without any processing.
·     Make sure the receive control VLAN is the same as the transmit control VLAN configured on the Smart Link device. If they are not the same, the associated device will forward the received flush messages directly without any processing.
·     Do not remove the control VLANs. Otherwise, flush messages cannot be sent correctly.
·     Make sure the control VLANs are existing VLANs, and assign the ports capable of receiving flush messages to the control VLANs.
Disable the spanning tree feature on the associated device's ports that connect to the member ports of the smart link group. Otherwise, the ports will discard flush messages when they are not in forwarding state if a topology change occurs.
3.     Configure the control VLANs for receiving flush messages.
smart-link flush enable [ control-vlan vlan-id-list ]
By default, no control VLAN receives flush messages.
Display and maintenance commands for Smart Link
Execute display commands in any view and the reset command in user view:
Display information about the received flush messages.
display smart-link flush
Display smart link group information.
display smart-link group { group-id | all }
Clear the statistics about flush messages.
reset smart-link statistics
Smart Link configuration examples
Example: Configuring a single smart link group
As shown in Figure 2:
·     Device C and Device D are Smart Link devices. Device A, Device B, and Device E are associated devices. Traffic of VLANs 1 through 30 on Device C and Device D is dually uplinked to Device A.
·     Configure Smart Link on Device C and Device D for dual uplink backup.
Figure 2 Network diagram
IMPORTANT
IMPORTANT:
·     By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
·     By default, interfaces on the device operate in Layer 3 mode. In this example, the interfaces must operate in Layer 2 mode. You can use the port link-mode command to change the link mode of an interface.
1.     Configure Device C:
# Create VLANs 1 through 30.
<DeviceC> system-view
[DeviceC] vlan 1 to 30
# Map these VLANs to MSTI 1.
[DeviceC-mst-region] instance 1 vlan 1 to 30
# Activate the MST region configuration.
[DeviceC-mst-region] quit
# Shut down HundredGigE 1/0/1.
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] shutdown
# Disable the spanning tree feature on the port.
[DeviceC-HundredGigE1/0/1] undo stp enable
# Configure the port as a trunk port.
[DeviceC-HundredGigE1/0/1] port link-type trunk
# Assign the port to VLANs 1 through 30.
[DeviceC-HundredGigE1/0/1] port trunk permit vlan 1 to 30
[DeviceC-HundredGigE1/0/1] quit
# Configure HundredGigE 1/0/2 in the same way HundredGigE 1/0/1 is configured.
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] shutdown
[DeviceC-HundredGigE1/0/2] undo stp enable
[DeviceC-HundredGigE1/0/2] port link-type trunk
[DeviceC-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceC-HundredGigE1/0/2] quit
# Create smart link group 1, and configure all VLANs mapped to MSTI 1 as the protected VLANs.
[DeviceC] smart-link group 1
[DeviceC-smlk-group1] protected-vlan reference-instance 1
# Configure HundredGigE 1/0/1 as the primary port and HundredGigE 1/0/2 as the secondary port for smart link group 1.
[DeviceC-smlk-group1] port hundredgige 1/0/1 primary
[DeviceC-smlk-group1] port hundredgige 1/0/2 secondary
# Enable flush message sending in smart link group 1, and configure VLAN 10 as the transmit control VLAN.
[DeviceC-smlk-group1] flush enable control-vlan 10
[DeviceC-smlk-group1] quit
# Bring up HundredGigE 1/0/1 and HundredGigE 1/0/2 again.
[DeviceC-HundredGigE1/0/1] undo shutdown
[DeviceC-HundredGigE1/0/2] undo shutdown
2.     Configure Device D:
<DeviceD> system-view
[DeviceD] vlan 1 to 30
[DeviceD-mst-region] instance 1 vlan 1 to 30
[DeviceD-mst-region] quit
[DeviceD] interface hundredgige 1/0/1
[DeviceD-HundredGigE1/0/1] shutdown
[DeviceD-HundredGigE1/0/1] undo stp enable
[DeviceD-HundredGigE1/0/1] port link-type trunk
[DeviceD-HundredGigE1/0/1] port trunk permit vlan 1 to 30
[DeviceD-HundredGigE1/0/1] quit
[DeviceD] interface hundredgige 1/0/2
[DeviceD-HundredGigE1/0/2] shutdown
[DeviceD-HundredGigE1/0/2] undo stp enable
[DeviceD-HundredGigE1/0/2] port link-type trunk
[DeviceD-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceD-HundredGigE1/0/2] quit
[DeviceD] smart-link group 1
[DeviceD-smlk-group1] protected-vlan reference-instance 1
[DeviceD-smlk-group1] port hundredgige 1/0/1 primary
[DeviceD-smlk-group1] port hundredgige 1/0/2 secondary
# Enable flush message sending in smart link group 1, and configure VLAN 20 as the transmit control VLAN.
[DeviceD-smlk-group1] flush enable control-vlan 20
[DeviceD-smlk-group1] quit
[DeviceD-HundredGigE1/0/1] undo shutdown
[DeviceD-HundredGigE1/0/2] undo shutdown
3.     Configure Device B:
[DeviceB] vlan 1 to 30
# Configure HundredGigE 1/0/1 as a trunk port.
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port link-type trunk
[DeviceB-HundredGigE1/0/1] port trunk permit vlan 1 to 30
# Enable flush message receiving and configure VLAN 10 and VLAN 20 as the receive control VLANs on the port.
[DeviceB-HundredGigE1/0/1] smart-link flush enable control-vlan 10 20
[DeviceB-HundredGigE1/0/1] quit
# Configure HundredGigE 1/0/2 as a trunk port.
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] port link-type trunk
[DeviceB-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceB-HundredGigE1/0/2] undo stp enable
# Enable flush message receiving and configure VLAN 20 as the receive control VLAN on the port.
[DeviceB-HundredGigE1/0/2] smart-link flush enable control-vlan 20
[DeviceB-HundredGigE1/0/2] quit
# Configure HundredGigE 1/0/3 as a trunk port.
[DeviceB] interface hundredgige 1/0/3
[DeviceB-HundredGigE1/0/3] port link-type trunk
[DeviceB-HundredGigE1/0/3] port trunk permit vlan 1 to 30
[DeviceB-HundredGigE1/0/3] undo stp enable
# Enable flush message receiving and configure VLAN 10 as the receive control VLAN on the port.
[DeviceB-HundredGigE1/0/3] smart-link flush enable control-vlan 10
[DeviceB-HundredGigE1/0/3] quit
4.     Configure Device E:
<DeviceE> system-view
[DeviceE] vlan 1 to 30
[DeviceE] interface hundredgige 1/0/1
[DeviceE-HundredGigE1/0/1] port link-type trunk
[DeviceE-HundredGigE1/0/1] port trunk permit vlan 1 to 30
[DeviceE-HundredGigE1/0/1] smart-link flush enable control-vlan 10 20
[DeviceE-HundredGigE1/0/1] quit
[DeviceE] interface hundredgige 1/0/2
[DeviceE-HundredGigE1/0/2] port link-type trunk
[DeviceE-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceE-HundredGigE1/0/2] undo stp enable
[DeviceE-HundredGigE1/0/2] smart-link flush enable control-vlan 10
[DeviceE-HundredGigE1/0/2] quit
[DeviceE] interface hundredgige 1/0/3
[DeviceE-HundredGigE1/0/3] port link-type trunk
[DeviceE-HundredGigE1/0/3] port trunk permit vlan 1 to 30
[DeviceE-HundredGigE1/0/3] undo stp enable
[DeviceE-HundredGigE1/0/3] smart-link flush enable control-vlan 20
[DeviceE-HundredGigE1/0/3] quit
5.     Configure Device A:
[DeviceA] vlan 1 to 30
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] port link-type trunk
[DeviceA-HundredGigE1/0/1] port trunk permit vlan 1 to 30
[DeviceA-HundredGigE1/0/1] smart-link flush enable control-vlan 10 20
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port link-type trunk
[DeviceA-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceA-HundredGigE1/0/2] smart-link flush enable control-vlan 10 20
[DeviceA-HundredGigE1/0/2] quit
# Display the smart link group configuration on Device C.
[DeviceC] display smart-link group 1
Smart link group 1 information:
  Device ID       : 000f-e23d-5af0
  Preemption mode : None
  Preemption delay: 1(s)
  Control VLAN    : 10
  Protected VLAN  : Reference Instance 1
  Member                  Role      State   Flush-count     Last-flush-time
  HGE1/0/1                PRIMARY   ACTIVE  5               16:45:20 2012/04/21
  HGE1/0/2                SECONDARY STANDBY 1               16:37:20 2012/04/21
# Display the flush messages received on Device B.
[DeviceB] display smart-link flush
 Received flush packets                             : 5
 Receiving interface of the last flush packet       : HundredGigE1/0/3
 Receiving time of the last flush packet            : 16:50:21 2012/04/21
 Device ID of the last flush packet                 : 000f-e23d-5af0
 Control VLAN of the last flush packet              : 10
Example: Configuring multiple smart link groups load sharing
As shown in Figure 3:
·     Device C is a Smart Link device. Device A, Device B, and Device D are associated devices. Traffic of VLANs 1 through 200 on Device C is dually uplinked to Device A by Device B and Device D.
·     Implement dual uplink backup and load sharing on Device C. Traffic of VLANs 1 through 100 is uplinked to Device A by Device B. Traffic of VLANs 101 through 200 is uplinked to Device A by Device D.
Figure 3 Network diagram
IMPORTANT
IMPORTANT:
# Create VLAN 1 through VLAN 200.
[DeviceC] vlan 1 to 200
# Map VLANs 1 through 100 to MSTI 1, and VLANs 101 through 200 to MSTI 2.
[DeviceC-mst-region] instance 1 vlan 1 to 100
[DeviceC-mst-region] instance 2 vlan 101 to 200
# Assign the port to VLAN 1 through VLAN 200.
[DeviceC-HundredGigE1/0/1] port trunk permit vlan 1 to 200
[DeviceC-HundredGigE1/0/2] port trunk permit vlan 1 to 200
# Create smart link group 1, and configure all VLANs mapped to MSTI 1 as the protected VLANs for smart link group 1.
# Enable role preemption in smart link group 1, enable flush message sending, and configure VLAN 10 as the transmit control VLAN.
[DeviceC-smlk-group1] preemption mode role
# Create smart link group 2, and configure all VLANs mapped to MSTI 2 as the protected VLANs for smart link group 2.
[DeviceC] smart-link group 2
[DeviceC-smlk-group2] protected-vlan reference-instance 2
# Configure HundredGigE 1/0/1 as the secondary port and HundredGigE 1/0/2 as the primary port for smart link group 2.
[DeviceC-smlk-group2] port hundredgige 1/0/2 primary
[DeviceC-smlk-group2] port hundredgige 1/0/1 secondary
# Enable role preemption in smart link group 2, enable flush message sending, and configure VLAN 110 as the transmit control VLAN.
[DeviceC-smlk-group2] preemption mode role
[DeviceC-smlk-group2] flush enable control-vlan 110
[DeviceC-smlk-group2] quit
# Bring up HundredGigE 1/0/1 and HundredGigE 1/0/2.
2.     Configure Device B:
[DeviceB] vlan 1 to 200
# Assign the port to VLANs 1 through 200.
[DeviceB-HundredGigE1/0/1] port trunk permit vlan 1 to 200
# Enable flush message receiving and configure VLAN 10 and VLAN 110 as the receive control VLANs on the port.
[DeviceB-HundredGigE1/0/1] smart-link flush enable control-vlan 10 110
[DeviceB-HundredGigE1/0/2] port trunk permit vlan 1 to 200
[DeviceB-HundredGigE1/0/2] smart-link flush enable control-vlan 10 110
3.     Configure Device D:
[DeviceD] vlan 1 to 200
[DeviceD-HundredGigE1/0/1] port trunk permit vlan 1 to 200
[DeviceD-HundredGigE1/0/1] smart-link flush enable control-vlan 10 110
[DeviceD-HundredGigE1/0/2] port trunk permit vlan 1 to 200
[DeviceD-HundredGigE1/0/2] smart-link flush enable control-vlan 10 110
4.     Configure Device A:
[DeviceA] vlan 1 to 200
[DeviceA-HundredGigE1/0/1] port trunk permit vlan 1 to 200
[DeviceA-HundredGigE1/0/1] smart-link flush enable control-vlan 10 110
[DeviceA-HundredGigE1/0/2] port trunk permit vlan 1 to 200
[DeviceA-HundredGigE1/0/2] smart-link flush enable control-vlan 10 110
[DeviceC] display smart-link group all
  Preemption mode : Role
  Control VLAN    : 10
Smart link group 2 information:
  Control VLAN    : 110
  Protected VLAN  : Reference Instance 2
  HGE1/0/2                PRIMARY   ACTIVE  5               16:45:20 2012/04/21
  HGE1/0/1                SECONDARY STANDBY 1               16:37:20 2012/04/21
 Receiving interface of the last flush packet       : HundredGigE1/0/2
 Receiving time of the last flush packet            : 16:25:21 2012/04/21
Example: Configuring Smart Link and Track collaboration
As shown in Figure 4:
·     Device A, Device B, Device C, and Device D form maintenance domain (MD) MD_A of level 5. Device C is a Smart Link device, and Device A, Device B, and Device D are associated devices. Traffic of VLANs 1 through 200 on Device C is dually uplinked to Device A by Device B and Device D.
·     Configure collaboration between Smart Link and the CC function of CFD through track entries to meet the following requirements:
¡     Traffic of VLANs 1 through 100 is uplinked to Device A by Device C through HundredGigE 1/0/1 (primary port of smart link group 1).
¡     Traffic of VLANs 101 through 200 is uplinked to Device A by Device C through HundredGigE 1/0/2 (primary port of smart link group 2).
¡     When the link between Device C and Device A fails, traffic is quickly switched to the secondary port of each smart link group. After the fault is cleared, traffic is switched back to the primary ports.
For more information about CFD, see "Configuring CFD."
Figure 4 Network diagram
IMPORTANT
IMPORTANT:
1.     Configure Device A:
# Enable CFD and create MD MD_A of level 5.
[DeviceA] cfd enable
[DeviceA] cfd md MD_A level 5
# Create service instance 1 in which the MA name is based on the VLAN ID in MD_A and configure the MA to serve VLAN 10.
[DeviceA] cfd service-instance 1 ma-id vlan-based md MD_A vlan 10
# Create a MEP list in service instance 1, create outward-facing MEP 1002, and enable CCM sending in service instance 1 on HundredGigE 1/0/1.
[DeviceA] cfd meplist 1001 1002 service-instance 1
[DeviceA-HundredGigE1/0/1] cfd mep 1002 service-instance 1 outbound
[DeviceA-HundredGigE1/0/1] cfd cc service-instance 1 mep 1002 enable
# Create service instance 2 in which the MA name is based on the VLAN ID in MD_A and configure the MA to serve VLAN 110.
[DeviceA] cfd service-instance 2 ma-id vlan-based md MD_A vlan 110
# Create a MEP list in service instance 2, create outward-facing MEP 1002, and enable CCM sending in service instance 2 on HundredGigE 1/0/2.
[DeviceA] cfd meplist 2001 2002 service-instance 2
[DeviceA-HundredGigE1/0/2] cfd mep 2002 service-instance 2 outbound
[DeviceA-HundredGigE1/0/2] cfd cc service-instance 2 mep 2002 enable
3.     Configure Device C:
# Map VLANs 1 through 100 to MSTI 1 and VLANs 101 through 200 to MSTI 2.
[DeviceC] cfd enable
[DeviceC] cfd md MD_A level 5
[DeviceC] cfd service-instance 1 ma-id vlan-based md MD_A vlan 10
# Create a MEP list in service instance 1. Create outward-facing MEP 1001, and enable CCM sending in service instance 1 on HundredGigE 1/0/1.
[DeviceC] cfd meplist 1001 1002 service-instance 1
[DeviceC-HundredGigE1/0/1] cfd mep 1001 service-instance 1 outbound
[DeviceC-HundredGigE1/0/1] cfd cc service-instance 1 mep 1001 enable
[DeviceC] cfd service-instance 2 ma-id vlan-based md MD_A vlan 110
# Create a MEP list in service instance 2. Create outward-facing MEP 2001. Enable CCM sending in service instance 2 on HundredGigE 1/0/2.
[DeviceC] cfd meplist 2001 2002 service-instance 2
[DeviceC-HundredGigE1/0/2] cfd mep 2001 service-instance 2 outbound
[DeviceC-HundredGigE1/0/2] cfd cc service-instance 2 mep 2001 enable
# Create track entry 1 that is associated with the CFD CC function of MEP 1001 in service instance 1.
[DeviceC] track 1 cfd cc service-instance 1 mep 1001
# Configure collaboration between the primary port HundredGigE 1/0/1 of smart link group 1 and the CC function of CFD through track entry 1, and bring up the port.
[DeviceC-HundredGigE1/0/1] port smart-link group 1 track 1
[DeviceC] track 2 cfd cc service-instance 2 mep 2001
# Configure collaboration between the primary port HundredGigE 1/0/2 of smart link group 2 and the CC function of CFD through track entry 2, and bring up the port.
[DeviceC-HundredGigE1/0/2] port smart-link group 2 track 2
4.     Configure Device D:
# When the optical fiber between Device A and Device B fails, display the smart link group configuration on Device C.
  Control VLAN    : 10
  HGE1/0/1                PRIMARY   DOWN    5               16:45:20 2012/04/21
  HGE1/0/2                SECONDARY ACTIVE  1               16:37:20 2012/04/21
  Control VLAN    : 110
The output shows that primary port HundredGigE 1/0/1 of smart link group 1 fails, and secondary port HundredGigE 1/0/2 is in forwarding state.
