- 05-Network Connectivity
- 01-About the network connectivity configuration guide
- 02-ARP configuration
- 03-DHCP configuration
- 04-DHCPv6 configuration
- 05-GRE configuration
- 06-IGMP snooping configuration
- 07-IP addressing configuration
- 08-Basic IP routing configuration
- 09-IP performance optimization configuration
- 10-IP forwarding basics configuration
- 11-L2TP configuration
- 12-LLDP configuration
- 13-MAC address table configuration
- 14-NAT configuration
- 15-PPP configuration
- 16-MLD snooping configuration
- 17-VLAN configuration
- 18-VLAN termination configuration
- 19-Policy-based routing configuration
- 20-Port isolation configuration
- 21-Layer 2 forwarding configuration
- 22-Loop detection configuration
- 23-RIP configuration
- 24-RIPng configuration
- 25-IPv6 static routing configuration
- 26-IPv6 policy-based routing configuration
- 27-IPv6 basics configuration
- 28-Static routing configuration
- 29-Spanning tree configuration
- 30-Tunneling configuration
- 31-Ethernet link aggregation configuration
- 32-DNS configuration
- 33-Multicast overview
- 34-Modem management configuration
- 35-3G and 4G modem management configuration
25-IPv6 static routing configuration | 42.14 KB |
Configuring IPv6 static routing
Configuring an IPv6 static route
Display and maintenance commands for IPv6 static routing
Configuring an IPv6 default route
About IPv6 static routing
Static routes are manually configured and cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually. IPv6 static routing works well in a simple IPv6 network.
1. Enter system view.
2. Configure an IPv6 static route.
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no IPv6 static route is configured.
3. (Optional.) Set the default preference for IPv6 static routes.
ipv6 route-static default-preference default-preference
The default setting is 60.
Deleting IPv6 static routes
To delete an IPv6 static route, use the undo ipv6 route-static command. To delete all IPv6 static routes including the default route, use the delete ipv6 static-routes all command.
2. Delete all IPv6 static routes, including the default route.
Task |
Command |
Display IPv6 static route next hop information. |
display ipv6 route-static nib [ nib-id ] [ verbose ] |
Display IPv6 static routing table information. |
display ipv6 route-static routing-table [ ipv6-address prefix-length ] |
Display IPv6 static route information. |
display ipv6 routing-table protocol static [ inactive | verbose ] |
For more information about the display ipv6 routing-table protocol static [ inactive | verbose ] command, see basic IP routing in Network Connectivity Command Reference.
A default IPv6 route is used to forward packets that match no entry in the routing table.
A default IPv6 route can be configured in either of the following ways:
· The network administrator can configure a default route with a destination prefix of ::/0. For more information, see "Configuring IPv6 static routing."
· Some dynamic routing protocols (such as RIPng) can generate a default IPv6 route. For example, an upstream router running a dynamic routing protocol can generate a default IPv6 route and advertise it to other routers. These routers install the default IPv6 route with the next hop being the upstream router. For more information, see the respective chapters on those routing protocols in this configuration guide.
