03-Layer 2-LAN Switching Configuration Guide
HomeSupportResource CenterSwitchesH3C S6860 Switch SeriesH3C S6860 Switch SeriesTechnical DocumentsConfigureConfiguration GuidesH3C S6860 Switch Series Configuration Guide-Release 26xx-6W10203-Layer 2-LAN Switching Configuration Guide
16-Service loopback group configuration
16-Service loopback group configuration 52.28 KB
Configuring service loopback groups
A service loopback group contains one or multiple Ethernet ports for looping packets sent out by the device back to the device. This feature must work with other features, such as GRE.
A service loopback group provides one of the following services:
·     Tunnel—Supports unicast tunnel traffic.
·     Multicast tunnel—Supports multicast tunnel traffic.
·     Multiport—Supports multiport ARP traffic.
·     VSI gateway—Supports VSI gateway traffic.
You can configure only one service loopback group for a service type. However, you can use one service loopback group with multiple features.
Member ports in a service loopback group are load balanced.
Configuration procedure
Follow these guidelines when you configure a service loopback group:
·     Make sure the ports you are assigning to a service loopback group meet the following requirements:
¡     The ports are not used for any other purposes. The configuration on a port is removed when it is assigned to a service loopback group.
¡     The ports support the service type of the service loopback group and are not members of any other service loopback group.
·     You cannot change the service type of a service loopback group.
·     Do not delete a service loopback group that is being used by a feature.
·     To avoid IRF split, do not assign a port to a service loopback group if that port is the only IRF physical interface of an IRF port.
·     For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
To configure a service loopback group:
Step
Remarks
N/A
2.     Create a service loopback group and specify its service type.
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | vsi-gateway }
By default, no service loopback groups exist.
3.     Enter Layer 2 Ethernet interface view.
N/A
4.     Assign the port to the service loopback group.
port service-loopback group group-id
By default, a port does not belong to any service loopback group.
You can assign a maximum of 32 ports to a service loopback group.
Displaying and maintaining service loopback groups
Display information about service loopback groups.
display service-loopback group [ group-id ]
Service loopback group configuration example
Network requirements
All Ethernet ports on Device A support the tunnel service. Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
# Create service loopback group 1, and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[DeviceA-Ten-GigabitEthernet1/0/1] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [DeviceA-Ten-GigabitEthernet1/0/1] quit
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [DeviceA-Ten-GigabitEthernet1/0/2] quit
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [DeviceA-Ten-GigabitEthernet1/0/3] quit
# Create the interface Tunnel 1 and set it to GRE mode. The interface will automatically use service loopback group 1.
[DeviceA] interface tunnel 1 mode gre
[DeviceA-Tunnel1]
