09-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10709-Network Management and Monitoring Command Reference
03-NTP Commands
03-NTP Commands 134.46 KB
display ntp-service sessions
display ntp-service sessions [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed information about all NTP sessions. If you do not specify this keyword, the command displays only brief information about the NTP sessions.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ntp-service sessions to display information about all NTP sessions.
# Display brief information about all NTP sessions.
<Sysname> display ntp-service sessions
       source          reference       stra reach poll  now offset  delay disper
[12345]127.127.1.0     127.127.1.0        3     1   64   33    0.0    0.0    0.0
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations :  1
source
IP address of the clock source.
reference
Reference clock ID of the clock source:
·     If the reference clock is the local clock, the value of this field is related to the value of the stra field:
¡ When the value of the stra field is 0 or 1, this field will be LOCL.
¡ When the stra field has another value, this field will be the IP address of the local clock.
·     If the reference clock is the clock of another device on the network, the value of this field will be the IP address of that device.
stra
Stratum level of the clock source, which determines the clock precision. The value ranges from 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized and cannot be used as a reference clock.
reach
Reachability count of the clock source. 0 indicates that the clock source in unreachable.
poll
Poll interval in seconds, namely, the maximum interval between successive NTP messages.
now
Length of time from when the last NTP message was received or when the local clock was last updated to the current time.
Time is in second by default. If the time length is greater than 2048 seconds, it is displayed in minute. If greater than 300 minutes, in hour. If greater than 96 hours, in day.
offset
Offset of the system clock relative to the reference clock, in milliseconds.
delay
Roundtrip delay from the local device to the clock source, in milliseconds.
disper
Maximum error of the system clock relative to the reference source.
[12345]
·     1—Clock source selected by the system, namely, the current reference source, with a system clock stratum level less than or equal to 15.
·     2—Stratum level of the clock source is less than or equal to 15.
·     3—This clock source has survived the clock selection algorithm.
·     4—This clock source is a candidate clock source.
·     5—This clock source was created by a configuration command.
Total associations
Total number of associations.
# Display detailed information about all NTP sessions.
<Sysname> display ntp-service sessions verbose
 clock source: 127.127.1.0
 clock stratum: 3
 clock status: configured, master, sane, valid
 reference clock ID: 127.127.1.0
 local mode: client, local poll: 6
 peer mode: server, peer poll: 6
 offset: 0.0000 ms,delay: 0.00 ms,  disper: 0.02 ms
 root delay: 0.00 ms, root disper: 10.00 ms
 reach: 1, sync dist: 0.010, sync state: 2
 precision: 2^18, version: 3, peer interface: InLoopBack0
 reftime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 orgtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71484513)
 rcvtime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.7149E881)
 xmttime: 10:56:22.442 UTC Aug 7 2009(CE2686D6.71464DC2)
 filter delay :  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter offset:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 filter disper:  0.00   0.00   0.00   0.00   0.00   0.00   0.00   0.00
 reference clock status: working abnormally
 timecode:
clock source
clock stratum
clock status
Status of the clock source corresponding to this session:
·     configured—The session was created by a configuration command.
·     dynamic—This session is established dynamically.
·     master—The clock source is the primary reference source of the current system.
·     selected—The clock source has survived the clock selection algorithm.
·     candidate—The clock source is the candidate reference source.
·     sane—The clock source has passed the sane authentication.
·     insane—The clock source has failed the sane authentication.
·     valid—The clock source is valid, which means the clock source meet the following requirements: it has passed the authentication and is being synchronized; its stratum level is valid; its root delay and root dispersion values are within their ranges.
·     invalid—The clock source is invalid.
·     unsynced—The clock source has not been synchronized or the value of the stratum level is invalid.
reference clock ID
·     If the reference clock is the local clock, the value of this field is related to the stratum level of the clock source:
¡ When the stratum level of the clock source is 0 or 1, this field is LOCL.
¡ When the stratum level of the clock source has another value, this field is the IP address of the local clock.
·     If the reference clock is the clock of another device on the network, the value of this field is the IP address of that device.
local mode
Operation mode of the local device:
·     unspec—The mode is unspecified.
·     active—Active mode.
·     passive—Passive mode.
·     client—Client mode.
·     server—Server mode.
·     bdcast—Broadcast server mode.
·     control—Control query mode.
·     private—Private message mode.
local poll
Poll interval of the local device, in seconds. The value displayed is a power of 2. For example, if the displayed value is 6, the poll interval of the local device is 26, or 64 seconds.
peer mode
Operation mode of the peer device:
peer poll
Poll interval of the peer device, in seconds. The value displayed is a power of 2. For example, if the displayed value is 6, the poll interval of the local device is 26, or 64 seconds.
offset
delay
disper
Maximum error of the system clock relative to the reference clock.
root delay
Roundtrip delay from the local device to the primary reference source, in milliseconds.
root disper
Maximum error of the system clock relative to the primary reference clock, in milliseconds.
reach
Reachability count of the clock source. 0 indicates that the clock source is unreachable.
sync dist
Synchronization distance relative to the upper-level clock, in seconds, and calculated from dispersion and roundtrip delay values.
sync state
State of the state machine.
Displayed value is an integer that ranges from 0 to 5.
precision
Precision of the system clock.
version
NTP version.
Displayed value is an integer that ranges from 1 to 3.
peer interface
Source interface.
If the source interface is not specified, this field is wildcard.
reftime
Reference timestamp in the NTP message.
orgtime
Originate timestamp in the NTP message.
rcvtime
Receive timestamp in the NTP message.
xmttime
Transmit timestamp in the NTP message.
filter delay
Delay information.
filter offset
Offset information.
filter disper
Dispersion information.
Status of the reference clock:
·     working normally.
·     working abnormally.
timecode
Time code.
Total associations
When a device is operating in NTP broadcast/multicast server mode, using the display ntp-service sessions command on the device does not display the NTP session information corresponding to the broadcast/multicast server, but the sessions are counted in the total number of associations.
display ntp-service status
display ntp-service status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ntp-service status to display the NTP service status.
# Display the NTP service status.
<Sysname> display ntp-service status
Clock status: unsynchronized
 Clock stratum: 16
 Reference clock ID: none
 Nominal frequency: 100.0000 Hz
 Actual frequency: 100.0000 Hz
 Clock precision: 2^17
 Clock offset: 0.0000 ms
 Root delay: 0.00 ms
 Root dispersion: 0.00 ms
 Peer dispersion: 0.00 ms
 Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Clock status
Status of the system clock:
·     Synchronized—The system clock has been synchronized.
·     Unsynchronized—The system clock has not been synchronized.
Clock stratum
Stratum level of the system clock.
Reference clock ID
When the system clock is synchronized to a remote time server, this field indicates the address of the remote time server. When the system clock is synchronized to a local reference source, this field indicates the address of the local clock source:
·     When the local clock has a stratum level of 1, the value of this field is LOCL.
·     When the stratum of the local clock has another value, the value of this field is the IP address of the local clock.
Nominal frequency
Nominal frequency of the local system hardware clock, in Hz.
Actual frequency
Actual frequency of the local system hardware clock, in Hz.
Clock precision
Clock offset
Offset of the system clock relative to the reference source, in milliseconds.
Root delay
Root dispersion
Maximum error of the system clock relative to the primary reference source, in milliseconds.
Peer dispersion
Maximum error of the system clock relative to the reference source, in milliseconds.
Reference time
Reference timestamp.
display ntp-service trace
display ntp-service trace [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ntp-service trace to display brief information about each NTP server along the NTP server chain from the local device back to the primary reference source.
The display ntp-service trace command takes effect only when the local device and all the devices on the NTP server chain can reach one another. Otherwise, this command is unable to display all the NTP servers on the NTP chain due to timeout.
# Display brief information about each NTP server from the local device back to the primary reference source.
<Sysname> display ntp-service trace
 server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
 server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
 refid LOCL
The output shows an NTP server chain for server 127.0.0.1: Server 127.0.0.1 is synchronized to server 133.1.1.1, and server 133.1.1.1 is synchronized to the local clock source.
server
IP address of the NTP server.
stratum
Stratum level of the corresponding system clock.
offset
Clock offset relative to the upper-level clock, in seconds.
synch distance
refid
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL. Otherwise, it is displayed as the IP address of the primary reference clock.
ntp-service access
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
View
Default level
3: Manage level
peer: Permits full access. This level of right permits the peer devices to perform synchronization and control query to the local device and also permits the local device to synchronize its clock to that of a peer device. Control query refers to query of NTP status information, such as alarm information, authentication status, and clock source information.
query: Permits control query. This level of right permits the peer devices to perform control query to the NTP service on the local device but does not permit a peer device to synchronize its clock to that of the local device.
server: Permits server access and query. This level of right permits the peer devices to perform synchronization and control query to the local device but does not permit the local device to synchronize its clock to that of a peer device.
synchronization: Permits server access only. This level of right permits a peer device to synchronize its clock to that of the local device but does not permit the peer devices to perform control query.
acl-number: Specifies a basic ACL number, which ranges from 2000 to 2999.
Use ntp-service access to configure the access-control right for the peer devices to access the NTP services of the local device.
Use undo ntp-service access to remove the configured NTP service access-control right to the local device.
By default, the access-control right for the peer devices to access the NTP services of the local device is set to peer.
From the highest NTP service access-control right to the lowest one are peer, server, synchronization, and query. When a device receives an NTP request, it matches against the access-control right in this order and uses the first matched right.
The ntp-service access command provides only a minimum degree of security protection. A more secure method is identity authentication. The related command is ntp-service authentication enable.
Before specifying an ACL number in the ntp-service access command, make sure you have already created and configured this ACL.
# Configure the peer devices on subnet 10.10.0.0/16 to have the full access right to the local device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
undo ntp-service authentication enable
View
Default level
3: Manage level
None
Use ntp-service authentication enable to enable NTP authentication.
Use undo ntp-service authentication enable to disable NTP authentication.
By default, NTP authentication is disabled.
Related commands: ntp-service authentication-keyid and ntp-service reliable authentication-keyid.
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
ntp-service authentication-keyid keyid authentication-mode md5 value
undo ntp-service authentication-keyid keyid
View
Default level
3: Manage level
keyid: Specifies an authentication key ID, which ranges from 1 to 4294967295.
authentication-mode md5 value: Specifies the MD5 algorithm for key authentication, where the value argument represents authentication key and is a string of 1 to 32 characters.
Use ntp-service authentication-keyid to set the NTP authentication key.
Use undo ntp-service authentication-keyid to remove the set NTP authentication key.
By default, no NTP authentication key is set.
In a network where there is a high security demand, the NTP authentication feature should be enabled for a system running NTP. This feature enhances the network security by means of the client-server key authentication, which prohibits a client from synchronizing with a device that has failed authentication.
When the NTP authentication key is configured, configure the key as a trusted key by using the ntp-service reliable authentication-keyid command.
The system supports only the MD5 algorithm for key authentication.
You can set up to 1024 keys for each device.
If an NTP authentication key is specified as a trusted key, the key automatically changes to untrusted after you delete the key. In this case, you do not need to execute the undo ntp-service reliable authentication-keyid command.
Related commands: ntp-service reliable authentication-keyid.
# Set an MD5 authentication key, with the key ID of 10 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
ntp-service broadcast-client
undo ntp-service broadcast-client
View
Interface view
Default level
3: Manage level
None
Use ntp-service broadcast-client to configure the device to operate in NTP broadcast client mode and use the current interface to receive NTP broadcast packets.
Use undo ntp-service broadcast-client to remove the configuration.
By default, the device does not operate in any NTP operation mode.
# Configure the device to operate in broadcast client mode and receive NTP broadcast messages on VLAN-interface 1.
[Sysname-Vlan-interface1] ntp-service broadcast-client
ntp-service broadcast-server
undo ntp-service broadcast-server
View
Interface view
Default level
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients, where keyid ranges from 1 to 4294967295. This parameter is not meaningful if authentication is not required.
version number: Specifies the NTP version, where number ranges from 1 to 3 and defaults to 3.
Use ntp-service broadcast-server to configure the device to operate in NTP broadcast server mode and use the current interface to send NTP broadcast packets.
Use undo ntp-service broadcast-server to remove the configuration.
# Configure the device to operate in broadcast server mode and send NTP broadcast messages on VLAN-interface 1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-keyid 4 version 3
ntp-service in-interface disable
undo ntp-service in-interface disable
View
Interface view
Default level
3: Manage level
None
Use ntp-service in-interface disable to disable an interface from receiving NTP messages.
Use undo ntp-service in-interface disable to restore the default.
By default, all interfaces are enabled to receive NTP messages.
# Disable VLAN-interface 1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
ntp-service max-dynamic-sessions
undo ntp-service max-dynamic-sessions
View
Default level
3: Manage level
number: Sets the maximum number of dynamic NTP sessions that are allowed to be established, which ranges from 0 to 100.
Use ntp-service max-dynamic-sessions to set the maximum number of dynamic NTP sessions that are allowed to be established locally.
Use undo ntp-service max-dynamic-sessions to restore the maximum number of dynamic NTP sessions to the system default.
By default, the number is 100.
A single device can have a maximum of 128 concurrent associations, including static associations and dynamic associations. A static association refers to an association that a user has manually created by using an NTP command, while a dynamic association is a temporary association created by the system during operation. A dynamic association is removed if the system fails to receive messages from it over a specific long time. In client/server mode, for example, when you carry out a command to synchronize the time to a server, the system creates a static association, and the server just responds passively upon the receipt of a message, rather than creating an association (static or dynamic). In symmetric mode, static associations are created at the symmetric-active peer side, and dynamic associations are created at the symmetric-passive peer side. In broadcast or multicast mode, static associations are created at the server side, and dynamic associations are created at the client side.
# Set the maximum number of dynamic NTP sessions allowed to be established to 50.
[Sysname] ntp-service max-dynamic-sessions 50
ntp-service multicast-client
undo ntp-service multicast-client [ ip-address ]
View
Interface view
Default level
3: Manage level
ip-address: Specifies a multicast IP address, which defaults to 224.0.1.1.
Use ntp-service multicast-client to configure the device to operate in NTP multicast client mode and use the current interface to receive NTP multicast packets.
Use undo ntp-service multicast-client to remove the configuration.
# Configure the device to operate in multicast client mode and receive NTP multicast messages on VLAN-interface 1, and set the multicast address to 224.0.1.1.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.1
ntp-service multicast-server
undo ntp-service multicast-server [ ip-address ]
View
Interface view
Default level
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending multicast messages to multicast clients, where keyid ranges from 1 to 4294967295. This parameter is not meaningful if authentication is not required.
ttl ttl-number: Specifies the TTL of NTP multicast messages, where ttl-number ranges from 1 to 255 and defaults to 16.
Use ntp-service multicast-server to configure the device to operate in NTP multicast server mode and use the current interface to send NTP multicast packets.
Use undo ntp-service multicast-server to remove the configuration.
# Configure the device to operate in multicast server mode and send NTP multicast messages on VLAN-interface 1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
ntp-service refclock-master
undo ntp-service refclock-master [ ip-address ]
View
Default level
3: Manage level
ip-address: Specifies the IP address of the local clock, which is 127.127.1.u, where u is the NTP process ID that ranges from 0 to 3. If you do not specify ip-address, it defaults to 127.127.1.0.
stratum: Specifies the stratum level of the local clock, which ranges from 1 to 15 and defaults to 8.
Use ntp-service refclock-master to configure the local clock as a reference source for other devices.
Use undo ntp-service refclock-master to remove the configuration.
The stratum level of a clock defines the clock precision. The value ranges from 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized and cannot be used as a reference clock.
# Specify the local clock as the reference source, with the stratum level 3.
[Sysname] ntp-service refclock-master 3
undo ntp-service reliable authentication-keyid keyid
View
Default level
3: Manage level
keyid: Specifies an authentication key number, which ranges from 1 to 4294967295.
Use ntp-service reliable authentication-keyid to specify that the created authentication key is a trusted key. When NTP authentication is enabled, a client can be synchronized only to a server that can provide a trusted authentication key.
Use undo ntp-service reliable authentication-keyid to remove the configuration.
By default, no authentication key is configured to be trusted.
# Enable NTP authentication, and specify the MD5 encryption algorithm, with the key ID of 37 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
# Specify this key as a trusted key.
[Sysname] ntp-service reliable authentication-keyid 37
ntp-service source-interface
ntp-service source-interface interface-type interface-number
undo ntp-service source-interface
View
Default level
3: Manage level
Use ntp-service source-interface to specify the source interface for NTP messages.
Use undo ntp-service source-interface to restore the default.
By default, no source interface is specified for NTP messages, and the system uses the IP address of the interface determined by the matched route as the source IP address of NTP messages.
If you do not want the IP address of a certain interface on the local device to become the destination address of response messages, use this command to specify the source interface for NTP messages so that the source IP address in NTP messages is the primary IP address of this interface.
# Specify the source interface of NTP messages as VLAN-interface 1.
[Sysname] ntp-service source-interface vlan-interface 1
ntp-service unicast-peer
ntp-service unicast-peer { ip-address | peer-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-peer { ip-address | peer-name }
View
Default level
3: Manage level
peer-name: Specifies a host name of the symmetric-passive peer, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the peer, where keyid ranges from 1 to 4294967295.
priority: Specifies the peer designated by ip-address or peer-name as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message the local device sends to its peer, the source IP address is the primary IP address of this interface. The interface-type interface-number argument represents the interface type and number.
Use ntp-service unicast-peer to designate a symmetric-passive peer for the device.
Use undo ntp-service unicast-peer to remove the symmetric-passive peer designated for the device.
By default, no symmetric-passive peer is designated for the device.
# Designate the device with the IP address of 10.1.1.1 as the symmetric-passive peer of the device, configure the device to run NTP version 3, and specify the source interface of NTP messages as VLAN-interface 1.
[Sysname] ntp-service unicast-peer 10.1.1.1 version 3 source-interface vlan-interface 1
ntp-service unicast-server
ntp-service unicast-server { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number  ] *
undo ntp-service unicast-server { ip-address | server-name }
View
Default level
3: Manage level
server-name: Specifies a host name of the NTP server, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server, where keyid ranges from 1 to 4294967295.
priority: Specifies this NTP server as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message the local device sends to the NTP server, the source IP address is the primary IP address of this interface. The interface-type interface-number argument represents the interface type and number.
Use ntp-service unicast-server to designate an NTP server for the device.
Use undo ntp-service unicast-server to remove an NTP server designated for the device.
By default, no NTP server is designated for the device.
# Designate NTP server 10.1.1.1 for the device, and configure the device to run NTP version 3.
[Sysname] ntp-service unicast-server 10.1.1.1 version 3
