- H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Emergency shell configuration
- 09-Automatic configuration
- 10-Device management configuration
- 11-Tcl configuration
- 12-Python configuration
- 13-License management
23-IGMP Configuration Examples | 148.10 KB |
H3C S12500X-AF & S12500-X & S9800 |
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring basic IGMP features
Example: Configuring IGMP static group members
Introduction
This document provides IGMP configuration examples.
This document assumes that you have basic knowledge of IGMP.
As shown in Figure 1:
· OSPF and PIM-DM run on the network.
· VOD streams are sent in multicast. Hosts of different organizations form stub networks N1 and N2.
· IGMPv2 runs between Switch A and N1, and between the other two switches and N2. Switch A acts as the IGMP querier in N1. Switch B acts as the IGMP querier in N2 because it has a lower IP address.
Configure basic IGMP features on the switches to meet the following requirements:
· Hosts in N1 can join any multicast groups.
· Hosts in N2 can join only multicast group 224.1.1.1.
Analysis
To limit the multicast groups that hosts can join, create an IPv4 basic ACL and specify the multicast groups that you want the hosts to join.
Software versions used
Table 1 shows the software versions used in this configuration example.
Table 1 Product and software version compatibility
Product |
Software version |
S12500X-AF Switch Series |
S12500X-CMW710-R2712 |
S12500-X Switch Series |
S9800 Switch Series |
S9800-CMW710-R2712 |
When you configure basic IGMP features, follow these restrictions and guidelines:
· The protocol packets of different IGMP versions are different in structures and types. For IGMP to operate correctly, you must enable the same IGMP version for all switches on the same subnet.
· You must configure the same multicast group policy for all switches on the same subnet.
· By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 1. (Details not shown.)
2. Configure OSPF on the switches in the PIM-DM domain. (Details not shown.)
3. Configure Switch A:
# Enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
# Enable IGMP on the receiver-side interface VLAN-interface 100.
[SwitchA-Vlan-interface100] igmp enable
# Enable PIM-DM on VLAN-interface 101.
[SwitchA-Vlan-interface101] pim dm
4. Configure Switch B:
# Create ACL 2001 to permit IGMP reports for multicast group 224.1.1.1.
[SwitchB] acl basic 2001
[SwitchB-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[SwitchB-acl-ipv4-basic-2001] quit
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Enable IGMP on the receiver-side interface VLAN-interface 200.
[SwitchB-Vlan-interface200] igmp enable
# Configure a multicast group policy that uses ACL 2001.
[SwitchB-Vlan-interface200] igmp group-policy 2001
# Enable PIM-DM on VLAN-interface 201.
[SwitchB] interface vlan-interface 201
[SwitchB-Vlan-interface201] pim dm
[SwitchB-Vlan-interface201] quit
5. Configure Switch C:
[SwitchC] acl basic 2001
[SwitchC-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[SwitchC-acl-ipv4-basic-2001] quit
[SwitchC] multicast routing
[SwitchC-mrib] quit
[SwitchC-Vlan-interface200] igmp group-policy 2001
# Enable PIM-DM on VLAN-interface 202.
[SwitchC] interface vlan-interface 202
[SwitchC-Vlan-interface202] pim dm
[SwitchC-Vlan-interface202] quit
1. Verify that hosts in N1 can join the multicast groups 224.1.1.1 and 224.1.1.2:
# Send IGMP reports from Host A (10.110.1.10) to join the multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
# Display information about IGMP groups that hosts have dynamically joined on Switch A.
[SwitchA] display igmp group
IGMP groups in total: 2.
Vlan-interface100 (10.110.1.1):
IGMP groups reported in total: 2
Group address Last reporter Uptime Expires
224.1.1.1 10.110.1.10 00:02:04 00:01:15
224.1.1.2 10.110.1.10 00:02:00 00:01:19
The output shows that Host A has joined the multicast groups 224.1.1.1 and 224.1.1.2.
2. Verify that hosts in N2 can join only multicast group 224.1.1.1:
# Send IGMP reports from Host C (10.110.2.10) to join the multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
# Display information about IGMP groups that hosts have dynamically joined on Switch B.
[SwitchB] display igmp group
IGMP groups in total: 1
Vlan-interface200(10.110.2.1):
IGMP groups reported in total: 1
224.1.1.1 10.110.2.10 04:36:03 00:01:23
# Display information about IGMP groups that hosts have dynamically joined on Switch C.
[SwitchC] display igmp group
Vlan-interface200(10.110.2.2):
224.1.1.1 10.110.2.10 04:21:03 00:01:13
The output shows that Switch B and Switch C each have IGMP information about only the multicast group, 224.1.1.1. The multicast group policy has taken effect, and hosts in N2 can join only multicast group 224.1.1.1.
Configuration files
· Switch A:
vlan 100 to 101
interface Vlan-interface100
ip address 10.110.1.1 255.255.255.0
igmp enable
interface Vlan-interface101
ip address 10.111.1.1 255.255.255.0
pim dm
port link-mode bridge
port access vlan 100
port access vlan 101
multicast routing
· Switch B:
acl basic 2001
rule 0 permit source 224.1.1.1 0
vlan 200 to 201
interface Vlan-interface200
ip address 10.110.2.1 255.255.255.0
igmp enable
interface Vlan-interface201
ip address 10.111.2.1 255.255.255.0
pim dm
port access vlan 200
port access vlan 201
multicast routing
· Switch C:
acl basic 2001
vlan 200
vlan 202
ip address 10.110.2.2 255.255.255.0
igmp enable
interface Vlan-interface202
ip address 10.111.3.1 255.255.255.0
pim dm
port access vlan 202
multicast routing
As shown in Figure 2:
Configure the switches to meet the following requirements:
· Hosts in N1 can join any multicast groups, and Host A can permanently receive multicast data addressed to multicast group 224.1.1.2.
Analysis
For Host A to permanently receive multicast data addressed to the group 224.1.1.2, configure VLAN-interface 100 on Switch A as a static member of the multicast group.
Table 2 shows the software versions used in this configuration example.
Table 2 Product and software version compatibility
Product |
Software version |
When you configure IGMP static group member ports, follow these restrictions and guidelines:
· The protocol packets of different IGMP versions are different in structures and types. For IGMP to operate correctly, specify the same IGMP version for all switches on the same subnet.
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 2. (Details not shown.)
[SwitchA-mrib] quit
# Configure VLAN-interface 100 as a static member of multicast group 224.1.1.2.
[SwitchA-Vlan-interface100] igmp static-group 224.1.1.2
[SwitchB-mrib] quit
[SwitchC-mrib] quit
# Enable IGMP on VLAN-interface 200.
The output shows that Host A has dynamically joined the multicast groups 224.1.1.1 and 224.1.1.2.
# Display information about IGMP groups that hosts have statically joined on Switch A.
[SwitchA] display igmp group static
Entries in total: 1
Group address Source address Interface Expires
224.1.1.2 0.0.0.0 Vlan100 Never
The output shows that Host A has statically joined multicast group 224.1.1.1 through VLAN-interface 100.
# Send IGMP reports from Host C (10.110.2.10) to join multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
The output shows that Switch B and Switch C each have information only about multicast group 224.1.1.1. The multicast group policy has taken effect, and hosts in N2 can join only multicast group 224.1.1.1.
Configuration files
· Switch A:
vlan 100 to 101
igmp enable
pim dm
multicast routing
· Switch B:
acl basic 2001
vlan 200 to 201
igmp enable
pim dm
multicast routing
· Switch C:
acl basic 2001
vlan 200
vlan 202
igmp enable
pim dm
multicast routing
Example: Configuring IGMP SSM mappings
As shown in Figure 3:
· The SSM group range for the PIM-SSM domain is 232.1.1.0/24.
· Switch A and Switch B in the PIM-SSM domain run IGMPv3.
· Host A in N1 and Host B in N2 run IGMPv2, and they do not support IGMPv3. The other hosts in N1 and N2 run IGMPv3.
Configure IGMP SSM mappings on Switch A and Switch B to meet the following requirements:
· Hosts in N1 receive multicast data only from Source 1.
· Hosts in N2 receive multicast data only from Source 2.
Table 3 shows the software versions used in this configuration example.
Table 3 Product and software version compatibility
Product |
Software version |
Procedures
1. Assign an IP address and subnet mask to each interface, as shown in Figure 3. (Details not shown.)
2. Configure OSPF on the switches in the PIM-SSM domain. (Details not shown.)
3. Enable IP multicast routing and enable PIM-SM:
# On Switch A, enable IP multicast routing, and enable PIM-SM on VLAN-interface 200.
[SwitchA-mrib] quit
[SwitchA-Vlan-interface200] pim sm
# Configure Switch B in the same way Switch A is configured. (Details not shown.)
# On Router C, enable IP multicast routing, and enable PIM-SM on each interface.
[SwitchC-mrib] quit
[SwitchC-Vlan-interface100] pim sm
[SwitchC-Vlan-interface200] pim sm
[SwitchC-Vlan-interface300] pim sm
[SwitchC-Vlan-interface300] quit
4. On Switch C, configure VLAN-interface 200 as a C-BSR and a C-RP:
[SwitchC] pim
[SwitchC-pim] c-bsr 192.168.1.1
[SwitchC-pim] c-rp 192.168.1.1
[SwitchC-pim] quit
5. Configure IGMPv3 on the receiver-side interfaces:
# On Switch A, enable IGMP, and specify IGMP version 3 on VLAN-interface 201.
[SwitchA] interface vlan-interface201
[SwitchA-Vlan-interface201] igmp enable
[SwitchA-Vlan-interface201] igmp version 3
[SwitchA-Vlan-interface201] quit
6. Configure the SSM group range:
# On Switch A, configure the SSM group range as 232.1.1.0/24.
[SwitchA] acl basic 2000
[SwitchA-acl-ipv4-basic-2000] rule permit source 232.1.1.0 0.0.0.255
[SwitchA] pim
[SwitchA-pim] ssm-policy 2000
[SwitchA-pim] quit
# Configure Switch B and Switch C in the same way Switch A is configured. (Details not shown.)
7. Configure IGMP SSM mappings:
# On Switch A, configure an IGMP SSM mapping with multicast source 10.110.5.100 and multicast group range 232.1.1.0/24 specified in ACL 2000.
[SwitchA] igmp
[SwitchA-igmp] ssm-mapping 10.110.5.100 2000
[SwitchA-igmp] quit
# On Switch B, configure an IGMP SSM mapping with multicast source 10.110.5.101 and multicast group range 232.1.1.0/24 specified in ACL 2000.
[SwitchB] igmp
[SwitchB-igmp] ssm-mapping 10.110.5.101 2000
[SwitchB-igmp] quit
# Send IGMPv2 reports from Host A and Host C to join multicast group 232.1.1.1. (Details not shown.)
# Send multicast data from Source 1 and Source 2 to multicast group 232.1.1.1. (Details not shown.)
# Display IGMP SSM mappings for multicast group 232.1.1.1 on Switch A.
[SwitchA] display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
10.110.5.100
The output shows that multicast group 232.1.1.1 is associated with Source 1 (10.110.5.100). Switch A will translate (0.0.0.0, 232.1.1.1) in IGMPv2 reports to (10.110.5.100, 232.1.1.1).
# Display the PIM routing table on Switch A.
[SwitchA] display pim routing-table
Protocol: pim-ssm, Flag:
UpTime: 00:13:25
Upstream interface: Vlan-interface200
Upstream neighbor: 192.168.1.1
RPF prime neighbor: 192.168.1.1
1: Vlan-interface201
Protocol: igmp, UpTime: 02:54:43, Expires: 00:02:47
The output shows that Switch A has the (10.110.5.100, 232.1.1.1) entry.
# Display IGMP SSM mappings for multicast group 232.1.1.1 on Switch B.
[SwitchB] display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
10.110.5.101
The output shows that multicast group 232.1.1.1 is associated with Source 2 (10.110.5.101). Switch B will translate (0.0.0.0, 232.1.1.1) in IGMPv2 reports to (10.101.5.101, 232.1.1.1).
# Display the PIM routing table on Switch B.
[SwitchB] display pim routing-table
(10.110.5.101, 232.1.1.1)
UpTime: 00:12:16
Upstream interface: Vlan-interface300
Upstream neighbor: 192.168.2.1
RPF prime neighbor: 192.168.2.1
1: Vlan-interface301
The output shows that Switch B has the (10.110.5.101, 232.1.1.1) entry.
Configuration files
· Switch A:
pim sm
igmp enable
igmp version 3
multicast routing
pim
ssm-policy 2000
igmp
acl basic 2000
rule 0 permit source 232.1.1.0 0.0.0.255
· Switch B:
interface Vlan-interface300
pim sm
interface Vlan-interface301
igmp enable
igmp version 3
multicast routing
pim
ssm-policy 2000
igmp
acl basic 2000
· Switch C:
pim sm
pim sm
pim sm
multicast routing
pim
c-bsr 192.168.1.1
c-rp 192.168.1.1
Related documentation
· H3C S12500X-AF & S12500-X & S9800 Switch Series IP Multicast Command Reference (Release 27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series IP Multicast Configuration Guide (Release 27xx)
