05-Layer 3 - IP Routing Configuration Examples
HomeSupportSwitchesH3C S7500E-X Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-X Switch Series Configuration Examples-R7585P05-6W10005-Layer 3 - IP Routing Configuration Examples
01-H3C_BGP_Configuration_Examples
01-H3C_BGP_Configuration_Examples 101.98 KB
H3C BGP Configuration Examples
Software version: Release 7585P05
Document version: 6W100-20200330
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides BGP configuration examples.
This document assumes that you have basic knowledge of BGP.
Example: Configuring basic BGP
As shown in Figure 1, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C so that Switch C can access the network 8.1.1.0/24 connected to Switch A.
Figure 1 Network diagram
Analysis
To enable Switch B to communicate with Switch C through loopback interfaces, enable OSPF in AS 65009.
By default, BGP does not advertise local networks. To enable Switch C to access the network 8.1.1.0/24 connected directly to Switch A, perform the following tasks:
·          Add network 8.1.1.0/24 to the BGP routing table of Switch A.
·          Add networks 3.1.1.0/24 and 9.1.1.0/24 to the BGP routing table of Switch B.
When you configure basic BGP, follow these restrictions and guidelines:
·          Use loopback interfaces to establish IBGP connections to prevent route flapping caused by port state changes.
·          Loopback interfaces are virtual interfaces. Use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections.
·          The EBGP peers, Switch A and Switch B, are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so the switches use directly connected interfaces to establish EBGP sessions.
Procedures
1.        Configure IP addresses for interfaces:
# Configure an IP address for VLAN-interface 100.
[SwitchA] interface Vlan-interface 100
[SwitchA-Vlan-interface100] ip address 8.1.1.1 24
# Configure IP addresses for other interfaces in the same way that VLAN-interface 100 is configured. (Details not shown.)
2.        Configure IBGP:
# Configure Switch B.
[SwitchB] bgp 65009
[SwitchB-bgp-default] peer 3.3.3.3 connect-interface Loopback 0
[SwitchB-bgp-default] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] bgp 65009
[SwitchC-bgp-default] peer 2.2.2.2 as-number 65009
[SwitchC-bgp-default] peer 2.2.2.2 connect-interface Loopback 0
[SwitchC-bgp-default] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1] quit
# Display BGP peer information on Switch C.
 BGP local router ID : 3.3.3.3
 Local AS number : 65009
 Total number of peers : 1                 Peers in established state : 1
  2.2.2.2              65009        2        2    0       0 00:00:13 Established
The output shows that Switch C has established an IBGP peer relationship with Switch B.
3.        Configure EBGP:
# Configure Switch A.
[SwitchA] bgp 65008
[SwitchA-bgp-default] quit
[SwitchB] bgp 65009
# Display BGP peer information on Switch B.
 BGP local router ID : 2.2.2.2
 Total number of peers : 2                 Peers in established state : 2
  3.3.3.3              65009        4        4    0       0 00:02:49 Established
  3.1.1.2              65008        2        2    0       0 00:00:05 Established
The output shows that Switch B has established an IBGP peer relationship with Switch C and an EBGP peer relationship with Switch A.
# Display the BGP routing table on Switch A.
 Total number of routes: 1
* >  8.1.1.0/24         8.1.1.1         0                     32768   i
# Display the BGP routing table on Switch B.
* >e 8.1.1.0/24         3.1.1.2         0                     0       65008i
# Display the BGP routing table on Switch C.
   i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
The outputs show that Switch A has learned no route to AS 65009, and Switch C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
4.        Configure BGP to redistribute direct routes on Switch B:
[SwitchB] bgp 65009
[SwitchB-bgp-default-ipv4] network 3.1.1.0 24
[SwitchB-bgp-default-ipv4] network 9.1.1.0 24
 Total number of routes: 3
* >e 3.1.1.0/24         3.1.1.1         0                     0       65009?
* >e 9.1.1.0/24         3.1.1.1         0                     0       65009i
The output shows that route 9.1.1.0/24 has been added in Switch A's routing table.
* >i 3.1.1.0/24         2.2.2.2         0          100        0       ?
* >i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
* >i 9.1.1.0/24         2.2.2.2         0          100        0       i
The output shows that the route 8.1.1.0 becomes valid with the next hop as Switch A.
# Verify that Switch C can ping 8.1.1.1.
[SwitchC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL_C to break
Configuration files
·          Switch A:
vlan 100
vlan 200
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface100
 ip address 8.1.1.1 255.255.255.0
interface Vlan-interface200
 ip address 3.1.1.2 255.255.255.0
bgp 65008
router-id 1.1.1.1
network 8.1.1.0 255.255.255.0
peer 3.1.1.1 enable
·          Switch B:
vlan 200
vlan 300
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 3.1.1.1 255.255.255.0
interface Vlan-interface300
ip address 9.1.1.1 255.255.255.0
bgp 65009
router-id 2.2.2.2
peer 3.3.3.3 connect-interface Loopback0
network 3.1.1.0 255.255.255.0
network 9.1.1.0 255.255.255.0
peer 3.1.1.2 enable
peer 3.3.3.3 enable
ospf 1
area 0.0.0.0
·          Switch C:
vlan 300
interface Loopback0
 ip address 3.3.3.3 255.255.255.255
 ip address 9.1.1.2 255.255.255.0
bgp 65009
 router-id 3.3.3.3
 peer 2.2.2.2 connect-interface Loopback0
 peer 2.2.2.2 enable
ospf 1
 area 0.0.0.0
Examples: Configuring BGP and IGP route redistribution
As shown in Figure 2, all devices of company A belong to AS 65008 and all devices of company B belong to AS 65009. Run EBGP between Switch A and Switch B, and run OSPF between Switch B and Switch C to allow communication only between networks 9.1.2.0/24 and 8.1.1.0/24.
Figure 2 Network diagram
Analysis
To enable Switch A to obtain the route to 9.1.2.0/24, configure BGP to redistribute routes from OSPF on Switch B. To enable Switch C to obtain the route to 8.1.1.0/24, configure OSPF to redistribute routes from BGP on Switch B.
Procedures
2.        Enable OSPF in AS 65009:
[SwitchB] ospf 1
[SwitchC] ospf 1
[SwitchC-ospf-1-area-0.0.0.0] network 9.1.2.0 0.0.0.255
3.        Configure the EBGP connection and add network 8.1.1.0/24 to the BGP routing table of Switch A:
[SwitchA] bgp 65008
[SwitchB] bgp 65009
4.        Configure BGP and IGP route redistribution:
# Configure route redistribution between BGP and OSPF on Switch B.
[SwitchB] ospf 1
* >e 9.1.2.0/24         3.1.1.1         1                     0       65009?
The output shows that Switch A has obtained the route to 9.1.2.0/24.
# Display the OSPF routing table on Switch C.
                   Routing Tables
 Routing for Network
 9.1.1.0/24         1        Transit 9.1.1.2         3.3.3.3         0.0.0.0
9.1.2.0/24         1        Stub    9.1.2.1         192.168.0.63    0.0.0.0
 2.2.2.2/32         1        Stub    9.1.1.1         2.2.2.2         0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 8.1.1.0/24         1        Type2   1           9.1.1.1         2.2.2.2
 Total Nets: 3
 Intra Area: 2  Inter Area: 0  ASE: 1  NSSA: 0
The output shows that Switch C has obtained the route to 8.1.1.0/24.
# Verify that 8.1.1.1 can ping 9.1.2.1.
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL_C to break
# Verify that 9.1.2.1 can ping 8.1.1.1.
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL_C to break
# Verify that 8.1.2.1 cannot ping 9.1.2.1 or 9.1.3.1.
[SwitchA] ping –a 8.1.2.1 9.1.2.1
Ping 9.1.2.1 (9.1.2.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
[SwitchA] ping –a 8.1.2.1 9.1.3.1
Ping 9.1.3.1 (9.1.3.1) from 8.1.2.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 9.1.3.1 ---
# Verify that 9.1.3.1 cannot ping 8.1.1.1 or 8.1.2.1.
[SwitchC] ping –a 9.1.3.1 8.1.1.1
Ping 8.1.1.1 (8.1.1.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
[SwitchC] ping –a 9.1.3.1 8.1.2.1
Ping 8.1.2.1 (8.1.2.1) from 9.1.3.1: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 8.1.2.1 ---
Configuration files
·          Switch A:
vlan 100
vlan 200
vlan 600
interface Loopback0
interface Vlan-interface600
 ip address 8.1.2.1 255.255.255.0
bgp 65008
 router-id 1.1.1.1
 peer 3.1.1.1 enable
·          Switch B:
vlan 200
vlan 300
vlan 500
interface Loopback0
bgp 65009
 router-id 2.2.2.2
 import-route ospf 1
 peer 3.1.1.2 enable
ospf 1
 import-route bgp
 area 0.0.0.0
·          Switch C:
vlan 300
vlan 400
interface Loopback0
interface Vlan-interface400
 ip address 9.1.2.1 255.255.255.0
interface Vlan-interface500
ip address 9.1.3.1 255.255.255.0
ospf 1
 area 0.0.0.0
Related documentation
·          H3C S7500E-X Switch Series Layer 3IP Routing Command Reference-R758X
·          H3C S7500E-X Switch Series Layer 3IP Routing Configuration Guide-R758X
