- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Device management configuration
- 09-Tcl configuration
- 10-Python configuration
- 11-Automatic configuration
- 12-License management
12-License management | 93.23 KB |
Licenses for different device types
Restrictions and guidelines: License management
Activation file and DID file operations
License consistency in an IRF fabric
License management tasks at a glance
Identifying the license storage
Compressing the license storage
Obtaining required information for license register
Registering licenses for the first time
Restrictions and guidelines for license uninstallation
Uninstalling an activation file
Display and maintenance commands for license management
Managing licenses
About licenses
License-based features require a license to run on your device.
License types
You must purchase a license key for each IRF member device. To license an IRF member device, use the license key and the member's SN and DID to register an activation file and install the activation file on the IRF member device. An IRF member device is licensed even if the device joins another IRF fabric.
Management operations
Make sure no one else is performing license management tasks on the device you are working with.
When you manage DID files or activation files, follow these restrictions and guidelines:
· Do not open and edit the files to avoid file corruption.
· Do not modify the names of the files to avoid licensing error.
· For licensed features to function correctly, do not delete files that are usable or in use in the flash:/license directory. The license management feature uses this directory for license management.
For licensed features to function correctly in an IRF fabric, make sure all IRF member devices are installed with the same licenses.
To manage licenses, perform the following tasks:
1. Identifying the license storage
2. (Optional.) Compressing the license storage
3. Obtaining required information for license register
6. Managing installed licenses
¡ Recovering an activation file
To identify the license storage, execute the following command in any view:
display license feature
From the command output, view the Total and Usage fields to examine whether the remaining license storage is sufficient for installing new licenses. If the remaining license storage is not sufficient, compress the license storage.
About license storage compression
Compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
This command clears expired licenses and uninstalled licenses that are installed by using activation files.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID change. Before performing a compression, make sure all licenses registered with the old DID have been installed. You will be unable to install such licenses after the compression.
7. Back up the Uninstall keys of uninstalled licenses.
When you uninstall an unexpired formal license, an Uninstall key is created. The Uninstall key is required for transferring the license.
8. Make sure all licenses generated based on the old DID have been installed.
9. Enter system view.
10. Compress the license storage.
license compress slot slot-number
11. Identify whether the required features need to be licensed on the device.
Execute the following command in any view:
12. Execute the following command in any view to display the current license status.
display license [ ] [ slot slot-number ]
13. Obtain the license key by purchasing a license.
The authorization serial number in the Software License Certificate is the license key.
14. Execute the following command in any view to obtain the SN and DID information.
display license device-id slot slot-number
15. If the DID is contained in an .id file, use FTP or TFTP to upload the file to the Web client, such as PC.
If FTP is used to transfer the .id file, use the Binary mode.
If the DID is a string, skip this step.
16. Back up the license key in case of loss.
Registering a license
About registering a license
License registration has the following procedures:
· Registering licenses for the first time—Register a license for a device that has not previously been registered.
· Registering upgrade licenses—Register licenses for capacity expansion, feature enhancement, or a time extension. This procedure is also applicable to the scenario that you register a new license for a device that has expired or uninstalled licenses.
If you do not know which registration procedure should be used, select registering licenses for the first time. If the selection is not correct, the website will display messages for the correct registration choice after you enter the required information Enter the required information, and the website will display messages for the correct registration choice.
If you cannot download the activation file due to problems such as operating system and browser errors, try to re-register the license. If the problem persists, contact H3C Support.
1. Visit the H3C website at http://www.h3c.com/en/License/.
2. Select Register the First Time.
3. Enter the authorization serial number in the Input the license key field and click Submit.
A dialog box opens, displaying product categories matching the license key.
4. In the dialog box, select a product category from the Product category dropdown list and click OK.
5. Enter the device S/N.
6. Upload the DID file.
7. Enter the required contact information and verify code, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
8. Download the activation file to the PC.
A copy of the activation file will also be sent to the email address that you enter in the contact information.
2. Select Register Upgrade Licenses.
6. Upload the DID file and click Submit.
Installing a license
When installing a license, the system automatically searches the storage media for a matching feature package. When a match is found, it stops searching and installs the package.
Installing an activation file
10. Install an activation file.
license activation-file install file-name slot slot-number
Uninstalling a license
About license uninstallation
Perform this task to uninstall an unexpired formal license when the license remains unused for a while or needs to be transferred to another device.
After uninstallation, Uninstall keys are generated, which will be used for license transfer.
Back up the Uninstall key of a license properly for the license's next use.
Trial licenses cannot be transferred. Uninstall a trial license does not create any uninstallation information.
Expired licenses cannot be uninstalled.
11. Enter system view.
12. Uninstall an activation file.
license activation-file uninstall file-name slot slot-number
Only unexpired activation files can be uninstalled.
Transferring a license
About license transfer
You can transfer a license from one device to another if the license has not expired.
13. Log in to the source device, and uninstall the license to obtain the uninstallation information. For more information, see "Uninstalling a license."
14. Obtain the Uninstall key of the license by using the display license command.
15. Access the target device and obtain SN and DID information. For more information, see "Obtaining required information for license register."
16. Register a license for the target device. For more information, see "Registering a license."
During the license register, you must provide SN and DID information of the target device and the Uninstall key of the source device.
17. Install the new license on the target device. For more information, see "Installing a license."
If you mistakenly delete an activation file, use the following procedure to recover the activation file:
18. Use the copy command to copy the backup activation file to directory flash:/license.
19. Use the display license command to verify that the state of the recovered activation file is In use.
20. Restart the device if the license state is In use but the licensed feature cannot function correctly.
Task |
Command |
Display detailed license information. |
display license [ ] [ slot slot-number ] |
Display the SN and DID information. |
display license device-id slot slot-number |
Display brief feature license information. |
display license feature |
