02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10702-WLAN Command Reference
07-WLAN QoS Commands
07-WLAN QoS Commands 151.40 KB
bandwidth-guarantee enable
undo bandwidth-guarantee enable
Radio view
Default level
2: System level
None
Use bandwidth-guarantee enable to enable bandwidth guaranteeing.
Use undo bandwidth-guarantee enable to restore the default.
By default, bandwidth guaranteeing is disabled.
# Enable bandwidth guaranteeing.
[Sysname] wlan ap ap1 model WA2100
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] bandwidth-guarantee enable
bandwidth-guarantee service-template
bandwidth-guarantee service-template service-template-number percent percent
undo bandwidth-guarantee { all | service-template service-template-number }
Radio view
Default level
2: System level
service-template service-template-number: Specifies a service template by its number.
percent percent: Specifies the percentage of the guaranteed bandwidth to the total bandwidth.
all: Specifies all service templates.
Use bandwidth-guarantee service-template to configure a guaranteed bandwidth percent for the specified BSS.
Use undo bandwidth-guarantee service-template to restore the default.
By default, no guaranteed bandwidth percent is configured for a BSS.
The WLAN service must have been bound to the radio.
For the same radio, the sum of guaranteed bandwidth percents cannot exceed 100%.
# Set the guaranteed bandwidth percent t0 30% for service template 1.
[Sysname] wlan ap 2220
[Sysname-wlan-ap-2220] radio 1
[Sysname-wlan-ap-2220-radio-1] bandwidth-guarantee service-template 1 percent 30
client-rate-limit direction (WLAN service-based)
client-rate-limit direction { inbound | outbound } mode { dynamic | static } cir cir
undo client-rate-limit direction { inbound | outbound }
Service template view
Default level
2: System level
inbound: Specifies the direction from client to AP.
outbound: Specifies the direction from AP to client.
dynamic: Specifies the dynamic mode, where the rate limit of a client is the configured total rate/the number of online clients.
static: Specifies the static mode, where the rate limit of a client is the configured value.
cir cir: Specifies the rate limit in kbps. In static mode, the CIR is the rate limit of a single client. In dynamic mode, the CIR is the total rate limit for all clients. This argument ranges from 16 to 300000.
Use client-rate-limit to configure WLAN service-based client rate limiting, which can limit the rate of traffic from clients to AP (incoming traffic) or the rate of traffic from AP to clients (outgoing traffic). You can configure client rate limiting for both incoming traffic and outgoing traffic in the same service template.
Use undo client-rate-limit to restore the default.
By default, WLAN service-based client rate limiting is not configured.
# Configure WLAN service-based client rate limiting to limit the static incoming traffic rate to 567 kbps and the shared outgoing traffic rate to 89 kbps.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] client-rate-limit direction inbound mode static cir 567
[Sysname-wlan-st-1] client-rate-limit direction outbound mode dynamic cir 89
client-rate-limit direction (radio-based)
Radio view
Default level
2: System level
Use client-rate-limit to configure radio-based client rate limiting, which can limit the rate of traffic from clients to AP (incoming traffic) or the rate of traffic from AP to clients (outgoing traffic). You can configure client rate limiting for both incoming traffic and outgoing traffic in the same service template.
By default, radio-based client rate limiting is disabled.
# Configure radio-based client rate limiting to limit the outgoing traffic rate to 567 kbps and the shared incoming traffic rate to 89 kbps for clients.
[Sysname-wlan-ap-ap1-1] client-rate-limit direction inbound mode static cir 567
[Sysname-wlan-ap-ap1-1] client-rate-limit direction outbound mode dynamic cir 89
display wlan bandwidth-guarantee
display wlan bandwidth-guarantee [ ap ap-name radio radio-id ] [ | { begin | exclude | include } regular-expression ]
Default level
1: Monitor level
ap ap-name: Specifies an AP by its name. If you do not specify an AP, this command displays bandwidth guaranteeing configuration of all APs.
radio radio-id: Specifies a radio by its ID. If you do not specify a radio, this command displays bandwidth guaranteeing configuration of all radios.
interface radio-interface-name: Specifies a radio interface by its name. If you do not specify a radio interface, this command displays bandwidth guaranteeing configuration of all radio interfaces.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display wlan bandwidth-guarantee to display the bandwidth guaranteeing configuration.
# Display bandwidth guaranteeing configuration.
<Sysname> display wlan bandwidth-guarantee
                            Bandwidth Guarantee
 ST: service template
 AP                                 Radio   Mode            ST  Percent
 2220                               1       802.11a         1   80%
 AP_wa2620_agn_1                    2       802.11n(2.4GHz) 1   20%
 AP_wa2620_agn_1                    2       802.11n(2.4GHz) 2   30%
AP
AP name
Radio
Radio ID
Mode
Radio mode:
·     802.11a
·     802.11b
·     802.11g
·     802.11n(2.4GHz)
·     802.11n(5GHz)
ST
Service template number
Percent
Bandwidth percent (which must be an integer)
display wlan client-rate-limit
display wlan client-rate-limit { service-template [ service-template-number ] | ap [ ap-name radio radio-id ] } [ | { begin | exclude | include } regular-expression ]
Default level
1: Monitor level
service-template: Displays WLAN service-based client rate limiting information.
service-template-number: Specifies a service template by its number. If you do not specify a service template, this command displays service-based client rate limiting information of all service templates.
ap: Displays radio-based client rate limiting information.
ap-name: Specifies an AP by its name. If you do not specify an AP, this command displays radio-based client rate limiting of all APs.
radio radio-id: Specifies a radio by its ID. If you do not specify a radio, this command displays client rate limiting configuration of all radios.
Use display wlan client-rate-limit service-template to display WLAN service-based client rate limiting information.
Use display wlan client-rate-limit ap to display wireless radio-based client rate limiting information.
# Display WLAN service-based client rate limiting information.
<Sysname> display wlan client-rate-limit service-template
                            Client Rate Limit
 Service Template       Direction       Mode            CIR(kbps)
 1                      Inbound         Dynamic         1000
 2                      Outbound        Static          150
 3                      Inbound         Static          300
Service Template
Direction
Rate-limited direction:
·     Inbound
·     Outbound
Mode
Rate-limiting mode:
·     Dynamic (shared bandwidth)
·     Static (exclusive bandwidth)
CIR(kbps)
Rate limit (in kbps)
# Display radio-based client rate limiting information.
<Sysname> display wlan client-rate-limit ap 2220 radio 1
                            Client Rate Limit
 AP             : 2220
 Radio          : 1
 Inbound
      Mode      : Dynamic
      CIR       : 1000kbps
 Outbound
      Mode      : Static
      CIR       : 150kbps
AP
AP name
Radio
Radio ID
Mode (Inbound)
Rate limiting mode for the incoming traffic:
CIR (Inbound)
Rate limit for the incoming traffic
Mode (Outbound)
Rate limiting mode for the outgoing traffic:
CIR (Outbound)
Rate limit for the outgoing traffic
display wlan wmm
display wlan wmm { radio { all | ap ap-name } | client { all | ap ap-name | mac-address mac-address } } [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
radio: Displays radio WMM information.
client: Displays client WMM information.
all: Displays WMM information about all radios or clients.
ap ap-name: Specifies an AP by its name. The ap-name argument is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
mac-address mac-address: Specifies a client by its MAC address.
Use display wlan wmm radio to display the WMM information of the specified AP's radio or all radios.
Use display wlan wmm client to display the WMM information of the client identified by the specified MAC address, of the clients associated with the specified AP, or of all clients.
# Display the WMM information of radios of the AP named test.
<Sysname> display wlan wmm radio ap test
AP ID : 4     AP Name : test
 Radio : 1
--------------------------------------------------------------------------Client EDCA update count : 0
 QoS Mode                 : WMM        Radio chip QoS mode   : WMM
 Radio chip max AIFSN     : 255        Radio chip max ECWmin : 10
 Radio chip max TXOPLimit : 32768      Radio chip max ECWmax : 10
 CAC Information
  Client accepted                : 0
   Voice                         : 0
   Video                         : 0
  Total request mediumtime(us)   : 0
   Voice(us)                     : 0
   Video(us)                     : 0
  Calls rejected due to insufficient resource   : 0
  Calls rejected due to invalid parameters      : 0
  Calls rejected due to invalid mediumtime      : 0
  Calls rejected due to invalid delaybound      : 0
 Radio : 2
 CAC Information
  Client accepted                : 0
   Voice                         : 0
   Video                         : 0
   Voice(us)                     : 0
   Video(us)                     : 0
AP ID
AP ID.
AP Name
AP name.
Radio
Radio ID.
Number of client EDCA parameters updates.
QoS mode
QoS mode:
·     WMMIndicates that the WMM function is supported.
·     noneIndicates that the WMM function is not supported.
Radio chip QoS mode
Indicates whether the radio chip supports QoS.
Radio chip WMM support
Indicates whether the radio chip supports the WMM function.
Maximum AIFSN allowed by the radio chip.
Radio chip max ECWMIN
Maximum ECWmin allowed by the radio chip.
Maximum TXOPLimit allowed by the radio chip.
Radio chip max ECWMAX
Maximum ECWmax allowed by the radio chip.
Client accepted
Number of clients that have been admitted to access the radio.
Total medium time, including voice calls and video calls.
Number of requests rejected due to insufficient resources.
Number of requests rejected due to invalid parameters.
Number of requests rejected due to invalid medium time.
Number of requests rejected due to invalid delay bound.
# Display the WMM information of all the clients.
<Sysname> display wlan wmm client all
 MAC address     : 000f-e23c-0000       SSID                : h3c
 QoS Mode        : None
 MAC address     : 000f-e23c-0001       SSID                : h3c
 QoS Mode        : WMM
 APSD information :
  Max SP Length : all
  L: Legacy      T: Trigger      D: Delivery
  AC             AC-BK   AC-BE   AC-VI   AC-VO
  State          T|D     L       T|D     L
  Assoc State    T|D     L       T|D     T|D
 CAC  information :
  Uplink CAC packets   : 0           Downlink CAC packets   : 0
  Uplink CAC bytes     : 0           Downlink CAC bytes     : 0
  Downgrade packets    : 0           Discard packets        : 0
  Downgrade bytes      : 0           Discard bytes          : 0
  AC                   : AC-VO       User Priority               : 7
   TID                 : 1           Direction              : Bidirectional
   PSB                 : 0           Surplus Bandwidth Allowance : 1.0000
   Medium Time(ms)     : 39.108      Nominal MSDU Size(bytes)    : 1500
   Mean Data Rate(Kbps): 78.125      Minimum PHY Rate(Mbps)      : 2.000
   Create TS time      :  5s
   Update TS time      :  5s
   Uplink TS packets   : 0           Downlink TS packets         : 0
   Uplink TS bytes     : 0           Downlink TS bytes           : 0
Table 5 Command output
MAC address
MAC address of a client.
SSID
Service set ID (SSID).
QoS Mode
QoS mode:
Max SP length
Maximum service period.
AC
Access category.
APSD attribute of an AC queue:
·     Tindicates that the AC queue is trigger-enabled.
·     DIndicates that the AC queue is delivery-enabled.
·     T | DIndicates that the AC queue is both trigger-enabled and delivery-enabled.
·     LIndicates that the AC queue is of legacy attributes.
Assoc State
APSD attributes of the four AC queues specified when a client accesses the AP.
Uplink CAC packets
Number of uplink CAC packets.
Uplink CAC bytes
Number of uplink CAC bytes.
Number of downlink CAC packets.
Downlink CAC bytes
Number of downlink CAC bytes.
Downgrade packets
Number of downgraded packets.
Downgrade bytes
Number of downgraded bytes.
Discard packets
Number of dropped packets.
Discard bytes
Number of dropped bytes.
Direction
Traffic direction.
User Priority
User priority.
TID
Traffic identifier.
PSB
Power saving mode banner.
Average MSDU size (in bytes).
Mean Data Rate(kbps)
Average data transmission rate (in kbps).
Minimum physical transmission rate (in Mbps).
Surplus bandwidth allowance.
Medium Time(ms)
Medium time (in microseconds).
Create TS time
time from when the TS was created to now.
Update TS time
Time from when the TS was updated to now.
Uplink TS packets
Number of uplink TS packets.
Uplink TS bytes
Number of uplink TS bytes.
Downlink TS packets
Number of downlink TS packets.
Downlink TS bytes
Number of downlink TS bytes.
reset wlan wmm
reset wlan wmm { radio { all | ap ap-name } | client { all | ap ap-name | mac-address mac-address } }
View
Default level
2: System level
radio: Clears the WMM statistics of radios.
client: Clears the WMM statistics of clients.
all: Clears the WMM statistics of all radios or clients.
Use reset wlan wmm radio to clear the WMM statistics of the radio of the specified AP or all radios.
Use reset wlan wmm client to clear the WMM statistics of the client identified by the specified MAC address, of the clients associated with the specified AP, or of all clients.
# Clear the WMM statistics of all the radios.
<Sysname> reset wlan wmm radio all
wmm cac policy
wmm cac policy { channelutilization [ channelutilization-value ] | users [ users-number ] }
undo wmm cac policy
View
Radio-policy view
Default level
2: System level
channelutilization: Uses the channel utilization-based admission policy for CAC.
channelutilization-value: Maximum channel utilization rate, which specifies the medium time of the accepted AC-VO traffic and AC-VI traffic to the valid time during the unit time. This argument ranges from 0 to 100. It is 65 by default. The unit is % (percentage). The valid time refers to the time available for transmitting and receiving data.
users: Uses the users-based admission policy for CAC.
users-number: Maximum number of clients allowed to be connected, which ranges from 0 to 64. This argument is 20 by default. A client is counted only once, even if it is using both the AC-VO and AC-VI queues.
Use wmm cac policy to configure the access control policy for CAC.
Use undo wmm cac policy to restore the default.
By default, the users-based admission policy applies, with the maximum number of admitted users being 20.
Related commands: wmm edca client.
# Configure CAC to use the channel utilization-based admission policy, with the channel utilization rate being 70%.
[Sysname] wlan radio-policy radio1
[Sysname-wlan-rp-radio1] wmm cac policy channelutilization 70
wmm edca radio
wmm edca radio { ac-vo | ac-vi | ac-be | ac-bk } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value | noack } *
undo wmm edca radio { ac-vo | ac-vi | ac-be | ac-bk } { aifsn | ecw | txoplimit | noack | all }
View
Radio-policy view
Default level
2: System level
ac-vo: Specifies the AC-VO (voice traffic) queue.
ac-vi: Specifies the AC-VI (video traffic) queue.
ac-be: Specifies the AC-BE (best-effort traffic) queue.
ac-bk: Specifies the AC-BK (background traffic) queue.
all: Specifies all the EDCA parameters.
noack: Specifies the AC queue to use the No ACK policy. The protocol defines two ACK policies: Normal ACK and No ACK.
txoplimit-value: TXOPLimit parameter of EDCA, which ranges from 0 to 65535 (in units of 32 microseconds). The TXOP value of 0 indicates that only one MPDU can be transmitted. The range of this argument is limited by the radio chip capability.
ecwmin-value: ECWmin parameter of EDCA, which ranges from 0 to 15. The range of this argument is limited by the radio chip capability.
ecwmax-value: ECWmax parameter of EDCA, which ranges from 0 to 15. The range of this argument is limited by the radio chip capability.
aifsn-value: AIFSN parameter of EDCA, which ranges from 1 to 15. The range of this argument is limited by the radio chip capability.
Use wmm edca radio to set the EDCA parameters and specify the ACK policy.
Use undo wmm edca radio to restore the default.
By default, Normal ACK is used, and the default EDCA parameters are as shown in Table 6.
Table 6 The default EDCA parameters for APs
AC queue
AIFSN
ECWmin
ECWmax
TXOP Limit
AC-BK queue
7
4
10
0
AC-BE queue
3
4
6
0
AC-VI queue
1
3
4
94
AC-VO queue
1
2
3
47
·     For more information about each EDCA parameter, see WLAN Configuration Guide.
·     ECWmin must be no greater than ECWmax. The two parameters must be enabled or disabled simultaneously.
·     When an AP uses 802.11b radio cards, set TXOPLimit values of the AC-BK, AC-BE, AC-VI, and AC-VO queues to 0, 0, 188, and 102, respectively.
# Set AIFSN to 2 for the AC-VO queue in radio policy radio1.
[Sysname-wlan-rp-radio1] wmm edca radio ac-vo aifsn 2
wmm edca client (ac-vo and ac-vi)
wmm edca client { ac-vo | ac-vi } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value | cac } *
undo wmm edca client { ac-vo | ac-vi } { aifsn | ecw | txoplimit | cac | all }
View
Radio-policy view
Default level
2: System level
cac: Enables CAC. The AC-VO and AC-VI queues support CAC, which is disabled by default. The AC-BE and AC-BK queues do not support CAC.
aifsn-value: AIFSN parameter of EDCA, which ranges from 2 to 15.
Use wmm edca client to set the EDCA parameters of the AC-VO or AC-VI queue for the clients in a BSS.
Use undo wmm edca client to restore the default.
The following table lists the default EDCA parameters of the AC-VI and AC-VO queue for clients.
Table 7 Default EDCA parameters for clients
AC queue
AIFSN
ECWmin
ECWmax
TXOP Limit
AC-VI queue
2
3
4
94
AC-VO queue
2
2
3
47
·     ECWmin must not be greater than ECWmax. The two parameters must be enabled or disabled simultaneously.
·     When all the clients are 802.11b terminals, set the TXOPLimit to 188 and 102 for the AC-VI and AC-VO queues, respectively.
·     If both 802.11b and 802.11g clients are present, use the default TXOPLimit settings in Table 7.
·     If CAC is enabled for an AC queue, CAC is also enabled for AC queues with higher priority. For example, if you use the wmm edca client command to enable CAC for the AC-VI queue, CAC is also enabled for the AC-VO queue. However, enabling CAC for the AC-VO queue does not enable CAC for the AC-VI queue.
# Set AIFSN to 3 for the AC-VO queue.
[Sysname-wlan-rp-radio1] wmm edca client ac-vo aifsn 3
wmm edca client (ac-be and ac-bk)
wmm edca client { ac-be | ac-bk } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value } *
undo wmm edca client { ac-be | ac-bk } { aifsn | ecw | txoplimit | all }
View
Radio-policy view
Default level
2: System level
Use wmm edca client to set EDCA parameters for the AC-BE or AC-BK queue for clients.
Use undo wmm edca client to restore the default of the specified or all EDCA parameters for the specified AC queue.
The following table lists the default EDCA parameter settings for the AC-BK and AC-BE queues for clients.
Table 8 Default EDCA parameter settings for clients
AC queue
AIFSN
ECWmin
ECWmax
TXOP Limit
AC-BK queue
7
4
10
0
AC-BE queue
3
4
10
0
·     When all the clients are 802.11b terminals, set the TXOPLimit value to 0 for both the AC-BK and AC-BE queues.
·     If both 802.11b and 802.11g clients are present, use the default TXOPLimit settings for the AC-BK and AC-BE queues.
# Set AIFSN to 3 for the AC-BE queue.
[Sysname-wlan-rp-radio1] wmm edca client ac-be aifsn 5
wmm enable
wmm enable
undo wmm enable
View
Radio-policy view
Default level
2: System level
None
Use wmm enable to enable the WMM function.
Use undo wmm enable to disable the WMM function.
The WMM function is enabled by default.
The 802.11n protocol stipulates that all 802.11n clients support WLAN QoS. Therefore, when the radio operates in 802.11an or 802.11gn mode, you should enable WMM. Otherwise, the associated 802.11n clients may fail to communicate.
# Disable the WMM function.
[Sysname-wlan-rp-radio1] undo wmm enable
wmm svp map-ac
wmm svp map-ac { ac-vo | ac-vi | ac-be | ac-bk }
undo wmm svp map-ac
View
Radio-policy view
Default level
2: System level
Use wmm svp map-ac to map SVP packets to a specific AC queue.
Use undo wmm svp map-ac to restore the default.
By default, SVP packet mapping is disabled.
H3C recommends that you map SVP packets to the AC-VO queue in normal cases.
# Map SVP packets to the AC-VO queue.
[Sysname-wlan-rp-radio1] wmm svp map-ac ac-vo
