- H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Emergency shell configuration
- 09-Automatic configuration
- 10-Device management configuration
- 11-Tcl configuration
- 12-Python configuration
- 13-License management
28-Control Plane-Based QoS Policy Configuration Examples | 52.00 KB |
H3C S12500X-AF & S12500-X & S9800 |
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This chapter provides examples for configuring control plane-based QoS policies.
This document assumes that you have basic knowledge of QoS policies.
Example: Rate limiting ICMP packets
As shown in Figure 1, the device receives a large number of ICMP packets from the Internet. As a result, CPU usage is high, and device performance degrades.
Configure a control plane-based QoS policy to meet the following requirements:
· Rate limit ICMP packets sent to the control plane to 320 kbps.
· Drop excess ICMP packets.
Analysis
To meet the network requirements, you must perform the following tasks:
· Use the if-match command to classify ICMP packets into a class.
· Use the car command to configure the rate limit value for ICMP packets and drop excess packets.
Software versions used
Table 1 shows the software versions used in this configuration example.
Table 1 Product and software version compatibility
Product |
Software version |
S12500X-AF Switch Series |
S12500X-CMW710-R2712 |
S12500-X Switch Series |
S9800 Switch Series |
S9800-CMW710-R2712 |
When you configure a control plane-based QoS policy to rate limit ICMP packets, follow these restrictions and guidelines:
· By default, the predefined QoS policy is applied to the control plane. The predefined QoS policy identifies packet types by system index and uses a default rate limit value for each packet type. To display the predefined QoS policy, use the display qos policy control-plane pre-defined command.
· You can use the if-match control-plane protocol or if-match control-plane protocol-group command to classify protocol packets.
· You can only configure the car command or a combination of the car and accounting packet commands in the behavior associated with the class.
Procedures
# Create a class named ICMP, and use the ICMP protocol as the match criterion.
[Device] traffic classifier ICMP
[Device-classifier-ICMP] if-match control-plane protocol icmp
[Device-classifier-ICMP] quit
# Create a behavior named ICMP, and configure a CAR action for ICMP packets.
[Device] traffic behavior ICMP
[Device-behavior-ICMP] car cir 320
[Device-behavior-ICMP] quit
# Create a QoS policy named ICMP, and associate the class ICMP with the behavior ICMP in the QoS policy.
[Device] qos policy ICMP
[Device-qospolicy-ICMP] classifier ICMP behavior ICMP
[Device-qospolicy-ICMP] quit
# Apply the QoS policy ICMP to the inbound direction of the control plane.
[Device] control-plane slot 1
[Device-cp-slot1] qos apply policy ICMP inbound
[Device-cp-slot1] quit
Verify the configuration
# Verify that the QoS policy is correctly applied to the control plane.
[Device] display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: ICMP
Classifier: ICMP
Operator: AND
Rule(s) :
If-match control-plane protocol icmp
Behavior: ICMP
Committed Access Rate:
CIR 320 (kbps), CBS 20480 (Bytes), EBS 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Green packets : 0 (Packets)
Red packets : 0 (Packets)
Configuration files
traffic classifier ICMP operator and
car cir 320 cbs 20480 ebs 0 green pass red discard yellow pass
qos policy ICMP
Related documentation
· H3C S12500X-AF & S12500-X & S9800 Switch Series ACL and QoS Command Reference (R27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series ACL and QoS Configuration Guide (R27xx)
