- 14-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-Network synchronization configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-CWMP configuration
- 09-EAA configuration
- 10-Process monitoring and maintenance configuration
- 11-Sampler configuration
- 12-Mirroring configuration
- 13-NetStream configuration
- 14-IPv6 NetStream configuration
- 15-Fast log output configuration
- 16-Flow log configuration
- 17-Information center configuration
- 18-GOLD configuration
- 19-Packet capture configuration
- 20-Flow monitor configuration
04-Network synchronization configuration | 89.87 KB |
Configuring network synchronization
Network synchronization tasks at a glance
Configuring clock reference selection
Setting an Sa bit for the SSM of BITS clocks
Setting the frequency of a BITS clock
Specifying a line clock input port
Configuring automatic reference selection parameters
Configuring the method for setting the SSM quality level of a clock source
Specifying an SSM quality level for a clock source
Controlling the use of SSM in automatic reference selection
Setting a priority for a clock source
Display and maintenance commands for network clock monitoring module
Network synchronization configuration examples
Example: Configuring network synchronization
About network synchronization
The network clock monitoring module provides network clock synchronization for all interface cards in the system. It ensures that all ports on the interface cards operate at the same clock rates for network synchronization.
The network clock monitoring module provides the following functions:
· Provides highly precise, reliable timing signal to all interface cards.
· Constantly monitors the signaling status on the interface cards.
· Selects a clock reference from available clock sources, and then distributes its timing signal to all interface cards.
· Performs phase lock to maintain a deterministic relationship between the input and output signals in frequency and phase.
Clock sources
The device supports the following clock sources:
· BITS—Building integrated timing supply (BITS) clock. The MPU has BITS ports to receive and send timing signals.
· Line clock—Timing signal extracted from the signal received on a WAN port from a higher-level device. The WAN port is called a line processing unit (LPU) port. Line timing signal is less precise than BITS timing signal.
· PTP—Timing signal obtained through PTP. PTP timing signal is less precise than BITS timing signal.
· Local clock source—38.88 MHz timing signal generated by a crystal oscillator on the clock daughter card. The local clock signal has the lowest precision.
Clock source levels
The level of a clock source is determined by its SSM quality level and priority.
SSM quality levels
The synchronization status message (SSM) is transmitted in a synchronization distribution trail to indicate the quality of the clock source. The following are the SSM quality levels supported by the device, from the highest to the lowest:
· PRC—G.811 primary reference clock.
· SSU-A—G.812 primary-level SSU.
· SSU-B—G.812 second-level SSU.
· SEC—SDH equipment clock.
· Unknown—Synchronization quality unknown.
· DNU—Do not use for synchronization.
Clock source priority
For a clock source to be selected as the clock reference, assign it a lower priority value than other clock sources. The lower the priority value, the better the clock source. For example, the clock source with a priority of 1 is better than the clock source with a priority of 3.
Clock reference selection
The network clock monitoring module supports automatic and manual clock reference selection.
Automatic reference selection
In an automatic reference selection process, the network clock monitoring module uses the SSM quality level, clock source priority, and clock source number to make a selection decision. The use of SSM in the automatic reference selection process is user configurable.
The selection process is as follows:
1. If SSM is enabled for automatic reference selection, the module selects the clock source with the highest SSM quality level.
2. If SSM is disabled for automatic reference selection, or clock sources have the same SSM quality level, the module selects the clock source with the lowest priority value. (A lower priority value indicates a better clock source.)
3. If the clock sources have the same priority, the module selects the clock source that has the lowest slot-number/subslot-number/port-number sequence.
After selecting the best reference, the network clock monitoring module distributes the selected timing signal to all interface cards, and locks the timing to the reference signal. When the traced timing signal is lost, the network clock monitoring module selects the next optimal clock reference. When the signal of the best clock source can be traced again, the module selects the best clock source to replace the less optimal clock source as the reference.
NOTE: A clock source will not be selected as the reference if the clock source is in one of the following situations: · The timing signal cannot be detected. · The clock source priority is 255. · The SSM quality level is DNU. |
Manual reference selection
If you specify a clock source as the reference, the network clock monitoring module does not change the clock reference automatically. When the signal of the specified clock reference is lost, the module changes to the holdover state. In this state, the module continues to distribute the signal of the clock reference to the interface cards.
Clock mode on a port
IMPORTANT: Set the clock mode to slave on the port connected to a SONET/SDH device, because the SONET/SDH clock is more precise. |
A port can operate in one of the following clock modes:
· Master—The port provides timing to the peer end. The timing signal is derived from the network clock monitoring module.
¡ If automatic reference selection is used, the timing signal is derived from the reference clock selected by the network clock monitoring module.
¡ If manual reference selection is used, the timing signal is derived from the manually specified clock reference.
¡ If the manually specified clock reference is not available, the port outputs the timing signal generated by the local clock.
· Slave—The port uses the timing signal received from the peer end. For the network clock monitoring module to extract timing signal from a port, you must place the port in slave clock mode. If the port is in master clock mode, the module does not extract the timing signal from the incoming traffic on the port.
To configure network synchronization, perform the following tasks:
1. Configuring clock reference selection
Enable automatic clock reference selection or manually select a clock reference.
2. (Optional.) Configuring BITS clocks
a. Setting an Sa bit for the SSM of BITS clocks
b. Setting the frequency of a BITS clock
3. (Optional.) Specifying a line clock input port
4. (Optional.) Configuring automatic reference selection parameters
¡ Configuring the method for setting the SSM quality level of a clock source
¡ Specifying an SSM quality level for a clock source
¡ Controlling the use of SSM in automatic reference selection
¡ Setting a priority for a clock source
To use the timing signal from an interface as the synchronization reference, you must also specify the interface as a line clock input port by using the network-clock lpuport command.
If manual reference selection is used, the SSM levels and priorities configured for the clock sources do not take effect.
1. (Optional.) Verify that the clock source you want to select is in Normal state.
display network-clock source
Skip this step if you use automatic reference selection.
2. Enter system view.
3. Enable automatic reference selection or manually select a reference.
In standalone mode:
network-clock work-mode { auto | manual source { bits0 | bits1 | lpuport interface-type interface-number } }
In IRF mode:
network-clock chassis chassis-number work-mode { auto | manual source { bits0 | bits1 } }
network-clock
work-mode manual source lpuport interface-type
interface-number
By default, automatic reference selection is enabled.
4. (Optional.) Display the operating state of the network clock monitoring module.
display network-clock status
It takes time for the clock reference selection mode change to take effect. To verify the effectiveness of the change, you can also check the logs.
About setting an Sa bit for the SSM of BITS clocks
Sa bits from Sa4 through Sa8 can be used to transmit the SSM quality level of BITS timing signal. Select one Sa bit as required by the network.
1. Enter system view.
2. Specify an Sa bit for the SSM of a BITS clock.
In standalone mode:
network-clock source { bits0 | bits1 } sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 }
In IRF mode:
network-clock chassis chassis-number source { bits0 | bits1 } sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 }
By default, BITS clocks use Sa 4 to transmit the SSM.
About setting the frequency of a BITS clock
You can set the frequency of a BITS clock to 2 Mbps or 2 MHz.
2. Set the frequency of a BITS clock.
In standalone mode:
network-clock source { bits0 | bits1 } frequency { bps-2m | hz-2m }
In IRF mode:
network-clock chassis chassis-number source { bits0 | bits1 } frequency { bps-2m | hz-2m }
By default, the frequency of a BITS clock is 2 Mbps.
Only main ports can be specified as line clock input ports. For the timing signal received on the line clock input port to be used for synchronization, you must set the port to operate in slave mode.
system view
2. Enter interface view.
3. Set the clock mode to slave.
clock slave
By default, slave clock mode is enabled on ports.
4. Return to system view.
5. Specify the port as a line clock input port.
network-clock lpuport interface-type interface-number
By default, no line clock input port is configured.
About setting the SSM quality level of a clock source
The network clock monitoring module can use one of the following methods to assign an SSM quality level to the timing signal from a clock source:
· Uses the SSM quality level extracted from the received timing signal.
· Uses the SSM quality level manually assigned as described in "Specifying an SSM quality level for a clock source."
2. Configure the method for setting the SSM quality level of a clock source.
In standalone mode:
network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } forcessm { off | on }
In IRF mode:
¡ For BITS and PTP:
network-clock chassis chassis-number source { bits0 | bits1 | ptp } forcessm { off | on }
¡ For a link clock input port:
network-clock source lpuport interface-type interface-number forcessm { off | on }
By default, the quality level of a clock source is a user-defined value. The network clock monitoring module does not extract the quality level from the SSM sent by the clock source.
To extract the SSM quality level from the received timing signal, specify the off keyword. To use the manually assigned SSM quality level, specify the on keyword.
The SSM quality level you specify for a clock source takes effect only when manual SSM quality level assignment is enabled.
2. Assign an SSM quality level to a clock source.
In standalone mode:
network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } ssm { dnu | prc | sec | ssua | ssub | unknown }
In IRF mode:
network-clock chassis chassis-number source { bits0 | bits1 | ptp } ssm { dnu | prc | sec | ssua | ssub | unknown }
network-clock
interface-number ssm { dnu | prc | sec | ssua | ssub | unknown }
By default, all clock sources use the unknown SSM quality level.
DNU clock sources are excluded from automatic reference selection.
3. (Optional.) Display the operating state of the network clock monitoring module.
It takes time for the SSM quality level change to take effect. To verify the effectiveness of the change, you can also check the logs.
2. Configure the use of SSM quality level in automatic reference selection.
In standalone mode:
network-clock ssmcontrol { off | on }
In IRF mode:
network-clock chassis chassis-number ssmcontrol { off | on }
To ignore the SSM quality level in clock reference selection, specify the off keyword. To use the SSM quality level in clock reference selection, specify the on keyword.
By default, SSM quality level is ignored in the automatic reference selection process.
About the priority of a clock source
In an automatic reference selection process, the network clock monitoring module selects the optimal clock as a reference from all available clock sources.
2. Set a priority for a clock source.
In standalone mode:
network-clock source { bits0 | bits1 | lpuport interface-type interface-number | ptp } priority
In IRF mode:
network-clock chassis chassis-number source { bits0 | bits1 | ptp } priority
network-clock source lpuport interface-type interface-number priority
By default, all clock sources have a priority of 255. None of the clock sources can be used in automatic clock reference selection.
Task |
Command |
Display the self-test result of the network clock monitoring module. |
In standalone mode: display network-clock self-test-result In IRF mode: display network-clock self-test-result [ chassis chassis-number ] |
Display the operating state of the network clock monitoring module. |
In standalone mode: display network-clock status In IRF mode: display network-clock status [ chassis chassis-number ] |
Display the states of clock sources. |
In standalone mode: display network-clock source In IRF mode: display network-clock source [ chassis chassis-number ] |
Display version information for the network clock monitoring module. |
In standalone mode: display network-clock version In IRF mode: display network-clock version [ chassis chassis-number ] |
Reset the state of the network clock monitoring module. |
In standalone mode: reset network-clock In IRF mode: reset network-clock [ chassis chassis-number ] |
As shown in Figure 1, Device A obtains its timing signal from an external BITS clock.
Configure Device B to derive its timing from Device A through POS 3/1/1.
1. On Device A:
# Specify the master clock mode on POS 3/1/1.
[DeviceA] interface pos 3/1/1
[DeviceA-Pos3/1/1] clock master
2. On Device B:
# Specify POS 3/1/1 as a line clock input port.
[DeviceB] network-clock lpuport pos 3/1/1
# Specify the slave clock mode on the POS interface.
[DeviceB] interface pos 3/1/1
[DeviceB-Pos3/1/1] clock slave
[DeviceB-Pos3/1/1] quit
# Specify the interface as the source to provide clock reference.
[DeviceB] network-clock work-mode manual source lpuport pos 3/1/1
[DeviceB] quit
# Verify that the POS interface provides the network clock reference for Device B.
<DeviceB> display network-clock status
Mode : Manual
Reference : pos 3/1/1
Traced reference : pos 3/1/1
Lock mode : Locked
SSM output level : SSUB
SSM control enable: Off
