14-Network Management and Monitoring Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-Release795x-6W10014-Network Management and Monitoring Configuration Guide
21-Flow monitor configuration
21-Flow monitor configuration 77.70 KB
Configuring flow monitor
About flow monitor
Flow monitor is a traffic monitoring feature that provides basic traffic flow statistics and helps you quickly identify sources of illegitimate traffic flows.
Flow monitor table
The flow monitor feature automatically imports flow data from NetStream to the flow monitor table and allows you to manually add and delete flow monitor entries. A flow monitor entry in this table can be of the IP or MPLS type and records the following information of a traffic flow:
·          Source and destination IPv4 addresses.
·          IP protocol number.
·          Inbound or outbound traffic direction.
·          Interface that the traffic passes through.
·          MPLS L3VPN (optional).
For more information about NetStream, see "Configuring NetStream."
Flow monitor table freezing
After the flow monitor table records information about all legitimate traffic flows in your network, you can perform the fix operation to freeze the table.
·          Before you perform this operation, all flow monitor entries, automatically or manually added, are legitimate and in Unfixed state.
·          After you perform this operation, the existing flow monitor entries are legitimate, and their state changes to Fixed. All new flow monitor entries generated based on new flow data are illegitimate (or invalid).
Flow monitor only records illegitimate entries. The device does not make forwarding decisions based on flow monitor table entries. To take action on the packets of an illegitimate flow, for example, to drop the packets, you must use features such as the packet filter.
Flow monitor tasks at a glance
1.        Enabling flow monitor
2.        (Optional.) Freezing the flow monitor table
3.        (Optional.) Adding a flow monitor entry
?  Adding an IP flow monitor entry
?  Adding an MPLS flow monitor entry
4.        (Optional.) Deleting flow monitor entries
?  Deleting an IP flow monitor entry
?  Deleting an MPLS flow monitor entry
?  Bulk deleting flow monitor entries
?  Deleting illegitimate flow monitor entries
Prerequisites for flow monitor
Before you configure flow monitor, enable NetStream in the desired direction.
Make sure flow monitor is enabled in the same traffic direction as NetStream.
1.        Enter system view.
2.        Enable flow monitor.
flow-monitor { inbound | outbound }
By default, flow monitor is disabled.
2.        Freeze the flow monitor table.
In standalone mode:
flow-monitor fixup [ slot slot-number ]
In IRF mode:
flow-monitor fixup [ chassis chassis-number slot slot-number ]
By default, the flow monitor table is in unfixed state.
About adding flow monitor entries
You can add IP and MPLS flow monitor entries before or after you freeze the flow monitor table.
·          If no freeze operation has been performed, the entry you add is in Unfixed state.
·          If the operation has been performed, the entry you add is in Fixed state. If the entry has already been identified as an illegitimate entry, the system automatically removes the entry from the illegitimate entry list.
2.        Add an IP flow monitor entry.
In standalone mode:
flow-monitor add ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number ]
In IRF mode:
flow-monitor add ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number ]
By default, no IP flow monitor entries exist.
2.        Add an MPLS flow monitor entry.
In standalone mode:
flow-monitor add mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number ]
In IRF mode:
flow-monitor add mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number ]
You can delete unfixed entries from an unfrozen flow monitor table or delete fixed entries from a frozen flow monitor table.
2.        Delete an IP flow monitor entry.
In standalone mode:
flow-monitor delete ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number ]
In IRF mode:
flow-monitor delete ip source source-address destination dest-address protocol protocol-number interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number ]
2.        Delete an MPLS flow monitor entry.
In standalone mode:
flow-monitor delete mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ slot slot-number ]
In IRF mode:
flow-monitor delete mpls label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] [ source source-address destination dest-address protocol protocol-number ] interface interface-type interface-number { inbound | outbound } [ vpn-instance vpn-instance-name ] [ chassis chassis-number slot slot-number ]
2.        Bulk delete flow monitor entries.
In standalone mode:
reset flow-monitor entry [ ip | mpls ] [ interface interface-type interface-number ] [ slot slot-number ] [ source slot source-slot-number ]
In IRF mode:
reset flow-monitor entry [ ip | mpls ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ source chassis source-chassis-number slot source-slot-number ]
2.        Delete illegitimate flow monitor entries.
In standalone mode:
reset flow-monitor entry invalid [ ip | mpls ] [ interface interface-type interface-number ] [ slot slot-number ] [ source slot source-slot-number ]
In IRF mode:
reset flow-monitor entry invalid [ ip | mpls ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ source chassis source-chassis-number slot source-slot-number ]
Display and maintenance commands for flow monitor
(In standalone mode.) Display information about flow monitor entries.
display flow-monitor [ invalid ] [ verbose ] [ { ip | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination dest-address | interface interface-type interface-number | source source-ip ] * [ slot slot-number ]
(In IRF mode.) Display information about flow monitor entries.
display flow-monitor [ invalid ] [ verbose ] [ { ip | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination dest-address | interface interface-type interface-number | source source-address ] * [ chassis chassis-number slot slot-number ]
(In standalone mode.) Clear flow monitor statistics.
reset flow-monitor statistics [ slot slot-number ]
(In IRF mode.) Clear flow monitor statistics.
reset flow-monitor statistics [ chassis chassis-number slot slot-number ]
Flow monitor configuration examples
Example: Configuring flow monitor
As shown in Figure 1, configure flow monitor on the router to monitor the following traffic:
·          Incoming traffic on GigabitEthernet 3/1/1.
·          Outgoing traffic on GigabitEthernet 3/1/2 and GigabitEthernet 3/1/3.
Figure 1 Network diagram
1.        # Assign an IP address to each interface, as shown in Figure 1. (Details not shown.)
2.        Configure NetStream:
# Enable NetStream globally.
<Router> system-view
[Router] ip netstream
# Configure a QoS policy to mirror IPv4 traffic to slot 1.
[Router] acl advanced 3000
[Router-acl-ipv4-adv-3000] rule 0 permit ip
[Router-acl-ipv4-adv-3000] quit
[Router] traffic classifier ns_ipv4
[Router-classifier-ns_ipv4] if-match acl 3000
[Router-classifier-ns_ipv4] quit
[Router] traffic behavior ns_ipv4
[Router-behavior-ns_ipv4] mirror-to slot 3
[Router-behavior-ns_ipv4] quit
[Router] qos policy ns_ipv4
[Router-qospolicy-ns_ipv4] classifier ns_ipv4 behavior ns_ipv4
[Router-qospolicy-ns_ipv4] quit
# Apply the QoS policy to the inbound direction of GigabitEthernet 3/1/1.
[Router] interface GigabitEthernet 3/1/1
[Router-GigabitEthernet3/1/1] qos apply policy ns_ipv4 inbound
[Router-GigabitEthernet3/1/1] quit
# Apply the QoS policy to the outbound direction of GigabitEthernet 3/1/2 and GigabitEthernet 3/1/3.
[Router] interface range GigabitEthernet 3/1/2 to GigabitEthernet 3/1/3
[Router-if-range] qos apply policy ns_ipv4 outbound
[Router-if-range] quit
3.        Configure flow monitor:
# Enable flow monitor for incoming and outgoing traffic.
[Router] flow-monitor inbound
[Router] flow-monitor outbound
# Freeze the flow monitor table after the table has been populated with all legitimate entries.
[Router] flow-monitor fixup
# Add new legitimate flow monitor entries to the flow monitor table.
[Router] flow-monitor add ip source 192.168.40.2 destination 192.168.80.2 protocol 17 interface gigabitethernet 3/1/2 outbound
[Router] flow-monitor add ip source 192.168.40.2 destination 192.168.80.2 protocol 17 interface gigabitethernet 3/1/3 outbound
# Display flow monitor entries in the flow monitor table.
[Router] display flow-monitor
Total 11 matching IP flow monitor entries and 0 matching MPLS flow monitor entries.
State: Fixed
Type Source          Destination     Protocol Direction Interface    VPN
Labels
IP   192.168.40.2    192.168.80.2    17       Outbound  GE3/1/3
IP   192.168.40.2    192.168.80.2    17       outbound  GE3/1/2
IP   192.168.1.102   192.168.1.255   17       Inbound   GE3/1/1
IP   192.168.1.1     239.255.255.250 17       Outbound  GE3/1/2
IP   192.168.20.65   239.255.255.250 17       Inbound   GE3/1/1
IP   40.0.0.3        40.0.0.255      17       Inbound   GE3/1/1
IP   56.56.56.44     224.0.0.5       89       Outbound  GE3/1/3
IP   192.168.20.167  192.168.20.255  17       Outbound  GE3/1/2
IP   192.168.20.170  192.168.20.255  17       Inbound   GE3/1/1
IP   192.168.20.191  192.168.20.255  17       Outbound  GE3/1/2
IP   192.168.80.133  192.168.80.131  1        Outbound  GE3/1/3
# Delete a fixed flow monitor entry.
[Router] flow-monitor delete ip source 40.0.0.3 destination 40.0.0.255 protocol 17 interface gigabitethernet 3/1/1 inbound
# Verify that the flow monitor table is populated with only legitimate flow monitor entries.
Total 10 matching IP flow monitor entries and 0 matching MPLS flow monitor entries.
State: Fixed
Labels
