01-Fundamentals Command References
HomeSupportResource CenterH3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Command References-6W10101-Fundamentals Command References
07-Software upgrade commands
07-Software upgrade commands 80.25 KB
As a best practice, store the startup images in a fixed storage medium. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
boot-loader file
Use boot-loader file to specify startup image files.
boot-loader file boot filename system filename [ feature filename&<1-30> ] [ patch filename&<1-16> ] { all | slot slot-number } { backup | main }
boot-loader file ipe-filename [ patch filename&<1-16> ] { all | slot slot-number } { backup | main }
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies a space-separated list of up to 30 feature image files.
patch: Specifies a space-separated list of up to 16 patch image files. You can specify only non-incremental patch image files.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
ipe-filename: Specifies an .ipe image package file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all hardware components to which the specified images apply.
slot slot-number: Specifies the IRF member ID of a member device.
backup: Specifies the files as backup startup image files. Backup images are used only when main images are not available.
main: Specifies the files as main startup image files. The device always first attempts to start up with main startup files.
The boot-loader file command overwrites the entire startup image list. To add new startup feature images, specify all feature image files in the old startup image list, including feature image files. The new startup image list will contain only the feature image files that are specified in the command.
Before you specify startup image files, register and activate a license for each upgrade image that requires a license. If a license-based software image lacks a license, the command execution result is as follows:
·     If .bin files are specified, the command cannot be executed.
·     If an .ipe file is specified, the command sets all images as startup images except for the image that does not have a license.
For more information about licensing, see Fundamentals Configuration Guide.
To load the specified startup software images, you must reboot the system.
If the upgrade images are not found in the file system on the slot specified to upgrade, the system automatically copies the images to that file system. The destination directory is the root directory of the file system. If the destination root directory already contains a startup image with the same name as an upgrade image, you must choose whether to overwrite the image.
# Specify flash:/all.ipe as the main startup image file for slot 1.
<Sysname> boot-loader file flash:/all.ipe slot 1 main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C S6820-32H images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to slot 1.
File flash:/boot.bin already exists on slot 1.
File flash:/system.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:Y
Decompressing file boot.bin to flash:/boot.bin........................Done.
Decompressing file system.bin to flash:/system.bin...............................Done.
Verifying the file flash:/boot.bin on slot 1...Done.
Verifying the file flash:/system.bin on slot 1.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Specify flash:/all.ipe as the main startup image file for all IRF member devices.
<Sysname> boot-loader file slot1#flash:/all.ipe all main
Verifying the file flash:/all.ipe on slot 1......................................Done.
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:y
Overwrite the existing files? [Y/N]:y
Decompressing file system.bin to flash:/system.bin........................Done.
File flash:/boot.bin already exists on slot 2.
Do you want to overwrite the file?
 Y: Overwrite the file.
 N: Not overwrite the file.
 A: From now on, overwrite or not overwrite without prompt.
Please make a choice. [Y/N/A]:a
What type of overwrite operation do you want to perform?
 Y: Overwrite without prompt.
 N: Not overwrite or display prompt.
 Q: Return to the previous step.
Please make a choice. [Y/N/Q]:y
An existing file will be overwritten without prompt if it has the same name as any upgrade file.
Loading......................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 2.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 3.
Decompression completed.
Do you want to delete flash:/all.ipe now? [Y/N]:n
display boot-loader
boot-loader pex file (IRF3.1)
Use boot-loader pex file to upgrade startup images for PEXs from the parent fabric.
The S6820 switch series does not support this command.
boot-loader pex file ipe ipe-filename transfer-service ftp { all | slot slot-list }
ipe ipe-filename: Specifies an .ipe image package file in the filesystemname/pex_images/filename.ipe format. The file must be stored in the root directory of a file system on the parent fabric. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
transfer-service: Specifies the file transfer service for the parent fabric to use to transfer the .ipe file to PEXs.
ftp Specifies FTP as the file transfer service.
all: Specifies all PEXs.
slot slot-list: Specifies a space-separated list of up to 10 virtual slot number items. An item specifies a PEX by its virtual slot number or a range of PEXs in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number.
This command upgrades PEXs from the parent fabric in an IRF 3.1 system. You can also upgrade a PEX by logging in to the PEX through the console port. Upgrading PEXs from the parent fabric has the following benefits:
·     It is easy to ensure compatibility between the startup images of PEXs and the startup images of the parent fabric.
·     You do not need to log in to PEXs.
After the file transfer process is completed, PEXs that successfully received the .ipe file automatically reboot to complete the upgrade. PEXs that failed to receive the .ipe file do not reboot and are not upgraded.
# Upgrade PEX 100 and PEXs 105 through 110.
<Sysname> boot-loader pex file ipe slot1#flash/pex_images:/all.ipe transfer-service ftp slot 100 105 to 110
boot-loader update
Use boot-loader update to synchronize startup images.
boot-loader update { all | slot slot-number }
all: Synchronizes startup images from the master to all subordinate devices.
slot slot-number: Specifies the IRF member ID of a subordinate device.
You can use this command to synchronize startup images after adding new member devices.
If any of the startup software images require a license, register and activate a license for the image on the new subordinate device before executing this command. Use the display license feature command to verify the licensing state of software images.
The startup images synchronized to the subordinate device are set as main startup images, regardless of whether the source startup images are main or backup.
·     If the master device has started up with main startup images, its main startup images are synchronized to the subordinate device, regardless of whether any main startup image has been respecified on the master device.
·     If the master device has started up with backup startup images, its backup startup images are synchronized to the subordinate device, regardless of whether any backup startup image has been respecified on the master device.
If a patch installation or ISSU has been performed on the master, use the install commit command to update the set of main startup images on the master before software synchronization. This command ensures startup image consistency between the master and the subordinate device.
Startup image synchronization fails if any software image being synchronized is not available or is corrupted.
# Synchronize startup images to a slot.
<Sysname> boot-loader update slot 2
This command will update the specified standby MPU. Continue? [Y/N]:y
Updating. Please wait...
Verifying the file flash:/system.bin on slot 1....Done.
Copying main startup software images to slot 2. Please wait...
Done.
Setting copied images as main startup software images for slot 2...
Done.
Successfully updated the startup software images of slot 2.
display boot-loader
install commit
bootrom update
Use bootrom update to load the BootWare image from a file system to the Normal BootWare area.
bootrom update file file slot slot-number-list [ subslot subslot-number-list ]
file file: Specifies the file that contains the BootWare image. The file argument represents the file name, a string of 1 to 63 characters.
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. An item specifies an IRF member device by its member ID or a range of IRF member devices in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number.
subslot subslot-number-list: Specifies a list of up to seven subslot number items. Each item specifies a subcard by its subslot number or a range of subcards in the form of start-subslot-number to end-subslot-number. If you do not specify a subcard, this command loads the BootWare image for the base card.
The S6820, S6860, and S6861 switch series do not support the subslot subslot-number-list option.
BootWare images are contained in the .bin Comware boot image file. You can specify a Comware boot image file in this command to upgrade the BootWares in the system before you upgrade the Comware images. If you do not upgrade BootWares before upgrading Comware images, the system automatically upgrades BootWares as necessary when loading Comware images.
The new BootWare images take effect after you reboot the device.
# Use the file a.bin in the root directory of the flash memory to upgrade the BootWare image.
<Sysname> bootrom update file flash:/a.bin slot 1
   This command will update the Boot ROM file on the specified board(s), Continue? [Y/N]:y
   Now updating the Boot ROM, please wait................Done.
boot-loader file
display boot-loader
Use display boot-loader to display current software images and startup software images.
display boot-loader [ slot slot-number ]
slot slot-number: Specifies the member ID of an IRF member device. If you do not specify a member device, this command displays the software images on each IRF member device.
# Display the current software images and startup software images.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
  flash:/boot.bin
  flash:/system.bin
Main startup software images:
  flash:/boot.bin
  flash:/system.bin
Backup startup software images:
  flash:/boot.bin
  flash:/system.bin
Comware images that have been loaded.
Primary Comware images for the next startup.
Backup Comware images for the next startup.
boot-loader file
install activate pex patch
Use install activate pex patch to install PEX patches.
install activate pex patch filename { all | slot slot-list }
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on a parent device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
slot slot-list: Specifies a space-separated list of up to 10 slot number items. An item specifies a PEX by its virtual slot number or specifies a range of PEXs in the form of slot-number1 to slot-number2. The end slot number must be equal to or greater than the start slot number.
CAUTION
CAUTION:
Do not install a patch image with the same name as an existing patch image. If you do so, the patch fails to be installed and the existing patch image is lost.
To install PEX patches in an IRF 3.1 system, you must use this command. This command transfers the patch images on the parent device to PEXs and installs them.
To install a non-incremental patch image, first use the install deactivate pex patch command to uninstall the old patch image. To install an incremental patch image, directly install the new patch image.
After a patch image is installed, the device adds it to the startup image list. You do not need to execute the install commit command or reboot the PEX for the patch to survive reboots.
# Install patches for PEX 100 and PEXs 105 through 110.
<Sysname> install activate pex patch slot1#flash:/patch.bin slot 100 105 to 110
Use install deactivate pex patch to uninstall PEX patches.
install deactivate pex patch filename { all | slot slot-list }
To uninstall PEX patches in an IRF 3.1 system, you can use this command.
# Uninstall patches for PEX 100 and PEXs 105 through 110.
<Sysname> install deactivate pex patch slot1#flash:/patch.bin slot 100 105 to 110
