13-Network Management and Monitoring Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R0618-5W20013-Network Management and Monitoring Command Reference
17-Flow log commands
17-Flow log commands 64.21 KB
Flow log commands
display userlog export
Use display userlog export to display flow log configuration and statistics.
# Display flow log configuration and statistics.
<Sysname> display userlog export
Flow:
  Export flow log as UDP Packet.
  Version: 3.0
  Source ipv4 address: 2.2.2.2
  Source ipv6 address:
  Log load balance function: Disabled
  Local time stamp: Disabled
  Number of log hosts: 2
  Log host 1:
    Host/Port: 1.2.3.6/2000
    Total logs/UDP packets exported: 112/87
  Log host 2:
    VPN instance:abc
    Host/Port:1.1.1.1/2000
    Total logs/UDP packets exported: 6553665536/409597846
Flow
Flow log configuration and statistics.
Flow log entries were sent to log hosts in UDP.
Version
Flow log feature version.
Source ipv4/ipv6 address
Source IP address of the flow log packets.
Load balancing status for flow log packets:
·     Enabled—Flow log packets are distributed among available log hosts.
·     Disabled—Every flow log packet is copied and sent to all available log hosts.
Local time stamp
Whether the use of the local time in the flow log timestamp is enabled or disabled.
Number of log hosts
Total number of log hosts.
Log host
Information about the log host.
VPN instance
VPN instance to which the log host belongs.
Host/port
IP address and port number of the log host.
Total logs
Total number of flow log entries exported to the log hosts.
Total number of UDP packets used to export the flow log entries.
A UDP packet can contain multiple flow log entries.
userlog flow export
display userlog host-group
Use display userlog host-group to display flow log host group information.
display userlog host-group [ ipv6 ] [ host-group-name ]
ipv6: Specifies an IPv6 flow log host group. Do not configure this keyword if you want to specify an IPv4 flow log host group.
host-group-name: Specify a flow log host group by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a log host group, this command displays information about all log host groups.
# Display information about IPv4 flow log host group test.
<Sysname> display userlog host-group test
Userlog host-group test:
  ACL number: 2000
  Flow log host numbers: 1
    Log host 1:
      VPN-instance: test
      Host/port: 1.1.1.2/2000
# Display information about all IPv4 flow log host groups.
There are 2 IPv4 host groups.
  ACL number: 2000
    Log host 1:
      VPN-instance: test
      Host/Port: 1.2.3.6/0
Userlog host-group test2:
  ACL name: test
    Log host 1:
      Host/Port: 1.1.1.1/0
Information about a flow log host group.
ACL number/ACL name
ACL used by the log host group to match flow log entries.
Number of flow log hosts in the group.
Log host
Information about a flow log host.
VPN-instance
This field is not displayed if no VPN instance is specified for the log host.
Host/Port
userlog host-group
userlog host-group host flow
reset userlog flow export
Use reset userlog flow export to clear flow log statistics.
# Clear flow log statistics.
<Sysname> reset userlog flow export
userlog flow export
userlog flow export host
Use userlog flow export host to specify a log host to receive flow log entries.
Use undo userlog flow export host to remove a log host.
userlog flow export [ vpn-instance vpn-instance-name ] host { hostname | ipv4-address | ipv6 ipv6-address } port udp-port
undo userlog flow export [ vpn-instance vpn-instance-name ] host { hostname | ipv4-address | ipv6 ipv6-address }
No log hosts are specified.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
hostname: Specifies a log host by its name, a case-insensitive string of 1 to 253 characters. The host name can contain letters, digits, and special characters including hyphen (-), underscore (_), and dot (.).
ipv4-address: Specifies a log host by its IPv4 address. The address must be a valid unicast address and cannot be a loopback address.
ipv6 ipv6-address: Specifies a log host by its IPv6 address.
port udp-port: Specifies the UDP port number of the log host, in the range of 1 to 65535. As a best practice, use UDP port numbers in the range 1025 to 65535 to avoid collision with well-known UDP port numbers.
# Export flow log entries to UDP port 2000 on the log host at 1.2.3.6.
[Sysname] userlog flow export host 1.2.3.6 port 2000
userlog flow export load-balancing
Use userlog flow export load-balancing to enable load balancing for flow log entries.
Use undo userlog flow export load-balancing to restore the default.
Load balancing is disabled. The device sends a copy of each flow log entry to all available log hosts.
In load balancing mode, flow log entries are distributed among log hosts based on the source IP addresses (before NAT) that are recorded in the entries. The flow log entries generated for the same source IP address are sent to the same log host. If a log host goes down, the flow logs sent to it will be lost.
# Enable load balancing for flow logging.
[Sysname] userlog flow export load-balancing
userlog flow export source-ip
Use userlog flow export source-ip to specify a source IP address for flow log packets.
Use undo userlog flow export source-ip to restore the default.
userlog flow export source-ip { ipv4-address | ipv6 ipv6-address }
undo userlog flow export source-ip [ ipv6 ]
The source IP address of flow log packets is the IP address of their outgoing interface.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address.
# Specify 1.2.1.2 as the source IP address for flow log packets.
[Sysname] userlog flow export source-ip 1.2.1.2
userlog flow export timestamp localtime
Use userlog flow export timestamp localtime to configure the device to use the local time in the timestamp of flow logs.
Use undo userlog flow export timestamp localtime to restore the default.
The device uses the UTC time in the timestamp of flow logs.
The device uses either the local time or the UTC time in the timestamp of flow logs.
·     UTC time—Standard https://en.wikipedia.org/wiki/Greenwich_Mean_Time (GMT).
·     Local time—Standard GMT plus or minus the time zone offset.
The time zone offset can be configured by using the clock timezone command. For more information, see Fundamentals Command Reference.
# Configure the device to use the local time in the timestamp of flow logs.
[Sysname] userlog flow export timestamp localtime
userlog flow export version
Use userlog flow export version to set the flow log version.
Use undo userlog flow export version to restore the default.
userlog flow export version version-number
The flow log version is 1.0.
version-number: Specifies a flow log version. Available options are 1, 3, and 5, which represent version 1.0, version 3.0, and version 5.0.
# Set the flow log version to 3.0.
[Sysname] userlog flow export version 3
userlog flow syslog
Use userlog flow syslog to specify the information center as the destination for flow log export.
Use undo userlog flow syslog to restore the default.
userlog flow syslog
Flow log entries are not exported.
You can export flow log entries to log hosts or the information center, but not both. If both methods are configured, the system exports flow log entries to the information center.
Flow log entries are converted to the syslog format when they are exported to the information center. Their severity level is informational. With the information center, you can specify multiple log output destinations, including the console, log host, and log file.
Log entries in ASCII format are human readable. However, the log data volume is higher in ASCII format than in binary format.
# Specify the information center as the destination for flow log export.
[Sysname] userlog flow syslog
userlog host-group
Use userlog host-group to create a flow log host group and enter its view, or enter the view of an existing flow log host group.
Use undo userlog host-group to delete a flow log host group.
userlog host-group [ ipv6 ] host-group-name acl { name acl-name | number acl-number }
undo userlog host-group [ ipv6 ] host-group-name
No flow log host groups exist.
ipv6: Creates an IPv6 flow log host group. Do not configure this keyword if you want to create an IPv4 flow log host group.
host-group-name: Specify a name for the flow log host group, a case-sensitive string of 1 to 63 characters.
acl: Specify an ACL to match the flow log entries to be sent to the flow log host group.
name acl-name: Specifies the ACL name, a case-insensitive string of 1 to 63 characters. The ACL name must start with a letter and cannot be all.
number acl-number: Specifies the ACL number, in the range of 2000 to 3999.
The flow log host group feature enables the device to send specific flow logs to specific group of log hosts. This facilitates log filtering and reduces the log sending and processing workload of the device.
A flow log host group uses an ACL to match the flow logs to be sent to it. Make sure the ACL exists and the ACL rules can identify the designated flow logs.
A flow log matches a log host group if it matches the group's ACL, and it is sent only to the log hosts in the matching group.
If a flow log matches multiple log host groups, the device sends the log to the group that comes first in alphabetical order of the matching group names.
If a flow log does not match any log host groups, the device ignores the log host group configuration and sends the log to all configured log hosts.
# Create an IPv4 flow log host group named test and specify ACL 2000 for it.
[Sysname] userlog host-group test acl number 2000
[Sysname-userlog-host-group-test]
Use userlog host-group host flow to assign a log host to a flow log host group.
Use undo userlog host-group host flow to remove a log host from a flow log host group.
IPv4 flow log host group view:
userlog host-group [ vpn-instance vpn-instance-name ] host flow { hostname | ipv4-address }
undo userlog host-group [ vpn-instace vpn-instance-name ] host flow { hostname | ipv4-address }
IPv6 flow log host group view:
userlog host-group [ vpn-instance vpn-instance-name ] host flow ipv6 { hostname | ipv6-address }
undo userlog host-group [ vpn-instance vpn-instance-name ] host flow ipv6 { hostname | ipv6-address }
No log hosts exist in a flow log host group.
hostname: Specifies a log host by its name, a case-insensitive string of 1 to 253 characters. The host name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
ipv4-address: Specifies a log host by its IPv4 address. The address must be a valid IPv4 unicast address and cannot be a loopback address.
ipv6 ipv6-address: Specifies a log host by its IPv6 address. The address must be a valid IPv6 unicast address and cannot be a loopback address or all zeros.
A flow log host group can contain multiple log hosts, and a log host can be assigned to multiple flow log host groups.
Before you assign a log host to a flow log host group, make sure the log host has been configured on the device by using userlog flow export host the command.
# Assign a log host to flow log host group test.
[Sysname-userlog-host-group-test] userlog host-group host flow 1.2.3.6
userlog host-group
