14-Network Management and Monitoring Configuration Guide
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-F Routers Configuration Guides-Release7951PXX-6W10014-Network Management and Monitoring Configuration Guide
18-GOLD configuration
18-GOLD configuration 55.69 KB
Configuring GOLD
About GOLD
Generic Online Diagnostics (GOLD) performs the following operations:
·          Runs diagnostic tests on a device to inspect device ports, RAM, chip, connectivity, forwarding paths, and control paths for hardware faults.
·          Reports the problems to the system.
Types of GOLD diagnostics
The device supports only monitoring diagnostics in the current software version. Monitoring diagnostics run diagnostic tests periodically when the system is in operation and record test results. Monitoring diagnostics execute only non-disruptive tests.
GOLD diagnostic tests
GOLD runs diagnostic tests. The parameters of a diagnostic test include test name, type, description, attribute (disruptive or non-disruptive), default status, and execution interval.
Support for the diagnostic tests and default values for a test's parameters depend on the device model. You can modify part of the parameters by using the commands provided by this document.
The diagnostic tests are released with the system software image of the device. All enabled diagnostic tests run in the background. You can use the display commands to view test results and logs to verify hardware faults.
GOLD tasks at a glance
To configure GOLD, perform the following tasks:
1.        Configuring monitoring diagnostics
2.        (Optional.) Simulating diagnostic tests
3.        (Optional.) Configuring the log buffer size
About monitoring diagnostics
The system automatically executes monitoring diagnostic tests that are enabled by default after the device starts. Use the diagnostic monitor enable command to enable monitoring diagnostic tests that are disabled by default.
1.        Enter system view.
2.        Enable monitoring diagnostics.
In standalone mode:
diagnostic monitor enable slot slot-number-list [ test test-name ]
In IRF mode:
diagnostic monitor enable chassis chassis-number slot slot-number-list [ test test-name ]
The default settings for this command vary by test. Use the display diagnostic content command to view the enabling status for a test.
3.        Set an execution interval for monitoring diagnostic tests.
In standalone mode:
diagnostic monitor interval slot slot-number-list [ test test-name ] time interval
In IRF mode:
diagnostic monitor interval chassis chassis-number slot slot-number-list [ test test-name ] time interval
The default settings for this command vary by test. Use the display diagnostic content command to view the execution interval for a test.
The configured interval cannot be smaller than the minimum execution interval of the tests. Use the display diagnostic content verbose command to view the minimum execution interval of the tests.
4.        Set the recovery action for monitoring diagnostic tests.
In standalone mode:
diagnostic monitor action slot slot-number-list [ test test-name ] mode { none | self-reboot | system-reboot }
In IRF mode:
diagnostic monitor action chassis chassis-number slot slot-number-list [ test test-name ] mode { none | self-reboot | system-reboot }
The default settings for this command vary by test. Use the display diagnostic content verbose command to view the recovery action for a test. If a test does not support any recovery action, its recovery action is displayed as -NA-.
About simulating diagnostic tests
Test simulation verifies GOLD frame functionality. When you use the diagnostic simulation commands to simulate a diagnostic test, only part of the test code is executed to generate a test result. Test simulation does not trigger hardware correcting actions such as device restart and active/standby switchover.
To simulate a test, execute the following command in user view:
In standalone mode:
diagnostic simulation slot slot-number-list test test-name { failure | random-failure | success }
In IRF mode:
diagnostic simulation chassis chassis-number slot slot-number-list test test-name { failure | random-failure | success }
By default, the system runs a test instead of simulating it.
About GOLD logs
GOLD saves test results in the form of logs. You can use the display diagnostic event-log command to view the logs.
2.        Configure the maximum number of GOLD logs that can be saved.
diagnostic event-log size number
By default, GOLD saves 512 log entries at most.
When the number of logs exceeds the configured log buffer size, the system deletes the oldest entries.
Display and maintenance commands for GOLD
(In standalone mode.) Execute display commands in any view and reset commands in user view.
Display test content.
display diagnostic content [ slot slot-number ] [ verbose ]
Display GOLD logs.
display diagnostic event-log [ error | info ]
Display test results.
display diagnostic result [ slot slot-number [ test test-name ] ] [ verbose ]
Display configurations for simulated tests.
display diagnostic simulation [ slot slot-number ]
Clear GOLD logs.
reset diagnostic event-log
Clear test results.
reset diagnostic result [ slot slot-number [ test test-name ] ]
(In IRF mode.) Execute display commands in any view and reset commands in user view.
display diagnostic content [ chassis chassis-number [ slot slot-number ] ] [ verbose ]
Display GOLD logs.
display diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ] [ verbose ]
display diagnostic simulation [ chassis chassis-number [ slot slot-number ] ]
Clear GOLD logs.
Clear test results.
reset diagnostic result [ chassis chassis-number [ slot slot-number [ test test-name ] ] ]
GOLD configuration examples
Example: Configuring GOLD
Enable monitoring diagnostic test LIPCMonitor on slot 3, and set its execution interval to 1 minute.
# View the default enabling status and execution interval of the test on slot 3.
<Sysname> display diagnostic content slot 3 verbose
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
slot 3:
Test name        : DBMMonitor
Test attributes  : **M**A
Test interval    : -NA-
Min interval     : -NA-
Correct-action   : self-reboot
Description      : This is a global monitor test.
Exec             : -NA-
Test name        : LIPCMonitor
Test interval    : 00:02:10
Min interval     : 00:01:00
Correct-action   : -NA-
Description      : This is a real-time test.
Exec             : -NA-
# (Optional.) Enable test LIPCMonitor on slot 3. Test LIPCMonitor is enabled by default. If the test is disabled, use this step to enable it.
[Sysname] diagnostic monitor enable slot 3 test LIPCMonitor
# Set the execution interval for test LIPCMonitor to 1 minute.
[Sysname] diagnostic monitor interval slot 3 test LIPCMonitor time 0:1:0
# View the test configuration.
[Sysname] display diagnostic content slot 3 verbose
slot 3:
Min interval     : -NA-
Exec             : -NA-
Test interval    : 00:01:00
Exec             : -NA-
# View the test result.
[Sysname] display diagnostic result slot 3 verbose
slot 3:
  Total run count          : 0
  Total failure count      : 0
  Consecutive failure count: 0
  Last execution time      : -NA-
  First failure time       : -NA-
  Last failure time        : -NA-
  Last pass time           : -NA-
  Last execution result    : -NA-
  Last failure reason      : -NA-
  Next execution time      : -NA-
  Total run count          : 2
  Last execution time      : Tue Jan  8 08:46:43 2019
  Last pass time           : Tue Jan  8 08:46:43 2019
  Last execution result    : Success
  Next execution time      : Tue Jan  8 08:49:00 2019
