- 12-Security Command Reference
- 01-Security zone commands
- 02-AAA commands
- 03-Portal commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-Group domain VPN commands
- 11-SSH commands
- 12-SSL commands
- 13-SSL VPN commands
- 14-ASPF commands
- 15-APR commands
- 16-mGRE commands
- 17-Session management commands
- 18-Connection limit commands
- 19-Object group commands
- 20-Object policy commands
- 21-Attack detection and prevention commands
- 22-ARP attack protection commands
- 23-uRPF commands
- 24-Crypto engine commands
- 25-FIPS commands
| 23-uRPF commands | 87.88 KB |
IPv4 uRPF commands
display ip urpf
Use display ip urpf to display uRPF configuration.
In standalone mode:
display ip urpf interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ip urpf interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays uRPF configuration for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays uRPF configuration for all cards. (In IRF mode.)
# (In standalone mode.) Display uRPF configuration on the specified interface.
<Sysname> display ip urpf interface gigabitethernet 2/0/1 slot 1
uRPF configuration information of interface GigabitEthernet2/0/1(failed):
Check type: loose
Allow default route
Suppress drop ACL: 2000
(failed) |
The system failed to deliver the uRPF configuration to the forwarding chip because of insufficient chip resources. This field is not displayed if the delivery is successful. |
Check type |
uRPF check mode: loose or strict. |
Allow default route |
Using the default route is allowed. |
Link check |
Link layer check is enabled. |
Suppress drop ACL |
ACL used for drop suppression. |
ip urpf
Use ip urpf to enable uRPF.
Use undo ip urpf to disable uRPF.
ip urpf { loose [ allow-default-route ] [ acl acl-number ] | strict [ allow-default-route ] [ acl acl-number ] [ link-check ] }
undo ip urpf
uRPF is disabled.
Interface view
loose: Enables loose uRPF check. To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry.
strict: Enables strict uRPF check. To pass strict uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry. You can enable strict uRPF check only in VLAN interface view.
allow-default-route: Allows using the default route for uRPF check.
acl acl-number: Specifies an ACL by its number.
· For a basic ACL, the value range is 2000 to 2999.
· For an advanced ACL, the value range is 3000 to 3999.
link-check: Enables link layer check (Ethernet link).
uRPF can be deployed on a PE connected to a CE or an ISP, or on a CE.
Configure strict uRPF check for traffic that uses symmetric path and configure loose uRPF check for traffic that uses asymmetric path. A symmetric path exists for a session if the PE uses the same interface to receive upstream traffic and send downstream traffic. The path is asymmetric if the PE uses different interfaces to receive upstream traffic and send downstream traffic.
· Typically, symmetric path applies to traffic that goes through an ISP's PE interface connected to the CE. You can configure strict uRPF checkon the PE interface.
· Asymmetric path might exist for traffic that goes through a PE interface connected to another ISP. In this case, configure loose uRPF checkon the PE interface.
Typically, you do not need to configure the allow-default-route keyword on a PE device, because it has no default route pointing to a CE. If you enable uRPF on a CE interface and the CE interface has a default route pointing to the PE, specify the allow-default-route keyword.
You can use an ACL to match specific packets, so they are forwarded even if they fail to pass uRPF check.
If a Layer 3 PE interface connects to a large number of PCs, configure the link-check keyword on the interface to enable link layer check. uRPF checks the validity of the source MAC address.
# Configure loose uRPF check on interface GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] ip urpf loose
display ip urpf
IPv6 uRPF commands
display ipv6 urpf
Use display ipv6 urpf to display IPv6 uRPF configuration.
In standalone mode:
display ipv6 urpf interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ipv6 urpf interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 uRPF configuration for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 uRPF configuration for all cards. (In IRF mode.)
# (In standalone mode.) Display IPv6 uRPF configuration on the specified interface.
<Sysname> display ipv6 urpf interface gigabitethernet 2/0/1 slot 1
IPv6 uRPF configuration information of interface GigabitEthernet2/0/1(failed):
Check type: loose
Allow default route
(failed) |
The system failed to deliver the IPv6 uRPF configuration to the forwarding chip because of insufficient chip resources. This field is not displayed if the delivery is successful. |
Check type |
IPv6 uRPF check mode: loose or strict. |
Suppress drop ACL |
IPv6 ACL used for drop suppression. |
ipv6 urpf
Use ipv6 urpf to enable IPv6 uRPF.
Use undo ipv6 urpf to disable IPv6 uRPF.
ipv6 urpf { loose | strict } [ allow-default-route ] [ acl acl-number ]
undo ipv6 urpf
IPv6 uRPF is disabled.
Interface view
loose: Enables loose IPv6 uRPF check. To pass loose IPv6 uRPF check, the source address of a packet must match the destination address of an IPv6 FIB entry.
strict: Enables strict IPv6 uRPF check. To pass strict IPv6 uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of an IPv6 FIB entry.
allow-default-route: Allows using the default route for IPv6 uRPF check.
acl acl-number: Specifies an IPv6 ACL by its number.
· For a basic IPv6 ACL, the value range is 2000 to 2999.
· For an advanced IPv6 ACL, the value range is 3000 to 3999.
IPv6 uRPF can be deployed on a CE or on a PE connected to either a CE or an ISP.
Configure strict IPv6 uRPF check for traffic that uses symmetric path and configure loose IPv6 uRPF check for traffic that uses asymmetric path. A symmetric path exists for a session if the PE uses the same interface to receive upstream traffic and send downstream traffic. The path is asymmetric if the PE uses different interfaces to receive upstream traffic and send downstream traffic.
· Typically, symmetric path applies to traffic that goes through an ISP's PE interface connected to the CE. You can configure strict IPv6 uRPF checkon the PE interface.
· Asymmetric path might exist for traffic that goes through a PE interface connected to another ISP. In this case, configure loose IPv6 uRPF checkon the PE interface.
You can use an ACL to match specific packets, so they are forwarded even if they fail to pass IPv6 uRPF check.
# Configure loose IPv6 uRPF check on interface GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] ipv6 urpf loose
display ipv6 urpf
