07 MPLS Command Reference
HomeSupportResource CenterSwitchesH3C S6860 Switch SeriesH3C S6860 Switch SeriesTechnical DocumentsCommandCommand ReferencesH3C S6860 Switch Series Command References-Release 26xx-6W10207 MPLS Command Reference
09-MPLS L2VPN commands
09-MPLS L2VPN commands 241.94 KB
MPLS L2VPN commands
ac interface
Use ac interface to bind an Ethernet service instance to a cross-connect.
Use undo ac interface to remove the binding.
ac interface interface-type interface-numberservice-instance instance-id [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo ac interface interface-type interface-numberservice-instance instance-id
No Ethernet service instance is bound to a cross-connect.
Cross-connect view
Auto-discovery cross-connect view
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096.
access-mode: Specifies the access mode. This keyword is configurable only when the AC is an Ethernet service instance, and the default access mode is VLAN.
·     ethernet: Specifies the Ethernet access mode.
·     vlan: Specifies the VLAN access mode.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
After you execute this command, packets matching the Ethernet service instance are forwarded to the bound PW or another AC.
The Ethernet service instance specified in this command must have a packet match criterion configured by the encapsulation command.
The access mode determines how the PE treats the VLAN tag in Ethernet frames received from the AC. It also determines how the PE forwards Ethernet frames to the AC.
·     VLAN access mode—Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The VLAN tag is called a P-tag assigned by the service provider. Ethernet frames sent to the AC must also carry the P-tag.
·     Ethernet access mode—If Ethernet frames from the AC have a VLAN tag in the header, the VLAN tag is called a U-tag, and the PE ignores it. Ethernet frames sent to the AC do not carry the P-tag.
# Configure Ethernet service instance 200 on Ten-GigabitEthernet 1/0/1 to match packets with an outer VLAN tag of 200. Bind the Ethernet service instance to cross-connect actopw in cross-connect group vpn1.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] quit
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1] connection actopw
[Sysname-xcg-vpn1-actopw] ac interface ten-gigabitethernet 1/0/1 service-instance 200
# Configure Ethernet service instance 200 on Ten-GigabitEthernet 1/0/1 to match packets with an outer VLAN tag of 200. Bind the Ethernet service instance to the auto-discovery cross-connect in cross-connect group vpwsbgp.
[Sysname] xconnect-group vpwsbgp
[Sysname-xcg-vpwsbgp] auto-discovery bgp
[Sysname-xcg-vpwsbgp-auto] site 1 range 10 default-offset 0
[Sysname-xcg-vpwsbgp-auto-1] connection remote-site-id 2
[Sysname-xcg-vpwsbgp-auto-1-2] ac interface ten-gigabitethernet 1/0/1 service-instance 200
connection
display l2vpn interface
display l2vpn service-instance
encapsulation
pw-type
address-family l2vpn
Use address-family l2vpn to create the BGP L2VPN address family and enter its view, or enter the view of the existing BGP L2VPN address family view.
Use undo address-family l2vpn to delete the BGP L2VPN address family and all settings from BGP L2VPN address family view.
No BGP L2VPN address family exists.
BGP instance view
To establish a BGP PW to a remote PE, you must execute the peer enable command in BGP L2VPN address family view to enable the remote PE.
# Create the BGP L2VPN address family and enter BGP L2VPN address family view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn
[Sysname-bgp-default-l2vpn]
peer enable (Layer 3—IP Routing Command Reference)
auto-discovery
Use auto-discovery to enable a cross-connect group to automatically discover neighbors and create PWs through BGP, and enter auto-discovery cross-connect group view.
Use undo auto-discovery to restore the default.
auto-discovery bgp
undo auto-discovery
A cross-connect group does not use BGP to automatically discover neighbors and create PWs.
Cross-connect group view
bgp: Enables the cross-connect group to automatically discover neighbors and create PWs through BGP.
In auto-discovery cross-connect group view, you can configure parameters such as the local site, remote site, and route target for BGP. The local PE can use BGP to discover remote PEs and create PWs.
# Enable cross-connect group bbb to automatically discover neighbors and create PWs through BGP, and enter auto-discovery cross-connect group view.
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] auto-discovery bgp
[Sysname-xcg-bbb-auto]
display l2vpn pw
display l2vpn xconnect-group
backup-peer
Use backup-peer to configure a backup PW for a cross-connect and enter cross-connect backup PW view, or enter the view of an existing cross-connect backup PW.
Use undo backup-peer to restore the default.
backup-peer ip-address pw-id pw-id [ in-label label-value out-label label-value ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
undo backup-peer ip-address pw-id pw-id
No backup PW exists for a cross-connect.
Cross-connect PW view
ip-address: Specifies the LSR ID of the peer PE on the backup PW.
pw-id pw-id: Specifies a PW ID for the backup PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label for the backup PW. The value range is 16 to 1023.
out-label label-value: Specifies the outgoing label for the backup PW. The value range is 16 to 1023.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW data encapsulation type and control word for the backup PW. If you do not specify a PW class, the PW data encapsulation type is determined by the link type of the interface. The control word feature is not supported for PW data encapsulation types that do not require using control word.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the default tunnel policy is used.
This command configures a backup PW to implement PW redundancy. The backup PW is used when the primary PW fails.
To configure a backup static PW, you must specify the in-label and out-label. To configure a backup LDP PW, you do not need to specify the in-label and out-label.
The peer LSR ID and PW ID for a backup PW must be different from those for an existing VPLS PW or PW bound to a cross-connect.
PW redundancy is mutually exclusive from the multi-segment PW feature. If you have configured two PWs by using the peer command in cross-connect view, you cannot configure a backup PW by using the backup-peer command in cross-connect PW view, and vice versa.
A static PW must have a different incoming label than an existing static LSP or static CRLSP. If they are the same, the static PW is not available, even if you change the incoming label of the static LSP or the static CRLSP. To make the static PW available, delete the static PW, and reconfigure it with an unused incoming label.
# Configure a primary PW and a backup PW for cross-connect pw2pw in cross-connect group vpn2. The primary PW is destined to 6.6.6.6 and has a PW ID of 100. The backup PW is destined to 7.7.7.7 and has a PW ID of 200.
[Sysname] xconnect-group vpn2
[Sysname-xcg-vpn2] connection pw2pw
[Sysname-xcg-vpn2-pw2pw] peer 6.6.6.6 pw-id 100 in-label 16 out-label 17
[Sysname-xcg-vpn2-pw2pw-6.6.6.6-100] backup-peer 7.7.7.7 pw-id 200 in-label 18 out-label 19
[Sysname-xcg-vpn2-pw2pw-6.6.6.6-100-backup]
display l2vpn ldp
display l2vpn pw
peer
ccc
Use ccc to create a remote Circuit Cross Connect (CCC) connection.
Use undo ccc to restore the default.
ccc in-label in-label-value out-label out-label-value { nexthop nexthop | out-interface interface-type interface-number } [ pw-class class-name ]
undo ccc
No remote CCC connections exist.
Cross-connect view
in-label in-label-value: Specifies an incoming label in the range of 16 to 1023.
out-label out-label-value: Specifies an outgoing label in the range of 16 to 1023.
nexthop nexthop: Specifies the IP address of the next hop.
out-interface interface-type interface-number: Specifies the outgoing interface by its type and number.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW data encapsulation type and control word. If you do not specify a PW class, the PW data encapsulation type is determined by the interface type. The control word feature is not supported for PW data encapsulation types that do not require using control word.
A remote CCC connection is a static L2VPN connection that is manually created by specifying the incoming and outgoing labels on two PEs. A remote CCC connection does not need a public tunnel, but it requires configuring two static LSPs in opposite directions on each P device between the two PEs. CCC employs only one level of label to transfer packets. The static LSPs on the P devices transfer data only for the CCC connection.
This command must be configured on both the local and remote PEs to create a remote CCC connection. The outgoing label specified on a device must be the same as the incoming label specified on the next hop device.
After you create a remote CCC connection, you must execute the ac interface command to bind an Ethernet service instance. The PE can forward packets matching the Ethernet service instance to the remote CCC connection.
Use the out-interface keyword to specify the outgoing interface only on a point-to-point link. On other interfaces, for example, Layer 3 Ethernet interfaces, VLAN interfaces, or Layer 3 aggregate interfaces, you must use the nexthop keyword to specify the next hop IP address.
For the PEs to forward packets over a CCC connection, make sure the two PEs have the same CCC connection settings such as the encapsulation type and control word feature.
# Create a remote CCC connection that has incoming label 100, outgoing label 200, and next hop 10.1.1.1, and uses PW class pwc1.
[Sysname-xcg-bbb] connection ccc1
[Sysname-xcg-bbb-ccc1] ccc in-label 100 out-label 200 nexthop 10.1.1.1 pw-class pwc1
ac interface
display l2vpn pw
connection
Use connection to create a cross-connect and enter its view, or enter the view of an existing cross-connect.
Use undo connection to remove a cross-connect.
connection connection-name
undo connection connection-name
No cross-connects exist.
connection-name: Specifies the name of the cross-connect, a case-sensitive string of 1 to 20 characters, excluding hyphens.
A cross-connect is a point-to-point connection.
You can perform the following operations in cross-connect view:
·     Execute ac interface and peer to connect an AC to a PW, so the PE can forward packets between the AC and the PW.
·     Execute ac interface twice to connect two ACs, so the PE can forward packets between the two ACs.
·     Execute peer twice to connect two PWs to form a multi-segment PW.
·     Execute ac interface and ccc to connect an AC to a remote CCC connection, so the PE can forward packets between the AC and the remote CCC connection.
# Create cross-connect ac2pw for cross-connect group vpn1 and enter cross-connect view.
[Sysname-xcg-vpn1] connection ac2pw
[Sysname-xcg-vpn1-ac2pw]
Use connection remote-site-id to create an auto-discovery cross-connect and enter its view, or enter the view of an existing auto-discovery cross-connect.
Use undo connection remote-site-id to remove the auto-discovery cross-connect.
connection remote-site-id remote-site-id
undo connection remote-site-id remote-site-id
No auto-discovery cross-connects exist.
Site view
remote-site-id: Specifies a remote site by its ID in the range of 0 to 256.
This command creates an auto-discovery cross-connect that uses BGP to establish a PW from the local site to the specified remote site.
The local and remote sites can have only one BGP PW. If you have configured multiple BGP PWs between the sites, remove all the BGP PWs and then re-create a BGP PW.
In auto-discovery cross-connect view, you can execute ac interface to bind an AC to the auto-discovery cross-connect. The PE can forward packets between the AC and the PW.
# Create an auto-discovery cross-connect from site 1 to site 3 in site view, and enter auto-discovery cross-connect view.
[Sysname-xcg-bbb-auto] site 1 range 10
[Sysname-xcg-bbb-auto-1] connection remote-site-id 3
[Sysname-xcg-bbb-auto-1-3]
control-word enable
Use control-word enable to enable the control word feature.
Use undo control-word enable to disable the control word feature.
control-word enable
The control word feature is disabled.
PW class view
The control word field is between the MPLS label stack and the Layer 2 data. It carries control information for the Layer 2 frame, for example, the sequence number.
The control word feature has the following functions:
·     Avoids fragment disorder. In multipath forwarding, fragments received might be disordered. You can configure the control word feature so the device reorders the fragments according to the sequence number carried in the control word field.
·     Transfers specific Layer 2 frame flags, such as the FECN bit and BECN bit of Frame Relay.
·     Identifies the original payload length for packets that include padding.
When the PW data encapsulation type is Ethernet or VLAN, the control word field is optional. Packets transmitted on the PW carry the control word field only when control word is enabled on both PEs.
# Enable the control word feature for PW class pw100.
[Sysname] pw-class pw100
[Sysname-pw-pw100] control-word enable
display l2vpn pw-class
description
Use description to configure a description for a cross-connect group.
No description is configured for a cross-connect group.
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description of vpws for vpn2 for cross-connect group vpn2.
[Sysname-xcg-vpn2] description vpws for vpn2
display bgp l2vpn signaling
Use display bgp l2vpn signaling to display MPLS L2VPN label block information discovered by BGP.
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] ]
instance instance-name: Displays MPLS L2VPN label block information in a BGP instance. The instance-name argument specifies the BGP instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays MPLS L2VPN label block information in the default BGP instance.
peer ip-address: Displays MPLS L2VPN label block information advertised to or received from a BGP peer. The ip-address argument specifies the peer IP address.
advertised: Displays MPLS L2VPN label block information advertised to the BGP peer.
received: Displays MPLS L2VPN label block information received from the BGP peer.
route-distinguisher route-distinguisher: Displays BGP MPLS L2VPN label block information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
site-id site-id: Displays BGP MPLS L2VPN label block information for a site. The site-id argument specifies the site ID. The site ID range is 0 to 65535.
label-offset label-offset: Displays information about the BGP MPLS L2VPN label block with an offset. The label-offset argument specifies the offset in the range of 0 to 65535.
advertise-info: Displays BGP MPLS L2VPN label block advertisement information.
If you do not specify any parameters, this command displays brief information about all BGP MPLS L2VPN label blocks.
# Display brief information about all BGP MPLS L2VPN label blocks.
<Sysname> display bgp l2vpn signaling
 BGP local router ID is 192.168.1.135
 Total number of label blocks: 2
 Route distinguisher: 2:2
     Site ID  LB offset  LB range  LB base    Nexthop
* >  1        0          10        1034       0.0.0.0
* >i 2        0          10        1162       192.3.3.3
Status codes
Status codes:
·     * – valid—Valid route.
·     > – best—Best route.
·     d – damped—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
Origin
Origin of the label block:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Unknown origin.
LB offset
Offset of the label block.
LB range
Size of the label block.
LB base
Initial value of the label block.
# Display detailed information about the BGP MPLS L2VPN label block that has RD 2:2, site ID 2, and offset 0.
<Sysname> display bgp l2vpn signaling route-distinguisher 2:2 site-id 2 label-offset 0
 Local AS number: 100
 Total number of label blocks: 1
 Paths:   1 available, 1 best
 Original nexthop: 192.3.3.3
 Ext-Community   : <RT: 2:2>, <L2VPN info: MTU 1500, Encap type VLAN>
 AS-path         : (null)
 Origin          : igp
 Attribute value : localpref 100, pref-val 0
 Site ID         : 2
 LB offset       : 0
 LB base         : 1162
 LB range        : 10
 State           : valid, internal, best
 CSV             : 0x01000ABFFF
Paths
Number of label block messages:
·     available—Number of available label block messages.
·     best—Number of best label block messages.
From
IP address of the peer from which the label block was received.
Original nexthop
Original next hop. If the label block was obtained from a BGP route update, this field displays the next hop address in that BGP route update.
Ext-Community
Extended community attribute:
·     RT—Route target.
·     L2VPN info—L2VPN information, including the MTU and encapsulation type.
AS-path
AS path attribute, which records all ASs that the label block passed to prevent routing loops.
Origin
·     igp—Originated in the AS.
·     egp—Learned through EGP.
·     incomplete—Unknown origin.
Attribute value
Attribute of the label block:
·     MED—Multi-Exit Discriminator attribute.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Preference value.
LB offset
LB base
LB range
State of the label block:
·     valid.
·     internal.
·     external.
·     local.
·     best.
CSV
Circuit status vector.
# Display BGP advertisement information for the specified MPLS L2VPN label block.
<Sysname> display bgp l2vpn signaling route-distinguisher 2:2 site-id 1 label-offset 0 advertise-info
 Paths:   1 best
 Site ID         : 1
 LB offset       : 0
 LB base         : 1034
 LB range        : 10
 CSV             : 0x01000ADFFF
    192.3.3.3
Paths
LB offset
LB base
LB range
CSV
Peers to which the label block has been advertised.
display l2vpn bgp
Use display l2vpn bgp to display MPLS L2VPN label block information.
display l2vpn bgp [ local | peer ip-address ] [ xconnect-group group-name ] [ verbose ]
local: Displays local MPLS L2VPN label block information.
peer ip-address: Displays MPLS L2VPN label block information received from the remote peer.
xconnect-group group-name: Displays MPLS L2VPN label block information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays MPLS L2VPN label block information for all cross-connect groups.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you specify a peer, this command displays both the label block received from the peer and the local label block that matches the received label block.
If you do not specify a peer or local, this command displays label blocks received from all peers and local label blocks that match the received ones. If no local label block matches the received ones, the command only displays the label blocks received from all peers.
A local label block matches a received label block if the following condition is met: local label block LO ≤ remote site ID ≤ local label block LO + local label block LR – 1.
# Display brief information about label blocks received from all peers.
<Sysname> display l2vpn bgp
Total number of BGP PWs: 1, 1 up, 0 down
Xconnect-group Name: vpnb, Site ID:1
Rmt Site   Offset  RD                    Nexthop          In/Out Label     State
2          0       2:2                   192.3.3.3        1036/1163        Up
Rmt Site
ID of the remote site.
Offset
# Display detailed information about label blocks received from all peers.
<Sysname> display l2vpn bgp verbose
 Remote Site ID     : 2
 Offset             : 0
 RD                 : 2:2
 PW State           : Up
 Encapsulation      : VLAN
 MTU                : 1500
 Nexthop            : 192.3.3.3
 Local VC Label     : 1036
 Remote VC Label    : 1163
 Link ID            : 1
 Local Label Block  : 1034/10/0
 Remote Label Block : 1162/10/0
 Export Route Target: 2:2
Table 5 Command output
Local VC Label
Incoming label of the PW.
Remote VC Label
Outgoing label of the PW.
Link ID
Link ID of the PW.
Local Label Block
Local label block: label base/label range/Label-block offset.
Remote Label Block
Remote label block: label base/label range/Label-block offset.
Export Route Target
Route target of the remote label block.
# Display brief information about all local label blocks.
<Sysname> display l2vpn bgp local
Site   Offset  Range  Label Base    RD
1      0       10     1034          2:2
# Display detailed information about all local label blocks.
<Sysname> display l2vpn bgp local verbose
 Site ID            : 1
 Offset             : 0
 RD                 : 2:2
 Range              : 10
 Label Base         : 1034
 Link ID            : 1
Table 6 Command output
Offset
RD
RD of the label block. If no RD is configured, this field displays a hyphen (-).
Range
Range of the label block.
Label Base
Link ID
Link ID of the PW established using the label block.
The link ID is fixed to 1 because an MPLS L2VPN cross-connect can establish only one BGP PW.
display l2vpn pw
display l2vpn forwarding
Use display l2vpn forwarding to display cross-connect forwarding information.
display l2vpn forwarding { ac | pw } [ xconnect-group group-name ] [ slot slot-number ] [ verbose ]
ac: Displays AC forwarding information.
pw: Displays PW forwarding information.
xconnect-group group-name: Displays forwarding information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a group, this command displays forwarding information for all cross-connect groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays cross-connect forwarding information for the master device.
# Display brief AC forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding ac
Total number of cross-connections: 3
Total number of ACs: 3
AC                               Xconnect-group                  Link ID
XGE1/0/1 srv1                    vpn1                            0
XGE1/0/2 srv2                    vpn2                            1
Table 7 Command output
Total number of cross-connects, including cross-connects not bound to any ACs.
AC
AC type:
Ethernet service instance on a Layer 2 interface.
# Display detailed AC forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding ac verbose
Xconnect-group: vpws1
 Connection: actopw1
  Interface: XGE1/0/3  Service Instance: 1
    Link ID      : 1
    Access Mode  : VLAN
    Encapsulation: s-vid 16
 Connection: actopw2
  Interface: XGE1/0/3  Service Instance: 4
    Link ID      : 1
    Access Mode  : VLAN
    Encapsulation: untagged
Table 8 Command output
Xconnect-group
Cross-connect group name.
Connection
Cross-connect name.
Service Instance
Ethernet service instance ID. This field is displayed only when the AC is an Ethernet service instance on a Layer 2 interface.
Access Mode
AC access mode:
·     VLAN.
·     Ethernet.
Encapsulation
Match criterion of the Ethernet service instance. This field is displayed only when the AC type is Ethernet service instance on a Layer 2 interface.
# Display brief PW forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding pw
Total number of cross-connections: 1
Total number of PWs: 2, 2 up, 0 blocked, 0 down
Xconnect-group                  In/Out Label    NID        Link ID    State
vpn1                            1279/1151       1025       0          Up
vpn1                            1278/1151       1027       1          Up
Table 9 Command output
Total number of cross-connects, including those not bound to any PW.
NID
NHLFE ID for the public tunnel that carries the PW.
If equal-cost tunnels are available, this field displays multiple NIDs.
If no tunnel is available, this field displays None.
PW state: Up, Down, BFD Defect, or Blocked.
Blocked indicates that the PW is a backup PW. BFD Defect indicates that BFD has detected a defect on the PW.
# Display detailed PW forwarding information for all cross-connect groups.
<Sysname> display l2vpn forwarding pw verbose
Xconnect-group: vpn1
 Connection: ldp
  Link ID: 0
    PW Type         : VLAN                  PW State : Up
    In Label        : 1279                  Out Label: 1151
    MTU             : 1500
    PW Attributes   : Main
    VCCV CC         : Router-Alert
    VCCV BFD        : Fault Detection with BFD
    Tunnel Group ID : 0x60000000
    Tunnel NHLFE IDs: 1025
  Link ID: 1
    In Label        : 1278                  Out Label: 1151
    MTU             : 1500
    Tunnel Group ID : 0x160000001
    Tunnel NHLFE IDs: 1027
Table 10 Command output
PW State
PW Attributes
PW attribute:
·     Main—The PW is the primary PW.
·     Backup—The PW is the backup PW.
VCCV CC
VCCV CC type:
·     Control-Word—Control word.
·     Router-Alert—MPLS Router Alert Label.
This field displays a hyphen (-) if no VCCV CC type is specified.
VCCV BFD
VCCV BFD type:
Fault Detection with BFD. BFD packets use IP/UDP encapsulation (with IP/UDP headers).
This field displays a hyphen (-) if BFD is not used to verify PW connectivity.
Tunnel Group ID
ID of the tunnel group for the PW.
Tunnel NHLFE IDs
NHLFE IDs of the public tunnels that carry the PW.
If equal-cost tunnels are available, this field displays multiple tunnel NHLFE IDs.
display l2vpn ldp
Use display l2vpn ldp to display LDP PW label information.
display l2vpn ldp [ peer ip-address [ pw-id pw-id ] | xconnect-group group-name ] [ verbose ]
peer ip-address: Displays LDP PW label information advertised by a peer PE. The ip-address argument specifies the LSR ID of the peer PE. If you do not specify a peer PE, this command displays LDP PW label information advertised by all peer PEs.
pw-id pw-id: Displays LDP PW label information for a PW. The pw-id argument specifies the PW ID in the range of 1 to 4294967295. If you specify peer ip-address without this option, the command displays all LDP PW label information advertised by the peer PE.
xconnect-group group-name: Displays LDP PW label information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays LDP PW label information for all cross-connect groups.
# Display brief information about all LDP PW labels.
<Sysname> display l2vpn ldp
Total number of LDP PWs: 5, 4 up, 1 down
Peer            PW ID/VPLS ID         In/Out Label    State Owner
192.3.3.3       1001                  775125/775126   Up    vpws1
192.3.3.3       1003                  775117/775122   Up    vpws3
192.3.3.3       1004                  775120/775120   Up    vpws4
192.4.4.4       1000                  775116/unknown  Down  vpws5
Table 11 Command output
PW ID/VPLS ID
This field displays the PW ID for FEC 128, and displays the VPLS ID for FEC 129. Only VPLS supports FEC 129.
Owner
Cross-connect group of the PW.
# Display detailed information about all LDP PW labels.
<Sysname> display l2vpn ldp verbose
Peer: 192.2.2.2        PW ID: 1000
  Connection    : ldp
  PW State      : Up
  PW Status Communication: Notification method
  PW ID FEC (Local/Remote):
    PW Type     : VLAN/VLAN
    Group ID    : 0/0
    Label       : 1151/1279
    Control Word: Disabled/Disabled
    VCCV CC Type: -/-
    VCCV CV Type: -/-
    MTU         : 1500/1500
    PW Status   : PW forwarding/PW forwarding
Table 12 Command output
Xconnect-group
Connection
Cross-connect of the PW.
PW state communicate:
·     Notification method—Uses notifications to communicate PW states.
·     Label withdraw method—Assigns a PW label to the PW when the AC is up and withdraws the PW label when the AC goes down.
VCCV CC Type
VCCV CC type:
For information about VCCV, see MPLS Configuration Guide.
VCCV CV Type
VCCV CV type:
·     LSP Ping—Uses MPLS LSP ping to verify PW connectivity.
·     BFD—Uses BFD to verify PW connectivity. BFD packets use IP/UDP encapsulation (with IP/UDP headers).
This field displays a hyphen (-) if VCCV is not performed on the PW.
display l2vpn pw
Use display l2vpn pw to display L2VPN PW information.
display l2vpn pw [ xconnect-group group-name ] [ protocol { bgp | ldp | static } ] [ verbose ]
xconnect-group group-name: Displays L2VPN PW information for a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive string of 1 to 31 characters. If you do not specify a group, this command displays L2VPN PW information for all cross-connect groups.
protocol: Displays L2VPN PW information established by a protocol. If you do not specify a protocol, this command displays L2VPN PW information established by all protocols.
bgp: Displays BGP PW information.
ldp: Displays LDP PW information.
static: Displays static PW information, including remote CCC connections.
# Display brief information about all L2VPN PWs.
<Sysname> display l2vpn pw
Flags: M - main, B - backup, N - no split horizon
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: ldp
Peer            PW ID/Rmt Site    In/Out Label    Proto   Flag  Link ID  State
192.3.3.3       500               1299/1299       LDP     M     0        Up
192.3.3.3       2                 1036/1163       BGP     M     1        Up
Table 13 Command output
Flags
PW flag.
PW ID/Rmt Site
This field displays the PW ID for a static or LDP PW, and displays the remote site ID for a BGP PW.
Proto
Protocol that established the PW: LDP, Static, or BGP.
Link ID
Link ID of the PW.
PW state:
·     Up—The PW is available.
·     Down—The PW is not available.
·     Blocked—The PW is a backup PW.
·     Defect—BFD has detected a defect on the PW.
·     Idle—The incoming label of the PW is not available.
·     Dup—The incoming label of the static PW is used by a static LSP or a static CRLSP.
# Display detailed information about all PWs.
<Sysname> display l2vpn pw verbose
 Connection Name: ldp
  Peer: 192.3.3.3        PW ID: 500
    Signaling Protocol  : LDP
    Link ID             : 0          PW State : Up
    In Label            : 1299       Out Label: 1299
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000160000000
    Tunnel NHLFE IDs    : 1026
 Connection of auto-discovery: Site 1
  Peer: 192.3.3.3        Remote Site: 2
    Signaling Protocol  : BGP
    Link ID             : 1          PW State : Up
    In Label            : 1036       Out Label: 1163
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
Table 14 Command output
Xconnect-group Name
Connection Name
Cross-connect name, which is displayed for LDP and static PWs.
Peer
IP address of the peer PE of the PW.
Signaling Protocol
PW State
PW state:
·     Duplicate—The incoming label of the static PW is used by a static LSP or a static CRLSP.
Wait to Restore Time
Wait time to switch traffic from the backup PW to the primary PW when the primary PW recovers, in seconds. If the switchover is disabled, this field displays Infinite.
This field is available when both primary and backup PW exist, and is displayed only for the primary PW.
Remaining Time
Remaining wait time for traffic switchover, in seconds.
PW Attributes
PW attribute:
·     Main—Primary PW.
·     Backup—Backup PW.
VCCV CC
VCCV CC type:
VCCV BFD
VCCV BFD type:
Tunnel Group ID
Tunnel NHLFE IDs
The PW is a BGP PW.
Site
Local site ID.
Remote site
Remote site ID.
Use display l2vpn pw-class to display PW class information.
display l2vpn pw-class [ class-name ] [ verbose ]
class-name: Displays information about the PW class specified by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a PW class, this command displays information about all PW classes.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief PW class information.
# Display information about all PW classes.
<Sysname> display l2vpn pw-class
Total number of PW classes: 2
PW Class Name       PW Type              Control Word   VCCV CC        VCCV BFD
pw1                 Ethernet             Enabled        Router-Alert   BFD
pw2                 VLAN                 Disabled       Router-Alert   BFD
Table 15 Command output
VCCV CC
VCCV CC type:
VCCV BFD
VCCV BFD type:
BFD—BFD packets use IP/UDP encapsulation (with IP/UDP headers).
# Display detailed information about all PW classes.
<Sysname> display l2vpn pw-class verbose
PW Class Name : pw1
  PW Type     : Ethernet
  Control Word: Enabled
  VCCV BFD    : BFD
  Sequencing  : Both
PW Class Name : pw2
  PW Type     : VLAN
  VCCV BFD    : BFD
  Sequencing  : -
Table 16 Command output
PW Type
PW data encapsulation type: Ethernet or VLAN.
Control Word
Whether control word is enabled.
VCCV CC
VCCV CC type:
VCCV BFD
VCCV BFD type:
Sequencing
Sequencing on the PW. The value is Both.
A hyphen (-) in this field indicates that sequencing is disabled on the PW.
Use display l2vpn service-instance to display Ethernet service instance information.
interface interface-type interface-number: Displays Ethernet service instance information for the specified Layer 2 Ethernet interface or Layer 2 aggregate interface. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Displays information about the Ethernet service instance specified by its ID. The instance ID is in the range of 1 to 4096. If you specify interface interface-type interface-number without this option, the command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 5, 5 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface                SrvID Owner                           LinkID State Type
XGE1/0/1                 1     vpws1                           1      Up    VPWS
XGE1/0/1                 2     vpws2                           1      Up    VPWS
Table 17 Command output
SrvID
Owner
Name of the cross-connect group bound to the Ethernet service instance. This field is empty if no cross-connect group is bound.
Link ID
Link ID of the AC.
State of the service instance: UP or Down.
L2VPN type. The value can only be VPWS for an MPLS L2VPN network.
# Display detailed information about all Ethernet service instances on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1.
<Sysname> display l2vpn service-instance interface ten-gigabitethernet 1/0/1 verbose
Interface: XGE1/0/1
  Service Instance: 10
    Type          : Manual
    Encapsulation : s-vid 1
    Bandwidth     : Unlimited
    Connection    : ac
    Link ID       : 0
    State         : Down
    Statistics    : Disabled
Table 18 Command output
Ethernet service instance type and packet matching method:
·     Dynamic (MAC-based)—The Ethernet service instance is dynamically created and the MAC address matching method is used.
·     Dynamic (VLAN-based)—The Ethernet service instance is dynamically created and the VLAN matching method is used.
·     Manual—The Ethernet service instance is manually created and the VLAN matching method is used.
This field can only be Manual for VPLS VSIs.
Encapsulation
Packet match criterion of the Ethernet service instance. This field is not displayed if no packet match criterion is configured.
Bandwidth
Maximum bandwidth for known unicast traffic in the VSI, in kbps.
Xconnect-group
Link ID
Link ID of the AC.
State of the Ethernet service instance: UP or Down.
Statistics
Packet statistics state on the Layer 3 interface:
·     Enabled.
·     Disabled.
service-instance
Use display l2vpn xconnect-group to display cross-connect group information.
display l2vpn xconnect-group [ name group-name ] [ verbose ]
name group-name: Displays information about a cross-connect group. The group-name argument specifies the cross-connect group name, a case-sensitive sting of 1 to 31 characters. If you do not specify a group, this command displays information about all cross-connect groups.
# Display brief information about all cross-connect groups.
<Sysname> display l2vpn xconnect-group
Total number of cross-connections: 3, 0 up, 3 down, 0 admin down
Xconnect-group Name             Connection ID   MTU    State
abc                             0               1500   Down
vpn1                            2               1500   Down
vpn2                            1               1500   Down
Table 19 Command output
Connection ID
Cross-connect ID.
Cross-connect group state: Up, Down, or Admin down. Admin down indicates that the cross-connect group has been shut down by using the shutdown command.
# Display detailed information about all cross-connect groups.
<Sysname> display l2vpn xconnect-group verbose
 Description   : ldp-pw
 Connection Name   : ldp
  Connection ID    : 1
  State            : Down
  MTU              : 1500
  LDP PWs:
    Peer            PW ID            Link ID    State
    192.3.3.3       200              1          Down
  ACs:
    AC                               Link ID    State
    Vlan10                           0          Up
 Connection of auto-discovery: Site 1, Remote Site 2
  Connection ID    : 0
  State            : Up
  MTU              : 1500
  BGP PWs:
    Peer            Remote Site      Link ID    State
    192.3.3.3       2                1          Up
  ACs:
    AC                               Link ID    State
    XGE1/0/4 srv1                    0          Up
Table 20 Command output
Xconnect-group Name
Description for the cross-connect group. If no description is configured, this field is not displayed.
Connection Name
Cross-connect name.
Auto-discovery cross-connect.
Site
Local site ID.
Remote site
Remote site ID.
Connection ID
Cross-connect ID.
PW state:
AC
AC type: Ethernet service instance on a Layer 2 interface.
xconnect-group
encapsulation
Use encapsulation to configure a packet match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid vlan-id [ only-tagged ]
encapsulation s-vid vlan-id-list
encapsulation { default | tagged | untagged }
undo encapsulation
No packet match criterion is configured for an Ethernet service instance.
Ethernet service instance view
s-vid: Matches packets with the specified outer VLAN IDs.
only-tagged: Matches tagged packets. If the outer VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
·     To match only PVID-tagged packets, specify the only-tagged keyword.
·     To match both untagged packets and PVID-tagged packets, do not specify the only-tagged keyword.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
vlan-id-list: Specifies a space-separated list of up to eight VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of start-VLAN-ID to end-VLAN-ID. The value range for VLAN IDs is 1 to 4094.
default: Matches packets that do not match any other Ethernet service instances on the interface. On an interface, you can configure this criterion only in one Ethernet service instance. The Ethernet service instance matches all packets if it is the only instance on the interface.
untagged: Matches any packets that do not have a VLAN tag. If you configure the encapsulation untagged command on an Ethernet service instance, do not configure nesting on the Layer 2 Ethernet interface or Layer 2 aggregate interface to which the Ethernet service instance belongs. For more information about nesting, see QoS in ACL and QoS Configuration Guide.
The match criteria of different Ethernet service instances cannot overlap on an interface.
An Ethernet service instance can contain only one match criterion. To change the match criterion, first execute the undo encapsulation command to remove the original criterion. When you remove the match criterion in an Ethernet service instance, the mapping between the service instance and the cross-connect is removed automatically.
# Configure Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1 to match packets that have an outer VLAN ID of 111.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before configuring other L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn switchover
Use l2vpn switchover to switch traffic from a PW to its backup or primary PW.
l2vpn switchover peer ip-address pw-id pw-id
peer ip-address: Specifies the LSR ID of the peer PE.
pw-id pw-id: Specifies a PW by its ID in the range of 1 to 4294967295.
The specified LSR ID and PW ID uniquely identify a PW.
If a PW has a backup PW or primary PW, this command switches traffic from the PW to the backup or primary PW. If the PW does not have a backup or primary PW, this command does not perform the switchover.
# Switch traffic from PW 100 destined for 3.3.3.3 to its backup PW.
<Sysname> l2vpn switchover peer 3.3.3.3 pw-id 100
mtu
Use mtu to set an MTU for PWs established on a cross-connect or auto-discovery cross-connect.
mtu size
undo mtu
A PW has an MTU of 1500 bytes.
Cross-connect view
Auto-discovery cross-connect group view
size: Specifies an MTU value. The value range is 300 to 65535.
The specified MTU applies to all PWs established in the cross-connect view or the auto-discovery cross-connect group view.
The MTU specifies the maximum packet length, including the control word, PW label, and network layer packet.
For an LDP PW to come up, the PEs at the two ends of the PW must have the same MTU.
# Set the MTU to 1400 bytes for cross-connect ac2pw in cross-connect group vpn1.
[Sysname-xcg-vpn1-ac2pw] mtu 1400
# Set the MTU to 1400 bytes for the auto-discovery cross-connect in cross-connect group bbb.
[Sysname-xcg-bbb-auto] mtu 1400
peer
Use peer to configure a PW for a cross-connect and enter cross-connect PW view, or enter the view of an existing cross-connect PW.
Use undo peer to delete a PW for a cross-connect.
undo peer ip-address pw-id pw-id
No PWs exist for a cross-connect.
Cross-connect view
pw-id pw-id: Specifies a PW ID for the PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label of the PW. The value range is 16 to 1023.
out-label label-value: Specifies the outgoing label of the PW. The value range is 16 to 1023.
To create a static PW, you must specify the incoming and outgoing labels. To enter the view of an existing static PW, you do not need to specify the incoming and outgoing labels.
If you do not specify the incoming and outgoing labels when you create a new PW, LDP is used to create the PW.
The PW ID for a PW must be the same on the PEs at the ends of the PW.
On a PE, the LSR ID of the peer PE and the PW ID uniquely identify a PW. The peer LSR ID and PW ID combination of a PW must be unique among all VPLS PWs and cross-connect PWs.
PW redundancy is mutually exclusive with the multi-segment PW feature. If you have configured two PWs by using the peer command in cross-connect view, you cannot configure a backup PW by using the backup-peer command in cross-connect PW view, and vice versa.
# Configure an LDP PW destined to 4.4.4.4 for cross-connect pw2pw in cross-connect group vpn1 and enter cross-connect PW view. The PW ID is 200.
[Sysname-xcg-vpn1] connection pw2pw
[Sysname-xcg-vpn1-pw2pw] peer 4.4.4.4 pw-id 200
[Sysname-xcg-vpn1-pw2pw-4.4.4.4-200]
# Configure a static PW destined to 5.5.5.5 for cross-connect pw2pw in cross-connect group vpn1 and enter cross-connect PW view. The static PW has an ID of 200, an incoming label of 100, and an outgoing label of 200.
[Sysname-xcg-vpn1-pw2pw] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200
[Sysname-xcg-vpn1-pw2pw-5.5.5.5-200]
display l2vpn ldp
display l2vpn pw
pw-class
tunnel-policy
peer signaling
Use peer signaling to enable BGP to exchange label block information with the specified peer or peer group.
Use undo peer signaling to disable BGP to exchange label block information with the specified peer or peer group.
peer { group-name | ip-address [ mask-length ] } signaling [ non-standard ]
undo peer { group-name | ip-address [ mask-length ] } signaling
BGP can exchange label block information with an L2VPN peer or peer group through RFC 4761 MP_REACH_NLRI.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must have been created.
ip-address: Specifies a peer by its IP address. The specified peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange label block information with all dynamic peers in the subnet.
non-standard: Uses draft-kompella-ppvpn-l2vpn-03 MP_REACH_NLRI to exchange label block information. If you do not specify this keyword, RFC 4761 MP_REACH_NLRI is used to exchange label block information.
L2VPN uses MP-BGP to exchange label blocks when creating a BGP PW.
To enable BGP to exchange label blocks with the specified peers through RFC 4761 MP_REACH_NLRI, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer signaling command.
# Enable BGP to exchange label block information with the peer 3.3.3.9 through draft-kompella-ppvpn-l2vpn-03 MP_REACH_NLRI.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] peer 3.3.3.9 signaling non-standard
policy vpn-target
Use policy vpn-target to enable route target-based filtering of incoming BGP L2VPN information.
Use undo policy vpn-target to disable route target-based filtering of incoming BGP L2VPN information.
policy vpn-target
Route target-based filtering of incoming BGP L2VPN information is enabled.
If route target-based filtering is enabled, L2VPN accepts only the incoming BGP L2VPN information whose export route target attribute matches the local import route target attribute.
On an inter-AS VPN option B network, an ASBR needs to store all BGP L2VPN information (label block information) and advertises the information to the remote ASBR. To meet this need, execute the undo policy vpn-target command on the ASBR to accept all incoming BGP L2VPN information.
For more information about an inter-AS VPN option B network, see MPLS Configuration Guide.
# Disable route target-based filtering of incoming BGP L2VPN information.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] undo policy vpn-target
pw-class (auto-discovery cross-connect group view)
Use pw-class to specify a PW class for an auto-discovery cross-connect group.
Use undo pw-class to restore the default.
pw-class class-name
undo pw-class
No PW class is specified.
The specified PW class will be used to establish all PWs in the auto-discovery cross-connect group.
# Specify a PW class named pw100 for auto-discovery cross-connect group bbb.
[Sysname-pw-pw100] quit
[Sysname-xcg-bbb-auto] pw-class pw100
control-word enable
pw-class
pw-type
pw-class (system view)
Use pw-class to create a PW class and enter its view, or enter the view of an existing PW class.
Use undo pw-class to delete a PW class.
pw-class class-name
undo pw-class class-name
No PW classes exist.
class-name: Specifies a name for the PW class, a case-sensitive string of 1 to 19 characters.
In PW class view, you can configure PW attributes such as the PW data encapsulation type and whether to enable control word. You can configure PWs to use the same PW class to simplify PW attribute configuration.
# Create a PW class named pw100 and enter PW view.
[Sysname-pw-pw100]
control-word enable
pw-type
pw-type
Use pw-type to specify a PW data encapsulation type for a PW class.
Use undo pw-type to restore the default.
pw-type { ethernet | vlan }
undo pw-type
The PW data encapsulation type is VLAN.
PW class view
ethernet: Specifies the PW data encapsulation type as Ethernet.
vlan: Specifies the PW data encapsulation type as VLAN.
This command takes effect only when the AC type is Ethernet.
When the PW data encapsulation type is Ethernet, P-tag is not transferred on a PW.
·     For a packet from a CE:
¡     If the packet contains a P-tag, the PE removes the P-tag, and adds a PW label and an outer tag into the packet before forwarding it.
¡     If the packet contains no P-tag, the PE directly adds a PW label and an outer tag into the packet before forwarding it.
·     For a packet to a CE:
¡     If the access mode is configured as VLAN by using the ac interface command, the PE adds a P-tag into the packet before sending it to the CE.
¡     If the access mode is configured as Ethernet by using the ac interface command, the PE directly sends the packet to the CE.
You cannot rewrite or remove existing tags.
When the PW data encapsulation type is VLAN, packets transmitted over a PW must carry a P-tag.
¡     If the peer PE does not require the ingress to rewrite the P-tag, the PE keeps the P-tag unchanged for the packet, and then encapsulates the packet. If the packet contains no P-tag, the PE adds a null label (the label value is 0) into the packet, and then encapsulates the packet.
¡     If the peer PE requires the ingress to rewrite the P-tag, the PE changes the P-tag to the expected VLAN tag (the tag value might be 0), and then adds a PW label and an outer tag into the packet. If the packet contains no P-tag, the PE adds a VLAN tag expected by the peer PE (the tag value might be 0), and then adds a PW label and an outer tag into the packet.
¡     If the access mode is configured as VLAN by using the ac interface command, the PE rewrites or retains the P-tag before forwarding the packet.
¡     If the access mode is configured as Ethernet by using the ac interface command, the PE removes the P-tag before forwarding the packet.
# Configure the PW data encapsulation type as Ethernet.
[Sysname-pw-pw100] pw-type ethernet
ac-interface
revertive
Use revertive to specify the switchover mode and set the switchover wait time.
Use undo revertive to restore the default.
revertive { wtr wtr-time | never }
undo revertive { wtr | never }
The switchover mode is revertive and the switchover wait time is 0 seconds. When the primary PW recovers, traffic is immediately switched from the backup PW to the primary PW.
Cross-connect view
wtr wtr-time: Specifies the switchover mode as revertive and specifies the wait time in the range of 0 to 3600 seconds. When the primary PW recovers, the PE waits for the specified time before switching traffic from the backup PW to the primary PW.
never: Specifies the switchover mode as non-revertive. After the primary PW recovers, traffic is not switched from the backup PW to the primary PW.
# Specify the revertive mode and set the switchover wait time to 120 seconds for cross-connect ac2pw in cross-connect group vpn1.
[Sysname-xcg-vpn1-ac2pw] revertive wtr 120
display l2vpn pw
route-distinguisher
Use route-distinguisher to configure a route distinguisher (RD) for a BGP cross-connect group.
Use undo route-distinguisher to restore the default.
No RD is configured for a BGP cross-connect group.
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. An RD can be in one of the following formats:
MPLS L2VPN uses RDs to differentiate the sites with the same site ID but in different VPNs.
BGP adds the configured RD before the site ID. The RD and the site ID uniquely identify a VPN site.
You cannot configure the same RD for different BGP cross-connect groups.
To modify an RD, execute the undo route-distinguisher command to remove the RD, and then execute the route-distinguisher command.
# Configure the RD 22:2 for BGP cross-connect group bbb.
[Sysname-xcg-bbb-auto] route-distinguisher 22:2
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
undo rr-filter
An RR does not filter reflected L2VPN information.
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 199.
After this command is executed, only the L2VPN information that is permitted by the specified extended community list is reflected.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
For more information about extended community lists, see Layer 3—IP Routing Configuration Guide.
# Configure the RR to reflect only the BGP L2VPN information that is permitted by extended community list 10.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
service-instance
Use service-instance to create an Ethernet service instance on an interface and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance on an interface.
undo service-instance instance-id
No Ethernet service instances exist.
instance-id: Specifies an ID for the Ethernet service instance, in the range of 1 to 4096.
# Create Ethernet service instance 1 on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1, and enter Ethernet service instance 1 view.
shutdown
Use shutdown to disable a cross-connect group.
Use undo shutdown to enable a cross-connect group.
shutdown
A cross-connect group is enabled.
After you disable a cross-connect group, all cross-connects in the group cannot provide L2VPN services.
Use the shutdown command when you want to temporarily disable L2VPN. When a cross-connect group is disabled, you can still configure the cross-connect group. After the configuration, use the undo shutdown command to enable the cross-connect group. The cross-connect group will provide L2VPN services using the new settings.
# Disable cross-connect group vpn2.
[Sysname-xcg-vpn2] shutdown
site
Use site to create a local site and enter its view, or enter the view of an existing local site.
Use undo site to delete a local site.
site site-id [ range range-value ] [ default-offset defalut-offset ]
undo site site-id
No sites exist.
site-id: Specifies a local site ID in the range of 0 to 256.
range range-value: Specifies the maximum number of sites in a VPN, in the range of 2 to 257. The default value is 10.
default-offset default-offset: Specifies the start site ID, 0 or 1. The default value is 0.
The range range-value and default-offset default-offset options determine the label block of the site.
·     If you execute the site command with the range-value of range1, a label block with LR of range1 and LO of default-offset is assigned to the site.
·     If you execute another site command with range-value of range2 (range2 is larger than range1), a second label block with LR of range2 to range1 and LO being range1 + default-offset is assigned to the site.
For example, if you execute the following commands, three label blocks LB1/0/10, LB2/10/12, and LB3/22/14 are assigned to site 1. LB1, LB2, and LB3 are automatically selected.
site 1 range 22
site 1 range 36
You can create multiple local sites for a cross-connect group.
You can use the site command to increase the range value for an existing site. You cannot decrease the range value for an existing site with the site command. To decrease the range value, execute the undo site command to delete the site and then execute the site command.
Select a large range value to reduce future modifications for VPN expansion.
You cannot modify the default-offset for a site with the site command. To modify it, execute the undo site command to delete the site and then execute the site command.
# Create site 1, configure the VPN to contain a maximum of 30 sites, set the start site ID to 0 for cross-connect group bbb, and enter site view.
[Sysname-xcg-bbb-auto] site 1 range 30 default-offset 0
display l2vpn pw
snmp-agent trap enable l2vpn
Use snmp-agent trap enable l2vpn to enable SNMP notifications for L2VPN PW.
Use undo snmp-agent trap enable l2vpn to disable SNMP notifications for L2VPN PW.
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
undo snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
SNMP notifications for L2VPN PW are disabled.
pw-delete: Enables PW deletion notifications.
pw-switch: Enables PW primary/backup switchover notifications.
pw-up-down: Enables PW up-down notifications.
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW status changes, or PW switchovers occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
If you do not specify a notification type, this command enables all types of notifications for L2VPN PW.
# Enable PW up-down notifications.
[Sysname] snmp-agent trap enable l2vpn pw-up-down
display snmp-agent trap-list (Network Management and Monitoring Command Reference)
tunnel-policy (auto-discovery cross-connect view)
Use tunnel-policy to specify a tunnel policy for an auto-discovery cross-connect.
Use undo tunnel-policy to restore the default.
undo tunnel-policy
No tunnel policy is specified.
Auto-discovery cross-connect view
The PWs on the auto-discovery cross-connect use the specified tunnel policy to select public tunnels.
If you do not specify a tunnel policy or specify a nonexistent tunnel policy, the default tunnel policy applies. The default tunnel policy selects only one public tunnel for a PW in this order: LSP tunnel, GRE tunnel, CRLSP tunnel.
# Specify tunnel policy policy1 for the auto-discovery cross-connect in cross-connect group bbb.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] quit
[Sysname-xcg-bbb-auto] site 2 range 10 default-offset 0
[Sysname-xcg-bbb-auto-2] connection remote-site-id 3
[Sysname-xcg-bbb-auto-2-3] tunnel-policy policy1
tunnel-policy (system view)
vpn-target
Use vpn-target to configure route targets for a cross-connect group.
Use undo vpn-target to remove the specified or all route targets for a cross-connect group.
undo vpn-target { vpn-target&<1-8> | all } [ both | export-extcommunity | import-extcommunity ]
No route targets are configured for a cross-connect group.
vpn-target&<1-8>: Specifies a space-separated list of a maximum of eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
both: Uses the specified route targets as both import targets and export targets. The both keyword is used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
A local PE sets the route targets as export targets in BGP update messages when it advertises L2VPN information through the update messages to a remote peer. The peer uses its import targets to match the received export targets. If a match is found, the peer accepts the L2VPN information.
# Configure import route targets as 10:1 100:1 1000:1 and export route targets as 20:1 200:1 2000:1 for BGP cross-connect group bbb.
[Sysname-xcg-bbb-auto] vpn-target 10:1 100:1 1000:1 import-extcommunity
[Sysname-xcg-bbb-auto] vpn-target 20:1 200:1 2000:1 export-extcommunity
xconnect-group
Use xconnect-group to create a cross-connect group and enter its view, or enter the view of an existing cross-connect group.
Use undo xconnect-group to delete a cross-connect group.
undo xconnect-group group-name
No cross-connect groups exist.
group-name: Specifies a name for the cross-connect group, a case-sensitive string of 1 to 31 characters excluding hyphens.
L2VPN can create multiple LDP, BGP, and static PWs for a cross-connect group.
# Create a cross-connect group named vpn1 and enter cross-connect group view.
[Sysname] xconnect-group vpn1
[Sysname-xcg-vpn1]
