12-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600[SR6600-X] Routers Command References(V7)-R7740-6W20012-Security Command Reference
01-Security zone commands
01-Security zone commands 95.25 KB
display security-zone
Use display security-zone to display security zone information.
display security-zone [ name zone-name ]
name zone-name: Specifies the security zone name, a case-insensitive string of 1 to 31 characters. If you do not specify this option, the command displays all security zones, including system-defined and user-defined security zones.
When displaying all security zones, the command uses the following order:
1.     System-defined security zones.
2.     User-defined security zones in alphabetical order of security zone names.
# Display information about security zone myZone.
<Sysname> display security-zone name myZone
Members:
  GigabitEthernet2/0/1
  GigabitEthernet2/0/2 in VLAN 3
Name
Security zone name.
Members
Members in the security zone:
·     Type and number of a Layer 3 interface.
·     Type and number of a Layer 2 Ethernet interface, and IDs of the VLANs to which the interface belongs.
If a security zone does not have members, this field displays None.
display zone-pair security
Use display zone-pair security to display all zone pairs.
# Display all zone pairs.
<Sysname> display zone-pair security
Source zone   Destination zone
DMZ           Local
Trust         Local
import interface
Use import interface to add a Layer 3 interface to a security zone.
Use undo import interface to remove Layer 3 interfaces from a security zone.
import interface layer3-interface-type layer3-interface-number
undo import interface layer3-interface-type layer3-interface-number
A security zone does not have Layer 3 interface members.
Security zone view
interface layer3-interface-type layer3-interface-number: Specifies a Layer 3 interface by its type and number. Layer 3 interfaces include Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, and other types of Layer 3 logical interfaces.
You cannot add a member to the system-defined security zone Local. You can add members to the other system-defined security zones.
To add multiple Layer 3 interfaces to a security zone, execute this command multiple times.
A Layer 3 interface can belong to only one security zone. To move a Layer 3 interface from one security zone to another security zone, perform the following tasks:
1.     Use the undo import interface command to remove the interface from the current security zone.
2.     Use the import interface command to add the interface to the new security zone.
# Add Layer 3 Ethernet interface GigabitEthernet 2/0/1 to security zone Trust.
[Sysname] security-zone name trust
[Sysname-security-zone-Trust] import interface gigabitethernet 2/0/1
import interface vlan
Use import interface vlan to add Layer 2 interface-VLAN combinations to a security zone.
Use undo import interface vlan to remove Layer 2 interface-VLAN combinations from a security zone .
import interface layer2-interface-type layer2-interface-number vlan vlan-list
undo import interface layer2-interface-type layer2-interface-number vlan vlan-list
A security zone does not have Layer 2 interface-VLAN combination members.
Security zone view
interface layer2-interface-type layer2-interface-number: Specifies a Layer 2 interface by its type and number.
vlan vlan-list: Specifies a list of VLANs. The vlan-list argument must be a space-separated list of up to 10 VLAN items that meet the following requirements:
·     Each item specifies a VLAN by its ID or a range of VLANs in the form of start-VLAN-ID to end-VLAN-ID. The end-VLAN-ID is greater than the start-VLAN-ID.
·     The VLAN IDs are in the range of 1 to 4094.
·     The VLANs already exist.
To add multiple Layer 2 Ethernet interface-VLAN combinations to a security zone, execute this command multiple times.
A Layer 2 interface-VLAN combination can belong to only one security zone. To move a Layer 2 interface-VLAN combination from one security zone to another security zone, perform the following tasks:
1.     Use the undo import interface vlan command to remove the combination from the current security zone.
2.     Use the import interface vlan command to add the combination to the new security zone.
# Add the combination of Layer 2 Ethernet interface GigabitEthernet 2/0/1 and VLAN 10 to security zone Untrust.
[Sysname] security-zone name untrust
[Sysname-security-zone-Untrust] import interface gigabitethernet 2/0/1 vlan 10
security-zone
Use security-zone to create a security zone and enter its view, or enter the view of an existing security zone.
Use undo security-zone to delete a security zone.
security-zone name zone-name
undo security-zone name zone-name
No security zones exist.
name zone-name: Specifies the security zone name, a case-insensitive string of 1 to 31 characters. It cannot be any. To include a backward slash (\) or quotation mark (") in the security zone name, you must use the escape character (\).
The device provides the following system-defined security zones: Local, Trust, DMZ, Management, and Untrust. The system creates these security zones automatically when one of following events occurs:
·     The first command for creating a security zone is executed.
·     The first command related to creating an interzone policy is executed.
System-defined security zones cannot be deleted.
You can use this command multiple times to create multiple security zones.
Deleting a security zone also deletes the following items:
·     All zone pairs that use the security zone as the source or destination security zone.
·     All interzone policy applications on the zone pairs.
# Create a security zone named zonetest and enter security zone view.
[Sysname] security-zone name zonetest
[Sysname-security-zone-zonetest]
security-zone intra-zone default permit
Use security-zone intra-zone default permit to set the default action to permit for packets exchanged between interfaces in the same security zone.
Use undo security-zone intra-zone default permit to restore the default.
The default action is deny for packets exchanged between interfaces in the same security zone.
The system uses the default action for packets that are exchanged between interfaces in the same security zone in the following situations:
·     A zone pair from the security zone to the security zone itself is not configured.
·     A zone pair from the security zone to the security zone itself is configured, but no interzone policy is applied to the zone pair.
# Set the default action to permit for packets exchanged between interfaces in the same security zone.
[Sysname] security-zone intra-zone default permit
zone-pair security
Use zone-pair security to create a zone pair and enter its view, or enter the view of an existing zone pair.
Use undo zone-pair security to delete a zone pair.
zone-pair security source { source-zone-name | any } destination { destination-zone-name | any }
undo zone-pair security source { source-zone-name | any } destination { destination-zone-name | any }
No zone pair exists.
source source-zone-name: Specifies the name of the source security zone, a case-insensitive string of 1 to 31 characters. This security zone must already exist.
destination destination-zone-name: Specifies the name of the destination security zone, a case-insensitive string of 1 to 31 characters. This security zone must already exist.
any: Specifies any security zone.
A zone pair has a source security zone and a destination security zone. The device examines received first data packets and uses zone pairs to identify data flows. You can apply interzone policies to zone pairs so the device processes data flows based on interzone policies.
You can use the zone-pair security source any destination any command to define the any-to-any zone pair. This zone pair matches all packets from one security zone to another security zone.
A zone pair between specific security zones has a higher priority than the any-to-any zone pair.
A packet between the Management and Local zones matches only zone pairs of the two zones. It does not match the any-to-any zone pair.
Deleting a zone pair deletes all interzone policy applications on the zone pair.
# Create a zone pair with the source security zone Trust and destination zone Untrust.
[Sysname] zone-pair security source trust destination untrust
[Sysname-zone-pair-security-Trust-Untrust]
