- 12-WLAN Advanced Features Configuration Guide
- 01-Bonjour gateway configuration
- 02-Hotspot 2.0 configuration
- 03-WLAN mesh configuration
- 04-Wireless location configuration
- 05-WLAN process maintenance configuration
- 06-WLAN fast forwarding configuration
- 07-WLAN optimization configuration
- 08-AC hierarchy configuration
- 09-WSA configuration
- 10-WLAN probe configuration
06-WLAN fast forwarding configuration | 49.58 KB |
Configuring WLAN fast forwarding
Restrictions: Hardware compatibility with WLAN fast forwarding
Restrictions and guidelines: WLAN fast forwarding configuration
Enabling fast broadcast forwarding
Display and maintenance commands for WLAN fast forwarding
About WLAN fast forwarding
WLAN fast forwarding uses both software and hardware to enhance forwarding performance. Software fast forwarding enables an AC to perform concurrent forwarding by using the multi-core CPU and the 5-tuple table. The AC learns the source IP, source port, destination IP, destination port, and protocol during forwarding and uses high-speed buffer technology to save the information in the 5-tuple table.
Hardware series |
Model |
Product code |
WLAN fast forwarding compatibility |
WX1800H series |
WX1804H |
EWP-WX1804H-PWR-CN |
No |
WX2500H series |
WX2508H-PWR-LTE WX2510H WX2510H-F WX2540H WX2540H-F WX2560H |
EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H |
No |
WX3000H series |
WX3010H WX3010H-X WX3010H-L WX3024H WX3024H-L WX3024H-F |
EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F |
Yes: · WX3010H · WX3010H-X · WX3024H · WX3024H-F No: · WX3010H-L · WX3024H-L |
WX3500H series |
WX3508H WX3510H WX3520H WX3520H-F WX3540H |
EWP-WX3508H EWP-WX3510H EWP-WX3520H EWP-WX3520H-F EWP-WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
EWP-WX5510E EWP-WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
EWP-WX5540H EWP-WX5560H EWP-WX5580H |
Yes |
Access controller modules |
LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F |
Yes |
Hardware series |
Model |
Product code |
WX1800H series |
WX1804H WX1810H WX1820H WX1840H |
EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL |
No |
WX3800H series |
WX3820H WX3840H |
EWP-WX3820H-GL EWP-WX3840H-GL |
Yes |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
Yes |
Only ACs embedded with the FPGA chip support hardware fast forwarding.
1. Enter system view.
2. Enable WLAN fast forwarding.
wlan fast-forwarding enable
By default, WLAN fast forwarding is enabled.
3. Set the WLAN fast forwarding mode.
wlan fast-forwarding mode { hardware | hardware-lite | software }
By default, the WLAN fast forwarding mode is hardware.
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware series |
Model |
Product code |
Command compatibility |
WX1800H series |
WX1804H |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H series |
No |
WX5500E series |
WX5510E WX5540E |
No |
WX5500H series |
Yes |
Yes |
Hardware series |
Model |
Product code |
WX1800H series |
No |
WX3800H series |
WX3820H WX3840H |
No |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
Yes |
Disabling hardware forwarding
Hardware and feature compatibility
Hardware series |
Model |
Product code |
Feature compatibility |
WX1800H series |
WX1804H |
No |
WX2500H series |
No |
WX3000H series |
No |
WX3500H series |
No |
WX5500E series |
WX5510E WX5540E |
No |
WX5500H series |
Yes |
Yes |
Hardware series |
Model |
Product code |
WX1800H series |
No |
WX3800H series |
WX3820H WX3840H |
No |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
Yes |
2. Disable the hardware forwarding function.
wlan fast-forwarding hardware disable
By default, the hardware forwarding function is enabled.
In centralized forwarding, the AC uses its CPU to process received wireless broadcast packets. This requires a lot of resources if a large number of devices and clients operate in the WLAN and might affect wireless services.
Fast broadcast forwarding enables the AC to use the FPGA chip, instead of the CPU, to process wireless broadcast packets. This reduces the workload of the CPU, enhances AC availability, and improves user experience.
For the feature to take effect, make sure WLAN fast forwarding is enabled before you enable fast broadcast forwarding.
Only devices that support hardware forwarding support this feature.
2. Enable fast broadcast forwarding.
wlan fast-forwarding broadcast-enhance enable
By default, fast broadcast forwarding is disabled.
Task |
Command |
Display WLAN fast forwarding status. |
display wlan fast-forwarding status |
