00-Preface | 100.07 KB |
Preface
This configuration guide describes how to set up an IRF fabric of multiple switches, including:
· Plan the switch roles in the IRF fabric.
· Connect the IRF links.
· Detect IRF splits and maintain the IRF fabric.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
