01-Fundamentals Command Reference
HomeSupportResource CenterH3C S5560S-EI[SI]&S5500V3-SI&MS4520V2&WS5850-Winet Command References-R63xx-6W10101-Fundamentals Command Reference
08-Device management commands
08-Device management commands 311.49 KB
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The system time is UTC time 00:00:00 01/01/2013.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
A device power cycling operation restores the local system time to the default. After the device is power cycled, you must execute this command again to set the local system time.
# Set the system time to 08:08:08 01/01/2015.
<Sysname> clock datetime 8:8:8 1/1/2015
# Set the system time to 08:10:00 01/01/2015.
<Sysname> clock datetime 8:10 2015/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | ntp }
undo clock protocol
The device obtains the UTC time from an NTP time source.
none: Uses the system time set by using the clock datetime command.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
The device can use the locally set system time, or obtain the UTC time from a time source on the network and calculate the system time.
If you configure the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you configure the clock protocol ntp command, the device obtains the UTC time through NTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week day, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down GigabitEthernet 1/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
copyright-info enable
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00.211 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU usage statistics for all member devices.
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
x% in last 5 seconds
Last 5 sec
Average CPU or CPU core usage during the most recent 5-second interval.
y% in last 1 minute
Last 1 min
Average CPU or CPU core usage during the most recent 1-minute interval.
z% in last 5 minutes
Last 5 min
Average CPU or CPU core usage during the most recent 5-minute interval.
display cpu-usage configuration
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the CPU usage monitoring settings for the master device.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 98%.
Current recovery-threshold is 50%.
CPU usage monitor is xxx.
Whether CPU usage tracking is enabled.
Current monitor interval is xxx.
Sampling interval for CPU usage tracking.
Current severe alarm threshold is xxx.
Severe CPU usage alarm threshold.
Current minor alarm threshold is xxx.
Minor CPU usage alarm threshold.
Current recovery threshold is xxx.
CPU usage recovery threshold.
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
display cpu-usage history
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID. If you specify a process but do not specify a member device, this command displays the statistics for the process on the master device. If you do not specify any options, this command displays the statistics for all processes on all member devices.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
The horizontal axis represents the time.
Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device information.
display device[ flash | usb ] [ slot slot-number | verbose ]
flash: Displays flash memory information.
usb: Displays USB interface information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
If you do not specify the flash and usb keywords, this command displays information about member devices.
# Display device information.
<Sysname> display device
Slot 1
Slot Type             State    Subslot  Soft Ver             Patch Ver
1    S5560S-52P-EI    Master   0        S5560S-6103          None
Device type.
Role of the device in an IRF fabric:
·     Master—The device is the master.
·     Standby—The device is a subordinate member.
Soft Ver
Software version of the device.
Patch Ver
Most recently released patch image version that is running on the device. If no patch image is installed, this field displays None.
If both incremental and non-incremental patch images are running on the device, this field displays the most recently released incremental patch image version. For more information about patch image types, see software upgrade in Fundamentals Configuration Guide.
display device manuinfo
Use display device manuinfo to display electronic label information for the device.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display electronic label information for the device.
<Sysname> display device manuinfo
display device manuinfo power
Use display device manuinfo power to display electronic label information for a power supply.
display device manuinfo slot slot-number power power-id
power-id: Specifies a power supply by its ID.
# Display electronic label information for a power supply.
<Sysname> display device manuinfo slot 1 power 1
display diagnostic-information
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware: Specifies hardware-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz extension. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
·     Use separate display commands to collect operating information feature by feature or module by module.
·     Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, this command automatically compresses the information before saving the information to a file. To view the file content:
1.     Use the tar extract command to extract the file.
2.     Use the gunzip command to decompress the extracted file.
3.     Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), pipeline signs (|), and quotation marks ("). For example, device name A/B will change to A_B in the file name, as in flash:/diag_A_B_20160101-000438.tar.gz.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
This command does not support the |, >, and >> options.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2015
# Save the operating information to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to file test.tar.gz.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
gunzip
more
tar extract
display dying-gasp host
Use display dying-gasp host to display poweroff alarm destination host settings.
# Display poweroff alarm destination host settings.
<Sysname> display dying-gasp host
IPv4 address: 1.1.1.0
Message type: SNMP Trap
Securityname: p1
Version: V1
IPv4 address: 1.1.1.1
Message type: Syslog
IPv4 address
IPv4 address of the poweroff alarm destination host.
IPv6 address
IPv6 address of the poweroff alarm destination host.
VPN instance
VPN instance to which the poweroff alarm destination host belongs.
Message type
Message types that the poweroff alarm destination host supports:
·     SNMP Trap—SNMP notification.
·     Syslog—Log message.
Securityname
SNMPv1 or SNMPv2c community name.
This field is displayed when the message type is SNMP Trap.
Version
SNMP version:
·     v1—SNMPv1.
·     v2c—SNMPv2c.
dying-gasp host
display environment
Use display environment to display temperature information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices.
# Display information about all temperature sensors on the device.
<Sysname> display environment
 System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 69           0      84       98     NA
 1     hotspot 2 67           0      84       98     NA
 1     hotspot 3 33           0      100      110    NA
 1     hotspot 4 33           0      100      110    NA
 1     hotspot 5 38           0      100      110    NA
 1     hotspot 6 36           0      100      110    NA
 1     hotspot 7 35           0      100      110    NA
 1     hotspot 8 42           0      100      110    NA
Table 5 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
hotspot—Hotspot sensor.
Slot
Sensor position.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ slot slot-number [ fan-id ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices.
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
 Slot 1:
 Fan 1:
 State    : Normal
Table 6 Command output
Slot 1
Number of the member device.
Fan 1
Fan tray number.
Fan tray status:
·     Absent—The slot is not installed with a fan tray.
·     Fault—The fan tray is faulty.
·     Normal—The fan tray is operating correctly.
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays memory usage for all member devices.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        498284    293884    204400         0      1316     76332       41.0%
-/+ Buffers/Cache:    216236    282048
Swap:           0         0         0
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU   Total      Used      Free      Buffers  Caches    FreeRatio
1    0     498284     293884    204400    1316     76332     41.0%
Table 7 Command output
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code and kernel management functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
display memory-threshold
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the memory usage thresholds and statistics for the master device.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free-memory thresholds:
    Minor: 60M
    Severe: 56M
    Critical: 52M
    Normal: 64M
Current free-memory state: Normal
Free-memory event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Entered minor alarm state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor alarm state]
 [Entered severe alarm state]
 [Back to severe alarm state]
 [Entered critical alarm state]
display power
Use display power to display power supply information.
display power [ slot slot-number [ power-id ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power supply information for all member devices.
power-id: Specifies a power supply by its ID. If you do not specify a power supply, this command displays information about all power supplies at the specified position.
# Display power supply information.
<Sysname> display power
 Slot 1:
 PowerID State    Mode   Current(A)  Voltage(V)  Power(W)
 1       Absent   --        --          --          --
 2       Normal   AC        --          --          --
Table 8 Command output
PowerID
Power supply ID. On a device that supports only one power supply, you need to view only information about power supply 1.
Power supply status.
·     Absent—The slot is not installed with a hot-swappable power supply.
·     Fault—The power supply is faulty or is not powered on.
·     Normal—The power supply is operating correctly.
Mode
Mode of the power supply:
·     AC—AC power supply.
·     DC—DC power supply.
Current(A)
Output current of the power supply, in amperes.
Voltage(V)
Output voltage of the power supply, in volts.
Power(W)
Output power of the power supply, in watts.
display scheduler job
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
display scheduler logfile
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
Table 9 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank.
Job output
Commands in the job and their output.
reset scheduler logfile
display scheduler reboot
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
scheduler reboot at
scheduler reboot delay
display scheduler schedule
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
shutdown                                          Successful
Table 10 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
display system stable state
Use display system stable state to display system stability and status information.
Before performing a switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the Redundancy Stable field is not Stable, you cannot perform a switchover.
The device startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices that are not in Stable state. You can also use other commands to identify the faulty components. For example:
·     Use the display device command to identify the device operating status.
·     Use the display system internal process state command in probe view to display service operating status.
# Display system stability and status information.
<Sysname> display system stable state
System state    : Stable
Redundancy state: No redundance
  Slot   CPU   Role      State
 1      0     Active    Stable
Table 11 Command output
System state
System status:
Stable—The system is operating stably.
Redundancy state
System redundancy status:
·     Stable—Member devices are operating stably. You can perform a switchover.
·     No redundance—The system has only one member device. You cannot perform a switchover.
·     Not ready—The system is not operating stably. You cannot perform a switchover.
Role
Role of the member device in the system:
·     Active—The member device is the master.
·     Standby—The member device is a subordinate member.
Member device status:
·     Stable—The member device is operating stably.
·     Board inserted—The member device has just been installed.
·     Kernel initiating—Member device kernel is being initialized.
·     Service starting—Services are starting on the member device.
·     Service stopping—Services are stopping on the member device.
·     HA Batch backup—An HA batch backup is going on.
·     Interface data batch backup—An interface data batch backup is in progress.
The object is not operating stably.
display device
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 12 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 12 Common transceiver alarm components
APD
Avalanche photo diode
PCS
Physical coding sublayer
PHY XS
PHY extended sublayer
PMA/PMD
Physical medium attachment/physical medium dependent
power
Optical power
REFCLK
Reference clock
RX
Receive
TEC
Thermoelectric cooler
Temp
Temperature
TX
Transmit
WIS
WAN interface sublayer
# Display the alarms present on the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver alarm interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
Table 13 Command output
Alarms present on the transceiver module.
RX loss of signal
Received signals are lost.
RX power low
Received power is low.
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver interface gigabitethernet 1/0/1
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for all transceiver modules.
# Display electronic label information for the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver manuinfo interface gigabitethernet 1/0/1
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
H3C Comware Software, Version 7.1.070, Release 6309P01
H3C S5560S-52P-EI uptime is 0 weeks, 2 days, 5 hours, 58 minutes
Last reboot reason : Cold reboot
Boot image: flash:/s5560s_ei-cmw710-boot-r6309p01.bin
Boot image version: 7.1.070, Release 6309P01
  Compiled Jan 21 2019 11:00:00
System image: flash:/s5560s_ei-cmw710-system-r6309p01.bin
System image version: 7.1.070, Release 6309P01
Table 14 Command output
Last reboot reason
Reason for the last reboot:
·     User reboot—The reboot was manually initiated from a user interface, such as the CLI or SNMP.
·     Cold reboot—The reboot was caused by a power cycle.
·     Kernel abnormality reboot—The reboot was caused by kernel exceptions.
·     DeadLoop reboot—The reboot was caused by a kernel thread dead loop.
·     DEV HandShake reboot—The reboot was caused by a device management handshake failure.
·     SlaveSwitch reboot—The reboot was caused by a master/subordinate switchover.
·     IRF Merge reboot—The reboot was caused by an IRF merge.
·     Auto Update reboot—The reboot was caused by an automatic software upgrade.
·     Memory exhaust reboot—The reboot was caused by a card-memory-exhausted event.
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2019 at 06:23:54):
 *Name        : simware-cmw710-boot.bin
  Version     : 7.1.070 Release 6309P01
  Compile time: Mar 25 2019 15:52:43
 *Name        : simware-cmw710-system.bin
Table 15 Command output
Record n
Number of the startup software image upgrade record. Record 1 is the most recent record.
Name
Software image file name.
The software image version changed during the upgrade.
reset version-update-record
dying-gasp host
Use dying-gasp host to configure poweroff alarm destination host settings.
Use undo dying-gasp host to remove poweroff alarm destination host settings.
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] snmp-trap version { v1 | v2c } securityname security-string
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] syslog
undo dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] { snmp-trap | syslog }
No poweroff alarm destination host settings are configured.
ip-address: Specifies the IPv4 address of the destination host to which the device sends the poweroff alarm.
ipv6 ipv6-address: Specifies the IPv6 address of the destination host to which the device sends the poweroff alarm.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the destination host belongs to the public network, do not specify this option.
snmp-trap: Uses an SNMP notification to send the poweroff alarm.
version: Specifies the SNMP version.
v1: Uses SNMPv1.
v2c: Uses SNMPv2c.
securityname security-string: Specifies an SNMPv1 or SNMPv2c community name, a case-sensitive string of 1 to 32 characters.
syslog: Uses a log message to send the poweroff alarm.
The device can send the poweroff alarm by using either or both of an SNMP notification and a log message.
The device can send the poweroff alarm to multiple destination hosts at the same time.
# Configure the device to send the poweroff alarm to the host at 1.1.1.1 by using an SNMPv1 notification. The community name is public.
[Sysname] dying-gasp host 1.1.1.1 snmp-trap version v1 securityname public
dying-gasp source
dying-gasp source
Use dying-gasp source to specify the source interface for sending the poweroff alarm.
Use undo dying-gasp source to restore the default.
dying-gasp source interface-type interface-number
No source interface is specified. On an IPv4 network, the device uses the primary IPv4 address of the output interface for the route to the destination host as the source address. On an IPv6 network, the device selects a source IPv6 address as defined in RFC 3484.
interface-type interface-number: Specifies a Layer 3 interface by its type and number.
The device uses the IPv6 address or primary IPv4 address of the specified source interface as the source address for outgoing poweroff alarm packets. The destination hosts use this address to identify SNMP notifications or log messages received from the device.
If no address is configured for the specified source interface, this command does not take effect. For this command to take effect, assign an address to the source interface.
# Use the Loopback 1 interface as the source interface for sending the poweroff alarm.
[Sysname] dying-gasp source loopback 1
dying-gasp host
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
The device does not have banners.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
memory-threshold [ slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 60 MB.
Severe alarm threshold: 56 MB.
Critical alarm threshold: 52 MB.
Normal state threshold: 64 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets free-memory thresholds for the master device.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the memory usage threshold for the master device.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables CPU usage monitoring for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore default settings.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the interval for the master device.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore default settings.
monitor cpu-usage threshold severe-threshold minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
Severe CPU usage alarm threshold: 99%.
Minor CPU usage alarm threshold: 98%.
CPU usage recovery threshold: 50%.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the CPU usage threshold for the master device.
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the severe CPU usage alarm threshold to 90%, minor CPU usage alarm threshold to 80%, and CPU usage recovery threshold to 70%.
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore default settings.
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor alarm resending interval is 300 seconds. The severe alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets alarm resending intervals for the master device.
The device samples CPU usage periodically and compares the sample with the CPU usage threshold. If the sample increases above an alarm threshold, the CPU usage enters an alarm state and the device sends an alarm.
While the CPU usage is in minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
While the CPU usage is in severe alarm state, the device sends severe alarms periodically until the severe alarm is removed.
You can use this command to change CPU usage alarm resending intervals.
If you do not specify the minor-interval or severe-interval keyword, the undo monitor resend cpu-usage command restores default settings for both the minor and severe alarm resending intervals.
# Set the CPU usage minor alarm resending interval to 60 seconds for CPU 0 in slot 1.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend memory-threshold
Use monitor resend memory-threshold to set memory depletion alarm resending intervals.
Use undo monitor resend memory-threshold to restore default settings.
monitor resend memory-threshold { critical-interval critical-interval | minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
·     Minor alarm resending interval: 12 hours.
·     Severe alarm resending interval: 3 hours.
·     Critical alarm resending interval: 1 hour.
critical-interval critical-interval: Specifies the critical alarm resending interval in hours, in the range of 1 to 48.
minor-interval minor-interval: Specifies the minor alarm resending interval in hours, in the range of 1 to 48.
severe-interval severe-interval: Specifies the severe alarm resending interval in hours, in the range of 1 to 48.
The device samples the amount of free memory space periodically and compares the sample with free-memory thresholds. If the sample decreases to or below a threshold, the device enters a memory depletion alarm state and sends an alarm.
In critical alarm state, the device sends critical alarm notifications periodically until the critical alarm is removed.
In a lower alarm state, the device sends notifications for the alarm state periodically until it enters a higher alarm state or the current alarm is removed.
You can use this command to change the alarm resending intervals.
If you do not specify any memory depletion alarm resending intervals, the undo monitor resend memory-threshold command restores default settings for all memory depletion alarm resending intervals.
# Set the minor memory depletion alarm resending interval to 12 hours for CPU 0 in slot 1.
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
reboot
Use reboot to reboot the device.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command reboots all IRF member devices.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A reboot might interrupt network services.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
If the IRF fabric has only one member device, rebooting the member device reboots the entire IRF fabric. If the IRF fabric has a subordinate member and the member is operating correctly, rebooting the master triggers a master/subordinate switchover.
To ensure correct operation of the IRF fabric and member devices, do not trigger a switchover by rebooting the master if no subordinate member devices are in Stable state. To view the status of subordinate member devices, execute the display system stable state command.
# Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
Device reboot interrupts network services.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2015.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2015.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. To disable port status detection, set this argument to 0.
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number hotspot sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently configured command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2015.
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is configured most recently takes effect.
# Configure the device to execute schedule saveconfig once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
command
scheduler schedule
