01 Fundamentals Command Reference
HomeSupportResource CenterSwitchesH3C S6860 Switch SeriesH3C S6860 Switch SeriesTechnical DocumentsCommandCommand ReferencesH3C S6860 Switch Series Command References-Release 26xx-6W10201 Fundamentals Command Reference
08-ISSU commands
08-ISSU commands 175.74 KB
ISSU commands
display install active
Use display install active to display active software images.
display install active [ slot slot-number ] [ verbose ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all IRF members.
verbose: Displays detailed information. If you do not specify this keyword, the command displays only image names.
# Display active software images.
<Sysname> display install active
Active packages on slot 1:
  flash:/boot.bin
  flash:/system.bin
  flash:/feature1.bin
# Display detailed information about active software images.
<Sysname> display install active verbose
flash:/boot.bin
 [Package]
 Vendor: H3C
 Product: S6860
 Service name: boot
 Platform version: 7.1.070
 Product version: Test 0001015
 Supported board: mpu
 [Component]
 Component: boot
 Description: boot package
flash:/system.bin
 [Package]
 Vendor: H3C
 Product: S6860
 Service name: system
 [Component]
 Component: system
 Description: system package
flash:/feature1.bin
 [Package]
 Vendor: H3C
 Product: S6860
 Service name: test
 [Component]
 Component: test
 Description: test package
[Package]
Detailed information about the software image.
Service name
Image type:
·     boot—Boot image.
·     system—System image.
·     boot patch—Patch image for the boot image.
·     system patch—Patch image for the system image.
·     Any other value indicates a feature image.
Supported board
Hardware types supported by the software image:
mpu—Member device.
[Component]
Information about components included in the image file.
install active
display install backup
Use display install backup to display backup startup software images.
display install backup [ slot slot-number ] [ verbose ]
Backup startup images are used only when the main boot or system image is missing or corrupt. For more information, see Fundamental Configuration Guide.
To modify the backup startup image list, use the boot-loader file command.
# Display the backup startup software images.
<Sysname> display install backup
Backup startup software images on slot 1:
  flash:/boot.bin
  flash:/system.bin
# Display detailed information about backup startup software images.
<Sysname> display install backup verbose
 flash:/boot.bin
 [Package]
 Vendor: H3C
 Product: S6860
 Service name: boot
 [Component]
 Component: boot
 flash:/system.bin
 [Package]
 Vendor: H3C
 Product: S6860
 [Component]
 Component: system
For information about the command output, see Table 1.
boot-loader file
display install committed
Use display install committed to display main startup software images.
display install committed [ slot slot-number ] [ verbose ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices.
Some install commands modify the current software image list but do not modify the main startup image list. For the software image changes to take effect after a reboot, you must execute the install commit command to update the main startup image list with the image changes. You can use the display install committed command to verify the operation results.
Both the install commit and boot-loader file commands modify the main startup software image list.
# Display the main startup software images.
<Sysname> display install committed
Committed packages on slot 1:
 flash:/boot.bin
 flash:/system.bin
 flash:/feature1.bin
# Display detailed information about main startup software images.
<Sysname> display install committed verbose
 flash:/boot.bin
 [Package]
 Vendor: H3C
 Product: S6860
 Service name: boot
 [Component]
 Component: boot
 flash:/system.bin
 [Package]
 Vendor: H3C
 Product: S6860
 [Component]
 Component: system
flash:/feature1.bin
 [Package]
 Vendor: H3C
 Product: S6860
 Service name: feature1
 [Component]
 Component: feature1
 Description: feature1 package
boot-loader file
install commit
display install inactive
Use display install inactive to display inactive software images in the root directories of file systems.
display install inactive [ slot slot-number ] [ verbose ]
# Display brief information about inactive software images in the root directories of the file systems.
<Sysname> display install inactive
Inactive packages on slot 1:
 flash:/feature1.bin
# Display detailed information about inactive software images in the root directories of the file systems.
<Sysname> display install inactive verbose
flash:/feature1.bin
 [Package]
 Vendor: H3C
 Product: S6860
 [Component]
 Component: feature1
install deactivate
display install ipe-info
Use display install ipe-info to display the software images included in an .ipe file.
display install ipe-info ipe-filename
ipe-filename: Specifies an .ipe file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see Fundamental Configuration Guide.
# Display information about .ipe file flash:/test.ipe.
<Sysname> display install ipe-info flash:/test.ipe
Verifying the file flash:/test.ipe on slot 1................Done.
H3C S6860-54HF images in IPE:
  boot.bin
  system.bin
display install package
display install job
Use display install job to display ongoing ISSU activate, deactivate, and rollback operations.
display install job
# Display ongoing ISSU activate, deactivate, and rollback operations.
<Sysname> display install job
 JobID:5
  Action:install activate flash:/feature1.bin on slot 1
The output shows that the device is executing the install activate flash:/feature1.bin slot 1 command.
display install log
Use display install log to display ISSU log information.
display install log [ log-id ] [ verbose ]
log-id: Specifies a log entry by its ID. If you do not specify this argument, the command displays all ISSU log entries.
verbose: Displays detailed ISSU log information. If you do not specify this keyword, the command displays brief ISSU log information.
The device creates one log entry for each ISSU operation to track the ISSU process and operation result.
The ISSU log can contain a maximum of 50 entries. The latest entry overwrites the oldest entry if the log is full.
# Display all ISSU log entries.
<Sysname> display install log
Install job 1 started by user root at 04/28/2001 08:39:29.
Job 1 completed successfully at 04/28/2001 08:39:30.
    Install activate flash:/feature1.bin on slot 1
Install job 2 started by user root at 04/28/2001 08:40:29.
Job 2 completed successfully at 04/28/2001 08:40:30.
    Install activate flash:/route.bin on slot 1
# Displays detailed information about ISSU log entry 1.
<Sysname> display install log 1 verbose
Detail of activating packages on slot 1.
    Get upgrade policy successfully.
    Uncompress package to system successfully.
    Remove files from system successfully.
Detail of xxx
Detailed information about an ISSU operation.
Obtained the upgrade policy.
Decompressed the package successfully.
Deleted files from the system successfully.
reset install log-history oldest
Use display install package to display software image file information.
display install package { filename | all } [ verbose ]
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see Fundamental Configuration Guide.
all: Specifies all software image files in the root directories of the master's file systems.
verbose: Displays detailed information. If you do not specify this keyword, the command displays only basic software image information.
# Display information about system.bin.
<Sysname> display install package flash:/system.bin
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: S6860
# Display detailed information about system.bin.
<Sysname> display install package flash:/system.bin verbose
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: S6860
  [Component]
  Component: system
display install rollback
Use display install rollback to display rollback point information.
display install rollback [ point-id ]
point-id: Specifies a rollback point ID. If you do not specify a rollback point ID, the command displays all rollback points.
Use this command to identify available rollback points during an ISSU that uses install commands. The system does not record rollback points during an ISSU that uses issu commands.
# Display all rollback points.
<Sysname> display install rollback
Install rollback information 1 on slot 1:
  Updating from flash:/route-1.bin
         to flash:/route-2.bin.
Install rollback information 2 on slot 1:
   Deactivating flash:/route-2.bin
The output shows that the device has two rollback points.
·     At rollback point 1, flash:/route-1.bin was upgraded to flash:/route-2.bin.
·     At rollback point 2, flash:/route-2.bin was deactivated.
install rollback
reset install rollback oldest
display install which
Use display install which to display all software image files that include a specific component or file.
display install which { component name | file filename } [ slot slot-number ]
component name: Specifies a component name.
file filename: Specifies a file in the filename.extension format, a case-insensitive string of up to 63 characters. It cannot contain path information.
A component is a collection of features. The features of a component are installed or uninstalled at the same time.
When the system displays a component or file error, use this command to identify the image files that include the component or file. Then, you can use the install verify command to identify image file problems.
This command searches only the root directories of the file systems at the specified location.
# Display the software image file that includes pkg_ctr.
<Sysname> display install which file pkg_ctr
Verifying the file flash:/system-t0001015.bin on slot 1..........................Done.
Found pkg_ctr in flash:/system-t0001015.bin on slot 1.
  [Package]
  Vendor: H3C
  Product: S6860
Verifying the file flash:/boot-d2601007.bin on slot 1.....Done.
Verifying the file
The system was verifying the validity of the file.
[Package]
Service name
Image type:
·     boot—Boot image.
·     patch—Patch image.
Supported board
mpu—Member device.
display issu rollback-timer
Use display issu rollback-timer to display automatic rollback timer information.
Change to the automatic rollback interval does not take effect on the ongoing ISSU process. The current remaining rollback time might be greater than the specified automatic rollback interval.
# Display automatic rollback timer information after the issu run switchover command is executed.
<Sysname> display issu rollback-timer
Rollback timer: Working
Rollback interval: 45 minutes
Rollback time remaining : 40 minutes
# Display automatic rollback timer information after the issu accept command is executed.
Rollback timer: Not working
Rollback interval: 30 minutes
# Display automatic rollback timer information when no ISSU process is taking place.
issu rollback-timer
display issu state
Use display issu state to display ISSU status information.
display issu state
During an ISSU that uses issu commands, you can use this command to verify the ISSU status and determine what to do next.
This command does not apply to an ISSU that uses install commands, because the ISSU state machine is not involved.
# Display ISSU status information when no upgrade is taking place.
<Sysname> display issu state
ISSU state: Init
Compatibility: Unknown
Work state: Normal
Upgrade method: Card by card
Upgraded slot: None
Current upgrading slot: None
Current version list:
  boot: 7.1.070, Test 0001015
  system: 7.1.070, Test 0001015
  feature1: 7.1.070, Test 0001015
Current software images:
  flash:/boot-t0001015.bin
  flash:/feature1-t0001015.bin
# Display ISSU status information while the issu load command is being executed.
ISSU state: Loading
Compatibility: Incompatible
Work state: Normal
Upgraded slot: None
  slot 1
Previous version list:
Previous software images:
Upgrade version list:
  boot: 7.1.070, Test 0001016
  system: 7.1.070, Test 0001016
  feature1: 7.1.070, Test 0001016
Upgrade software images:
  flash:/boot-t0001016.bin
  flash:/system-t0001016.bin
  flash:/feature1-t0001016.bin
ISSU state
ISSU status:
·     Init—The ISSU process has not started or has finished.
·     Loading—The system is executing the issu load command.
·     Loaded—The issu load command is completed.
·     Switching—The system is executing the issu run switchover command.
·     Switchover—The issu run switchover command is completed.
·     Accepted—The issu accept command is completed.
·     Committing—The system is executing the issu commit command.
·     Rollbacking—A rollback is in progress.
·     Unknown—An upgrade is in progress. This value is displayed if you execute the command on an original subordinate member.
Compatibility
Version compatibility:
·     Compatible—Upgrade to a compatible version.
·     Incompatible—Upgrade to an incompatible version.
·     Unknown—No upgrade is in progress.
Work state
Operating status of the device:
·     Normal—The device is operating correctly.
·     Independent active—When you perform an ISSU to an incompatible version, a subordinate member that is upgraded first enters this state. In this state, member devices are not running the same software versions.
Upgrade method
Upgrade mode.
The value of this field is fixed at Card by card. In this mode, member devices are upgraded one by one.
Upgraded slot
Upgraded members.
 During a rollback, this field displays Unknown.
Members that are being upgraded.
Versions of currently running images.
This field is displayed if no upgrade is taking place.
File names of currently running images.
Versions of the images that were running on the device before the ISSU.
If you execute the command on an original subordinate member while the member is being upgraded to an incompatible version, this field displays Unknown.
File names of the images that were running on the device before the ISSU.
Versions of the upgrade images.
File names of the upgrade images.
issu accept
issu commit
issu load
issu rollback
issu run switchover
display version comp-matrix
Use display version comp-matrix to display the recommended ISSU methods.
display version comp-matrix file { boot filename | system filename | feature filename&<1-30> } *
display version comp-matrix file ipe ipe-filename
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies a space-separated list of up to 30 feature image files.
To display compatibility information for the running software images, do not specify any image files for the command. If you specify the upgrade image files, the command displays the following information:
·     Compatibility information for upgrade images.
·     Recommended ISSU methods for upgrading the running images to the upgrade images.
If one or more images are incompatible, the incompatible upgrade method applies. The entire system needs to be rebooted during an incompatible upgrade.
# Display the recommended ISSU methods. In this example, the specified images are compatible with the running images.
<Sysname> display version comp-matrix file boot flash:/boot-t0001015.bin system flash:/system-t0001015.bin feature flash:/feature1-t0001015.bin
Verifying the file flash:/feature1-t0001015.bin on slot 1.....Done.
Verifying the file flash:/boot-t0001015.bin on slot 1.....Done.
Verifying the file flash:/system-t0001015.bin on slot 1.....Done.
Identifying the upgrade methods..........Done.
  Slot     Upgrade Way
  1        File Upgrade
Table 5 Command output
Verifying the file
Upgrade Way
ISSU method:
·     Service Upgrade.
·     File Upgrade.
·     Reboot.
This field is displayed only for compatible versions.
For more information about ISSU methods, see Fundamentals Configuration Guide.
issu load
install abort
Use install abort to abort an ongoing activate or deactivate operation.
install abort [ job-id ]
job-id: Specifies the job ID of an ISSU operation. If you do not specify this argument, the command aborts all ongoing software image activate and deactivate operations.
The system creates a software image management job each time you use the install activate, install add, install commit, install deactivate, install remove, or install rollback to command. Each job represents one command and is assigned a unique job ID. To obtain the ID of a job, use the display install job command.
When you abort an ongoing activate or deactivate operation, the system rolls back to the status it was in before the operation was started.
# Abort all ongoing software image activate and deactivate operations.
<Sysname> install abort
display install job
install activate
Use install activate to activate software images, or identify the ISSU method and the possible impact on the device.
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number [ test ]
install activate patch filename { all | slot slot-number }
patch: Specifies a patch image file.
all: Specifies all member devices.
test: Only identifies the ISSU method to be used for the upgrade. If you do not specify this keyword, the command activates the specified software images.
Before you use this command to activate a software image, read the release notes to identify the licensing requirements for the image. If the image requires a license, make sure the device has a valid license installed for the image.
Images run in memory immediately after they are activated. However, only images activated by using the install activate patch filename all command still run in memory after a reboot. For other images to take effect after a reboot, you must commit the software change by using the install commit command.
If the specified files are not stored on the member device to be upgraded, the command copies the images to the member device automatically.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install activate command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
You can install up to 32 .bin files on the device, including one boot image file, one system image file, and up to 30 feature or patch image files.
# Identify the ISSU method for feature upgrade with feature1.bin on subordinate member 2 and the upgrade impact.
<Sysname> install activate feature flash:/feature1.bin slot 2 test
Copying file flash:/feature1.bin to slot2#flash:/feature1.bin......Done.
Verifying the file flash:/feature1.bin on slot 2.....Done.
flash:/feature1.bin
  Running Version             New Version
  Test 0001015                Test 0001016
  Slot                        Upgrade Way
  2                           Reboot
Influenced service according to following table:
flash:/feature1.bin
     Feature1
The output shows that a service upgrade is recommended. The Feature1 module will be rebooted during the upgrade.
# Activate the system image in system.bin and the feature images in feature1.bin on member device 2.
<Sysname> install activate system flash:/system.bin feature flash:/feature1.bin slot 2
Copying file flash:/system.bin to slot2#flash:/system.bin......Done.
Verifying the file flash:/system.bin on slot 2.....Done.
flash:/system.bin
flash:/feature1.bin
  None                        Test 0001016
  Slot                        Upgrade Way
  2                           Service Upgrade
This operation might take several minutes, please wait...Done.
Table 6 Command output
Verifying the file
Upgrade summary.
Running Version
Version number of the running software.
New Version
Version number of the new software.
Upgrade Way
ISSU methods:
·     Service Upgrade.
·     File Upgrade.
·     Reboot.
This field is displayed only for an upgrade to a compatible version.
Services influenced by the upgrade.
install commit
install deactivate
install add
Use install add to decompress an .ipe file.
install add ipe-filename filesystem
filesystem: Specifies the destination file system for the software images, in the filesystemname format.
To use the install activate command to activate software images, you must use .bin image files. If the upgrade file is an .ipe file, use this command to decompress the .ipe file before you start the upgrade.
To identify software images that are included in an .ipe file, use the display install ipe-info command.
# Decompress all.ipe to the flash memory.
<Sysname> install add flash:/all.ipe flash:
Verifying the file flash:/all.ipe on slot 1...Done.
Decompressing file boot.bin to flash:/boot.bin.......................Done.
Decompressing file system.bin to flash:/system.bin..........................Done.
install commit
Use install commit to commit software changes.
install commit
Before you use this command, read the release notes to identify software image licensing requirements. Make sure the device has valid licenses for all license-based images.
This command modifies the main startup software image list to be the same as the current software image list.
You must execute this command after using the following commands:
·     The install activate command in an incremental upgrade.
·     The install deactivate command.
·     The install rollback command.
In a reboot upgrade, the install activate command modifies both the current and startup software image lists. You do not need to commit software changes.
Both the install commit and boot-loader file commands modify the main startup software image list. To modify the backup startup image list or add inactive images as main startup images, however, you must use the boot-loader file command.
For more information about main and backup startup software images, see Fundamental Configuration Guide.
# Commit software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
install activate
install deactivate
install rollback
install deactivate
Use install deactivate to deactivate feature images and patch images.
install deactivate feature filename&<1-30> slot slot-number
install deactivate patch filename { all | slot slot-number }
filename: Specifies a .bin file in the filesystemname/filename.bin format. The value string can have a maximum of 63 characters. The file system name cannot contain file system location information. For more information about specifying a file, see Fundamental Configuration Guide.
all: Specifies all member devices on which the specified patch image file has been activated.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install deactivate command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
You can deactivate only active feature and patch images.
Images deactivated by using the install deactivate patch filename all command do not run after a reboot. To prevent other deactivated images from running after a reboot, you must commit the software change by using the install commit command.
# Deactivate the patch images in the route-patch.bin file for a slot.
<Sysname> install deactivate patch flash:/route-patch.bin slot 1
install remove
Use install remove to delete an inactive software image file.
install remove [ slot slot-number ] { filename | inactive }
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command deletes inactive software images from all IRF members.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The value string can have a maximum of 63 characters. The file must be stored in the root directory of a file system on the device. The file system name cannot contain file system location information. For more information about specifying a file, see Fundamental Configuration Guide.
inactive: Deletes all inactive software image files in the root directories of the specified file systems.
This command permanently deletes the image files from the device. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
# Delete inactive software image file flash:/feature1.bin.
<Sysname> install remove flash:/feature1.bin
install rollback to
Use install rollback to to roll back the software to an earlier rollback point.
install rollback to { point-id | original }
point-id: Specifies a rollback point ID. This option is supported only when there are two or more rollback points. To identify available rollback points, use the display install rollback command.
original: Rolls back to the status before any activate or deactivate operations were performed.
During an incremental upgrade, the system creates a rollback point for each activate or deactivate operation of a boot, system, or feature image. The device supports a maximum of 50 rollback points. The earliest rollback point is deleted if this limit has been reached when a rollback point is created.
During a reboot upgrade, the system does not create rollback points. After the upgrade, you can roll back the software only to the status before any activate or deactivate operations were performed.
For a rollback to take effect after a reboot, you must perform a commit operation to update the main startup software image list.
After a commit operation is performed, you cannot perform a rollback.
Patch images do not support rollback.
# Roll back the software to rollback point 1.
<Sysname>install rollback to 1
# Roll back the software to the original software versions and observe the change made by the rollback.
  Updating from no package
         to flash:/feature1-t0001015.bin.
The output shows that currently three image files are active but only two of them are confirmed. Image file flash:/feature1-t0001015.bin is not confirmed yet.
<Sysname> install rollback to original
The output shows the SSH feature has been rolled back to the original software version. The image file flash:/feature1-t0001015.bin has been removed.
install verify
Use install verify to verify the software change commit status, image integrity, and image consistency.
install verify
To ensure a successful ISSU and make sure that the system can start up and operate correctly after an ISSU, execute this command to verify the following items:
·     Integrity—Verify that the boot, system, and feature images are integral.
·     Consistency—Verify that the same active images are running across the entire system.
·     Software commit status—Verify that the active images are committed as needed.
If a software image fails the verification, perform the following tasks to resolve the problem:
·     To ensure software integrity, download and install the software images again.
·     To guarantee software image consistency or change software commit status, use the install activate, install deactivate, and install commit commands as appropriate.
# Verify the software change confirmation status and software image integrity and consistency.
<Sysname> install verify
Active packages on slot 1 are the reference packages.
Packages will be compared with the reference packages.
  Verifying packages on slot 1:
  Start to check active package completeness.
Verifying the file flash:/boot-t0001015.bin on slot 1.....................Done.
    flash:/boot-t0001015.bin verification successful.
Verifying the file flash:/system-t0001015.bin on slot 1.....................Done.
    flash:/system-t0001015.bin verification successful.
  Start to check active package consistency.
    Active packages are consistent with committed packages on their own board.
    Active packages are consistent with the reference packages.
  Verifying packages on slot 2:
Verifying the file flash:/boot-t0001015.bin on slot 2.....................Done.
Verifying the file flash:/system-t0001015.bin on slot 2.....................Done.
Verification is done.
issu accept
Use issu accept to accept the upgrade to a compatible version and delete the automatic rollback timer.
issu accept
The system cannot perform automatic rollback for the ISSU process after you execute this command. However, you can use the issu rollback command to perform a manual rollback.
The issu accept command does not apply to an ISSU to an incompatible version.
# Accept the upgrade to a compatible version.
<Sysname> issu accept
issu load
issu run switchover
issu commit
Use issu commit to upgrade the original master and the subordinate members that have not been upgraded and complete the ISSU upgrade.
issu commit slot slot-number
slot slot-number: Specifies the member ID of the original master or a subordinate member that has not been upgraded.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu commit command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
Use this command to upgrade the original master and the subordinate members that have not been upgraded, one by one. You must wait for one upgraded member to start up again and join the IRF fabric before upgrading another member. After all members are upgraded, the ISSU status changes to Init, and the ISSU process ends and cannot be rolled back.
# After member 2 is upgraded and becomes the new master, upgrade the original master (member 3) and the other subordinate members that have not been upgraded (member 4 and member 1).
<Sysname> issu commit slot 3
flash:/feature1.bin
  Slot                        Upgrade Way
  3                           Service Upgrade
<Sysname> issu commit slot 4
Verifying the file flash:/feature1.bin on slot 4..............Done.
Copying file flash:/feature1.bin to slot4#flash:/feature1.bin...Done.
flash:/feature1.bin
  Slot                        Upgrade Way
  4                           Service Upgrade
<Sysname> issu commit slot 1
Verifying the file flash:/feature1.bin on slot 1..............Done.
Copying file flash:/feature1.bin to slot1#flash:/feature1.bin...Done.
flash:/feature1.bin
  Slot                        Upgrade Way
  1                           Service Upgrade
For information about the command output, see Table 5.
issu accept
issu load
issu run switchover
issu load
Use issu load to upgrade the software images of subordinate members and configure the new images as main startup software images for those members.
issu load file { boot filename | system filename | feature filename&<1-30> } * slot slot-number&<1-9> [ reboot ]
issu load file ipe ipe-filename slot slot-number&<1-9> [ reboot ]
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the master device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see Fundamental Configuration Guide.
ipe-filename: Specifies an .ipe file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the master device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see Fundamental Configuration Guide.
slot slot-number: Specifies the member ID of a subordinate member. You can specify a space-separated list of up to nine member IDs. On a single-chassis IRF fabric, enter the member ID of the member device to upgrade the entire fabric. On a multichassis IRF fabric, you can specify only one member ID for a compatible upgrade and can specify multiple member IDs for an incompatible upgrade. As a best practice, specify half of the subordinate members if the member devices form a ring. Make sure the specified subordinate members are directly connected by physical links.
reboot: Uses the reboot method for the upgrade. For an incremental upgrade, specify this keyword if you want to use the reboot upgrade method. If you do not specify this keyword, the recommended upgrade method is used.
You may upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
This command performs the following operations:
·     Checks the version compatibility.
·     Identifies the upgrade method.
·     Loads the new images to upgrade the member devices.
·     Sets the new images as the main startup software images so the upgrade can survive a reboot.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu load command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
# Upgrade member device 2 (a subordinate member) with feature image file flash:/feature1.bin. (In this example, the image is compatible with the running images.)
<Sysname> issu load file feature flash:/feature1.bin slot 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:Y
Verifying the file flash:/feature1.bin on slot 1...Done.
Verifying the file flash:/feature1.bin on slot 2...Done.
Identifying the upgrade methods….Done.
flash:/feature1.bin
  Slot                        Upgrade Way
  2                           Service Upgrade
# Use the reboot method to upgrade member device 2 (a subordinate member) when the incremental upgrade method is recommended.
<Sysname> issu load file feature flash:/feature1.bin slot 2 reboot
flash:/feature1.bin
  Slot                        Upgrade Way
  2                           Reboot
# Upgrade member devices 3 and 4 (subordinate members) with feature image file flash:/feature1.bin. (In this example, the image is incompatible with the running images.)
<Sysname> issu load file feature flash:/feature1.bin slot 3 4
Copying file flash:/feature1.bin to slot3#flash:/feature1.bin......Done.
Verifying the file flash:/feature1.bin on slot 3...Done.
Copying file flash:/feature1.bin to slot4#flash:/feature1.bin......Done.
Verifying the file flash:/feature1.bin on slot 4...Done.
flash:/feature1.bin
  Slot                        Upgrade Way
  3                           Reboot
  4                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
Table 7 Command output
Verifying the file
Copying file
The system was copying the upgrade file to a subordinate member. This field is displayed if you specified a subordinate member for the command.
Upgrade Way
ISSU method:
·     Service Upgrade.
·     File Upgrade.
·     Reboot.
issu one-step
Use issu one-step to perform an ISSU in one step.
issu one-step file { boot filename | system filename | feature filename&<1-30> } * [ slot slot-number&<1-9> ] [ reboot ]
issu one-step file ipe ipe-filename slot slot-number&<1-9> [ reboot ]
·     On a single-chassis IRF fabric, enter the member ID of the member device.
·     On a multichassis IRF fabric, you can specify only one member ID for a compatible upgrade. The member device will become the master device after the ISSU. For an incompatible upgrade, you can specify a space-separated list of up to nine member IDs. As a best practice, specify half of the subordinate members if the member devices form a ring. Make sure the specified subordinate members are directly connected by physical links. The device automatically selects one of the specified subordinate members as the master device after the ISSU. If you do not specify this option, the device automatically selects a subordinate member as the master device after the ISSU.
reboot: Uses the reboot method for the upgrade. For an incremental upgrade or ISSU reboot upgrade, specify this keyword if you want to use the reboot upgrade method. If you do not specify this keyword, the recommended upgrade method is used.
This command starts and finishes an ISSU. During the operation, you cannot perform a rollback or any other tasks.
Both the current version and the new version must support one-step ISSU.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. Before using this command, identify whether the synchronization is complete on all subordinate devices by using the display system stable state command. The synchronization is complete if the System State field displays Stable.
# Perform an ISSU in one step by using flash:/boot.bin, flash:/system.bin, and flash:/feature1.bin.
<Sysname> issu one-step file boot flash:/boot.bin system flash:/system.bin feature flash:/feature1.bin
# Use the reboot method to perform an ISSU in one step.
<<Sysname> issu one-step file boot flash:/boot.bin system flash:/system.bin feature flash:/feature1.bin flash:/feature1.bin reboot
issu rollback
Use issu rollback to cancel the ISSU and roll back to the original software versions.
issu rollback
The device supports automatic rollback and manual rollback. This command performs a manual rollback.
You can perform a manual rollback while an ISSU is in one of the following states:
·     Loaded.
·     Switching (during an upgrade to a compatible version).
·     Switchover (during an upgrade to a compatible version).
·     Accepted.
If the ISSU is in Loading state, the rollback might fail. Use the display version command to examine the rollback result after the rollback is completed.
If a rollback occurs while an ISSU is in Switching state, the entire system reboots automatically.
A rollback performed for a multichassis IRF fabric after you execute the issu run switchover command cancels all operations performed during the ISSU process, including the master/subordinate switchover.
# Roll back to the original software versions.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:y
issu accept
issu commit
issu load
issu run switchover
issu rollback-timer
Use issu rollback-timer to set the automatic rollback timer.
Use undo issu rollback-timer to restore the default.
issu rollback-timer minutes
The automatic rollback timer is set to 45 minutes.
minutes: Specifies the automatic rollback interval, in the range of 0 to 120 minutes. Setting it to 0 disables automatic rollback.
The automatic software version rollback feature is only available during an ISSU to a compatible version when the IRF fabric has multiple members.
The system starts the automatic rollback timer when you execute the issu run switchover command in a scenario where automatic rollback is supported. If you do not execute the issu accept or issu commit command before the timer expires, the system automatically rolls back to the software version used before the ISSU.
# Set the automatic rollback timer to 50 minutes.
[Sysname] issu rollback-timer 50
issu rollback
issu run switchover
Use issu run switchover to perform an ISSU switchover.
issu run switchover
Use this command on a multichassis IRF fabric.
·     For a compatible upgrade, this command performs operations depending on the ISSU method.
¡     Incremental upgrade—Performs a process-level master/subordinate switchover for the processes to be upgraded.
¡     Reboot upgrade or ISSU upgrade—Reboots the current master with the old software version, causing the upgraded subordinate member to be elected as the new master.
·     For an incompatible upgrade, the issu load command splits the IRF fabric into two fabrics, with the upgraded members forming a new fabric. The issu run switchover command reboots the members in the old IRF fabric with the upgrade images to upgrade the members. After startup, the members join the new IRF fabric as subordinate members.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu run switchover command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
When you execute the issu run switchover command during an ISSU to a compatible version, the system starts the automatic rollback timer. If you do not execute the issu accept or issu commit command before the timer expires, the system automatically rolls back to the original software versions.
# On a multichassis IRF fabric, perform a master/subordinate switchover during an ISSU to a compatible version.
<Sysname> issu run switchover
flash:/feature1.bin
  Slot                        Switchover Way
  1                           Active standby process switchover
# On a multichassis IRF fabric, perform a master/subordinate switchover, and upgrade members that have not been upgraded (member 1 and member 2) during an ISSU to an incompatible version.
flash:/feature1.bin
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
Table 8 Command output
Switchover Way
Switchover method:
·     Active standby process switchover—Switch from the active process to the standby process.
·     Master subordinate switchover—Switch from the master to a subordinate member.
For more information about the command output, see Table 5.
issu load
Use reset install log-history oldest to clear ISSU log entries.
reset install log-history oldest log-number
log-number: Specifies the number of ISSU log entries to be deleted.
This command clears the specified number of log entries, beginning with the oldest log entry.
# Clear the two oldest ISSU log entries.
<Sysname> reset install log-history oldest 2
display install log
Use reset install rollback oldest to clear ISSU rollback points.
reset install rollback oldest point-id
point-id: Specifies a rollback point by its ID.
This command clears the specified rollback point and all rollback points older than the specified rollback point.
# Clear rollback point 2 and all rollback points older than rollback point 2.
<Sysname> reset install rollback oldest 2
