- H3C S12500X-AF & S12500-X & S9800 Switch Series Configuration Examples-Release 27xx-6W100
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Emergency shell configuration
- 09-Automatic configuration
- 10-Device management configuration
- 11-Tcl configuration
- 12-Python configuration
- 13-License management
14-GRE with OSPF Configuration Examples | 105.46 KB |
H3C S12500X-AF & S12500-X & S9800 |
S12500X-AF Switch Series
S12500-X Switch Series
S9800 Switch Series
Document version: 6W100-20190628
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring GRE with OSPF· 1
Restrictions and guidelines· 2
Verifying the configuration· 5
Introduction
This document provides GRE with OSPF configuration examples.
This document assumes that you have basic knowledge of GRE and OSPF.
As shown in Figure 1, Device A is the gateway of the headquarters. Device B and Device C are the gateways of Branch 1 and Branch 2, respectively. The gateways have obtained public IP addresses from an ISP and can communicate with one another. Configure GRE with OSPF to meet the following requirements:
· The headquarters and the branches communicate with one another through the GRE tunnels established between the headquarters and the branches.
· The gateways learn the routes reaching the destination networks through the tunnel interfaces.
Device | Interface | IP address | Device | Interface | IP address |
Device A | Vlan-int10 | 191.2.1.1/24 | Device B | Vlan-int10 | 191.3.1.1/24 |
| Vlan-int20 | 10.1.1.1/24 |
| Vlan-int20 | 10.7.1.1/24 |
| Tunnel1 | 10.5.1.1/24 |
| Tunnel1 | 10.5.1.2/24 |
| Tunnel2 | 10.6.1.1/24 |
Device C | Vlan-int10 | 191.4.1.1/24 |
| Vlan-int20 | 10.8.1.1/24 |
| Tunnel2 | 10.6.1.2/24 |
Software versions used
Table 2 shows the software versions used in this configuration example.
Table 2 Product and software version compatibility
Product | Software version |
S12500X-AF Switch Series | S12500X-CMW710-R2712 |
S12500-X Switch Series | S12500X-CMW710-R2712 |
S9800 Switch Series | S9800-CMW710-R2712 |
Encapsulated packets cannot be forwarded on Layer 3 according to the destination IP addresses and routing tables. You must create a service loopback group of the tunnel service type to loop encapsulated packets back to the forwarding module for Layer 3 forwarding.
By default, interfaces on the devices are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Before configuring GRE and OSPF, configure an IPv4 routing protocol on the gateways so that they can reach one another. (Details not shown.)
Configuring Device A
# Configure VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceA-vlan10] quit
[DeviceA-vlan-interface10] ip address 191.2.1.1 255.255.255.0
[DeviceA-vlan-interface10] quit
# Configure global resources of VLAN-interfaces 3001 and 3002. (This step is required for creating a tunnel interface on an S12500-X or S9800 switch or on an F card of an S12500X-AF switch.)
[DeviceA] reserve-vlan-interface 3001 to 3002 global
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
# Create service loopback group 1, and specify its service type as Tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Add Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[DeviceA] interface Ten-GigabitEthernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceA-Ten-GigabitEthernet1/0/3] quit
# Create a tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 1 mode gre
# Configure an IP address for the tunnel interface Tunnel 1.
[DeviceA-Tunnel1] ip address 10.5.1.1 24
# Configure the source interface of the tunnel interface Tunnel 1 as VLAN-interface 10.
[DeviceA-Tunnel1] source vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 1 as the IP address of VLAN-interface 10 on Device B.
[DeviceA-Tunnel1] destination 191.3.1.1
[DeviceA-Tunnel1] quit
# Create a tunnel interface Tunnel 2, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 2 mode gre
# Configure an IP address for the tunnel interface Tunnel 2.
[DeviceA-Tunnel2] ip address 10.6.1.1 24
# Configure the source interface of the tunnel interface Tunnel 2 as VLAN-interface 10.
[DeviceA-Tunnel2] source vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 2 as the IP address of VLAN-interface 10 on Device C.
[DeviceA-Tunnel2] destination 191.4.1.1
[DeviceA-Tunnel2] quit
# Configure the OSPF router ID as 10.6.1.1.
[DeviceA] router-id 10.6.1.1
# Enable OSPF process 1.
[DeviceA] ospf 1
# Create OSPF area 0.
[DeviceA-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.1.1.0/24, 10.5.1.0/24, or 10.6.1.0/24 in area 0.
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
Configuring Device B
[DeviceB] vlan 10
[DeviceB-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-vlan-interface10] ip address 191.3.1.1 255.255.255.0
[DeviceB-vlan-interface10] quit
[DeviceB] reserve-vlan-interface 3001 to 3002 global
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface Ten-GigabitEthernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceB-Ten-GigabitEthernet1/0/3] quit
[DeviceB] interface tunnel 1 mode gre
[DeviceB-Tunnel1] ip address 10.5.1.2 24
[DeviceB-Tunnel1] source Vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 1 as the IP address of VLAN-interface 10 on Device A.
[DeviceB-Tunnel1] destination 191.2.1.1
[DeviceB-Tunnel1] quit
# Configure the OSPF router ID as 10.7.1.1.
[DeviceB] router-id 10.7.1.1
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.7.1.0/24 or 10.5.1.0/24 in area 0.
[DeviceB-ospf-1-area-0.0.0.0] network 10.7.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port Ten-GigabitEthernet 1/0/1
[DeviceC-vlan10] quit
[DeviceC] interface Vlan-interface 10
[DeviceC-Vlan-interface10] ip address 191.4.1.1 255.255.255.0
[DeviceC-Vlan-interface10] quit
[DeviceC] reserve-vlan-interface 3001 to 3002 global
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface Ten-GigabitEthernet 1/0/3
[DeviceC-Ten-GigabitEthernet1/0/3] port service-loopback group 1
[DeviceC-Ten-GigabitEthernet1/0/3] quit
[DeviceC] interface tunnel 2 mode gre
[DeviceC-Tunnel2] ip address 10.6.1.2 24
[DeviceC-Tunnel2] source Vlan-interface 10
# Configure the destination address of the tunnel interface Tunnel 2 as the IP address of VLAN-interface 10 on Device A.
[DeviceC-Tunnel2] destination 191.2.1.1
[DeviceC-Tunnel2] quit
# Configure the OSPF router ID as 10.8.1.1.
[DeviceC] router-id 10.8.1.1
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.8.1.0/24 or 10.6.1.0/24 in area 0.
[DeviceC-ospf-1-area-0.0.0.0] network 10.8.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
# Verify that Host A can ping Host B successfully.
C:\> ping 10.7.1.2
Pinging 10.7.1.2 with 32 bytes of data:
Reply from 10.7.1.2: bytes=32 time=19ms TTL=253
Reply from 10.7.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.7.1.2:
Minimum = 0ms, Maximum = 19ms, Average = 4ms
# Verify that Host A can ping Host C successfully.
C:\> ping 10.8.1.2
Pinging 10.8.1.2 with 32 bytes of data:
Reply from 10.8.1.2: bytes=32 time=18ms TTL=253
Reply from 10.8.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.8.1.2:
# Verify that Host B can ping Host C successfully.
C:\> ping 10.8.1.2
Reply from 10.8.1.2: bytes=32 time=20ms TTL=251
Reply from 10.8.1.2: bytes=32 time<1ms TTL=251
Configuration files
· Device A
vlan 10
vlan 20
interface Vlan-interface10
interface Vlan-interface20
port link-mode bridge
port access vlan 10
port access vlan 20
interface Tunnel1 mode gre
source vlan-interface10
ip address 10.5.1.1 255.255.255.0
interface Tunnel2 mode gre
ip address 10.6.1.1 255.255.255.0
ospf 1
area 0.0.0.0
· Device B
vlan 10
vlan 20
ip address 10.7.1.1 255.255.255.0
port access vlan 10
port access vlan 20
source Vlan-interface10
ip address 10.5.1.2 255.255.255.0
ospf 1
area 0.0.0.0
· Device C
vlan 10
vlan 20
ip address 10.8.1.1 255.255.255.0
port access vlan 10
port access vlan 20
ip address 10.6.1.2 255.255.255.0
ospf 1
area 0.0.0.0
Related documentation
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3—IP Routing Command Reference (R27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3—IP Routing Configuration Guide (R27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3—IP Services Command Reference (R27xx)
· H3C S12500X-AF & S12500-X & S9800 Switch Series Layer 3—IP Services Configuration Guide (R27xx)
