- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Preprovisioning commands
- 09-Device management commands
- 10-Tcl commands
- 11-Python commands
00-Preface | 80.85 KB |
Preface
This command reference describes commands that help you get started with the device. It includes the commands for the following features and tasks:
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, and configuration files.
· FTP and TFTP.
· Tcl and Python.
· Software upgrade.
· Preprovisioning.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S9820-8C switch.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
