08-Network Management and Monitoring Command Reference
HomeSupportWirelessWX3000E Series Wireless SwitchesReference GuidesCommand ReferencesH3C WX3000E Series Wireless Switches Switching Engine Command References(R3507P26)-6W10208-Network Management and Monitoring Command Reference
07-Mirroring Commands
07-Mirroring Commands 92.84 KB
display mirroring-group
display mirroring-group { group-id | all | local } [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
group-id: Number of the mirroring group to be displayed. The value is in the range of 1 to 5.
all: Displays all mirroring groups.
local: Displays local mirroring groups.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see the Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, which is a case sensitive string of 1 to 256 characters.
Use the display mirroring-group command to display information about the specified mirroring group or groups.
The output varies by mirroring group types and is sorted by mirroring group numbers.
# Display information about all the mirroring groups.
<Sysname> display mirroring-group all
mirroring-group 1:
    type: local
    status: active
    mirroring port:
        GigabitEthernet1/0/1  both
    monitor port: GigabitEthernet1/0/2
Table 1 Output description
mirroring-group
type
Type of the mirroring group
status
Status of the mirroring group, which can be active or inactive
mirroring port
Source port
monitor port
Destination port
mirroring-group
mirroring-group group-id local
undo mirroring-group { group-id | all | local  }
View
Default level
2: System level
group-id: Specifies the number of the mirroring group to be created or removed. The value is in the range of 1 to 5.
all: Removes all mirroring groups by using the undo command.
local: Creates a local mirroring group or removes all local mirroring groups with the undo command.
Use the mirroring-group command to create a mirroring group.
Use the undo mirroring-group command to remove the specified mirroring group or groups.
By default, no mirroring group exists on a device.
# Create a local mirroring group numbered 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-port
mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound }
View
Default level
2: System level
group-id: Number of a local group. The mirroring group specified by the group-id argument must already exist. The value is in the range of 1 to 5.
mirroring-port-list: A list of source ports/port ranges to be assigned to or removed from the mirroring group specified by group-id. You can specify up to eight single ports, port ranges, or combinations of both for the list.
both: Mirrors both inbound and outbound packets on the specified port(s).
inbound: Mirrors only inbound packets on the specified port(s).
outbound: Mirrors only outbound packets on the specified port(s).
Use the mirroring-group mirroring-port command to assign ports to a local group as source ports.
Use the undo mirroring-group mirroring-port command to remove source ports from the mirroring group.
By default, no source port is configured for any mirroring group.
When removing a source port from a mirroring group, make sure the traffic direction you specified in the undo mirroring-group mirroring-port command matches the actual monitored direction specified earlier in the mirroring-group mirroring-port command.
Related commands: mirroring-group.
# Create local mirroring group 1, configure GigabitEthernet 1/0/1 as a source port of the mirroring group, and specify that the mirroring group monitor the bidirectional traffic of the port.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
# Remove GigabitEthernet 1/0/1 from mirroring group 1.
[Sysname] undo mirroring-group 1 mirroring-port gigabitethernet 1/0/1 both
mirroring-group monitor-port
mirroring-group group-id monitor-port monitor-port-id
undo mirroring-group group-id monitor-port monitor-port-id
View
Default level
2: System level
group-id: Number of a local group. The mirroring group specified by group-id must already exist. The value is in the range of 1 to 5.
monitor-port-id: Port to be assigned to the specified mirroring group as the monitor port. The argument takes the form of interface-type interface-number, where interface-type specifies the port type and interface-number specifies the port number.
Use the mirroring-group monitor-port command to assign a port to a local group as the monitor port.
Use the undo mirroring-group monitor-port command to remove the monitor port from the local group.
By default, no monitor port is configured for a mirroring group.
You cannot assign a source port in an existing mirroring group to another mirroring group as the monitor port.
# Create local mirroring group 1, and configure port GigabitEthernet 1/0/1 as its monitor port.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0/1
mirroring-port
[ mirroring-group group-id ] mirroring-port { inbound | outbound | both }
undo [ mirroring-group group-id ] mirroring-port { inbound | outbound | both }
View
Interface view
Default level
2: System level
mirroring-group group-id: Specifies a local group by its number. The mirroring group specified by group-id must already exist. The value is in the range of 1 to 5, and the default value is 1.
both: Mirrors both inbound and outbound packets on the current port.
inbound: Mirrors only inbound packets on the current port.
outbound: Mirrors only outbound packets on the current port.
Use the mirroring-port command to assign the current port to a local group as a source port.
Use the undo mirroring-port command to remove the current port from the mirroring group.
By default, a port does not serve as a source port for any mirroring group.
When removing a source port from a mirroring group, make sure the traffic direction you specified in the undo mirroring-group command matches the actual monitored direction of the port specified earlier in the mirroring-port command.
[Sysname-GigabitEthernet1/0/1] mirroring-group 1 mirroring-port both
monitor-port
[ mirroring-group group-id ] monitor-port
undo [ mirroring-group group-id ] monitor-port
View
Interface view
Default level
2: System level
Use the monitor-port command to assign the current port to a local group as the monitor port.
Use the undo monitor-port command to remove the current port from the mirroring group.
By default, a port does not serve any mirroring group as the monitor port.
You cannot configure a source port of an existing mirroring group as a monitor port.
# Create local mirroring group 1, and configure GigabitEthernet 1/0/1 as its monitor port.
[Sysname-GigabitEthernet1/0/1] monitor-port
