- H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Emergency shell configuration
- 09-Automatic configuration
- 10-Device management configuration
- 11-Tcl configuration
- 12-Python configuration
- 13-License management
62-VXLAN Configuration Examples | 219.45 KB |
H3C S12500X-AF & S12500-X & S9800 |
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
The information in this document is subject to change without notice
General restrictions and guidelines
Example: Configuring VXLAN Layer 2 forwarding
Configuring IP addresses for interfaces
Configuring a routing protocol on the transport network
Example: Configuring a centralized VXLAN IP gateway
Configuring basic VXLAN settings
Configuring the centralized VXLAN IP gateway
Example: Configuring a centralized VXLAN IP gateway group
Configuring centralized VXLAN IP gateway settings
Specifying the VTEP group as the gateway for access layer VTEPs
Introduction
This document provides Virtual eXtensible LAN (VXLAN) configuration examples. VXLAN is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network. VXLAN is typically used in data centers for multitenant services.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of VXLAN.
Before you can configure VXLANs, you must perform the following tasks:
1. Set the system operating mode to standard by using the system-working-mode standard command.
2. Save the configuration.
3. Reboot the device.
When you configure VXLAN, follow these restrictions and guidelines:
· If you enable Layer 3 forwarding for VXLANs, reserve one global-type VLAN interface resource for the VSI interface of each VXLAN before the VXLAN is created on the following hardware:
¡ The S12500X-AF F card series.
¡ The S12500-X switch series.
¡ The S9800 switch series.
You do not need to reserve VLAN interface resources for the S12500X-AF H card series.
· The VXLAN VSIs use broadcast traffic to learn remote MAC addresses. Do not use the flooding disable command to disable flooding for any VXLAN VSIs.
· A VXLAN IP gateway cannot have a lower-layer VXLAN IP gateway.
· VXLAN IP gateways are vulnerable to scanning attacks. To control the number of ARP packets on VXLAN IP gateways in an SDN network, set an appropriate ARP packet sending rate limit for the gateway VSI interfaces. For a gateway interface, the number of VXLAN tunnels multiplied by the ARP packet sending rate limit cannot exceed 4000.
As shown in Figure 1:
· Configure VXLAN 10 as a unicast-mode VXLAN on Switch A, Switch B, and Switch C to provide Layer 2 connectivity for the VMs across the network sites.
· Manually establish VXLAN tunnels and assign the tunnels to VXLAN 10.
Analysis
To ensure that the switches in the transport network can reach one another, configure a routing protocol on the switches to advertise routes for interfaces, including the loopback interfaces. In this example, OSPF is used.
To assign Switch A, Switch B, and Switch C to a VXLAN network, create VXLAN tunnels on the switches and assign the tunnels to the VXLAN.
To assign the customer traffic of a VLAN to a VXLAN, you must perform the following tasks:
· Create an Ethernet service instance on the interface that receives the traffic.
· Configure the Ethernet service instance to match the VLAN.
· Map the Ethernet service instance to the VSI on which the VXLAN is created.
Software versions used
Table 1 shows the software versions used in this configuration example.
Table 1 Product and software version compatibility
Product |
Software version |
S12500X-AF Switch Series |
S12500X-CMW710-R2712 |
S12500-X Switch Series |
S9800 Switch Series |
S9800-CMW710-R2712 |
Execute the undo vxlan ip-forwarding command on each VTEP to enable Layer 2 forwarding for VXLANs on the VTEPs.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# Configure IP addresses for interfaces on Switch A.
[SwitchA] vlan 11
[SwitchA-vlan11] port ten-gigabitethernet 1/0/2
[SwitchA-vlan11] quit
[SwitchA-Vlan-interface11] ip address 11.1.1.1 24
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] quit
# Configure IP addresses for interfaces on other switches in the same way the IP addresses are configured on Switch A. (Details not shown.)
# Configure OSPF to advertise routes for Switch A.
[SwitchA] ospf 1 router-id 1.1.1.1
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SwitchA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchA-ospf-1] quit
# Configure OSPF to advertise routes for Switch B.
[SwitchB] ospf 1 router-id 2.2.2.2
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchB-ospf-1] quit
# Configure OSPF to advertise routes for Switch C.
[SwitchC] ospf 1 router-id 3.3.3.3
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchC-ospf-1] quit
# Configure OSPF to advertise routes for Switch D.
[SwitchD] ospf 1 router-id 4.4.4.4
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
Configuring VXLAN settings
Configuring Switch A
# Enable L2VPN.
[SwitchA] l2vpn enable
# Enable Layer 2 forwarding for VXLANs. (Only on the S12500X-AF F card series, S12500-X switch series, and S9800 switch series.)
[SwitchA] undo vxlan ip-forwarding
# Create VSI vpna and VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna-vxlan10] quit
[SwitchA-vsi-vpna] quit
# Create a VXLAN tunnel to Switch B. The tunnel interface name is Tunnel 1.
[SwitchA-Tunnel1] quit
# Create a VXLAN tunnel to Switch C. The tunnel interface name is Tunnel 2.
[SwitchA] interface tunnel 2 mode vxlan
[SwitchA-Tunnel2] source 1.1.1.1
[SwitchA-Tunnel2] destination 3.3.3.3
[SwitchA-Tunnel2] quit
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-vxlan10] tunnel 1
[SwitchA-vsi-vpna-vxlan10] tunnel 2
# On Ten-GigabitEthernet 1/0/1, configure Ethernet service instance 1000 to match VLAN 2.
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchA-Ten-GigabitEthernet1/0/1] quit
Configuring Switch B
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] undo vxlan ip-forwarding
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna-vxlan10] quit
[SwitchB-vsi-vpna] quit
# Create a VXLAN tunnel to Switch A. The tunnel interface name is Tunnel 1.
[SwitchB] interface tunnel 1 mode vxlan
[SwitchB-Tunnel1] source 2.2.2.2
[SwitchB-Tunnel1] destination 1.1.1.1
[SwitchB-Tunnel1] quit
[SwitchB] interface tunnel 2 mode vxlan
[SwitchB-Tunnel2] source 2.2.2.2
[SwitchB-Tunnel2] destination 3.3.3.3
[SwitchB-Tunnel2] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-vxlan10] tunnel 1
[SwitchB-vsi-vpna-vxlan10] tunnel 2
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchB-Ten-GigabitEthernet1/0/1] quit
Configuring Switch C
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] undo vxlan ip-forwarding
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna-vxlan10] quit
[SwitchC-vsi-vpna] quit
[SwitchC] interface tunnel 1 mode vxlan
[SwitchC-Tunnel1] source 3.3.3.3
[SwitchC-Tunnel1] destination 1.1.1.1
[SwitchC-Tunnel1] quit
# Create a VXLAN tunnel to Switch B. The tunnel interface name is Tunnel 2.
[SwitchC] interface tunnel 2 mode vxlan
[SwitchC-Tunnel2] source 3.3.3.3
[SwitchC-Tunnel2] destination 2.2.2.2
[SwitchC-Tunnel2] quit
[SwitchC] vsi vpna
[SwitchC-vsi-vpna-vxlan10] tunnel 1
[SwitchC-vsi-vpna-vxlan10] tunnel 2
[SwitchC] interface ten-gigabitethernet 1/0/1
[SwitchC-Ten-GigabitEthernet1/0/1] service-instance 1000
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchC-Ten-GigabitEthernet1/0/1-srv1000] quit
[SwitchC-Ten-GigabitEthernet1/0/1] quit
1. Verify the VXLAN settings on the VTEPs. This example uses Switch A.
# Verify that the VXLAN tunnel interfaces on the VTEP are in up state.
[SwitchA] display interface tunnel
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel2
Current state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 3.3.3.3
# Verify that the VXLAN tunnels have been assigned to the VXLAN, and the VXLAN tunnels and Ethernet service instances are in up state.
[SwitchA] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : Unlimited
Broadcast Restrain : Unlimited
Multicast Restrain : Unlimited
Unknown Unicast Restrain: Unlimited
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Statistics : Disabled
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel1 0x5000001 Up Manual Disabled
Tunnel2 0x5000002 Up Manual Disabled
ACs:
AC Link ID State Type
XGE1/0/1 srv1000 0 Up Manual
# Verify that the VTEP has learned the MAC addresses of remote VMs.
[SwitchA] display l2vpn mac-address
MAC Address State VSI Name Link ID/Name Aging
cc3e-5f9c-6cdb Dynamic vpna Tunnel1 Aging
cc3e-5f9c-23dc Dynamic vpna Tunnel2 Aging
--- 2 mac address(es) found ---
2. Verify that VM 1, VM 2, and VM 3 can ping each other. (Details not shown.)
Configuration files
· Switch A:
area 0.0.0.0
vlan 2
vlan 11
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface11
ip address 11.1.1.1 255.255.255.0
port link-mode bridge
xconnect vsi vpna
port access vlan 11
interface Tunnel1 mode vxlan
source 1.1.1.1
destination 2.2.2.2
interface Tunnel2 mode vxlan
source 1.1.1.1
destination 3.3.3.3
return
· Switch B:
area 0.0.0.0
vlan 2
vlan 12
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
interface Vlan-interface12
ip address 12.1.1.2 255.255.255.0
xconnect vsi vpna
port access vlan 12
source 2.2.2.2
destination 1.1.1.1
source 2.2.2.2
destination 3.3.3.3
return
· Switch C:
area 0.0.0.0
vlan 2
vlan 13
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
interface Vlan-interface13
ip address 13.1.1.3 255.255.255.0
xconnect vsi vpna
port access vlan 13
source 3.3.3.3
destination 1.1.1.1
source 3.3.3.3
destination 2.2.2.2
return
· Switch D:
area 0.0.0.0
vlan 11
vlan 12
vlan 13
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 11.1.1.4 255.255.255.0
ip address 12.1.1.4 255.255.255.0
ip address 13.1.1.4 255.255.255.0
port access vlan 11
port access vlan 12
port access vlan 13
return
As shown in Figure 2:
· Configure VXLAN 10 and VXLAN 20 as unicast-mode VXLANs on Switch A, Switch B, and Switch C.
· Manually establish VXLAN tunnels and assign the tunnels to VXLAN 10 or VXLAN 20. Make sure VM 1 and VM 3 belong to VXLAN 10 and VM 2 and VM 4 belong to VXLAN 20.
· Configure a centralized VXLAN IP gateway on Switch C to provide gateway services for VXLAN 10 and VXLAN 20.
Analysis
To assign Switch A, Switch B, and Switch C to VXLANs, create VXLAN tunnels on the switches and assign the tunnels to the VXLANs.
To assign the customer traffic of a VLAN to a VXLAN on Switch A or Switch B, you must perform the following tasks:
For Switch C to provide centralized VXLAN IP gateway services for VXLANs, you must perform the following tasks:
· Create a VSI interface for each VXLAN on the switch.
· Assign an IP address to each VSI interface.
· Specify the VSI interfaces as the gateway interfaces for VXLANs.
For Layer 3 nodes in the transport network to reach the VMs, configure a routing protocol on Switch C to advertise routes for VSI interfaces and VLAN-interface 100. In this example, OSPF is used.
Table 2 shows the software versions used in this configuration example.
Table 2 Product and software version compatibility
Product |
Software version |
Procedures
[SwitchA] vlan 20
[SwitchA-vlan20] port ten-gigabitethernet 1/0/2
[SwitchA-vlan20] quit
[SwitchA-Vlan-interface20] ip address 20.1.1.1 24
# Configure IP addresses for interfaces on other devices in the same way the IP addresses are configured on Switch A. (Details not shown.)
[SwitchA-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
# Enable L2VPN.
[SwitchA] vsi vpna
# Create VSI vpnb and VXLAN 20.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb] vxlan 20
[SwitchA-vsi-vpnb-vxlan10] quit
[SwitchA-vsi-vpnb] quit
[SwitchA] vsi vpna
# Assign Tunnel 1 and Tunnel 2 to VXLAN 20.
[SwitchA] vsi vpnb
[SwitchA-vsi-vpnb-vxlan20] tunnel 1
[SwitchA-vsi-vpnb-vxlan20] tunnel 2
[SwitchA-vsi-vpnb-vxlan20] quit
# On Ten-GigabitEthernet 1/0/1, configure Ethernet service instance 1000 to match VLAN 10.
[SwitchA-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 10
# On Ten-GigabitEthernet 1/0/1, configure Ethernet service instance 2000 to match VLAN 11.
[SwitchA-Ten-GigabitEthernet1/0/1] service-instance 2000
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 11
# Map Ethernet service instance 2000 to VSI vpnb.
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchA-Ten-GigabitEthernet1/0/1-srv2000] quit
# Enable L2VPN.
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb] vxlan 20
[SwitchB-vsi-vpnb-vxlan10] quit
[SwitchB-vsi-vpnb] quit
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchB-vsi-vpnb-vxlan20] tunnel 1
[SwitchB-vsi-vpnb-vxlan20] tunnel 2
[SwitchB-vsi-vpnb-vxlan20] quit
# On Ten-GigabitEthernet 1/0/1, configure Ethernet service instance 1000 to match VLAN 12.
[SwitchB-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 12
# On Ten-GigabitEthernet 1/0/1, configure Ethernet service instance 2000 to match VLAN 13.
[SwitchB-Ten-GigabitEthernet1/0/1] service-instance 2000
[SwitchB-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 13
[SwitchB-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi vpnb
[SwitchB-Ten-GigabitEthernet1/0/1-srv2000] quit
# Enable L2VPN.
# Reserve the global VLAN interface resources of VLAN 3000 and VLAN 3001. (Only on the S12500X-AF F card series, S12500-X switch series, and S9800 switch series.)
[SwitchC] reserve-vlan-interface 3000 to 3001 global
[SwitchC] vsi vpna
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] vxlan 20
[SwitchC-vsi-vpnb-vxlan10] quit
[SwitchC-vsi-vpnb] quit
[SwitchC] vsi vpna
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb-vxlan20] tunnel 1
[SwitchC-vsi-vpnb-vxlan20] tunnel 2
[SwitchC-vsi-vpnb-vxlan20] quit
# Create VSI-interface 1 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 10.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
# Create VSI-interface 2 and assign the interface an IP address. The IP address will be used as the gateway address for VXLAN 20.
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchC-Vsi-interface2] quit
# Specify VSI-interface 2 as the gateway interface for VSI vpnb.
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] gateway vsi-interface 2
# Configure OSPF to advertise routes for the VSI interfaces and VLAN-interface 100.
[SwitchC] ospf 2 router-id 3.3.3.3
[SwitchC-ospf-2] area 0
[SwitchC-ospf-2-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchC-ospf-2-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[SwitchC-ospf-2-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[SwitchC-ospf-2-area-0.0.0.0] quit
[SwitchC-ospf-2] quit
# Verify that the VXLAN tunnel interfaces are in up state.
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel2
Current state: UP
Bandwidth: 64 kbps
# Verify that the VXLAN tunnels have been assigned to their respective VXLANs, and the VXLAN tunnels and Ethernet service instances are in up state.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
ACs:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
XGE1/0/1 srv2000 0 Up Manual
2. Verify the configuration on the VXLAN IP gateway:
[SwitchC] display interface tunnel
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 1.1.1.1
Tunnel2
Current state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 2.2.2.2
# Verify that the VSI interfaces are in up state.
[SwitchC] display interface vsi-interface
Vsi-interface1
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
Internet Address: 10.1.1.1/24 (primary)
IP packet frame type: Ethernet II, hardware address: 0000-fc00-458d
IPv6 packet frame type: Ethernet II, hardware address: 0000-fc00-458d
Vsi-interface2
Current state: UP
Description: Vsi-interface2 Interface
Internet Address: 10.1.2.1/24 (primary)
# Verify that the VXLAN tunnels have been assigned to VXLANs 10 and 20, VSI-interface 1 is the gateway interface of VSI vpna, and VSI-interface 2 is the gateway interface of VSI vpnb.
[SwitchC] display l2vpn vsi verbose
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway interface : VSI-interface 1
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flooding proxy
Tunnel1 0x5000002 Up Manual Disabled
Tunnel2 0x5000003 Up Manual Disabled
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway interface : VSI-interface 2
VXLAN ID : 20
Tunnels:
# Verify that Switch C has created ARP entries for the VMs.
[SwitchC] display arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI Interface/Link ID Aging Type
10.1.1.11 0000-1234-0001 N/A Tunnel1 20 D
10.1.1.12 0000-1234-0002 N/A Tunnel2 19 D
# Verify that Switch C has created FIB entries for the VMs.
[SwitchC] display fib 10.1.1.11
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
10.1.1.11/32 10.1.1.11 UH Vsi1 Null
3. Verify the network connectivity for VMs:
# Verify that VM 1, VM 2, VM 3, and VM 4 can ping each other. (Details not shown.)
# Verify that VM 1, VM 2, VM 3, VM 4, and VLAN-interface 100 (100.1.1.1) on Switch C can ping each other. (Details not shown.)
Configuration files
· Switch A:
area 0.0.0.0
vlan 20
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface Vlan-interface20
ip address 20.1.1.1 255.255.255.0
xconnect vsi vpna
xconnect vsi vpnb
port access vlan 20
source 1.1.1.1
destination 2.2.2.2
source 1.1.1.1
destination 3.3.3.3
· Switch B:
area 0.0.0.0
vlan 30
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface Vlan-interface30
ip address 30.1.1.2 255.255.255.0
xconnect vsi vpna
xconnect vsi vpnb
port access vlan 30
source 2.2.2.2
destination 1.1.1.1
source 2.2.2.2
destination 3.3.3.3
· Switch C:
area 0.0.0.0
area 0.0.0.0
vlan 40
vlan 100
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface Vlan-interface40
ip address 40.1.1.3 255.255.255.0
interface Vlan-interface100
ip address 100.1.1.1 255.255.255.0
port access vlan 40
port access vlan 100
interface Vsi-interface1
interface Vsi-interface2
source 3.3.3.3
destination 1.1.1.1
source 3.3.3.3
destination 2.2.2.2
return
· Switch D:
area 0.0.0.0
vlan 20
vlan 30
vlan 40
interface LoopBack0
ip address 20.1.1.4 255.255.255.0
ip address 30.1.1.4 255.255.255.0
ip address 40.1.1.4 255.255.255.0
port access vlan 20
port access vlan 30
port access vlan 40
return
As shown in Figure 3:
· Configure VXLAN 10 and VXLAN 20 as unicast-mode VXLANs on Switch A, Switch B, Switch C, and Switch D.
· Assign Switch C and Switch D to a VTEP group to provide gateway services for VXLAN 10 and VXLAN 20.
Analysis
To assign Switch A, Switch B, Switch C, and Switch D to VXLANs, create VXLAN tunnels on the switches and assign the tunnels to the VXLANs.
For Switch C and Switch D to act as centralized VXLAN IP gateways, you must perform the following tasks:
· Create a VSI interface for each VXLAN on the switches.
For Layer 3 nodes in the transport network to reach the VMs, configure a routing protocol on Switch C and Switch D to advertise routes for VSI interfaces and VLAN-interface 100. In this example, OSPF is used.
Table 3 shows the software versions used in this configuration example.
Table 3 Product and software version compatibility
Product |
Software version |
When you configure a VTEP group, follow these restrictions and guidelines:
· You must create the same VSI interface on all VTEPs in the VTEP group and assign the same IP and MAC addresses to the VSI interface.
· The MAC address of a VSI interface is used only in ARP responses. The bridge MAC address of the device is used as the source MAC address for Layer 3 packets to be forwarded. To prevent ARP entries from being aged out, configure the VSI interface to send gratuitous ARP packets periodically.
· Execute the vtep group group-ip member local member-ip command on each member VTEP in the VTEP group. The IP address specified by the member-ip argument must already exist on the VTEP. You must configure a routing protocol to advertise the IP address to the transport network.
· Member VTEPs in a VTEP group cannot use the group IP address or share an IP address.
· Execute the vtep group group-ip member remote member-ip&<1-8> command on each member VTEP in the VTEP group. Specify the member IP addresses of all the other VTEPs in the group for the command.
· By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
[SwitchA] vlan 20
[SwitchC-ospf-1-area-0.0.0.0] network 8.8.8.8 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 8.8.8.8 0.0.0.0
[SwitchD-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
# Configure OSPF to advertise routes for Switch E.
[SwitchE] ospf 1 router-id 5.5.5.5
[SwitchE-ospf-1] area 0
[SwitchE-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[SwitchE-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] quit
[SwitchE-ospf-1] quit
# Enable L2VPN.
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
# Create a VXLAN tunnel to the VTEP group. The tunnel interface name is Tunnel 1.
[SwitchA-Tunnel1] destination 8.8.8.8
[SwitchA-Tunnel2] destination 2.2.2.2
[SwitchA] vsi vpna
[SwitchA] vsi vpnb
# Enable L2VPN.
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
[SwitchB-Tunnel1] destination 8.8.8.8
# Create a VXLAN tunnel to Switch A. The tunnel interface name is Tunnel 2.
[SwitchB-Tunnel2] destination 1.1.1.1
[SwitchB] vsi vpna
[SwitchB] vsi vpnb
# Enable L2VPN.
[SwitchC] vsi vpna
[SwitchC] vsi vpnb
# Create a VXLAN tunnel for the VTEP group to Switch A. The tunnel source IP address is 8.8.8.8, and the tunnel interface name is Tunnel 1.
[SwitchC-Tunnel1] source 8.8.8.8
# Create a VXLAN tunnel for the VTEP group to Switch B. The tunnel source IP address is 8.8.8.8, and the tunnel interface name is Tunnel 2.
[SwitchC-Tunnel2] source 8.8.8.8
[SwitchC] vsi vpna
[SwitchC] vsi vpnb
Configuring Switch D
# Enable L2VPN.
[SwitchD] l2vpn enable
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] vxlan 10
[SwitchD-vsi-vpna-vxlan10] quit
[SwitchD-vsi-vpna] quit
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] vxlan 20
[SwitchD-vsi-vpnb-vxlan10] quit
[SwitchD-vsi-vpnb] quit
[SwitchD] interface tunnel 1 mode vxlan
[SwitchD-Tunnel1] source 8.8.8.8
[SwitchD-Tunnel1] destination 1.1.1.1
[SwitchD-Tunnel1] quit
[SwitchD] interface tunnel 2 mode vxlan
[SwitchD-Tunnel2] source 8.8.8.8
[SwitchD-Tunnel2] destination 2.2.2.2
[SwitchD-Tunnel2] quit
[SwitchD] vsi vpna
[SwitchD-vsi-vpna-vxlan10] tunnel 1
[SwitchD-vsi-vpna-vxlan10] tunnel 2
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb-vxlan20] tunnel 1
[SwitchD-vsi-vpnb-vxlan20] tunnel 2
[SwitchD-vsi-vpnb-vxlan20] quit
# Create VSI-interface 1 and assign the interface an IP address and a MAC address. The IP address will be used as the gateway address for VXLAN 10.
[SwitchC-Vsi-interface1] mac-address 1-1-1
# Enable periodic sending of gratuitous ARP packets on VSI-interface 1.
[SwitchC-Vsi-interface1] arp send-gratuitous-arp interval 200000
[SwitchC] vsi vpna
# Create VSI-interface 2 and assign the interface an IP address and a MAC address. The IP address will be used as the gateway address for VXLAN 20.
[SwitchC-Vsi-interface2] mac-address 2-2-2
# Enable periodic sending of gratuitous ARP packets on VSI-interface 2.
[SwitchC-Vsi-interface2] arp send-gratuitous-arp interval 200000
[SwitchC] vsi vpnb
[SwitchD] reserve-vlan-interface 3000 to 3001 global
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchD-Vsi-interface1] mac-address 1-1-1
[SwitchD-Vsi-interface1] arp send-gratuitous-arp interval 200000
[SwitchD-Vsi-interface1] quit
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] gateway vsi-interface 1
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchD-Vsi-interface2] mac-address 2-2-2
[SwitchD-Vsi-interface2] arp send-gratuitous-arp interval 200000
[SwitchD-Vsi-interface2] quit
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] gateway vsi-interface 2
[SwitchD] ospf 2 router-id 4.4.4.4
[SwitchD-ospf-2] area 0
[SwitchD-ospf-2-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchD-ospf-2-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[SwitchD-ospf-2-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[SwitchD-ospf-2-area-0.0.0.0] quit
[SwitchD-ospf-2] quit
Configuring the VTEP group
Configuring member VTEP Switch C
# Assign Switch C to VTEP group 8.8.8.8, and specify the member IP address of Switch C as 3.3.3.3.
[SwitchC] vtep group 8.8.8.8 member local 3.3.3.3
# Specify the other member VTEP in the VTEP group.
[SwitchC] vtep group 8.8.8.8 member remote 4.4.4.4
Configuring member VTEP Switch D
# Assign Switch D to VTEP group 8.8.8.8, and specify the member IP address of Switch D as 4.4.4.4.
[SwitchD] vtep group 8.8.8.8 member local 4.4.4.4
[SwitchD] vtep group 8.8.8.8 member remote 3.3.3.3
Configuring access layer VTEP Switch A
# Specify VTEP group 8.8.8.8 and its member VTEPs at 3.3.3.3 and 4.4.4.4.
[SwitchA] vtep group 8.8.8.8 member remote 3.3.3.3 4.4.4.4
Configuring access layer VTEP Switch B
[SwitchB] vtep group 8.8.8.8 member remote 3.3.3.3 4.4.4.4
# Verify that the VXLAN tunnel interfaces are in up state. Tunnel 1 and Tunnel 2 are manual tunnels, and Tunnel 3 and Tunnel 4 are VXLAN tunnels automatically established between the VTEP and each VXLAN IP gateway.
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 8.8.8.8
Tunnel2
Current state: UP
Bandwidth: 64 kbps
Tunnel3
Current state: UP
Description: Tunnel3 Interface
Bandwidth: 64 kbps
Tunnel4
Current state: UP
Description: Tunnel4 Interface
Bandwidth: 64 kbps
Tunnel source 1.1.1.1, destination 4.4.4.4
# Verify that the VXLAN tunnels have been assigned to VXLAN 10 and VXLAN 20, and the Ethernet service instances have been mapped to VSIs vpna and vpnb.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
Tunnel3 0x5000003 Up Auto Disabled
Tunnel4 0x5000004 Up Auto Disabled
ACs:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
ACs:
2. Verify the basic VXLAN settings and VXLAN IP gateway settings on VXLAN IP gateways. This example uses Switch C.
# Verify that the VXLAN tunnel interfaces are in up state on Switch C.
Tunnel1
Current state: UP
Bandwidth: 64 kbps
Tunnel source 8.8.8.8, destination 1.1.1.1
Tunnel2
Current state: UP
Bandwidth: 64 kbps
Tunnel source 8.8.8.8, destination 2.2.2.2
# Verify that the VSI interfaces are in up state on Switch C.
Vsi-interface1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 0001-0001-0001
IPv6 packet frame type: Ethernet II, hardware address: 0001-0001-0001
Vsi-interface2
Current state: UP
IP packet frame type: Ethernet II, hardware address: 0002-0002-0002
IPv6 packet frame type: Ethernet II, hardware address: 0002-0002-0002
# Verify that the VXLAN tunnels have been assigned to VXLANs 10 and 20, VSI-interface 1 is the gateway interface for VSI vpna, and VSI-interface 2 is the gateway interface for VSI vpnb.
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 10
Tunnels:
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 20
Tunnels:
Flag:
R:Relay F:FRR
# Verify that Switch D has created the same ARP entries and FIB entries for the VMs as Switch C.
[SwitchD] display arp
[SwitchD] display fib 10.1.1.11
Flag:
R:Relay F:FRR
# Verify that VM 1, VM 2, VM 3, and VM 4 can ping VLAN-interface 100 on Switch C (100.1.1.3) and Switch D (100.1.1.4). (Details not shown.)
Configuration files
· Switch A:
area 0.0.0.0
vlan 20
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
xconnect vsi vpna
xconnect vsi vpnb
port access vlan 20
source 1.1.1.1
destination 8.8.8.8
source 1.1.1.1
destination 2.2.2.2
· Switch B:
area 0.0.0.0
vlan 30
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
xconnect vsi vpna
xconnect vsi vpnb
port access vlan 30
source 2.2.2.2
destination 8.8.8.8
source 2.2.2.2
destination 1.1.1.1
· Switch C:
area 0.0.0.0
area 0.0.0.0
vlan 40
vlan 100
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface LoopBack1
ip address 8.8.8.8 255.255.255.255
ip address 100.1.1.3 255.255.255.0
port access vlan 40
mac-address 0001-0001-0001
mac-address 0002-0002-0002
source 8.8.8.8
destination 1.1.1.1
source 8.8.8.8
destination 2.2.2.2
return
· Switch D:
area 0.0.0.0
area 0.0.0.0
vlan 50
vlan 100
l2vpn enable
vsi vpna
vxlan 10
tunnel 1
tunnel 2
vsi vpnb
vxlan 20
tunnel 1
tunnel 2
interface LoopBack0
interface LoopBack1
interface Vlan-interface50
ip address 50.1.1.4 255.255.255.0
ip address 100.1.1.4 255.255.255.0
port access vlan 50
source 8.8.8.8
destination 1.1.1.1
source 8.8.8.8
destination 2.2.2.2
return
· Switch E:
area 0.0.0.0
vlan 20
vlan 30
vlan 40
vlan 50
interface LoopBack0
ip address 5.5.5.5 255.255.255.255
ip address 20.1.1.5 255.255.255.0
ip address 30.1.1.5 255.255.255.0
ip address 40.1.1.5 255.255.255.0
ip address 50.1.1.5 255.255.255.0
port access vlan 20
port access vlan 30
port access vlan 40
interface Ten-GigabitEthernet1/0/4
port access vlan 50
return
Related documentation
· H3C S12500X-AF & S12500-X & S9800 Switch Series VXLAN Command Reference (R27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series VXLAN Configuration Guide (R27xx)
