14-Network Management and Monitoring Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-Release795x-6W10014-Network Management and Monitoring Configuration Guide
13-Mirroring configuration
13-Mirroring configuration 400.30 KB
Configuring port mirroring· 1
About port mirroring· 1
Terminology· 1
Port mirroring classification· 2
Local port mirroring· 2
Layer 2 remote port mirroring· 2
Layer 3 remote port mirroring· 4
Restrictions and guidelines: Port mirroring configuration· 5
Configuring local port mirroring· 5
Restrictions and guidelines for local port mirroring configuration· 5
Local port mirroring tasks at a glance· 5
Creating a local mirroring group· 6
Configuring mirroring sources· 6
Configuring the monitor port 7
Configuring Layer 2 remote port mirroring· 8
Restrictions and guidelines for Layer 2 remote port mirroring configuration· 8
Layer 2 remote port mirroring with reflector port configuration tasks at a glance· 8
Layer 2 remote port mirroring with egress port configuration tasks at a glance· 9
Creating a remote destination group· 9
Configuring the monitor port 9
Configuring the remote probe VLAN·· 10
Assigning the monitor port to the remote probe VLAN·· 11
Creating a remote source group· 11
Configuring mirroring sources· 11
Configuring the reflector port 13
Configuring the egress port 14
Configuring local port mirroring with multiple monitoring devices· 15
Configuring Layer 3 remote port mirroring· 16
Restrictions and guidelines for Layer 3 remote port mirroring configuration· 16
Layer 3 remote port mirroring tasks at a glance· 16
Prerequisites for Layer 3 remote port mirroring· 17
Configuring local mirroring groups· 17
Configuring mirroring sources· 17
Configuring the monitor port 18
Display and maintenance commands for port mirroring· 19
Port mirroring configuration examples· 19
Example: Configuring local port mirroring (in source port mode) 19
Example: Configuring local port mirroring (in source CPU mode) 21
Example: Configuring Layer 2 remote port mirroring (with reflector port) 22
Example: Configuring Layer 2 remote port mirroring (with egress port) 24
Example: Configuring Layer 2 remote port mirroring (with egress port) 26
Example: Configuring local port mirroring with multiple monitoring devices· 29
Example: Configuring Layer 3 remote port mirroring· 30
Configuring flow mirroring· 34
Restrictions and guidelines: Flow mirroring configuration· 34
Flow mirroring tasks at a glance· 34
Configuring a traffic class· 35
Configuring a traffic behavior 35
Configuring a QoS policy· 36
Applying a QoS policy· 36
Applying a QoS policy to an interface· 36
Applying a QoS policy to a VLAN·· 36
Applying a QoS policy globally· 37
Applying a QoS policy to the control plane· 37
Flow mirroring configuration examples· 38
Example: Configuring flow mirroring· 38
Port mirroring copies the packets passing through a port or CPU to a port that connects to a data monitoring device for packet analysis.
Terminology
The following terms are used in port mirroring configuration.
Mirroring source
The mirroring sources can be one or more monitored ports or CPUs. The monitored ports and CPUs are called source ports and source CPUs, respectively.
Packets passing through mirroring sources are copied to a port connecting to a data monitoring device for packet analysis. The copies are called mirrored packets.
Source device
The device where the mirroring sources reside is called a source device.
Mirroring destination
The mirroring destination connects to a data monitoring device and is the destination port (also known as the monitor port) of mirrored packets. Mirrored packets are sent out of the monitor port to the data monitoring device.
A monitor port might receive multiple copies of a packet when it monitors multiple mirroring sources. For example, two copies of a packet are received on Port A when the following conditions exist:
·          Port A is monitoring bidirectional traffic of Port B and Port C on the same device.
·          The packet travels from Port B to Port C.
Destination device
The device where the monitor port resides is called the destination device.
Mirroring direction
The mirroring direction specifies the direction of the traffic that is copied on a mirroring source.
·          Inbound—Copies packets received.
·          Outbound—Copies packets sent.
·          Bidirectional—Copies packets received and sent.
Mirroring group
Port mirroring is implemented through mirroring groups. Mirroring groups can be classified into local mirroring groups, remote source groups, and remote destination groups.
Reflector port, egress port, and remote probe VLAN
Reflector ports, remote probe VLANs, and egress ports are used for Layer 2 remote port mirroring. The remote probe VLAN is a dedicated VLAN for transmitting mirrored packets to the destination device. Both the reflector port and egress port reside on a source device and send mirrored packets to the remote probe VLAN.
On port mirroring devices, all ports except source, destination, reflector, and egress ports are called common ports.
Port mirroring can be classified into local port mirroring and remote port mirroring.
·          Local port mirroringThe source device is directly connected to a data monitoring device. The source device also acts as the destination device and forwards mirrored packets directly to the data monitoring device.
·          Remote port mirroring—The source device is not directly connected to a data monitoring device. The source device sends mirrored packets to the destination device, which forwards the packets to the data monitoring device.
Remote port mirroring can be further classified into Layer 2 and Layer 3 remote port mirroring:
¡  Layer 2 remote port mirroring—The source device and destination device are on the same Layer 2 network.
¡  Layer 3 remote port mirroring—The source device and destination device are separated by IP networks.
As shown in Figure 1, the source port (Port A) and the monitor port (Port B) reside on the same device. Packets received on Port A are copied to Port B. Port B then forwards the packets to the data monitoring device for analysis.
Figure 1 Local port mirroring implementation
In Layer 2 remote port mirroring, the mirroring sources and destination reside on different devices and are in different mirroring groups.
A remote source group is a mirroring group that contains the mirroring sources. A remote destination group is a mirroring group that contains the mirroring destination. Intermediate devices are the devices between the source device and the destination device.
Layer 2 remote port mirroring can be implemented through the reflector port method or the egress port method.
Reflector port method
In Layer 2 remote port mirroring that uses the reflector port method, packets are mirrored as follows:
1.        The source device copies packets received on the mirroring sources to the reflector port.
2.        The reflector port broadcasts the mirrored packets in the remote probe VLAN.
3.        The intermediate devices transmit the mirrored packets to the destination device through the remote probe VLAN.
4.        Upon receiving the mirrored packets, the destination device determines whether the ID of the mirrored packets is the same as the remote probe VLAN ID. If the two VLAN IDs match, the destination device forwards the mirrored packets to the data monitoring device through the monitor port.
Figure 2 Layer 2 remote port mirroring implementation through the reflector port method
The reflector port must be manually specified in the remote source group on the source device.
Egress port method
In Layer 2 remote port mirroring that uses the egress port method, packets are mirrored as follows:
1.        The source device copies packets received on the mirroring sources to the egress port.
2.        The egress port forwards the mirrored packets to the intermediate devices.
3.        The intermediate devices flood the mirrored packets in the remote probe VLAN and transmit the mirrored packets to the destination device.
Figure 3 Layer 2 remote port mirroring implementation through the egress port method
Layer 3 remote port mirroring is implemented through configuring a local mirroring group on both the source device and the destination device.
To implement Layer 3 remote port mirroring, perform the following tasks:
·          Configure the source device:
¡  Create a local mirroring group and specify the mirroring sources for the group.
¡  Configure the tunnel interface as the monitor port for the mirroring group.
·          Configure the destination device:
¡  Create a local mirroring group and specify the physical port corresponding to the tunnel interface as the source port.
¡  Configure the port that connects to the data monitoring device as the monitor port.
For example, in a network as shown in Figure 4, Layer 3 remote port mirroring works as follows:
1.        The source device sends one copy of a packet received on the source port (Port A) to the tunnel interface.
The tunnel interface acts as the monitor port in the local mirroring group created on the source device.
2.        The tunnel interface on the source device forwards the mirrored packet to the tunnel interface on the destination device through the GRE tunnel.
3.        The destination device receives the mirrored packet from the physical interface of the tunnel interface.
The tunnel interface acts as the source port in the local mirroring group created on the destination device.
4.        The physical interface of the tunnel interface sends one copy of the packet to the monitor port (Port B).
5.        The monitor port (Port B) forwards the packet to the data monitoring device.
For more information about GRE tunnels and tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Figure 4 Layer 3 remote port mirroring implementation
The reflector port method for Layer 2 remote port mirroring can be used to implement local port mirroring with multiple monitor ports.
In the reflector port method, the reflector port broadcasts mirrored packets in the remote probe VLAN. By assigning ports that connect to data monitoring devices to the remote probe VLAN, you can implement local port mirroring to mirror packets to multiple monitor ports. Make sure the ports remove the remote probe VLAN tag of the mirrored packets so the original packets can be sent to the data monitoring devices.
The egress port method cannot implement local port mirroring in this way.
A local mirroring group takes effect only after it is configured with the monitor port and mirroring sources.
Local port mirroring supports multicard mirroring. The mirroring sources and destination can reside on different cards of the same device.
To configure local port mirroring, perform the following tasks:
1.        Configuring mirroring sources
¡  Configuring source ports
¡  Configuring source CPUs
2.        Configuring the monitor port
1.        Enter system view.
2.        Create a local mirroring group.
mirroring-group group-id local
Restrictions and guidelines for mirroring source configuration
When you configure source ports for a local mirroring group, follow these restrictions and guidelines:
·          A mirroring group can contain multiple source ports.
·          A source port cannot be configured as a reflector port, egress port, or monitor port.
·          A Layer 3 Ethernet subinterface cannot be configured as a source port for a mirroring group.
·          A port on the CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPC-GE16XP4L-E, CSPEX, or CEPC card can act as a source port for only one mirroring group.
·          A port on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card can act as a source port for multiple mirroring groups.
·          To mirror traffic of a POS interface on a MIC subcard installed on a CSPEX-1204, CSPEX-1104-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, or CSPC-GE16XP4L-E card after the interface is assigned to an HDLC link bundle, follow these guidelines:
¡  If you specify the HDLC link bundle interface as a source port, only the inbound traffic of the POS interface can be mirrored, even if you enable bidirectional traffic mirroring for the HDLC link bundle interface.
¡  If you specify the POS interface as a source interface, only the outbound traffic of the POS interface can be mirrored, even if you enable bidirectional traffic mirroring for the POS interface.
·          To mirror traffic of a POS interface on a PIC subcard installed on a CSPEX-1204, CSPEX-1104-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, or CSPC-GE16XP4L-E card after the interface is assigned to an HDLC link bundle, specify the POS interface as a source port.
·          To mirror traffic of a POS interface on a MIC or PIC subcard installed on a CSPEX (except CSPEX-1204 and CSPEX-1104-E) or CEPC card after the interface is assigned to an HDLC link bundle, specify the HDLC link bundle interface as a source port.
·          Only ATM interfaces on the CSPEX-1304X, CSPEX-1404X, or CSPEX-1504X card can be configured as source ports.
When you configure source CPUs for a local mirroring group, follow these restrictions and guidelines:
·          A local mirroring group can contain multiple source CPUs.
·          Outbound traffic mirroring is not supported for CPUs on the following cards:
¡  CSPC-GE24L-E card.
¡  CSPC-GP24GE8XP2L-E card.
¡  CSPC-GE16XP4L-E card.
¡  CSPEX card.
¡  CEPC card.
·          Both inbound and outbound traffic mirroring are supported for CPUs on the following cards:
¡  CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) card.
¡  CMPE-1104 card.
·          Configure source ports in system view.
a.    Enter system view.
b.    Configure source ports for a local mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
By default, no source port is configured for a local mirroring group.
·          Configure source ports in interface view.
b.    Enter interface view.
c.    Configure the port as a source port for a local mirroring group.
mirroring-group group-id mirroring-port { both | inbound | outbound }
By default, a port does not act as a source port for any local mirroring groups.
2.        Configure source CPUs for a local mirroring group.
In standalone mode:
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
In IRF mode:
mirroring-group group-id mirroring-cpu chassis chassis-number slot slot-number-list { both | inbound | outbound }
By default, no source CPU is configured for a local mirroring group.
A port that has the spanning tree feature enabled cannot be cannot be configured as the monitor port for a mirroring group.
For a Layer 2 or Layer 3 aggregate interface configured as the monitor port of a mirroring group, do not configure its member ports as source ports of the mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
·          Configure the monitor port in system view.
b.    Configure the monitor port for a local mirroring group.
mirroring-group group-id monitor-port interface-type interface-number [ pop-label ]
By default, no monitor port is configured for a local mirroring group.
·          Configure the monitor port in interface view.
c.    Configure the port as the monitor port for a mirroring group.
mirroring-group group-id monitor-port [ pop-label ]
By default, a port does not act as the monitor port for any local mirroring groups.
When you configure Layer 2 remote port mirroring through the reflector port method, follow these restrictions and guidelines:
·          Only ports on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card can be configured as reflector ports.
·          In enhanced VLAN mode, you cannot configure Layer 2 remote port mirroring through the reflector port method. For more information about the enhanced VLAN mode, see VLAN configuration in Layer 2—LAN Switching Configuration Guide.
To ensure successful traffic mirroring, configure devices in the order of the destination device, the intermediate devices, and the source device.
If intermediate devices exist, configure the intermediate devices to allow the remote probe VLAN to pass through.
The egress port must be assigned to the remote probe VLAN. This restriction does not apply to the reflector port.
For a mirrored packet to successfully arrive at the remote destination device, make sure its VLAN ID is not removed or changed.
Do not configure both MVRP and Layer 2 remote port mirroring. Otherwise, MVRP might register the remote probe VLAN with incorrect ports, which would cause the monitor port to receive undesired copies. For more information about MVRP, see Layer 2—LAN Switching Configuration Guide.
To monitor the bidirectional traffic of a source port, disable MAC address learning for the remote probe VLAN on the source, intermediate, and destination devices. For more information about MAC address learning, see Layer 2—LAN Switching Configuration Guide.
To configure Layer 2 remote port mirroring with reflector port, perform the following tasks:
1.        Configuring the destination device
a.    Creating a remote destination group
b.    Configuring the monitor port
c.    Configuring the remote probe VLAN
d.    Assigning the monitor port to the remote probe VLAN
2.        Configuring the source device
a.    Creating a remote source group
b.    Configuring mirroring sources
-      Configuring source ports
-      Configuring source CPUs
c.    Configuring the reflector port
d.    Configuring the remote probe VLAN
To configure Layer 2 remote port mirroring with an egress port, perform the following tasks:
c.    Configuring the egress port
Perform this task on the destination device only.
2.        Create a remote destination group.
mirroring-group group-id remote-destination
Restrictions and guidelines for monitor port configuration
A Layer 2 aggregate interface cannot be configured as the monitor port of a mirroring group for Layer 2 remote port mirroring.
A monitor port can belong to only one mirroring group.
Configuring the monitor port in system view
2.        Configure the monitor port for a remote destination group.
By default, no monitor port is configured for a remote destination group.
Configuring the monitor port in interface view
2.        Enter interface view.
3.        Configure the port as the monitor port for a remote destination group.
By default, a port does not act as the monitor port for any remote destination groups.
This task is required on the both the source and destination devices.
Only an existing static VLAN can be configured as a remote probe VLAN.
When a VLAN is configured as a remote probe VLAN, use the remote probe VLAN for port mirroring exclusively.
Configure the same remote probe VLAN for the remote source group and the remote destination group.
To implement Layer 2 remote port mirroring with the reflector port method, make sure the remote probe VLAN ID is different from any subinterface IDs configured for the following interfaces:
·          Physical interfaces on the card where the reflector port resides.
·          Layer 3 aggregate interfaces that contain physical interfaces on the card where the reflector port resides.
2.        Configure the remote probe VLAN for the remote source or destination group.
mirroring-group group-id remote-probe vlan vlan-id
By default, no remote probe VLAN is configured for a remote source or destination group.
2.        Enter the interface view of the monitor port.
3.        Assign the port to the remote probe VLAN.
¡  Assign an access port to the remote probe VLAN.
port access vlan vlan-id
¡  Assign a trunk port to the remote probe VLAN.
port trunk permit vlan vlan-id
¡  Assign a hybrid port to the remote probe VLAN.
port hybrid vlan vlan-id { tagged | untagged }
For more information about the port access vlan, port trunk permit vlan, and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference.
Perform this task on the source device only.
2.        Create a remote source group.
mirroring-group group-id remote-source
When you configure source ports for a remote source group, follow these restrictions and guidelines:
·          Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
·          A source port cannot be configured as a reflector port, monitor port, or egress port.
·          A mirroring group can contain multiple source CPUs.
¡  CSPEX card.
¡  CEPC card.
¡  CMPE-1104 card.
b.    Configure source ports for a remote source group.
By default, no source port is configured for a remote source group.
c.    Configure the port as a source port for a remote source group.
By default, a port does not act as a source port for any remote source groups.
2.        Configure source CPUs for a remote source group.
In standalone mode:
In IRF mode:
By default, no source CPU is configured for a remote source group.
Restrictions and guidelines for reflector port configuration
The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port.
If you need to configure a subinterface for a physical interface on the card where the reflector port resides, make sure the subinterface ID is different from the remote probe VLAN ID. This restriction also applies when you configure subinterfaces for Layer 3 aggregate interfaces that contain physical interfaces on the card where the reflector port resides.
When a port is configured as a reflector port, the default settings of the port are automatically restored. You cannot configure other features on the reflector port.
If an IRF port is bound to only one physical interface, do not configure the physical interface as a reflector port. Otherwise, the IRF might split.
A remote source group supports only one reflector port.
A port can be configured as a reflector port only when it is operating with the default setting of the following parameters:
·          Duplex mode.
·          Speed.
·          MDI settings.
Configuring the reflector port in system view
2.        Configure the reflector port for a remote source group.
mirroring-group group-id reflector-port interface-type interface-number
By default, no reflector port is configured for a remote source group.
Configuring the reflector port in interface view
3.        Configure the port as the reflector port for a remote source group.
By default, a port does not act as the reflector port for any remote source groups.
Restrictions and guidelines for egress port configuration
Disable the following features on the egress port:
·          Spanning tree.
·          802.1X.
·          IGMP snooping.
·          Static ARP.
·          MAC address learning.
A mirroring group supports only one egress port.
A port of an existing mirroring group cannot be configured as an egress port.
If the remote source group contains a source CPU on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card, do not configure a port on the CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPC-GE16XP4L-E, CSPEX, or CEPC card as the egress port.
If the remote source group contains a source port on the CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPC-GE16XP4L-E, CSPEX, or CEPC card, the following ports must be configured as trunk ports that permit all VLANs and use the remote probe VLAN as the PVID for Layer 2 remote port mirroring to operate correctly:
·          Egress port on the source device.
·          Ports on intermediate devices directly connected to the source and destination devices.
·          Port that receives mirrored packets on the destination device.
·          Monitor port on the destination device.
Configuring the egress port in system view
2.        Configure the egress port for a remote source group.
mirroring-group group-id monitor-egress interface-type interface-number
By default, no egress port is configured for a remote source group.
3.        Enter the egress port view.
4.        Assign the egress port to the remote probe VLAN.
For more information about the port trunk permit vlan and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference.
Configuring the egress port in interface view
3.        Configure the port as the egress port for a remote source group.
By default, a port does not act as the egress port for any remote source groups.
About local port mirroring with multiple monitoring devices
To monitor interesting traffic passing through a device on multiple directly connected data monitoring devices, configure local port mirroring with a remote probe VLAN as follows:
1.        Configure a remote source group on the device.
2.        Configure mirroring sources and a reflector port for the remote source group.
3.        Specify a VLAN as the remote probe VLAN and assign the ports connecting to the data monitoring devices to the VLAN.
This configuration enables the device to copy packets received on the mirroring sources to the reflector port, which broadcasts the packets in the remote probe VLAN. The packets are then sent out of the member ports of the remote probe VLAN to the data monitoring devices.
The reflector port must be a port not in use. Do not connect a network cable to the reflector port.
When a port is configured as a reflector port, the port restores to the factory default settings. You cannot configure other features on the reflector port.
A VLAN can act as the remote probe VLAN for only one remote source group. As a best practice, use the VLAN for port mirroring exclusively. Do not create a VLAN interface for the VLAN or configure other features for the VLAN.
The remote probe VLAN must be a static VLAN.
To delete a VLAN that has been configured as the remote probe VLAN in a mirroring group, remove the remote probe VLAN from the mirroring group first.
3.        Configure mirroring sources for the remote source group. Choose one option as needed:
¡  Configure mirroring ports in system view.
¡  Execute the following commands in sequence to enter interface view and then configure the interface as a source port.
4.        Configure the reflector port for the remote source group.
¡  Configure the reflector ports in system view.
mirroring-group group-id reflector-port reflector-port
¡  Execute the following commands in sequence to enter interface view and then configure the interface as a reflector port.
5.        Create a VLAN and enter its view.
vlan vlan-id
6.        Assign the ports that connect to the data monitoring devices to the VLAN.
port interface-list
By default, a VLAN does not contain any ports.
7.        Return to system view.
8.        Specify the VLAN as the remote probe VLAN for the remote source group.
By default, no remote probe VLAN is configured for a remote source group.
To implement Layer 3 remote port mirroring, you must configure a unicast routing protocol on the intermediate devices to ensure Layer 3 reachability between the source and destination devices.
Layer 3 remote port mirroring can be used to mirror traffic of ports or CPUs on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card.
To configure Layer 3 remote port mirroring, perform the following tasks:
1.        Configuring the source device
a.    Configuring local mirroring groups
c.    Configuring the monitor port
2.        Configuring the destination device
Before configuring Layer 3 remote mirroring, complete the following tasks:
·          Create a tunnel interface and a GRE tunnel.
·          Configure the source and destination addresses of the tunnel interface as the IP addresses of the physical interfaces on the source and destination devices, respectively.
For more information about tunnel interfaces, see Layer 3—IP Services Configuration Guide.
Configure a local mirroring group on both the source device and the destination device.
Restrictions and guidelines for source port configuration
On the source device, configure the ports you want to monitor as the source ports. On the destination device, configure the physical interface corresponding to the tunnel interface as the source port.
·          Perform this task on the source device only.
In standalone mode:
In IRF mode:
On the source device, configure the tunnel interface as the monitor port. A tunnel interface can be configured as the monitor port on the source device only when the mirroring sources are ports on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card.
On the destination device, follow these restrictions and guidelines:
·          Configure the port that connects to a data monitoring device as the monitor port.
·          A port that has the spanning tree feature enabled cannot be cannot be configured as the monitor port for a mirroring group.
·          For a Layer 2 or Layer 3 aggregate interface configured as the monitor port of a mirroring group, do not configure its member ports as source ports of the mirroring group.
·          Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
c.    Configure the port as the monitor port for a local mirroring group.
Display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
As shown in Figure 5, configure local port mirroring in source port mode to enable the server to monitor the bidirectional traffic of the two departments.
Figure 5 Network diagram
# Create local mirroring group 1.
[Device] mirroring-group 1 local
# Configure GigabitEthernet 3/1/1 and GigabitEthernet 3/1/2 as source ports for local mirroring group 1.
[Device] mirroring-group 1 mirroring-port gigabitethernet 3/1/1 gigabitethernet 3/1/2 both
# Configure GigabitEthernet 3/1/3 as the monitor port for local mirroring group 1.
[Device] mirroring-group 1 monitor-port gigabitethernet 3/1/3
# Disable the spanning tree feature on the monitor port (GigabitEthernet 3/1/3). This configuration is required only when the monitor port is operating in Layer 2 mode.
[Device] interface gigabitethernet 3/1/3
[Device-GigabitEthernet3/1/3] undo stp enable
[Device-GigabitEthernet3/1/3] quit
# Verify the mirroring group configuration.
[Device] display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        GigabitEthernet3/1/1  Both
        GigabitEthernet3/1/2  Both
    Monitor port: GigabitEthernet3/1/3
As shown in Figure 6, GigabitEthernet 3/1/1 and GigabitEthernet 3/1/2 are located on the card in slot 3.
Configure local port mirroring in source CPU mode to enable the server to monitor all packets matching the following criteria:
·          Received and sent by the Marketing Department and the Technical Department.
·          Processed by the CPU of the card in slot 3 of the device.
Figure 6 Network diagram
# Configure the CPU of the card in slot 3 of the device as a source CPU for local mirroring group 1.
[Device] mirroring-group 1 mirroring-cpu slot 3 both
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring CPU:
        Slot 3  Both
As shown in Figure 7, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
Figure 7 Network diagram
1.        Configure Device C (the destination device):
# Configure GigabitEthernet 3/1/1 as a trunk port, and assign the port to VLAN 2.
<DeviceC> system-view
[DeviceC] interface gigabitethernet 3/1/1
[DeviceC-GigabitEthernet3/1/1] port link-mode bridge
[DeviceC-GigabitEthernet3/1/1] port link-type trunk
[DeviceC-GigabitEthernet3/1/1] port trunk permit vlan 2
[DeviceC-GigabitEthernet3/1/1] quit
# Create a remote destination group.
[DeviceC] mirroring-group 2 remote-destination
# Create VLAN 2.
[DeviceC] vlan 2
# Disable MAC address learning for VLAN 2.
[DeviceC-vlan2] undo mac-address mac-learning enable
[DeviceC-vlan2] quit
# Configure VLAN 2 as the remote probe VLAN for the mirroring group.
[DeviceC] mirroring-group 2 remote-probe vlan 2
# Configure GigabitEthernet 3/1/2 as the monitor port for the mirroring group.
[DeviceC] interface gigabitethernet 3/1/2
[DeviceC-GigabitEthernet3/1/2] port link-mode bridge
[DeviceC-GigabitEthernet3/1/2] mirroring-group 2 monitor-port
# Disable the spanning tree feature on GigabitEthernet 3/1/2.
[DeviceC-GigabitEthernet3/1/2] undo stp enable
# Assign GigabitEthernet 3/1/2 to VLAN 2.
[DeviceC-GigabitEthernet3/1/2] port access vlan 2
[DeviceC-GigabitEthernet3/1/2] quit
2.        Configure Device B (the intermediate device):
# Create VLAN 2.
[DeviceB] vlan 2
[DeviceB-vlan2] undo mac-address mac-learning enable
[DeviceB-vlan2] quit
[DeviceB] interface gigabitethernet 3/1/1
[DeviceB-GigabitEthernet3/1/1] port link-mode bridge
[DeviceB-GigabitEthernet3/1/1] port link-type trunk
[DeviceB-GigabitEthernet3/1/1] port trunk permit vlan 2
[DeviceB-GigabitEthernet3/1/1] quit
# Configure GigabitEthernet 3/1/2 as a trunk port, and assign the port to VLAN 2.
[DeviceB] interface gigabitethernet 3/1/2
[DeviceB-GigabitEthernet3/1/2] port link-mode bridge
[DeviceB-GigabitEthernet3/1/2] port link-type trunk
[DeviceB-GigabitEthernet3/1/2] port trunk permit vlan 2
[DeviceB-GigabitEthernet3/1/2] quit
3.        Configure Device A (the source device):
# Create a remote source group.
[DeviceA] mirroring-group 1 remote-source
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] undo mac-address mac-learning enable
[DeviceA-vlan2] quit
[DeviceA] mirroring-group 1 remote-probe vlan 2
# Configure GigabitEthernet 3/1/1 as a source port for the mirroring group.
[DeviceA] mirroring-group 1 mirroring-port gigabitethernet 3/1/1 both
# Configure GigabitEthernet 3/1/3 as the reflector port for the mirroring group.
[DeviceA] interface gigabitethernet 3/1/3
[DeviceA-GigabitEthernet3/1/3] port link-mode bridge
[DeviceA-GigabitEthernet3/1/3] mirroring-group 1 reflector-port
[DeviceA-GigabitEthernet3/1/3] quit
[DeviceA] interface gigabitethernet 3/1/2
[DeviceA-GigabitEthernet3/1/2] port link-mode bridge
[DeviceA-GigabitEthernet3/1/2] port link-type trunk
[DeviceA-GigabitEthernet3/1/2] port trunk permit vlan 2
[DeviceA-GigabitEthernet3/1/2] quit
# Verify the mirroring group configuration on Device C.
[DeviceC] display mirroring-group all
Mirroring group 2:
    Type: Remote destination
    Status: Active
    Monitor port: GigabitEthernet3/1/2
    Remote probe VLAN: 2
# Verify the mirroring group configuration on Device A.
[DeviceA] display mirroring-group all
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
    Reflector port: GigabitEthernet3/1/3
IMPORTANT
IMPORTANT:
The example uses a port on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card as the egress port.
On the Layer 2 network shown in Figure 8, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
Figure 8 Network diagram
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign the port to VLAN 2.
[DeviceC-GigabitEthernet1/0/1] port link-mode bridge
[DeviceC-GigabitEthernet1/0/1] port trunk permit vlan 2
# Create VLAN 2.
[DeviceC] vlan 2
# Configure GigabitEthernet 1/0/2 as the monitor port for the mirroring group.
[DeviceC-GigabitEthernet1/0/2] port link-mode bridge
[DeviceC-GigabitEthernet1/0/2] mirroring-group 2 monitor-port
# Disable the spanning tree feature on GigabitEthernet 1/0/2.
[DeviceC-GigabitEthernet1/0/2] undo stp enable
# Assign GigabitEthernet 1/0/2 to VLAN 2 as an access port.
[DeviceC-GigabitEthernet1/0/2] port access vlan 2
# Create VLAN 2.
[DeviceB] vlan 2
[DeviceB-GigabitEthernet1/0/1] port link-mode bridge
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 2
# Configure GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLAN 2.
[DeviceB-GigabitEthernet1/0/2] port link-mode bridge
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 2
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-GigabitEthernet1/0/2] port link-mode bridge
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 2
# Disable the spanning tree feature on the port.
[DeviceA-GigabitEthernet1/0/2] undo stp enable
# Configure VLAN 2 as the remote probe VLAN of the mirroring group.
# Configure GigabitEthernet 1/0/1 as a source port and GigabitEthernet 1/0/2 as the egress port in the mirroring group.
[DeviceA] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
[DeviceA] mirroring-group 1 monitor-egress gigabitethernet 1/0/2
Mirroring group 2:
    Status: Active
    Monitor port: GigabitEthernet1/0/2
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
        GigabitEthernet1/0/1  Both
    Monitor egress port: Gigabitethernet1/0/2
IMPORTANT
IMPORTANT:
The example uses a port on the CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPC-GE16XP4L-E, CSPEX, or CEPC card as the egress port.
On the Layer 2 network shown in Figure 9, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
Figure 9 Network diagram
# Configure GigabitEthernet 3/1/1 as a trunk port, set its PVID to VLAN 2, and assign the port to VLAN 2.
[DeviceC-GigabitEthernet3/1/1] port trunk pvid vlan 2
[DeviceC-GigabitEthernet3/1/1] port trunk permit vlan all
# Create VLAN 2.
[DeviceC] vlan 2
# Configure GigabitEthernet 3/1/2 as a trunk, set its PVID to VLAN 2, and assign it to all VLANs.
[DeviceC-GigabitEthernet3/1/2] port link-type trunk
[DeviceC-GigabitEthernet3/1/2] port trunk pvid vlan 2
[DeviceC-GigabitEthernet3/1/2] port trunk permit vlan all
# Create VLAN 2.
[DeviceB] vlan 2
# Configure GigabitEthernet 3/1/1 as a trunk, set its PVID to VLAN 2, and assign the port to all VLANs.
[DeviceB-GigabitEthernet3/1/1] port trunk pvid vlan 2
[DeviceB-GigabitEthernet3/1/1] port trunk permit vlan all
# Configure GigabitEthernet 3/1/2 as a trunk, set its PVID to VLAN 2, and assign the port to all VLANs.
[DeviceB-GigabitEthernet3/1/2] port trunk pvid vlan 2
[DeviceB-GigabitEthernet3/1/2] port trunk permit vlan all
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-GigabitEthernet3/1/2] port trunk pvid vlan 2
[DeviceA-GigabitEthernet3/1/2] port trunk permit vlan all
[DeviceA-GigabitEthernet3/1/2] undo stp enable
# Configure GigabitEthernet 3/1/2 as the egress port for the mirroring group.
[DeviceA] mirroring-group 1 monitor-egress gigabitethernet 3/1/2
Mirroring group 2:
    Status: Active
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
    Monitor egress port: Gigabitethernet3/1/2
As shown in Figure 10, Dept. A, Dept. B, and Dept. C are connected to the device through GigabitEthernet 3/1/1, GigabitEthernet 3/1/2, and GigabitEthernet 3/1/3, respectively.
Configure port mirroring to enable data monitoring devices Server A and Server B to monitor the incoming and outgoing traffic of departments A, B, and C.
Figure 10 Network diagram
# Create remote source group 1.
[Device] mirroring-group 1 remote-source
# Configure GigabitEthernet 3/1/1 through GigabitEthernet 3/1/3 as source ports of remote source group 1.
[Device] mirroring-group 1 mirroring-port gigabitethernet 3/1/1 to gigabitethernet 3/1/3 both
# Configure an unused port (GigabitEthernet 3/1/6 in this example) as the reflector port of remote source group 1.
[Device] interface gigabitethernet 3/1/6
[Device-GigabitEthernet3/1/6] port link-mode bridge
[Device-GigabitEthernet3/1/6] mirroring-group 1 reflector-port
[Device-GigabitEthernet3/1/6] quit
# Create VLAN 10.
[Device] vlan 10
[Device-vlan10] quit
# Configure VLAN 10 as the remote probe VLAN of remote source group 1.
[Device] mirroring-group 1 remote-probe vlan 10
# Assign the ports connecting the data monitoring devices to VLAN 10.
[Device] interface range GigabitEthernet 3/1/4 GigabitEthernet 3/1/5
[Device-if-range] port link-mode bridge
[Device-if-range] port access vlan 10
[Device-if-range] quit
# Verify the mirroring group configuration on the device.
Mirroring group 1:
    Type: Remote source
    Status: Active
    Mirroring port:
        GigabitEthernet3/1/3  Both
    Reflector port: GigabitEthernet3/1/6
    Remote probe VLAN: 10
On a Layer 3 network shown in Figure 11, configure Layer 3 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
Figure 11 Network diagram
1.        Configure IP addresses and routes on the devices and make sure Device A and Device B can reach each other. (Details not shown.)
2.        Configure Device A (the source device):
# Create service loopback group 1 and specify the unicast tunnel service for the group. Assign GigabitEthernet 3/1/3 to service loopback group 1.
IMPORTANT
IMPORTANT:
The service loopback group configuration is required if the tunnel source interface or the ingress interface of the tunneled traffic resides on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card.
[DeviceA] service-loopback group 1 type tunnel
[DeviceA-GigabitEthernet3/1/3] port service-loopback group 1
# Create tunnel interface Tunnel 0 that operates in GRE mode, and configure an IP address and subnet mask for the interface.
[DeviceA] interface tunnel 0 mode gre
[DeviceA-Tunnel0] ip address 50.1.1.1 24
# Configure source and destination IP addresses for Tunnel 0.
[DeviceA-Tunnel0] source 20.1.1.1
[DeviceA-Tunnel0] destination 30.1.1.2
[DeviceA-Tunnel0] quit
# Configure a static route to the server through Tunnel 0.
[DeviceA] ip route-static 40.1.1.0 255.255.255.0 tunnel 0
[DeviceA] mirroring-group 1 local
# Configure GigabitEthernet 3/1/1 as a source port and Tunnel 0 as the monitor port of local mirroring group 1.
[DeviceA] mirroring-group 1 monitor-port tunnel 0
3.        Configure Device C (the destination device):
IMPORTANT
IMPORTANT:
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface gigabitethernet 3/1/3
[DeviceC-GigabitEthernet3/1/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y
[DeviceC-GigabitEthernet3/1/3] quit
[DeviceC] interface tunnel 0 mode gre
[DeviceC-Tunnel0] ip address 50.1.1.2 24
[DeviceC-Tunnel0] source 30.1.1.2
[DeviceC-Tunnel0] destination 20.1.1.1
[DeviceC-Tunnel0] quit
# Configure a static route to the marketing department through Tunnel 0.
[DeviceC] ip route-static 10.1.1.0 255.255.255.0 tunnel 0
[DeviceC] mirroring-group 1 local
# Configure GigabitEthernet 3/1/1 as a source port for local mirroring group 1.
[DeviceC] mirroring-group 1 mirroring-port gigabitethernet 3/1/1 inbound
# Configure GigabitEthernet 3/1/2 as the monitor port for local mirroring group 1.
[DeviceC] mirroring-group 1 monitor-port gigabitethernet 3/1/2
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
    Monitor port: Tunnel0
# Display information about all mirroring groups on Device C.
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        GigabitEthernet3/1/1  Inbound
Flow mirroring copies packets matching a class to a destination for packet analyzing and monitoring. It is implemented through QoS policies.
To configure flow mirroring, perform the following tasks:
·          Define traffic classes and configure match criteria to classify packets to be mirrored. Flow mirroring allows you to flexibly classify packets to be analyzed by defining match criteria.
·          Configure traffic behaviors to mirror the matching packets to the specified destination.
You can configure an action to mirror the matching packets to one of the following destinations:
·          Interface—The matching packets are copied to an interface and then forwarded to a data monitoring device for analysis.
·          CPU—The matching packets are copied to the CPU of the card where they are received. The CPU analyzes the packets or delivers them to upper layers.
·          Card—The matching packets are copied to a card for processing.
·          LocalThe matching packets are copied to the slot to which the interface where the packets were captured belongs.
For more information about QoS policies, traffic classes, and traffic behaviors, see ACL and QoS Configuration Guide.
The device supports mirroring only inbound traffic of interfaces on the CSPC (except CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPC-GE16XP4L-E) or CMPE-1104 card.
To mirror inbound or outbound traffic on the CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPC-GE16XP4L-E, CSPEX, or CEPC card to a card, you must specify the sampler keyword in the mirror-to command.
When you configure traffic mirroring to tunnel interfaces in a traffic behavior, follow these restrictions and guidelines:
·          A maximum of three GRE over IPv4 tunnel interfaces can be specified for the traffic behavior. Traffic mirroring to other types of tunnel interfaces is not supported.
·          QoS policies that use the traffic behavior can be applied only to interfaces on the CSPEX (except CSPEX-1204 and CSPEX-1104-E) or CEPC card.
For information about the configuration commands except the mirror-to command, see ACL and QoS Command Reference.
1.        Configuring a traffic class
A traffic class defines the criteria that filters the traffic to be mirrored.
2.        Configuring a traffic behavior
A traffic behavior specifies mirroring destinations.
3.        Configuring a QoS policy
4.        Applying a QoS policy
¡  Applying a QoS policy to an interface
¡  Applying a QoS policy to a VLAN
¡  Applying a QoS policy globally
¡  Applying a QoS policy to the control plane
2.        Create a class and enter class view.
3.        Configure match criteria.
if-match match-criteria
By default, no match criterion is configured in a traffic class.
4.        (Optional.) Display traffic class information.
display traffic classifier
This command is available in any view.
2.        Create a traffic behavior and enter traffic behavior view.
3.        Configure mirroring destinations for the traffic behavior. Choose the following tasks as needed:
¡  Mirror traffic to an interface.
mirror-to interface interface-type interface-number [ sampler sampler-name ] [ pop-label ]
By default, no mirroring actions exist to mirror traffic to interfaces.
¡  Mirror traffic to the CPU.
mirror-to cpu
By default, no mirroring actions exist to mirror traffic to the CPU.
¡  Mirror traffic to a card.
In standalone mode:
mirror-to slot slot-number [ sampler sampler-name ]
In IRF mode:
mirror-to chassis chassis-number slot slot-number [ sampler sampler-name ]
By default, no mirroring actions exist to mirror traffic to cards.
¡  Mirror traffic to the slot where the traffic was received or sent out.
mirror-to local [ sampler sampler-name ]
By default, no mirroring actions exist to mirror traffic to the slot where the traffic was received or sent out.
4.        (Optional.) Display traffic behavior configuration.
display traffic behavior
2.        Create a QoS policy and enter QoS policy view.
qos policy policy-name
3.        Associate a class with a traffic behavior in the QoS policy.
classifier classifier-name behavior behavior-name
By default, no traffic behavior is associated with a class.
4.        (Optional.) Display QoS policy configuration.
display qos policy
You can apply a QoS policy to an interface to mirror the traffic of the interface.
A policy can be applied to multiple interfaces.
In one traffic direction of an interface, only one QoS policy can be applied.
3.        Apply a policy to the interface.
4.        (Optional.) Display the QoS policy applied to the interface.
display qos policy interface
You can apply a QoS policy to a VLAN to mirror the traffic on all ports in the VLAN.
2.        Apply a QoS policy to a VLAN.
3.        (Optional.) Display the QoS policy applied to the VLAN.
display qos vlan-policy
You can apply a QoS policy globally to mirror the traffic on all ports.
2.        Apply a QoS policy globally.
3.        (Optional.) Display global QoS policies.
display qos policy global
You can apply a QoS policy to the control plane to mirror the traffic of all ports on the control plane.
2.        Enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
3.        Apply a QoS policy to the control plane.
4.        (Optional.) Display QoS policies applied to the control plane
display qos policy control-plane
As shown in Figure 12, configure flow mirroring and sampling so that the server can monitor the following traffic:
·          All traffic that the Technical Department sends to access the Internet.
·          IP traffic that the Technical Department sends to the Marketing Department during working hours (8:00 to 18:00) on weekdays.
Figure 12 Network diagram
# Create sampler samp1 in fixed sampling mode, and set the rate to 8. The first packet of 256 (2 to the 8th power) packets is selected.
[Device] sampler samp1 mode fixed packet-interval n-power 8
# Create working hour range work, in which working hours are from 8:00 to 18:00 on weekdays.
[DeviceA] time-range work 8:00 to 18:00 working-day
# Create IPv4 advanced ACL 3000 to allow packets from the Technical Department to access the Internet and the Marketing Department during working hours.
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule permit tcp source 192.168.2.0 0.0.0.255 destination-port eq www
[DeviceA-acl-ipv4-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255 time-range work
[DeviceA-acl-ipv4-adv-3000] quit
# Create traffic class tech_c, and configure the match criterion as ACL 3000.
[DeviceA] traffic classifier tech_c
[DeviceA-classifier-tech_c] if-match acl 3000
[DeviceA-classifier-tech_c] quit
# Create traffic behavior tech_b, configure the action of mirroring traffic to GigabitEthernet 3/1/3 by using sampler samp1.
[DeviceA] traffic behavior tech_b
[DeviceA-behavior-tech_b] mirror-to interface gigabitethernet 3/1/3 sampler samp1
[DeviceA-behavior-tech_b] quit
# Create QoS policy tech_p, and associate traffic class tech_c with traffic behavior tech_b in the QoS policy.
[DeviceA] qos policy tech_p
[DeviceA-qospolicy-tech_p] classifier tech_c behavior tech_b
[DeviceA-qospolicy-tech_p] quit
# Apply QoS policy tech_p to the incoming packets of GigabitEthernet 3/1/4.
[DeviceA] interface gigabitethernet 3/1/4
[DeviceA-GigabitEthernet3/1/4] qos apply policy tech_p inbound
[DeviceA-GigabitEthernet3/1/4] quit
# Verify that the server can monitor the following traffic:
·          All traffic sent by the Technical Department to access the Internet.
·          IP traffic that the Technical Department sends to the Marketing Department during working hours on weekdays.
