- 13-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-SNMP commands
- 05-RMON commands
- 06-Event MIB commands
- 07-NETCONF commands
- 08-CWMP commands
- 09-EAA commands
- 10-Process monitoring and maintenance commands
- 11-Sampler commands
- 12-Mirroring commands
- 13-NetStream commands
- 14-IPv6 NetStream commands
- 15-sFlow commands
- 16-Fast log output commands
- 17-Flow log commands
- 18-Information center commands
- 19-GOLD commands
- 20-Packet capture commands
- 21-VNF connection commands
| 21-VNF connection commands | 51.99 KB |
display vnfm information
Use display vnfm information to display VNF connection information.
In standalone mode:
In IRF mode:
display vnfm information [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command displays connection information about the master VNF.
# Display VNF connection information. In this example, the application scenario is VSG and a Layer 3 connection is already established between a VNF and the VNFM.
<Sysname> display vnfm information
Slot 0:Current connect status: ONLINE
Connect mode: L3
VNFM IP: 192.168.120.44
UDP port: 2093
Cluster mode: VSG
Cluster IP: 10.2.3.1
Borrowed interface: LoopBack1
# Display VNF connection information. In this example, the application scenario is VSG-vPCpeer and a Layer 3 connection is configured between a VNF and the VNFM.
Slot 0: Current connection status: OFFLINE
Connection mode: L3
VNFM IP: 192.168.100.1
UDP port: 2093
Cluster mode: VSG-VPCPEER
Cluster ID: 1
VSG IP: 192.168.120.2
Backup device
Current connection status |
Status of the connection: · ONLINE—The connection is already established. · OFFLINE—The connection is not established yet. |
Connection mode |
Connection mode: · Alone—No VNF connection is configured for the VNF. · L2—Layer 2 connection. · L3—Layer 3 connection. |
vnfm interface
Use vnfm interface to configure a Layer 2 VNF connection.
Use undo vnfm to delete a VNF connection.
vnfm interface interface-type interface-number
undo vnfm
No Layer 2 VNF connection exists.
interface-type interface-number: Specifies the interface to be used as the source interface of the connection.
(In standalone mode.) If you execute this command multiple times, the most recent configuration takes effect.
(In IRF mode.) To configure a connection for a member VNF, specify an interface on the member VNF as the source interface. If you execute this command multiple times and specify interfaces on the same member VNF, the most recent configuration takes effect.
A VNF can connect to a VNFM in only one mode at the same time. The available connection modes depend on the VNFM. VNFM2.0 supports only Layer 2 mode. Tencent VNFM supports only Layer 3 mode.
# Configure the VNF to use GigabitEthernet 1/0/1 to establish a Layer 2 connection to the VNFM.
[Sysname] vnfm interface GigabitEthernet 1/0/1
vnfm
Use vnfm to configure a Layer 3 VNF connection.
In standalone mode:
vnfm ip-address [ udp-port udp-number ] [ source-ip ip-address ] [ vpn-instance vpn-instance-name ]
undo vnfm
In IRF mode:
vnfm ip-address [ udp-port udp-number ] [ source-ip ip-address ] [ vpn-instance vpn-instance-name ] [ slot slot-number ]
undo vnfm
No Layer 3 VNF connection exists.
ip-address: Specifies the IPv4 address of the VNFM.
udp-port udp-number: Specifies the UDP port number of the VNFM, in the range of 1 to 65535 The default UDP port number is 2093.
source-ip ip-address: Specifies the IP address to be used as the source IP address of the connection. If you do not specify the source IP address, the system randomly selects the IP address of an interface that can communicate with the VNFM as the source IP address.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the interface that owns the source IP address belongs. The vpn-instance-name argument is a case-sensitive string to 1 to 31 characters. If the interface belongs to the public network, do not specify this option.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, you configure a connection for the master VNF. (In IRF mode.)
(In IRF mode.) If you specify the slot slot-number option, you must configure a Layer 3 VNF connection for each IRF member device.
# Configure the VNF to establish a Layer 3 connection to VNFM 192.168.100.1. The VNFM is using the default UDP port (2093).
[Sysname] vnfm 192.168.100.1
vnf cluster-mode
Use vnf cluster-mode to set the application scenario to VSG or VSG-NAT and set the relevant parameters.
Use undo vnf cluster-mode to restore the default.
vnf cluster-mode [ vsg | vsg-nat ] cluster-ip ip-address tunnel unnumbered interface interface-type interface-number
No IRF fabric operating parameters are set.
vsg: Sets the application scenario to VSG.
vsg-nat: Sets the application scenario to NAT-capable VSG.
cluster-ip ip-address: Specifies the IP address of the IRF fabric to which the VNF belongs.
tunnel unnumbered interface interface-type interface-number: Specifies the interface whose IP address is to be used to establish a tunnel.
Before executing this command, you must use the vnfm command to configure a Layer 3 VNF connection.
The following command overwrites each other:
· vnf cluster-mode vsg.
· vnf cluster-mode vsg-nat.
· vnf cluster-mode vsg-vpcpeer.
· vnf cluster-mode string parameter string.
To change the settings for the parameters in VSG or VSG-NAT scenario, you must perform the following tasks:
1. Log in to the VNFM configuration management platform.
2. Remove information about the VNF.
3. Execute this command again, specifying the new settings for the command.
# Set the application scenario to VSG and set the relevant parameters.
[Sysname] vnf cluster-mode vsg cluster-ip 10.2.0.1 tunnel unnumbered interface LoopBack 1
vnfm
Use vnf cluster-mode vsg-vpcpeer to set the application scenario to VSG-vPCpeer and set the relevant parameters.
vnf cluster-mode vsg-vpcpeer cluster-id string tunnel unnumbered interface interface-type interface-number vsg-ip ip-address [ backup ]
cluster-id string: Specifies the IP address of the IRF fabric to which the VNF belongs, in the range of 1 to 64.
vsg-ip ip-address: Specifies the IP address for the VNF to use when the VNF acts as a VSG.
backup: Specifies the VNF as a backup device in the IRF fabric.
To change the settings for the parameters in VSG-vPCpeer scenario, you must perform the following tasks:
# Set the application scenario to VSG-vPCpeer and set the relevant parameters.
[Sysname] vnf cluster-mode vsg-vpcpeer cluster-id 1 tunnel unnumbered interface Loopback 1 vsg-ip 192.168.120.2
vnfm
vnf cluster-mode parameter
Use vnf cluster-mode string parameter string to set the application scenario to a customized scenario and set the relevant parameters.
to set IRF fabric operating parameters in a customized application scenario.
string: Specifies the name of the customized application scenario.
parameter string: Sets the parameter for the customized application scenario.
To use a VNF in a customized application scenario, use this command to specify the application scenario and set the relevant parameters. Make sure the configuration commands required for the scenario have been configured on the VNFM.
To change the settings for the parameters in a customized scenario, you must perform the following tasks:
# Set the application scenario to a customized scenario and set the relevant parameters.
[Sysname] vnf cluster-mode vsg-vpcpeer parameter cluster-id 1 tunnel unnumbered interface Loopback 1 vsg-ip 192.168.120.2
vnfm
