- 05-Layer 3 - IP Routing Configuration Examples
- 01-H3C_BGP_Configuration_Examples
- 02-H3C_BGP_Route_Selection_Configuration_Examples
- 03-H3C_IPv6_IS-IS_Configuration_Examples
- 04-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 05-H3C_IS-IS_Configuration_Examples
- 06-H3C_OSPFv3_Configuration_Examples
- 07-H3C_OSPF_Configuration_Examples
- 08-H3C_Policy-Based_Routing_Configuration_Examples
- 09-H3C_Routing_Policy_Configuration_Examples
- 10-H3C_IPv6_over_IPv4_Manual_Tunneling_with_OSPFv3_Configuration_Examples
- 11-H3C_GRE_with_OSPF_Configuration_Examples
04-H3C_IS-IS_Route_Summarization_Configuration_Examples | 79.82 KB |
H3C IS-IS Route Summarization Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring IS-IS route summarization
Configuring IP addresses for interfaces
Introduction
This document provides IS-IS route summarization configuration examples.
This document assumes that you have basic knowledge of IS-IS route summarization.
As shown in Figure 1, the three departments of a company use IS-IS to connect to the backbone network. The three departments are assigned the networks 192.168.1.0/24, 192.168.2.0/24, and 192.168.3.0/24. Configure IS-IS route summarization to reduce routing entries and save system resources for Device B.
Device |
IP address |
Device A |
Vlan-int10 |
172.16.1.1/24 |
Device A |
Vlan-int101 |
10.1.1.1/24 |
Device A |
Vlan-int102 |
10.1.2.1/24 |
Device A |
Vlan-int103 |
10.1.3.1/24 |
Device B |
Vlan-int10 |
172.168.1.2/24 |
Router B |
Loop0 |
172.168.1.2/24 |
GW 1 |
Vlan-int101 |
10.1.1.2/24 |
GW 1 |
Vlan-int11 |
192.168.1.1/24 |
GW 2 |
Vlan-int102 |
10.1.2.2/24 |
GW 2 |
Vlan-int12 |
192.168.2.1/24 |
GW 3 |
Vlan-int103 |
10.1.3.2/24 |
GW 3 |
Vlan-int13 |
192.168.3.1/24 |
Analysis
Configure route summarization on Device A because route summarization applies only to locally generated LSPs.
To avoid blackhole routes, set the summary route to 192.168.0.0/21.
Procedures
# Configure an IP address for the interface VLAN-interface 10 on Device A.
[DeviceA-Vlan-interface10] ip address 172.16.1.2 24
# Configure IP addresses for other interfaces as shown in Figure 1 in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring basic IS-IS
Configuring Device A
# Enable IS-IS on Device A and configure Device A as a Level-1-2 router.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 10.0000.0000.0001.00
[DeviceA-isis-1] is-level level-1-2
[DeviceA-isis-1] quit
# Enable IS-IS on the interface VLAN-interface 10.
[DeviceA–Vlan-interface10] isis enable 1
[DeviceA–Vlan-interface10] quit
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring Device B
# Enable IS-IS on Device B and configure Device B as a Level-2 router.
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 10.0000.0000.0002.00
[DeviceB-isis-1] is-level level-2
[DeviceB-isis-1] quit
[DeviceB] interface vlan-interface 10
[DeviceB–Vlan-interface10] isis enable 1
[DeviceB–Vlan-interface10] quit
Configuring the gateways
# Enable IS-IS on GW 1 and configure GW 1 as a Level-1 router.
[GW1] isis 1
[GW1-isis-1] network-entity 10.0001.0001.0001.00
[GW1-isis-1] is-level level-1
[GW1-isis-1] quit
# Enable IS-IS on the interface VLAN-interface 101.
[GW1] interface vlan-interface 101
[GW1–Vlan-interface101] isis enable 1
[GW1–Vlan-interface101] quit
# Enable IS-IS on the interface VLAN-interface 11.
[GW1] interface vlan-interface 11
[GW1–Vlan-interface11] isis enable 1
[GW1–Vlan-interface11] quit
# Configure other gateways in the same way GW 1 is configured. (Details not shown.)
Displaying IS-IS routing information on Device B
# Display IS-IS routing information on Device B to view the network address of each department.
[DeviceB] display isis route
Level-2 IPv4 Forwarding Table
IPv4 Destination IntCost ExtCost ExitInterface NextHop Flags
192.168.1.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.1.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.2.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.2.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.3.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.3.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.4.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.4.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
192.168.5.0/24 30 NULL GE3/0/1 172.16.1.1 R/-/-
10.1.5.0/24 20 NULL GE3/0/1 172.16.1.1 R/-/-
172.16.1.0/24 10 NULL GE3/0/1 Direct D/L/-
# Configure IS-IS route summarization on Device A.
[DeviceA] isis 1
[DeviceA-isis-1]address-family ipv4
[DeviceA-isis-1-ipv4]summary 192.168.0.0 21
# Display IS-IS routing information on Device B.
192.168.0.0/21 30 NULL GE3/0/1 172.16.1.1 R/-/-
The output shows that the networks have been summarized into a single network 192.168.0.0/21.
Configuration files
· Device A:
isis 1
address-family ipv4 unicast
summary 192.168.0.0 255.255.248.0
vlan 10
vlan 101 to 105
interface vlan-interface10
ip address 172.16.1.1 255.255.255.0
isis enable 1
interface vlan-interface101
isis enable 1
interface vlan-interface102
ip address 10.1.2.1 255.255.255.0
isis enable 1
interface vlan-interface103
ip address 10.1.3.1 255.255.255.0
isis enable 1
interface vlan-interface104
ip address 10.1.4.1 255.255.255.0
isis enable 1
interface vlan-interface105
ip address 10.1.5.1 255.255.255.0
isis enable 1
· Device B:
isis 1
is-level level-2
vlan 10
ip address 172.16.1.2 255.255.255.0
isis enable 1
· GW 1:
isis 1
is-level level-1
vlan 11
vlan 101
isis enable 1
interface vlan-interface11
isis enable 1
· The configuration files for other gateways are similar to the configuration file for GW 1. (Details not shown.)
Related documentation
· H3C S7500E-X Switch Series Layer 3—IP Routing Command Reference-R758X
· H3C S7500E-X Switch Series Layer 3—IP Routing Configuration Guide-R758X
