- 16-High Availability Command Reference
- 01-VRRP commands
- 02-Reth interface and redundancy group commands
- 03-BFD commands
- 04-Track commands
- 05-Process placement commands
- 06-Interface collaboration commands
- 07-Monitor Link commands
- 08-Interface backup commands
- 09-RBM commands
- 10-Smart Link commands
| 09-RBM commands | 79.10 KB |
configuration auto-sync enable
display remote-backup-group status
display remote-backup-group sync-check
RBM commands
backup-mode
Use backup-mode to configure the VRRP hot backup mode.
Use undo backup-mode to restore the default.
backup-mode dual-active
undo backup-mode
The VRRP hot backup mode is active/standby.
Remote backup group view
context-admin
VRRP hot backup supports active/standby mode and dual-active mode. In active/standby mode, only the primary device processes services. In dual-active mode, both devices process services.
# Configure the dual-active hot backup mode.
[Sysname] remote-backup group
[Sysname-remote-backup-group] backup-mode dual-active
Use configuration auto-sync enable to enable automatic configuration synchronization.
Use undo configuration auto-sync enable to disable automatic configuration synchronization.
Automatic configuration synchronization is disabled.
context-admin
The automatic configuration synchronization feature synchronizes existing configuration on the primary device in bulk to the secondary device. Consequent synchronization for added, deleted, or modified configuration will be performed in real time.
If the amount of configuration to be synchronized is large, bulk synchronization might take one to two hours.
# Enable automatic configuration synchronization.
[Sysname-remote-backup-group] configuration auto-sync enable
configuration manual-sync
Use configuration manual-sync to manually synchronize the configuration of the primary device to the secondary device.
context-admin
For manual configuration synchronization to take effect, you must first enable automatic configuration synchronization.
# Manually synchronize the configuration of the primary device to the secondary device.
[Sysname-remote-backup-group] configuration manual-sync
configuration sync-check
Use configuration sync-check to enable configuration consistency check.
Use undo configuration sync-check to restore the default.
configuration sync-check [ interval interval ]
Configuration consistency check is disabled.
context-admin
interval interval: Specifies the configuration consistency check interval, in the range of 1 to 168 hours. The default value is 24.
RBM verifies configuration consistency between the primary and secondary devices to avoid service interruption upon primary/secondary member switchover. If a device detects configuration inconsistency, it generates a log for you to manually synchronize configuration.
# Enable configuration consistency check and set the check interval to 120 hours.
<Sysname>system-view
[Sysname-remote-backup-group] configuration sync-check interval 120
data-channel
Use data-channel to configure an RBM data channel.
Use undo data-channel to restore the default.
data-channel interface interface-type interface-number
undo data-channel
No RBM data channel is configured.
context-admin
interface interface-type interface-number: Specifies an interface by its type and number to set up a data channel between the primary and secondary devices.
The primary and secondary devices use the interface specified in the command to set up an RBM data channel. The data channel transmits only hot backup packets and the packets that require transparent transmission.
# Set up an RBM data channel using interface GigabitEthernet 1/0/1.
[Sysname-remote-backup-group] data-channel interface gigabitethernet 1/0/1
device-role
Use device-role to configure the RBM role.
Use undo device-role to restore the default.
device-role { primary | secondary }
undo device-role
The RBM role is not configured.
context-admin
primary: Assigns the primary role to the device.
secondary: Assigns the secondary role to the device.
RBM backs up important configuration from the primary device to the secondary device to prevent service interruption when a primary/secondary member switchover occurs. The configuration on the secondary device is overwritten. The unidirectional backup mechanism avoids configuration conflicts, especially in dual-active mode, and ensures configuration consistency on the primary and secondary devices.
# Assign the primary role to the device.
[Sysname-remote-backup-group] device-role primary
Use display remote-backup-group status to display remote backup group status information.
context-admin
context-operator
# Display remote backup group status information.
<Sysname> display remote-backup-group status
Remote backup group information:
Backup mode: Dual-active
Device role: Primary
Control channel interface: GigabitEthernet1/0/1
Data channel interface: GigabitEthernet1/0/1
Local IP: 1.1.1.1 Source port: 3455
Remote IP: 1.1.1.2 Destination port: 1028
Control channel status: Connected
Hot backup status: Enabled
Auto configuration synchronization: Enabled
Configuration consistency check interval: 30 hour
Vrrp delay-time: 1 min
Backup mode |
VRRP hot backup mode: · Dual-active. · Active/standby. |
Device role |
RBM role of the device: · Primary. · Secondary. |
Control channel interface |
Interface used to set up the control channel. |
Data channel interface |
Interface used to set up the data channel. |
Local IP |
Local IP address used by control channel packets. |
Source port |
Local port number used by control channel packets. |
Remote IP |
Peer IP address used by control channel packets. |
Destination port |
Peer port number used by control channel packets. |
Control channel status |
Control channel status: · Connected. · Disconnected. |
Hot backup status |
Hot backup status: · Enabled. · Disabled. |
Auto configuration synchronization |
Automatic configuration synchronization status: · Enabled. · Disabled. |
Configuration consistency check interval |
Configuration consistency check interval in hours. This field is displayed only when configuration consistency check is enabled. |
Vrrp delay-time |
VRRP state switchover delay time in minutes. |
Use display remote-backup-group sync-check to display the configuration consistency check result for the remote backup group.
context-admin
context-operator
Use this command when the primary and secondary devices have inconsistent configuration.
The command displays detailed inconsistency information for only the service modules supported by RBM. For a module not supported by RBM, the command displays only the interface where configuration inconsistency exists.
# Display the configuration consistency check result for the remote backup group. (No inconsistent configuration exists.)
<Sysname> display remote-backup-group sync-check
# Display the configuration consistency check result for the remote backup group. (Inconsistent configuration exists.)
Configuration on secondary device:
nat address-group 2
address 10.1.1.91 10.1.1.92
nat outbound address-group 2
Configuration on primary device:
nat outbound address-group 1
hot-backup enable
Use hot-backup enable to enable RBM hot backup.
Use undo hot-backup enable to disable RBM hot backup.
hot-backup enable
RBM hot backup is enabled.
context-admin
This command enables the primary device in the remote backup group to back up service entries to the secondary device in real time. This prevents service interruption when a primary/secondary member switchover occurs.
# Enable RBM hot backup.
[Sysname-remote-backup-group] hot-backup enable
local-ip
Use local-ip to configure the local IP address for setting up the RBM control channel.
Use undo local-ip to restore the default.
local-ip ip-address
undo local-ip
The local IP address is not configured for setting up the RBM control channel.
context-admin
ip-address: Specifies the local IP address for setting up the RBM control channel.
RBM compares the specified local and peer IP address to determine the device role for setting up the control channel. The device with higher IP address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
# Configure the local IP address as 1.1.1.2 for setting up the RBM control channel.
[Sysname-remote-backup-group] local-ip 1.1.1.2
remote-backup group
Use remote-backup group command to enter remote backup group view.
Use undo remote-backup group to remove all settings of the remote backup group.
remote-backup group
context-admin
RBM provides backup for important configuration and service entries between devices. It collaborates with VRRP to implement hot backup that enables smooth master/backup switchover upon link failures for service continuity. For more information about VRRP, see High Availability Configuration Guide.
# Enter remote backup group view.
remote-ip
Use remote-ip to configure the peer IP address for setting up the RBM control channel.
Use undo remote-ip to restore the default.
remote-ip ip-address [ port port-number ]
undo remote-ip ip-address
The peer IP address is not configured for setting up the RBM control channel.
context-admin
ip-address: Specifies the peer IP address for setting up the RBM control channel. You can specify only an IPv4 address as the peer IP address.
port port-number: Specifies a port by its number used for establishing TCP connection. The value range for the port-number argument is 1024 to 65535, and the default value is 60064.
The RBM control channel transmits data by using packets, including remote backup group status packets, configuration consistency check packets, and configuration synchronization packets. RBM compares the specified local and peer IP address to determine the device role for setting up the control channel. The device with higher IP address acts as the server to listen for TCP connection requests, and the other device acts as the client to initiate the TCP connection.
If the port number is configured on the server, the port provides services for the client. If the port number is configured on the client, the port serves as the destination port to establish TCP connection to the server. The source port is randomly generated on the client.
You can specify only one peer IP address with the same port number on the primary and secondary devices.
# Configure the peer IP address and port number as 1.1.1.1 and 4456 for setting up the RBM control channel.
[Sysname-remote-backup-group] remote-ip 1.1.1.1 port 4456
vrrp delay-time
Use vrrp delay-time to set the VRRP state switchover delay.
Use undo vrrp delay-time to restore the default.
vrrp delay-time [ delay-time ]
The VRRP state switchover delay is one minute.
context-admin
delay-time: Specifies the VRRP state switchover delay time in the range of 1 to 50 minutes.
Execute this command to set the delay that the primary and secondary devices must wait before a switchback. This delay ensures that the devices can finish service entry backup to prevent traffic loss.
# Set the VRRP state switchover delay time to two minutes.
[Sysname-remote-backup-group] vrrp delay-time 2
