- 11-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PTP configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-Event MIB configuration
- 08-NETCONF configuration
- 09-CWMP configuration
- 10-EAA configuration
- 11-Process monitoring and maintenance configuration
- 12-Mirroring configuration
- 13-sFlow configuration
- 14-Information center configuration
- 15-Packet capture configuration
- 16-VCF fabric configuration
- 17-Puppet configuration
- 18-Chef configuration
04-PTP configuration | 268.85 KB |
Feature and hardware compatibility
Feature and software version compatibility
Configuring an OC to operate only as a member clock
Configuring a priority for a clock
Configuring the role of a PTP port
Specifying a delay measurement mechanism for a BC or an OC
Configuring the port type for a TC+OC
Setting the interval for sending announce messages and the interval timeout
Setting the interval for sending Pdelay_Req messages
Setting the interval for sending Sync messages
Setting the minimum interval for sending Delay_Req messages
Configuring the MAC address for non-pdelay messages
Specifying the protocol for encapsulating PTP messages as UDP (IPv4)
Configuring the source IP address for multicast PTP message transmission over UDP (IPv4)
Configuring the destination IP address for unicast PTP message transmission over UDP (IPv4)
Setting the delay correction value
Setting the cumulative offset between the UTC and TAI
Setting the correction date of the UTC
Setting a DSCP value for PTP messages transmitted over UDP (IPv4)
Specifying a VLAN tag for PTP messages
Specifying the system time protocol as PTP
Displaying and maintaining PTP
PTP configuration example (IEEE 1588 version 2, IEEE 802.3/Ethernet encapsulation)
PTP configuration example (IEEE 1588 version 2, multicast transmission)
PTP configuration example (IEEE 802.1AS)
Configuring PTP
Overview
Precision Time Protocol (PTP) synchronizes time among devices. It provides greater accuracy than other time synchronization protocols such as NTP. It can also be used for frequency synchronization. For more information about NTP, see "Configuring NTP."
Basic concepts
PTP profile
PTP profiles (PTP standards) include:
· IEEE 1588 version 2—1588v2 defines high-accuracy clock synchronization mechanisms. It can be customized, enhanced, or tailored as needed. 1588v2 is the latest version.
· IEEE 802.1AS—802.1AS is introduced based on IEEE 1588. It specifies a profile for use of IEEE 1588-2008 for time synchronization over a virtual bridged local area network (as defined by IEEE 802.1Q). 802.1AS supports point-to-point full-duplex Ethernet, IEEE 802.11, and IEEE 802.3 EPON links.
PTP domain
A PTP domain refers to a network that is enabled with PTP. A PTP domain has only one reference clock called "grandmaster clock (GM)." All devices in the domain synchronize to the clock.
Clock node and PTP port
A node in a PTP domain is a clock node. A port enabled with PTP is a PTP port. PTP defines the following types of basic clock nodes:
· Ordinary Clock (OC)—A PTP clock with a single PTP port in a PTP domain for time synchronization. It synchronizes time from its upstream clock node through the port. If an OC operates as the clock source, it sends synchronization time through a single PTP port to its downstream clock nodes.
· Boundary Clock (BC)—A clock with more than one PTP port in a PTP domain for time synchronization. A BC uses one of the ports to synchronize time from its upstream clock node. It uses the other ports to synchronize time to the relevant upstream clock nodes. If a BC operates as the clock source, such as BC 1 in Figure 1, it synchronizes time through multiple PTP ports to its downstream clock nodes.
· Transparent Clock (TC)—A TC does not keep time consistency with other clock nodes. A TC has multiple PTP ports. It forwards PTP messages among these ports and performs delay corrections for the messages, instead of performing time synchronization. TCs include the following types:
¡ End-to-End Transparent Clock (E2ETC)—Forwards non-P2P PTP packets in the network and calculates the delay of the entire link.
¡ Peer-to-Peer Transparent Clock (P2PTC)—Forwards only Sync, Follow_Up, and Announce messages, terminates other PTP messages, and calculates the delay of each link segment.
Figure 1 shows the positions of these types of clock nodes in a PTP domain.
Figure 1 Clock nodes in a PTP domain
Besides the three basic types of clock nodes, PTP introduces hybrid clock nodes. For example, a TC+OC has multiple PTP ports in a PTP domain. One port is the OC type, and the others are the TC type.
A TC+OC forwards PTP messages through TC-type ports and performs delay corrections. In addition, it synchronizes time through its OC-type port. TC+OCs include these types: E2ETC+OC and P2PTC+OC.
Master-member/subordinate relationship
The master-member/subordinate relationship is automatically determined based on the Best Master Clock (BMC) algorithm. You can also manually specify a role for the clock nodes, but you must activate the PTP port role configuration to make the master-member/subordinate relationship take effect.
The master-member/subordinate relationship is defined as follows:
· Master/Member node—A master node sends a synchronization message, and a member node receives the synchronization message.
· Master/Member clock—The clock on a master node is a master clock (parent clock) The clock on a member node is a member clock.
· Master/Subordinate port—A master port sends a synchronization message, and a subordinate port receives the synchronization message. The master and subordinate ports can be on a BC or an OC.
A port that neither receives nor sends synchronization messages is a passive port.
Grandmaster clock
As shown in Figure 1, the clock nodes in a PTP domain are organized into a master-member hierarchy, where the GM operates as the reference clock for the entire PTP domain. Time synchronization is implemented through exchanging PTP messages.
A GM can be manually configured, or it can be elected through the BMC algorithm by following this procedure:
1. The clock nodes in a PTP domain exchange announce messages and elect a GM by using the following rules in descending order:
a. Clock node with higher priority 1.
b. Clock node with higher time class.
c. Clock node with higher time accuracy.
d. Clock node with higher priority 2.
e. Clock node with a smaller port ID (containing clock number and port number).
The master nodes, member nodes, master ports, and subordinate ports are determined during the process. Then a spanning tree with the GM as the root is generated for the PTP domain.
2. The master node periodically sends announce messages to the member nodes. If the member nodes do not receive announce messages from the master node, they determine that the master node is invalid, and they start to elect another GM.
Local clock
Local clock is 38.88 MHz clock signals generated by a crystal oscillator inside the clock monitoring module.
Synchronization mechanism
PTP sends synchronization messages between the master and member nodes to determine the delay measurement. The one-way delay time is the average of the delay of the transmit and receive messages. The member nodes use this delay time to adjust their local clocks.
PTP defines the following transmission delay measurement mechanisms:
· Request_Response.
· Peer Delay.
Both mechanisms assume a symmetric communication path.
Request_Response
The Request_Response mechanism includes the following modes:
· Single-step mode—t1 is carried in the Sync message, and no Follow_Up message is sent. This mode is not supported in the current software version.
· Two-step mode—t1 is carried in the Follow_Up message.
Figure 2 Operation procedure of the Request_Response mechanism
Figure 2 shows an example of the Request_Response mechanism in two-step mode.
1. The master clock sends a Sync message to the member clock, and records the sending time t1. Upon receiving the message, the member clock records the receiving time t2.
2. After sending the Sync message, the master clock immediately sends a Follow_Up message that carries time t1.
3. The member clock sends a Delay_Req message to calculate the transmission delay in the reverse direction, and records the sending time t3. Upon receiving the message, the master clock records the receiving time t4.
4. The master clock returns a Delay_Resp message that carries time t4.
After this procedure, the member clock collects all four timestamps and obtains the round-trip delay to the master clock by using the following calculation:
· [(t2 – t1) + (t4 – t3)]
The member clock also obtains the one-way delay by using the following calculation:
· [(t2 – t1) + (t4 – t3)] / 2
The offset between the member and master clocks is obtained by using the following calculations:
· (t2 – t1) – [(t2 – t1) + (t4 – t3)] / 2
· [(t2 – t1) – (t4 – t3)] / 2
Peer Delay
The Peer Delay mechanism includes the following modes:
· Single-step mode:
¡ t1 is carried in the Sync message, and no Follow_Up message is sent.
¡ The offset between t5 and t4 is carried in the Pdelay_Resp message, and no Pdelay_Resp_Follow_Up message is sent.
· Two-step mode:
¡ t1 is carried in the Follow_Up message.
¡ t4 and t5 are carried in the Pdelay_Resp and Pdelay_Resp_Follow_Up messages.
Figure 3 Operation procedure of the Peer Delay mechanism
The Peer Delay mechanism uses Pdelay messages to calculate link delay, which applies only to point-to-point delay measurement. Figure 3 shows an example of the Peer Delay mechanism by using the two-step mode.
3. The member clock sends a Pdelay_Req message to calculate the transmission delay in the reverse direction, and records the sending time t3. Upon receiving the message, the master clock records the receiving time t4.
4. The master clock returns a Pdelay_Resp message that carries time t4, and records the sending time t5. Upon receiving the message, the member clock records the receiving time t6.
5. After sending the Pdelay_Resp message, the master clock immediately sends a Pdelay_Resp_Follow_Up message that carries time t5.
After this procedure, the member clock collects all six timestamps and obtains the round-trip delay to the master clock by using the following calculation:
· [(t4 – t3) + (t6 – t5)]
· [(t4 – t3) + (t6 – t5)] / 2
The offset between the member and master clocks is as follows:
· (t2 – t1) – [(t4 – t3) + (t6 – t5)] / 2
Protocols and standards
· IEEE 1588-2008, IEEE Standard for a Precision Clock Synchronization Protocol for Networked Measurement and Control Systems
· IEEE P802.1AS, Timing and Synchronization for Time-Sensitive Applications in Bridged Local Area Networks
Compatibility information
The PTP feature is supported only on the following devices:
· S6800-54HF switch
· S6800-54HT switch
· S6800-2C-FC switch
· Switches labeled with the following product codes:
¡ LS-6800-32Q-H1
¡ LS-6800-54QF-H1
¡ LS-6800-54QT-H1
¡ LS-6800-2C-H1
¡ LS-6800-4C-H1
¡ LS-6800-54QF-H3
¡ LS-6800-54QT-H3
The PTP feature is available in R2612 and later.
Configuring clock nodes
Before performing the following configurations, define the scope of the PTP domain and the role of every clock node.
Configuration task list
Specifying a PTP standard
For PTP to operate correctly, specify a PTP standard before you configure PTP. Changing the PTP standard for the device clears all PTP configurations defined by the standard.
To specify a PTP standard:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Specify a PTP standard. |
ptp profile { 1588v2 | 8021as } |
By default, no PTP standard is configured, and PTP is not running on the device. |
Specifying a clock node type
You can configure only one of the following types of clock nodes for a device: OC, BC, E2ETC, P2PTC, E2ETC+OC, or P2PTC+OC.
Follow these guidelines when you specify a clock node type:
· Before you specify the clock node type, specify a PTP standard.
· If the PTP standard is IEEE 802.1AS, the clock node type cannot be E2ETC or E2ETC+OC.
· Changing the clock node type clears all PTP configurations except the PTP standard.
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a clock node type for the device. |
ptp mode { bc | e2etc | e2etc-oc | oc | p2ptc | p2ptc-oc } |
By default, no clock node type is specified. |
Specifying a PTP domain
Within a PTP domain, all devices follow the same rules to communicate with each other. Devices in different PTP domains cannot exchange PTP messages.
To specify a PTP domain:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a PTP domain for the device. |
ptp domain value |
By default, PTP devices are in PTP domain 0. |
An OC can operate either as a master clock to send synchronization messages or as a member clock to receive synchronization messages. This task allows you to configure an OC to operate only as a member clock.
This task is applicable only to OCs.
This configuration is automatically cleared after you change the clock node type for the device.
If an OC is operating only as a member clock, you can also use the ptp force-state command to configure its PTP port as a master port or passive port.
To configure an OC to operate only as a member clock:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the OC to operate only as a member clock. |
ptp slave-only |
By default, the OC is not configured to operate only as a member clock. |
Priorities for clocks are used to elect the GM. The smaller the priority value, the higher the priority.
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the priority for the specified clock for GM election through BMC. |
ptp priority clock-source local { priority1 priority1 | priority2 priority2 } |
If the PTP profile is IEEE 1588 version 2, the default value is 128 for both priority 1 and priority 2. If the PTP profile is IEEE 802.1AS, the default value is 246 for priority 1 and 248 for priority 2. |
Follow these guidelines when you configure the role of a PTP port:
· Only one subordinate port is allowed to be configured for a device.
· This task is also applicable to an OC that operates in slave-only mode.
To configure the PTP port role on an OC, BC, E2ETC+OC, or P2PTC+OC:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface view or Layer 3 Ethernet interface view. |
N/A |
3. Configure the role of the PTP port. |
ptp force-state { master | passive | slave } |
By default, the PTP port role is automatically specified through BMC. |
4. Quit interface view. |
quit |
N/A |
5. Activate the port role configuration. |
ptp active force-state |
By default, the port role configuration is not activated. |
PTP defines two transmission delay measurement mechanisms: Request_Response and Peer Delay. Ports on the same link must share the same delay measurement mechanism. Otherwise, they cannot communicate with one another.
BCs and OCs do not have a default delay measurement mechanism. You must specify a delay measurement mechanism for them.
The delay measurement mechanism is Request_Response for E2ETCs and E2ETC+OCs and Peer Delay for P2PTCs and P2PTC+OCs. You cannot change these default settings.
This task is applicable only to BCs and OCs.
If the PTP standard is IEEE 802.1AS, only Peer Delay mode is supported.
To specify a delay measurement mechanism for a BC or an OC:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify a delay measurement mechanism for a BC or an OC. |
ptp delay-mechanism { e2e | p2p } |
By default, the delay measurement mechanism might vary depending on the PTP standard. |
All ports on a TC+OC (E2ETC+OC or P2PTC+OC) are TCs by default. This feature allows you to configure one of the ports as an OC. This task is applicable only to E2ETC+OCs and P2PTC+OCs.
When a TC+OC is synchronizing time to a downstream clock node through a TC, do not enable an OC to synchronize with the downstream clock node. Otherwise, time synchronization might be affected.
To configure the port type for a TC+OC as OC:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port type for a TC+OC as OC. |
ptp port-mode oc |
By default, the port type for all ports on a TC+OC is TC. |
A master node sends announce messages to the member nodes at the specified interval. If a member node does not receive any announce messages from the master node within the specified interval, it determines that the master node is invalid.
To set the announce message sending interval and the interval timeout:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the interval for sending announce messages. |
ptp announce-interval interval |
By default: · The interval is 2 (21) seconds if the PTP standard is IEEE 1588 version 2. · The interval is 1 (20) second if the PTP standard is IEEE 802.1AS. |
4. Set the number of intervals before a timeout occurs. |
ptp announce-timeout multiple-value |
By default, a timeout occurs when three intervals are reached. |
For IEEE 1588 version 2, the timeout for receiving announce messages is the announce message sending interval for the subordinate node × multiple-value. For IEEE 802.1AS, the timeout for receiving announce messages is the announce message sending interval for the master node × multiple-value.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. (Optional.) Set the interval for sending Pdelay_Req messages. |
ptp pdelay-req-interval interval |
The default is 1 (20) second. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the interval for sending Sync messages. |
ptp syn-interval interval |
By default: · The interval is 1 (20) second if the PTP standard is IEEE 1588 version 2. · The interval is 1/8 (2-3) seconds if the PTP standard is IEEE 802.1AS. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the minimum interval for sending Delay_Req messages. |
ptp min-delayreq-interval interval |
The default is 1 (20) second. When receiving a Sync or Follow_Up message, an interface can send Delay_Req messages only when the minimum interval is reached. |
Pdelay messages include Pdelay_Req, Pdelay_Resp, and Pdelay_Resp_Follow_Up messages. The destination MAC address of Pdelay messages is 0180-C200-000E by default, which cannot be modified. The destination MAC address of non-Pdelay messages is either 0180-C200-000E or 011B-1900-0000.
To configure the destination MAC address for non-Pdelay messages on every clock node:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the destination MAC address for non-Pdelay messages. |
ptp destination-mac mac-address |
The default is 011B-1900-0000. This command takes effect only if PTP messages are encapsulated in IEEE 802.3/Ethernet packets. |
PTP messages can be encapsulated in IEEE 802.3/Ethernet packets or UDP (IPv4) packets.
To configure the protocol for encapsulating PTP messages as UDP (IPv4):
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the protocol for encapsulating PTP messages as UDP (IPv4). |
ptp transport-protocol udp |
By default, PTP messages are encapsulated in IEEE 802.3/Ethernet packets. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the source IP address for multicast PTP message transmission over UDP (IPv4). |
ptp source ip-address [ vpn-instance vpn-instance-name ] |
By default, no source IP address is configured for multicast PTP messages. This command takes effect only when multicast PTP messages are transmitted over UDP (IPv4). The ptp unicast-destination command has precedence over the ptp source command. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 3 Ethernet interface view. |
N/A |
3. Configure the destination IP address for unicast PTP message transmission over UDP (IPv4). |
ptp unicast-destination ip-address |
By default, no destination IP address is configured for unicast PTP message transmission. You must use this command on the current interface, and make sure the interface and the peer PTP interface can reach each other. This command takes effect only when unicast PTP messages are transmitted over UDP (IPv4). This command has precedence over the ptp source command. |
PTP performs time synchronization based on the assumption that the delays in sending and receiving messages are the same. However, this is not practical. If you know the offset between the delays in sending and receiving messages, you can set the delay correction value for more accurate time synchronization.
To set the delay correction value for every clock node:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. (Optional.) Set delay correction value. |
ptp asymmetry-correction { minus | plus } value |
The default is 0 nanoseconds, which means delay correction is not performed. |
The time displayed on a device is based on the Coordinated Universal Time (UTC). There is an offset between UTC and TAI (International Atomic Time, in English), which is made public periodically. This task allows you to adjust the offset between the UTC and TAI on the device. It is applicable only to the GM.
This task takes effect only when configured on the master clock node, and the local clock of the master clock node is the GM.
To set the cumulative offset between the UTC and TAI:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the cumulative offset between the UTC and TAI. |
ptp utc offset utc-offset |
The default is 0 seconds. |
This task allows you to adjust the UTC at the last minute (23:59) of the specified date.
To set the correction date of the UTC:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the correction date of the UTC. |
ptp utc { leap59-date | leap61-date } date |
By default, the correction date of the UTC is not configured. If you execute this command multiple times, the most recent configuration takes effect. This command takes effect only on the GM. |
The DSCP value determines the sending precedence of a packet.
To set a DSCP value for PTP messages transmitted over UDP (IPv4):
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set a DSCP value for PTP messages transmitted over UDP (IPv4). |
ptp dscp dscp |
By default, the DSCP value is 56. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface view. |
N/A |
3. Specify a VLAN tag for PTP messages. |
ptp vlan vlan-id [ dot1p dot1p-value ] |
By default, PTP messages do not have a VLAN tag. |
Make sure you use the clock protocol command to specify the time protocol as PTP. For more information about the clock protocol command, see Fundamentals Command Reference.
To specify the system time protocol as PTP:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify the system time protocol as PTP. |
clock protocol ptp |
By default, the device uses NTP to obtain time. |
Enabling PTP on a port
You can enable PTP on only one port on an OC.
To enable PTP on a Layer 2 Ethernet interface, make sure the VLAN interface for the VLAN to which the Layer 2 interface belongs is not associated with any VPN instance (the ip binding command not configured on the VLAN interface).
To enable PTP on a port:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable PTP on the port. |
ptp enable |
By default, PPP is disabled on a port. |
Task |
Command |
Display PTP clock information. |
display ptp clock |
Display the delay correction history. |
display ptp corrections |
Display information about foreign master nodes. |
display ptp foreign-masters-record [ interface interface-type interface-number ] |
Display PTP information on an interface. |
display ptp interface [ interface-type interface-number | brief ] |
Display parent node information for the PTP device. |
display ptp parent |
Display PTP statistics. |
display ptp statistics [ interface interface-type interface-number ] |
Display PTP clock time properties. |
display ptp time-property |
Clear PTP statistics. |
reset ptp statistics [ interface interface-type interface-number ] |
PTP configuration examples
Network requirements
As shown in Figure 4, a PTP domain contains Device A, Device B, and Device C.
· Configure all devices to use PTP standard IEEE 1588 version 2.
· Configure PTP messages to be encapsulated in IEEE 802.3/Ethernet packets.
· Configure the clock node type of Device A and Device C as OC, and that of Device B as E2ETC. All clock nodes elect a GM through BMC based on their respective default GM attributes.
Configuration procedure
1. Configure Device A:
# Specify the PTP standard as IEEE 1588 version 2.
[DeviceA] ptp profile 1588v2
# Specify the clock node type as OC.
[DeviceA] ptp mode oc
# Enable PTP on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] ptp enable
2. Configure Device B:
[DeviceB] ptp profile 1588v2
# Specify the clock node type as E2ETC.
[DeviceB] ptp mode e2etc
[DeviceB-Ten-GigabitEthernet1/0/1] ptp enable
# Enable PTP on Ten-GigabitEthernet 1/0/2.
[DeviceB] interface ten-gigabitethernet 1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] ptp enable
[DeviceB-Ten-GigabitEthernet1/0/2] quit
3. Configure Device C:
<DeviceC> system-view
[DeviceC] ptp profile 1588v2
[DeviceC] ptp mode oc
[DeviceC] interface ten-gigabitethernet 1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] ptp enable
[DeviceC-Ten-GigabitEthernet1/0/1] quit
4. Verify the configuration:
When the network is stable, perform the following tasks to verify that Device A is elected as the GM, Ten-GigabitEthernet1/0/1 on Device A is the master port, and Device B has synchronized to Device A:
¡ Use the display ptp clock command to display PTP clock information.
¡ Use the display ptp interface brief command to display brief PTP statistics on an interface.
# Display PTP clock information on Device A.
[DeviceA] display ptp clock
PTP profile : IEEE 1588 Version 2
PTP mode : OC
Slave only : No
Clock ID : 000FE2-FFFE-FF0000
Clock type : Local
Clock domain : 0
Number of PTP ports : 1
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Offset (log variance) : 65535
Offset from master : 0 (ns)
Mean path delay : 0 (ns)
Steps removed : 0
Local clock time : Sun Jan 15 20:57:29 2011
# Display brief PTP statistics on Device A.
[DeviceA] display ptp interface brief
Name State Delay mechanism Clock step Asymmetry correction
XGE1/0/1 Master E2E Two 0
# Display PTP clock information on Device B.
[DeviceB] display ptp clock
PTP mode : E2ETC
Slave only : No
Clock ID : 000FE2-FFFE-FF0001
Clock type : Local
Clock domain : 0
Number of PTP ports : 2
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Offset from master : N/A
Mean path delay : N/A
Steps removed : N/A
# Display brief PTP statistics on Device B.
[DeviceB] display ptp interface brief
XGE1/0/1 N/A E2E Two 0
XGE1/0/2 N/A E2E Two 0
As shown in Figure 5, a PTP domain contains Device A, Device B, and Device C.
· Configure the source IP address for multicast PTP message transmission over UDP (IPv4).
· Configure the clock node type as OC for Device A and Device C, and P2PTC for Device B. All clock nodes elect a GM through BMC based on their respective default GM attributes.
· Configure the delay measurement mechanism for Device A and Device C as p2p.
# Configure the source IP address for multicast PTP message transmission over UDP (IPv4).
[DeviceA] ptp source 11.10.10.1
# On Ten-GigabitEthernet 1/0/1, specify the PTP transport protocol as UDP over IPv4, specify the delay measurement mechanism as p2p, and enable PTP.
[DeviceA-Ten-GigabitEthernet1/0/1] ptp transport-protocol udp [DeviceA-Ten-GigabitEthernet1/0/1] ptp delay-mechanism p2p
# Specify the clock node type as P2PTC.
[DeviceB] ptp mode p2ptc
[DeviceB] ptp source 10.10.10.2
# On Ten-GigabitEthernet 1/0/1, specify the PTP transport protocol as UDP over IPv4 and enable PTP.
DeviceB-Ten-GigabitEthernet1/0/1] ptp transport-protocol udp
# On Ten-GigabitEthernet 1/0/2, specify the PTP transport protocol as UDP over IPv4 and enable PTP.
[DeviceB-Ten-GigabitEthernet1/0/2] ptp transport-protocol udp
[DeviceC] ptp source 10.10.10.3
[DeviceC-Ten-GigabitEthernet1/0/1] ptp transport-protocol udp [DeviceC-Ten-GigabitEthernet1/0/1] ptp delay-mechanism p2p
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
XGE1/0/1 Master P2P Two 0
PTP mode : P2PTC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : N/A
XGE1/0/1 N/A P2P Two 0
XGE1/0/2 N/A P2P Two 0
As shown in Figure 6, a PTP domain contains Device A, Device B, and Device C.
· Configure all devices to use PTP standard IEEE 802.1AS.
# Specify the PTP standard as IEEE 802.1AS.
[DeviceA] ptp profile 802.1AS
[DeviceB] ptp profile 802.1AS
# Specify the PTP standard as IEEE 1588 802.1AS.
[DeviceC] ptp profile 802.1AS
PTP profile : IEEE 802.1AS
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 246
Priority2 : 248
Clock quality :
Class : 248
Accuracy : 254
Offset (log variance) : 16640
Steps removed : 0
PTP mode : P2PTC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 246
Priority2 : 248
Clock quality :
Class : 248
Accuracy : 254
Steps removed : N/A
