02-WLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10702-WLAN Command Reference
02-WLAN Service Commands
02-WLAN Service Commands 463.43 KB
WLAN configuration commands 1
WLAN global service control commands 1
wlan enable· 1
802.11 MAC configuration commands 1
a-mpdu enable· 1
a-msdu enable· 2
ani enable· 3
antenna type· 3
beacon ssid-hide· 4
beacon-interval 4
bind wlan-ess 5
broadcast-probe reply· 6
channel 6
channel band-width· 7
channel lock· 8
client dot11n-only· 9
client forwarding-mode local 9
client idle-timeout 10
client keep-alive· 11
client max-count (radio policy view) 11
client max-count (service template view) 12
country-code· 12
display wlan client 13
display wlan country-code· 17
display wlan radio-policy· 18
display wlan service-template· 22
display wlan statistics ap connect-history· 23
display wlan statistics client 24
display wlan statistics radio· 26
display wlan statistics service-template· 30
distance· 32
dtim·· 33
fast-association enable· 33
fragment-threshold· 34
long-retry threshold· 34
max-power 35
max-rx-duration· 36
nas-id· 36
nas-port-id· 37
power lock· 37
preamble· 38
protection-mode· 39
radio· 39
radio type· 40
radio-policy· 41
reset wlan client 41
reset wlan statistics 42
rts-threshold· 42
service-template (radio view) 43
service-template (service template view) 44
short-gi enable· 44
short-retry threshold· 45
shut-all-led enable· 46
ssid· 46
trap enable· 47
wlan country-code· 47
wlan link-test 50
wlan radio· 51
wlan radio-policy· 52
wlan radio-policy auto-create· 53
wlan service-template· 53
AC-AP tunnel configuration commands 54
ac· 54
ap-name· 55
backup-ac· 56
cir 56
cpu-usage threshold· 57
data-tunnel encryption enable· 57
description· 58
display wlan ap· 59
display wlan ap address 66
display wlan ap radio· 67
display wlan ap reboot-log· 68
display wlan ap-model 69
dns domain· 71
dns server 71
echo-interval 72
gateway· 73
hybrid-remote-ap enable· 73
ip address 74
ipv6 address 75
jumboframe enable· 75
map-configuration· 76
memory-usage threshold· 77
priority level 77
provision· 78
reset wlan ap· 78
reset wlan ap provision· 79
reset wlan ap reboot-log· 79
save wlan ap provision· 80
serial-id· 80
tunnel encryption ipsec pre-shared-key· 81
vlan pvid· 82
vlan tagged· 82
vlan untagged· 83
wlan ap· 84
wlan apdb· 84
wlan ap-execute· 85
wlan ap-provision ac· 85
wlan ap-provision dns domain· 86
wlan ap-provision dns server 87
wlan auto-ap enable· 87
wlan auto-ap persistent 88
wlan backup-ac· 89
wlan lwapp discovery-policy· 89
User isolation commands 90
display user-isolation statistics 90
reset user-isolation statistics 91
user-isolation enable· 91
user-isolation permit broadcast 92
user-isolation vlan enable· 92
user-isolation vlan permit-mac· 93
AP group configuration commands 94
ap· 94
description· 94
display wlan ap-group· 95
wlan ap-group· 96
wlan permit-ap-group· 96
SSID-based access control configuration commands 97
wlan permit-ssid· 97
Uplink detection commands 98
wlan uplink track· 98
AC hot backup configuration commands 98
display hot-backup state· 98
hot-backup enable· 99
hot-backup hellointerval 100
hot-backup vlan· 101
wlan backup-ac switch-delay· 101
wlan enable
wlan enable
undo wlan enable
View
Default level
2: System level
None
Use wlan enable to enable WLAN service.
Use undo wlan enable to disable WLAN service.
By default, WLAN service is enabled.
All WLAN services are available if and only if WLAN service is enabled.
# Enable WLAN service if it is disabled.
[Sysname] wlan enable
a-mpdu enable
a-mpdu enable
undo a-mpdu enable
View
Radio view
Default level
2: System level
None
Use a-mpdu enable to enable the A-MPDU function for the radio.
Use undo a-mpdu enable to disable the A-MPDU function for the radio.
By default, the A-MPDU function is enabled.
This command is only effective on 802.11n radios.
If you change the radio type of an 802.11n radio, the default setting for this function of the new radio type is restored.
# Disable the A-MPDU function.
[Sysname] wlan ap ap3 model WA2620-AGN
[Sysname-wlan-ap-ap3] radio 1 type dot11an
[Sysname-wlan-ap-ap3-radio-1] undo a-mpdu enable
a-msdu enable
a-msdu enable
undo a-msdu enable
View
Radio view
Default level
2: System level
None
Use a-msdu enable to enable the A-MSDU function for the radio.
Use undo a-msdu enable to disable the A-MSDU function for the radio.
By default, the A-MSDU function is enabled.
This command is only effective on 802.11n radios. If you change the radio type of an 802.11n radio, the default setting for this function of the new radio type is restored.
The device only receives but does not send A-MSDU frames.
# Disable the A-MSDU function.
[sysname-wlan-ap-ap3-radio-1] undo a-msdu enable
ani enable
ani enable
undo ani enable
View
Radio view
Default level
2: System level
None
Use ani enable to enable the Adaptive Noise Immunity (ANI) function.
Use undo ani enable to disable the ANI function.
By default, ANI is enabled.
After the ANI function is enabled, the device automatically adjusts the noise immunity level according to the surrounding signal environment to eliminate RF interference.
# Disable ANI.
[Sysname] wlan ap ap1 model WA2100
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] undo ani enable
antenna type
antenna type type
undo antenna type
View
Radio view
Default level
2: System level
type: Specifies the antenna type.
Use antenna type to specify the antenna type.
Use undo antenna type to restore the default.
The default setting of the command depends on the device model.
# Specify the antenna type.
[Sysname] wlan ap ap1 model wa2620e-agn
[Sysname-wlan-ap-ap1-radio-1] antenna type C5060
beacon ssid-hide
beacon ssid-hide
undo beacon ssid-hide
View
Service template view
Default level
2: System level
None
Use beacon ssid-hide to configure hiding the Service Set Identifier (SSID) in beacon frames.
Use undo beacon ssid-hide to restore the default.
By default, the SSID is not hidden in beacon frames.
If the SSID in beacon frames is hidden, the SSID must be configured for the clients to associate with the AP.
Hiding the SSID in beacon frames does little good to wireless security. Allowing the advertising of the SSID in beacon frames enables a client to discover an AP more easily.
# Hide the SSID in beacon frames.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] beacon ssid-hide
beacon-interval
beacon-interval interval
undo beacon-interval
View
Radio policy view
Default level
2: System level
interval: Specifies the interval for sending beacon frames. The value is in the range of 32 to 8191 time units (TUs).
Use beacon-interval to set the interval for sending beacon frames. Beacon frames are transmitted at a regular interval to allow mobile clients to join the network.
Use undo beacon-interval to restore the default beacon interval.
By default, the beacon interval is 100 TUs.
# Specify the beacon interval as 1000 TUs.
[Sysname] wlan radio-policy radio1
[Sysname-wlan-rp-radio1] beacon-interval 1000
bind wlan-ess
bind wlan-ess interface-index
undo bind wlan-ess
View
Default level
2: System level
interface-index: Specifies the index of the WLAN-ESS interface. The value range varies with AC models. For more information about AC models, see About the WX Series Access Controllers Command References.
Use bind wlan-ess to bind the specified WLAN-ESS interface to the service template.
Use undo bind wlan-ess to unbind the WLAN-ESS interface to the service template.
By default, no WLAN-ESS interface is bound to the service template.
# Bind interface WLAN-ESS 1 to service template 1.
[Sysname] interface WLAN-ESS 1
[Sysname-WLAN-ESS1] quit
[Sysname-wlan-st-1] bind wlan-ess 1
undo broadcast-probe reply
View
AP template view
Default level
2: System level
None
Use broadcast-probe reply to enable the AP to respond to the probe requests that carry no SSID.
Use undo broadcast-probe reply to configure the AP to respond only to probe requests that carry an SSID.
By default, an AP responds to probe requests that carry no SSID.
# Enable AP3 to respond to probe requests that carry no SSID.
[Sysname] wlan ap ap3 model WA2100
[Sysname-wlan-ap-ap3] broadcast-probe reply
channel
channel { channel-number | auto }
undo channel
View
Radio view
Default level
2: System level
channel-number: Specifies a channel. The working channels depend on the country code and radio mode.
auto: Specifies that the channel is automatically selected by the device according to the actual environment during system initialization.
Use channel to specify a channel for the radio. Different radios support different channels. Channels may differ for each country.
Use undo channel to restore the default.
By default, auto mode is set.
The channel channel-number, if specified, is always used, and you do not need to configure the channel lock command. If you configure the channel lock command first, and then the channel channel-number command, the earlier configuration is overwritten.
Before configuring DFS, be sure that the AC adopts the auto mode. Otherwise, DFS does not work. For more information about DFS, see WLAN Configuration Guide.
Related commands: channel lock, dot11a calibrate-channel, and dot11bg calibrate-channel.
# Specify channel 6 for radio 1 of AP3.
[Sysname-wlan-ap-ap3] radio 1 type dot11b
[Sysname-wlan-ap-ap3-radio-1] channel 6
channel band-width
channel band-width { 20 | 40 }
undo channel band-width
View
Radio view
Default level
2: System level
20: Specifies the channel bandwidth of the 802.11n radio as 20 MHz.
40: Specifies the channel bandwidth of the 802.11n radio as 40 MHz.
Use channel band-width to specify the channel bandwidth of the 802.11n radio.
Use undo channel band-width to restore the default.
By default, the channel bandwidth of the 802.11an radio is 40 MHz, and that of the 802.11gn radio is 20 MHz.
If the channel bandwidth of the radio is set to 40 MHz, a 40 MHz channel is used as the working channel. If no 40 MHz channel is available, only a 20 MHz channel can be used.
# Configure the channel bandwidth of the radio as 20 MHz.
[Sysname]wlan ap ap3 model WA2620-AGN
[Sysname-wlan-ap-ap3-radio-1] channel band-width 20
channel lock
channel lock
undo channel lock
View
Radio view
Default level
2: System level
None
Use channel lock to lock the current channel.
Use undo channel lock to unlock the current channel.
By default, the current channel is not locked.
The channel clock command takes effect only when the radio adopts the auto mode (configured with the channel auto command).
If you configure the channel lock command and then enable the radio by using the radio enable command, the radio automatically selects an optimal channel, and then locks the channel.
When the AC detects any radar signals on its channel, it immediately selects another channel even if the channel lock command is configured, and locks the new channel.
If you configure the channel lock command first, and then enable dynamic frequency selection (DFS), DFS does not work because the channel is locked. Therefore, before enabling DFS, make sure the current channel is not locked. If you enable DFS and then configure the channel lock command, the last selected channel is locked. For more information about DFS, see the WLAN Configuration Guide.
Related commands: channel, dot11a calibrate-channel, and dot11bg calibrate-channel.
# Lock the current channel.
[Sysname-wlan-ap-ap3] radio 1 type dot11g
[Sysname-wlan-ap-ap3-radio-1] channel lock
client dot11n-only
client dot11n-only
undo client dot11n-only
View
Radio view
Default level
2: System level
None
Use client dot11n-only to allow only 802.11n clients to access.
Use undo client dot11n-only to restore the default.
By default, an 802.11an radio permits both 802.11a and 802.11an clients to access, and an 802.11gn radio permits both 802.11b/g and 802.11gn clients to access.
An 802.11n radio supports both 2.4GHz and 5GHz bands and can allow 802.11a/b/g stations to access, providing good compatibility.
The client dot11n-only command prohibits non-802.11n clients from access. Therefore, if you want to provide access for all 802.11a/b/g clients, disable this command.
Related commands: dot11n mandatory maximum-mcs.
# Configure the radio to allow only 802.11n clients to access.
[Sysname-wlan-ap-ap3-radio-1] client dot11n-only
client forwarding-mode local [ vlan vlan-id-list ]
undo client forwarding-mode local
View
vlan vlan-id-list: VLANs used for local forwarding. This argument is expressed in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>, where vlan-id is in the range of 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. If this parameter is not specified, local forwarding is enabled on all the VLANs.
Use client forwarding-mode local to enable AP local forwarding in the service template.
Use undo client forwarding-mode local to disable AP local forwarding in the service template.
By default, remote forwarding is enabled in the service template.
After the service template is bound with an AP:
·     If local forwarding is enabled in the service template, the AP forwards data frames from associated clients.
·     If remote forwarding is enabled, the AC forwards data frames from associated clients.
Local forwarding greatly reduces the load of the AC by enabling APs to forward client traffic, especially in a WLAN servicing many clients.
# Enable local forwarding in service template 1.
[Sysname-wlan-st-1] client forwarding-mode local
client idle-timeout
client idle-timeout interval
undo client idle-timeout
View
AP template view
Default level
2: System level
interval: Specifies the time for which the link between AP and client ( power-save or awake ) can be idle. The value is in the range of 60 to 86400 seconds.
Use client idle-timeout to specify the client idle timeout interval. If a client is idle for more than the specified interval, or, if the AP does not receive any data from the client within a specified interval, the client is removed from the network.
Use undo client idle-timeout to restore the default.
By default, the client idle timeout interval is 3600 seconds.
# Specify the client idle timeout as 600 seconds.
[Sysname-wlan-ap-ap3] client idle-timeout 600
client keep-alive
client keep-alive interval
undo client keep-alive
View
AP template view
Default level
2: System level
interval: Interval between keep-alive requests. The value is in the range of 3 to 1800 seconds.
Use client keep-alive to specify the client keep-alive interval.
Use undo client keep-alive to disable the client keep-alive functionality.
The client keep-alive mechanism is used to detect clients segregated from the system due to various reasons such as power failure or crash, and disconnect them from AP.
By default, the client keep-alive functionality is disabled.
# Specify the client keep-alive interval as 60 seconds.
[Sysname-wlan-ap-ap3] client keep-alive 60
client max-count max-number
undo client max-count
View
Radio policy view
Default level
2: System level
max-number: Maximum number of allowed clients, in the range of 1 to 124.
Use client max-count to specify the maximum number of allowed clients for the radio policy.
Use undo client max-count to restore the default.
The default maximum number is 64.
# Specify that radio policy radio1 can accommodate at most 10 clients.
[Sysname-wlan-rp-radio1] client max-count 10
View
Default level
2: System level
max-number: Maximum number of clients associated to an SSID, in the range of 1 to 64.
Use client max-count to specify the maximum number of clients associated to an SSID on a radio.
By default, up to 64 clients can be associated to an SSID on a radio.
When the number of clients associated to an SSID on a radio reaches the maximum number, the SSID is automatically hidden.
# Specify the maximum number of clients associated to the SSID service on a radio as 10.
[Sysname-wlan-st-1] ssid service
[Sysname-wlan-st-1] client max-count 10
country-code
country-code code
undo country code
View
AP template view
Default level
2: System level
code: Country code. For information about country codes, see Table 11.
Use country-code to specify the country code of the AP.
Use undo country-code to remove the configuration.
By default, no country code is configured for the AP, and the AP uses the global country code.
An AP configured with a country code uses its own country code.
Related commands: wlan country-code, display wlan country-code.
# Specify the country code for the AP as US.
[Sysname] wlan ap ap1 model WA2620-AGN
[Sysname-wlan-ap-ap1] country-code us
display wlan client
display wlan client [ ap ap-name [ radio radio-number ] | mac-address mac-address | service-template service-template-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ap ap-name: Displays the information of clients which are connected to the specified AP.
radio radio-number: Displays the information of clients attached to the specified radio. The radio number value is 1.
mac-address mac-address: Specifies the MAC address of a client.
service-template service-template-number: Displays client information based on the specified service template. The service template number is in the range of 1 to 1024.
verbose: Displays detailed client information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display wlan client to display WLAN client information. The information is displayed in the order of client MAC address.
# Display information about all clients.
<Sysname> display wlan client
Total Number of Clients           : 3
                               Client Information
 SSID: office
 MAC Address   User Name            APID/RID        IP Address              VLAN
000f-e265-6400 –NA-                  1/1              1.1.1.1                1
000f-e265-6401 user                 1024/1          3.0.0.3                  3
000f-e265-6402 [email protected]       103 /1          FE:11:12:03::11:25:13    1
SSID
SSID with which the client is associated.
MAC address
MAC address of the client.
User Name
Username of the client:
·     The field displays -NA- if the client adopts plaintext authentication or ciphertext authentication with no username.
·     The field is irrelevant to the portal authentication method. If the client uses the portal authentication method, the field does not display the portal username of the client.
APID/RID
ID of the AP or radio that the client is associated with.
IP Address
IP address of the client.
VLAN
VLAN to which the client belongs.
# Display detailed information about all clients.
<Sysname> display wlan client verbose
 Total Number of Clients           : 1
                              Client Information
 MAC Address                       : 001e-58f6-01bf
 User Name                         : -NA-
 AID                               : 1
 AP Name                           : 2
Radio Id                           : 2
 SSID                              : office
 BSSID                             : 0026-3e08-1150
 Port                              : WLAN-DBSS0:3
 VLAN                              : 1
 State                             : Running
 Power Save Mode                   : Active
 Wireless Mode                     : 11gn
 Channel Band-width                : 20MHz
 SM Power Save Enable              : Disabled
 Short GI for 20MHz                : Not Supported
 Short GI for 40MHz                : Supported
 Support MCS Set                   : 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
 BLOCK ACK-TID 0                   : IN
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 10
 RSSI                              : 62
 Rx/Tx Rate                        : 130/11
 Client Type                       : PRE-RSNA
 Authentication Method             : Open System
 AKM Method                        : None
 4-Way Handshake State             : -NA-
 Group Key State                   : -NA-
 Encryption Cipher                 : Clear
 Roam Status                       : Normal
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 00:01:13
MAC address
User Name
AID
Association ID of the client.
AP Name
Name of the associated access point.
Radio ID
ID of the radio associated with the client.
SSID
SSID of the client.
BSSID
ID of the BSS.
Port
WLAN-DBSS interface associated with the client.
VLAN
State of the client such as running.
Backup indicates a backup client.
Power Save Mode
Client's power save mode such as active or sleep.
Wireless Mode
Wireless mode such as 802.11a, 802.11b, 802.11g, 802.11gn, 802.11an.
Channel Band-width
Channel bandwidth, 20 MHz or 40 MHz.
SM Power Save enables a client to have one antenna in the active state, and others in sleep state to save power.
·     EnabledSM Power Save is enabled.
·     DisabledSM Power Save is disabled.
Short GI for 20MHz
Whether the client supports short GI when its channel bandwidth is 20 MHz.
Short GI for 40MHz
Whether the client supports short GI when its channel bandwidth is 40 MHz.
Support MCS Set
MCS supported by the client.
BLOCK ACK-TID 0
BLOCK ACK is negotiated based on traffic identifier (TID) 0:
·     OUTOutbound direction.
·     INInbound direction.
·     BOTHBoth outbound and inbound directions.
BLOCK ACK-TID 3
BLOCK ACK is negotiated based on TID 3:
QoS Mode
WMM indicates that the WMM function is supported; None indicates that the WMM function is not supported.
WMM information negotiation is carried out between an AP and a client that both support WMM.
Listen Interval
Number of times the client has woken up to listen to beacon frames.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
Rx/Tx Rate
Represents the receiving and sending rates of the frames such as data, management, and control frames. For the AC + fit AP architecture, there is delay because Rx Rate is transmitted from AP to AC periodically depending on the statistics interval.
Client Type
Client type such as WPA2(RSN), WPA, or Pre-RSNA.
Authentication method such as open system or shared key.
AKM Method
AKM suite used such as Dot1X or PSK.
Displays either of the 4-way handshake states:
·     IDLEDisplayed in initial state.
·     PTKSTARTDisplayed when the 4–way handshake is initialized.
·     PTKNEGOTIATINGDisplayed after sending valid message 3.
·     PTKINITDONEDisplayed when the 4-way handshake is successful.
Group Key State
Displays the group key state such as:
·     REKEYNEGOTIATEDisplayed after the AC sends the initial message to the client.
·     REKEYESTABLISHEDDisplayed when re-keying is successful.
Encryption Cipher
Encryption cipher such as clear or crypto.
Roam Status
Displays the roam status such as Normal or Fast Roaming.
Roam Count
Roaming count of the client, including intra-AC roaming and inter-AC roaming.
·     For intra-AC roaming, this field is reset after the client is de-associated with the AP connected to the AC.
·     For inter-AC roaming, this field is reset after the client leaves the mobility group to which the AC belongs.
Up Time
Time for which the client has been associated with the AP.
display wlan country-code ap { name ap-name | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
name ap-name: Specifies the name of the AP, a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
all: Displays the country code information of all APs.
Use display wlan country-code to display the country code information of a specified AP or all APs.
Related commands: country-code.
# Display the country code information of all APs.
<Sysname> display wlan country-code ap all
                            Country Code
 AP                                         Country Code
 ap1                                        CN China
 ap2                                        US United States
display wlan radio-policy [ radio-policy-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
radio-policy-name: Name of a radio policy, a case-insensitive string of 1 to 15 characters which can contain letters, digits and underscores, with spaces excluded.
Use display wlan radio-policy to display information about a radio policy or all radio policies. The information displayed is in the order of radio-policy name.
# Display the configuration information for radio policy rp.
<Sysname> display wlan radio-policy rp
                             Radio Policy Parameters
 Radio Policy Name               : rp
 Fragmentation Threshold (Bytes) : 2346
 Beacon Interval (TU)            : 100
 RTS Threshold (Bytes)           : 2346
 DTIM Period (Beacon Interval)   : 1
 Long Retry Threshold            : 4
 Short Retry Threshold           : 7
 Maximum Rx Duration (ms)        : 2000
 Maximum clients per Radio       : 64
 QoS Mode                        : WMM
 Admission Control Policy        : Users
 Threshold users count           : 20
 CAC-Free's AC Request Policy    : Response Success
 CAC Unauthed Frame Policy       : Downgrade
 CAC Medium Time Limitation(us)  : 100000
 CAC AC-VO's Max Delay(us)       : 50000
 CAC AC-VI's Max Delay(us)       : 300000
 SVP packet mapped AC number     : Disabled
 Radio's WMM Parameters:
                          AC-BK    AC-BE    AC-VI    AC-VO
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       AckPolicy         Normal   Normal   Normal   Normal
 Client's WMM Parameters:
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
       CAC              Disable  Disable  Disable  Disable
# Display the configuration information for all radio policies.
 Radio Policy Name               : default_rp
 QoS Mode                        : WMM
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
 Radio Policy Name               : radio1
 QoS Mode                        : WMM
 Admission Control Policy        : Channelutilization
 Threshold utilization (%)       : 70
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
Radio Policy Name
Radio policy name.
Fragmentation threshold. If the length of a packet exceeds the threshold, the packet is fragmented before being transmitted.
Beacon Interval
Interval for sending beacon frames.
RTS Threshold
RTS threshold. If the length of a packet received on an AP exceeds the specified RTS threshold, the AP enables the RTS/CTS mechanism.
DTIM Period
DTIM period in units of beacon intervals.
Delivery traffic indication messages (DTIMs) are used to tell whether the buffered multicast packets can be transmitted.
Maximum number of retransmission attempts allowed for a frame greater than the RTS threshold.
Maximum number of retransmission attempts allowed for a frame shorter than the RTS threshold.
Maximum Rx Duration
Maximum time that a received packet can stay in the buffer.
Maximum number of clients allowed per radio.
QoS Mode
Admission control policy.
Threshold when the users-based admission policy is applied.
Threshold users utilization (%)
Threshold when channel utilization-based admission policy is applied.
Response policy adopted for CAC-incapable ACs.
Policy of processing frames unauthorized by CAC.
Maximum medium time allowed by the CAC policy (in microseconds).
Maximum voice traffic delay allowed by the CAC policy (in microseconds).
Maximum video traffic delay allowed by the CAC policy (in microseconds).
Number of the AC to which SVP packets are mapped.
ECWmin
ECWmin value (Exponent form of CWmin)
ECWmin and ECWmax determine the average backoff slots, which increase as the two values increase. For the detailed description of EDCA parameters, see WLAN Configuration Guide.
ECWmax
ECWmax value (Exponent form of CWmax).
AIFSN
AIFSN value.
TXOPLimit
TXOPLimit value.
AckPolicy
ACK policy adopted by an AC.
CAC
Indicates whether an AC is controlled by CAC: Disabled indicates that the AC is not controlled by CAC, Enabled indicates that the AC is controlled by CAC.
display wlan service-template [ service-template-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
service-template-number: Displays information about the specified service template. The value is in the range of 1 to 1024. If no service template is specified, all service templates are displayed.
Use display wlan service-template to display WLAN service template information.
# Display the configuration information for service template 1.
<Sysname> display wlan service-template 1
                          Service Template Parameters
 Service Template Number      : 1
 SSID                         : sharedkey
 Binding Interface            : WLAN-ESS1
 Service Template Type        : Crypto
 Security IE                  : Not Configured
 Authentication Method        : Shared Key
 SSID-hide                    : Disable
 Cipher Suite                 : WEP40
 WEP Key Index  1             : WEP40
 WEP Key Mode                 : ASCII
 WEP Key                      : -_'PV5%9O`CQ=^Q`MAF4<1!!
 WEP Key Index                : 1
 TKIP Countermeasure Time(s)  : 60
 PTK Life Time(s)             : 43200
 GTK Rekey                    : Enable
 GTK Rekey Method             : Time-based
 GTK Rekey Time(s)            : 86400
 Bridge Mode                  : Remote Forwarding
 Service Template Status      : Enable
 Maximum clients per BSS      : 64
Current service template number.
SSID
Service set identifier with which the client associates.
Binding Interface
Name of the interface bound with the service template.
Service template type crypto or clear.
Security IE
Security IE such as WPA and WPA2(RSN).
Authentication Algorithm
Type of authentication used.
SSID-hide
Enabled or disabled.
Forwarding Mode
Forwarding mode, local or remote.
Cipher Suite
Cipher suite such as AES-CCMP, TKIP, WEP40, WEP104 or WEP128.
WEP Key Index
Key index to encrypt or decrypt frames.
WEP Key Mode
WEP key format.
·     HEXHexadecimal string.
·     ASCIIASCII character string.
Counter measure time for MIC failure in seconds.
PTK Life Time(s)
PTK lifetime in seconds.
GTK Rekey
GTK rekey configured.
GTK Rekey Method
GTK rekey method configured such as packet based or time based.
GTK Rekey Time
Time for GTK rekey in seconds.
Bridge Mode
Forwarding mode:
·     Local forwardingAPs forward client data.
·     Remote forwardingThe AC forwards client data.
Status such as enabled or disabled.
Maximum number of associated clients per BSS.
display wlan statistics ap { all | name ap-name } connect-history [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the connection statistics of all APs.
name ap-name: Specifies the name of the AP, a case-insensitive string of 1 to 32 characters.
Use display wlan statistics ap connect-history to display AP connection statistics.
# Display the connection statistics of AP1.
<sysname> display wlan statistics ap name ap1 connect-history
                            Connection History
 AP Name                    : ap1
Associations               : 120
 Reassociations              :16
 Failures                   : 3
 Rejections                 : 23
 Exceptional Deassociations : 2
 Current Associations       : 51
Table 5 Command output
AP name
AP name
Associations
Total number of associations
Reassociations
Total number of reassociations
Failures
Total number of failed associations
Rejections
Total number of associations rejected
Total number of exceptional associations
Number of current associations
display wlan statistics client { all | mac-address mac-address } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
client: Displays client statistics.
all: Displays the statistics of all clients.
mac-address mac-address: Displays the statistics of the client with the specified MAC address.
Use display wlan statistics client to display client statistics.
# Display the statistics of all the clients.
<Sysname> display wlan statistics client all
                                Client Statistics
 AP Name                           : ap1
 Radio Id                          : 1
 SSID                              : office-1
 BSSID                             : 000f-e2ff-7700
 MAC Address                       : 0014-6c8a-43ff
 RSSI                              : 31
 Transmitted Frames:
 Back Ground (Frames/Bytes)        : 0/0
 Best Effort (Frames/Bytes)        : 9/1230
 Video (Frames/Bytes)              : 0/0
 Voice (Frames/Bytes)              : 2/76
 Received Frames:
 Best Effort (Frames/Bytes)        : 18/2437
 Voice (Frames/Bytes)              : 7/468
 Discarded Frames:
 Best Effort (Frames/Bytes)        : 0/0
 Voice (Frames/Bytes)              : 5/389
Table 6 Command output
AP Name
Access Point name
Radio Id
Radio ID
SSID
SSID to which the client is associated
BSSID
ID of the BSS
MAC Address
RSSI
Received Signal Strength Indicator. It indicates the client signal strength detected by the AP.
Transmitted Frames
Transmitted Frames
Back Ground
Statistics of background traffic
Best Effort
Statistics of best effort traffic
Video
Statistics of video traffic
Voice
Statistics of voice traffic
Received Frames
Received frames
Discarded Frames
Discarded frames
Statistics for background, best effort, video, and voice traffic are only for QoS-capable clients. For QoS-incapable clients, only best effort traffic statistics are available (including SVP packets) and may be inconsistent with the real physical output queues because the priority-queue statistics can only identify priorities carried in Dot11E and WMM packets. Otherwise, statistics of received packets cannot be collected.
display wlan statistics radio [ ap ap-name ] [ load ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
radio: Displays radio statistics.
ap ap-name: Displays the radio statistics of an AP. The AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underscores (_), square brackets ([ ]), slashes (/), and hyphens (-), but not spaces. If the ap ap-name option is not specified, the radio statistics of all APs are displayed.
load: Displays the load information.
Use display wlan statistics radio to display radio statistics.
Use display wlan statistics radio load to display radio load information.
# Display the radio statistics of AP 1.
<Sysname> display wlan statistics radio ap1
Radio Statistics
 AP Name: ap1                                   Radio Id: 1
 Transmitted Frames Statistics:
   Total Frames (Frames/Bytes)               : 0/0
   Unicast Frames (Frames/Bytes)             : 0/0
   Broadcast/Multicast Frames (Frames/Bytes) : 0/0
   Discarded Frames                : 0          Failed RTS         : 0
   Retry Count                     : 0          Successful RTS     : 0
   Multiple Retry Count            : 0          Failed ACK         : 0
   Authentication Frames           : 0          Association Frames : 0
   Packet Count Statistics Based on Size:
     128 >= size                   : 0
     128 < size <= 512             : 0
     512 < size <= 1024            : 0
     1024 < size                   : 0
   Packet Count Statistics Based on Rate:
         6 Mbps                    : 0                   9 Mbps    : 0
        12 Mbps                    : 0                  18 Mbps    : 0
        24 Mbps                    : 0                  36 Mbps    : 0
        48 Mbps                    : 0                  54 Mbps    : 0
   Packet Count Statistics Based on MCS Rate:
       6.5 Mbps                    : 0                  13 Mbps    : 0
      13.5 Mbps                    : 0                  15 Mbps    : 0
      19.5 Mbps                    : 0                  26 Mbps    : 0
        27 Mbps                    : 0                  30 Mbps    : 0
        39 Mbps                    : 0                40.5 Mbps    : 0
        45 Mbps                    : 0                  52 Mbps    : 0
        54 Mbps                    : 0                58.5 Mbps    : 0
        60 Mbps                    : 0                  65 Mbps    : 0
        78 Mbps                    : 0                  81 Mbps    : 0
        90 Mbps                    : 0                 104 Mbps    : 0
       108 Mbps                    : 0                 117 Mbps    : 0
       120 Mbps                    : 0               121.5 Mbps    : 0
       130 Mbps                    : 0                 135 Mbps    : 0
       150 Mbps                    : 0                 162 Mbps    : 0
       180 Mbps                    : 0                 216 Mbps    : 0
       240 Mbps                    : 0                 243 Mbps    : 0
       270 Mbps                    : 0                 300 Mbps    : 0
 Received Frames Statistics:
   Fragmented Frames               : 0          Duplicate Frames   : 0
   FCS Failures                    : 0          Decryption Errors  : 0
     128 >= size                   : 0
     1024 < size                   : 0
Table 7 Command output
AP name
Access Point name
Radio ID
Radio ID
Total Frames
Number of frames transmitted, including probe responses and beacon frames
Unicast Frames
Number of unicast frames transmitted, excluding probe responses
Number of broadcast or multicast frames transmitted
Others (Frames/Bytes)
Number of other frames transmitted
Discard Frames
Number of frames discarded.
Failed RTS
Number of RTS failed during transmission
Retry Count
Number of transmission retries
Successful RTS
Number of RTS transmitted successfully
Failed Ack
Number of transmitted frames for which no acknowledgement is received
Number of authentication response frames transmitted
Association Frames
Number of association response frames transmitted
Packet statistics classified by packet size
Packet statistics classified by rate
Packet Count Statistics Based on 802.11n Rate
Packet statistics classified by 802.11n rate. The field is not displayed if the device does not support 802.11n.
Total Frames
Number of fragmented frames received
Unicast Frames
Number of unicast frames received
Number of broadcast or multicast frames received
Fragmented Frames
Duplicate Frames
Number of duplicate frames received
FCS Failures
Number of frames dropped due to FCS failure
Decryption Errors
Number of frames dropped due to decryption error
Number of authentication request frames received
Association Frames
Number of association request frames received
# Display the radio load information of all APs.
<sysname> display wlan statistics radio load
                            Radio Load
 AP Name                                Radio       Client Number
 ap1                                    1           0
 ap1                                    2           11
 ap2                                    1           20
 ap_chinanet_1                          1           5
 ap_chinanet_2                          2           35
Table 8 Command output
AP name
Access Point name
Radio ID
Radio ID
Client Number
Number of associated clients
display wlan statistics service-template service-template-number [ connect-history ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
service-template-number: Service template number, in the range of 1 to 1024.
connection-history: Displays the connection history.
Use display wlan statistics service-template to display service template statistics.
Use display wlan statistics service-template service-template-number connect-history to display the connection statistics for all APs bound to the service template.
# Display the statistics of service template office.
<sysname> display wlan statistics service-template office
                        Service Template Statistics
Service Template           : office
AP Name                    : ap1
 Radio                      : 1
 Receive                    :
    Frame Count             : 1713
    Frame Bytes             : 487061
    Data Frame Count        : 1683
    Data Frame Bytes        : 485761
    Associate Frame Count   : 2
 Send                       :
    Frame Count             : 62113
    Frame Bytes             : 25142076
    Data Frame Count        : 55978
    Data Frame Bytes        : 22626600
Table 9 Command output
Service Template
AP Name
AP name
Receive
Receive statistics:
·     Frame Count—Number of frames received
·     Frame Bytes—Number of bytes received
·     Data Frame Count—Number of data frames received
·     Data Frame Bytes—Number of data bytes received
·     Associate Frame Count—Number of association requests received
Send
Send statistics:
·     Frame Count—Number of frames sent
·     Frame Bytes—Number of bytes sent
·     Data Frame Count—Number of data frames sent
·     Data Frame Bytes—Number of data bytes sent
·     Associate Frame Count—Number of association requests sent
# Display the connection history of service template office.
<sysname> display wlan statistics service-template office connect-history
                            Connect History
 AP Name                    : ap1
 Radio                      : 1
 Associations               : 132
 Failures                   : 3
 Reassociations             : 30
 Rejections                 : 12
 Current Associations       : 57
 AP Name                    : ap1
 Radio                      : 2
 Associations               : 1004
 Failures                   : 35
 Reassociations             : 59
 Rejections                 : 4
 Exceptional Deassociations : 22
 Current Associations       : 300
Table 10 Command output
Service Template
AP name
AP name
Radio
Radio number
Associations
Failures
Reassociations
Rejections
distance
distance distance
undo distance
View
Radio view
Default level
2: System level
distance: Specifies the maximum distance that the radio can cover, in the range of 1 to 40 km (0.62 to 24.86 miles).
Use distance to configure the maximum distance that the radio can cover.
Use undo distance to restore the default.
By default, the radio can cover 1 km (0.62 miles) at most.
# Configure the maximum distance that the radio can cover as 5 km (3.11 miles).
[Sysname-wlan-ap-ap1-radio-1] distance 5
dtim
dtim counter
undo dtim
View
Radio policy view
Default level
2: System level
counter: Number of beacon intervals between delivery traffic indication message (DTIM) transmissions. The value is in the range of 1 to 31.
Use dtim to set the number of beacon intervals an AP waits before it sends buffered multicast and broadcast frames. The AP sends buffered broadcast/multicast frames when the DTIM counter reaches the configured value.
Use undo dtim to restore the default.
By default, the DTIM counter is 1.
# Set the DTIM counter to 10.
[Sysname] wlan radio-policy rp
[Sysname-wlan-rp-rp] dtim 10
undo fast-association enable
View
Default level
2: System level
None
Use fast-association enable to enable fast association.
Use undo fast-association enable to disable fast association.
By default, fast association is disabled.
When fast association is enabled, the AP does not perform band navigation and load balancing calculations for clients bound to the SSID.
# Enable fast association.
[Sysname-wlan-st-1] fast-association enable
fragment-threshold
fragment-threshold size
undo fragment-threshold
View
Radio policy view
Default level
2: System level
size: Maximum frame length without fragmentation. The value is in the range of 256 to 2346 bytes and must be an even number.
Use fragment-threshold to specify the maximum length of frames that can be transmitted without fragmentation. When the length of a frame exceeds the specified fragment threshold value, it is fragmented.
Use undo fragment-threshold to restore the default value.
By default, the fragment threshold is 2346 bytes. Frames that exceed 2346 bytes are fragmented.
# Specify the fragment threshold as 2048 bytes.
[Sysname-wlan-rp-rp] fragment-threshold 2048
long-retry threshold count
undo long-retry threshold
View
Radio policy view
Default level
2: System level
count: Number of retransmission attempts for frames larger than the RTS threshold, in the range of 1 to 15.
Use long-retry threshold to set the number of retransmission attempts for frames larger than the RTS threshold.
Use undo long-retry threshold to restore the default.
By default, the long retry threshold is 4.
# Specify the long-retry threshold as 10.
[Sysname-wlan-rp-rp] long-retry threshold 10
max-power
max-power radio-power
undo max-power
View
Radio view
Default level
2: System level
radio-power: Maximum radio transmission power, which varies with country codes and radio types. The value depends on the device model.
Use max-power to configure the maximum transmission power on the radio.
Use undo max-power to restore the default.
By default, the maximum radio power varies with country codes, channels, AP models, radio types and antenna types. If 802.11n is adopted, the maximum radio power also depends on the bandwidth mode.
Related commands: wlan country-code and radio type.
# Specify the max transmission power of radio 1 as 5.
[Sysname-wlan-ap-ap3-radio-1] max-power 5
max-rx-duration
max-rx-duration interval
undo max-rx-duration
View
Radio policy view
Default level
2: System level
interval: Maximum interval for which a frame received by an AP can stay in the buffer memory. The value is in the range of 500 to 250000 milliseconds.
Use max-rx-duration to specify the maximum interval for the AP to hold a received frame.
Use undo max-rx-duration to restore the default.
By default, the max-rx-duration is 2000 milliseconds.
# Set the max-rx-duration as 5000 milliseconds.
[Sysname-wlan-rp-radio1] max-rx-duration 5000
nas-id
nas-id text
undo nas-id
View
AP template view
Default level
2: System level
text: Sets the network access server (NAS)-ID for an AP. It is a case-sensitive string of 1 to 20 characters.
Use nas-id to set the NAS-ID for an AP.
Use undo nas-id to remove the NAS-ID.
By default, no NAS-ID is configured for an AP.
# Set the NAS-ID for AP 1 to 0002053110000460.
[Sysname-ap-ap1] nas-id 0002053110000460
nas-port-id
nas-port-id text
undo nas-port-id
View
AP template view
Default level
2: System level
text: Sets the NAS-PORT-ID for an AP. It is a case-sensitive string of 1 to 63 characters.
Use nas-port-id to set the NAS-PORT-ID for an AP.
Use undo nas-port-id to remove the NAS-PORT-ID.
By default, no NAS-PORT-ID is configured for an AP.
# Set the NAS-PORT-ID for AP 1 to abcd1234.
[Sysname-ap-ap1] nas-port-id abcd1234
power lock
power lock
undo power lock
View
Radio view
Default level
2: System level
None
Use power lock to lock the current power, and set the current power as the maximum power.
Use undo power lock to unlock the current power, and restore the maximum power set by the max-power command.
By default, the current power is not locked.
If you configure the power lock command first, and then enable power selection, Transmit power control (TPC) does not work because the power is locked. Therefore, before enabling TPC, be sure that the current power is not locked. If you enable TPC, and then configure the power lock command, the last selected power is locked. For more information about TPC, see WLAN Configuration Guide.
Related commands: max-power, dot11a calibrate-power, and dot11bg calibrate-power.
# Lock the current power.
[Sysname-wlan-ap-ap3-radio-1] power lock
preamble
preamble { long | short }
undo preamble
View
Radio view
Default level
2: System level
long: Indicates that only frames with long preamble can be transmitted.
short: Indicates that frames with either short preamble or long preamble can be transmitted.
Use preamble to specify the preamble type.
Use undo preamble to restore the default.
Preamble is a pattern of bits at the beginning of a frame so that the receiver can sync up and be ready for the real data. There are two different kinds of preambles, short and long.
By default, the short preamble is supported.
802.11a and 802.11an do not support this configuration.
# Configure the AP to support long preamble.
[Sysname] wlan ap ap2 model WA2100
[Sysname-wlan-ap-ap2] radio 1 type dot11b
[Sysname-wlan-ap-ap2-radio-1] preamble long
protection-mode
protection-mode { cts-to-self | rts-cts }
undo protection-mode
View
Radio policy view
Default level
2: System level
cts-to-self: Specifies the Clear to Send (CTS)-to-Self collision avoidance mechanism.
rts-cts: Specifies the Request to Send (RTS)/CTS collision avoidance mechanism.
Use protection-mode to specify a collision avoidance mechanism. When the size of a data frame sent by the AP exceeds the specified threshold, the specified collision avoidance mechanism is used.
Use undo protection-mode to restore the default.
By default, the collision avoidance mechanism is RTS/CTS.
For more information about CTS-to-Self and RTS/CTS, see WLAN Configuration Guide.
# Configure the collision avoidance mechanism as CTS-to-Self.
[Sysname] wlan radio-policy test
[Sysname-wlan-rp-test] protection-mode cts-to-self
radio
radio { disable | enable }
undo radio
View
Radio view
Default level
2: System level
disable: Disables the radio.
enable: Enables the radio.
Use radio to enable or disable the radio.
Use undo radio to remove the configuration.
By default, all radios are disabled.
# Enable radio 1 of the AP.
[Sysname-wlan-ap-ap3-radio-1] radio enable
radio type
radio radio-number [ type { dot11a | dot11an | dot11b | dot11g | dot11gn } ]
View
AP template view
Default level
2: System level
radio-number: Radio number. The radio number value is 1 or 2. The actual value range is based on the AP model.
dot11a: Indicates the wireless radio type is 802.11a.
dot11an: Indicates the wireless radio type is 802.11an (5GHz).
dot11b: Indicates the wireless radio type is 802.11b.
dot11g: Indicates the wireless radio type is 802.11g.
dot11gn: Indicates the wireless radio type is 802.11gn (2.4GHz).
Use radio type to specify the radio type to be used by a radio, and enter radio view.
The default setting varies depending on the AP model.
# Specify the radio type as 802.11g for radio 1.
# Specify the radio type as 802.11an for radio 1.
<sysname> system-view
[sysname] wlan ap ap1 model WA2620-AGN
[sysname-wlan-ap-ap1] radio 1 type dot11an
radio-policy
radio-policy radio-policy-name
undo radio-policy
View
Radio view
Default level
2: System level
radio-policy-name: Name of the radio policy, a case-insensitive string of 1 to 15 characters that can contain letters, digits and underscores but not spaces.
Use radio-policy to map a radio policy to a radio.
Use undo radio-policy to remove the mapping.
By default, the default_rp radio policy is mapped to a radio. The default_rp radio policy contains all the default parameters.
The radio policy to be bound must have been created with the wlan radio-policy command.
Related commands: display wlan radio-policy and wlan radio-policy.
# Map radio policy radiorp to radio 1.
[Sysname-wlan-ap-ap3-radio-1] radio-policy radiorp
reset wlan client
reset wlan client { all | mac-address mac-address }
View
Default level
2: System level
all: Terminates connections of all clients to the AP.
mac address mac-address: Specifies the MAC address of the client whose connection to the AP is to be terminated.
Use reset wlan client to terminate connections of a client or all clients to the AP. When this command is used, the AP sends a de-authentication frame to the client and the client is removed from the WLAN service.
# Terminate the connection of the client with MAC address 000f-e2cc-8501 to the AP.
<Sysname> reset wlan client mac-address 000f-e2cc-8501
reset wlan statistics { client { all |  mac-address mac-address } | radio [ ap-name ] }
View
Default level
2: System level
all: Clears the statistics of all clients.
mac-address mac-address: Clears the statistics of the client.
ap-name: Clears the radio statistics of an AP. The AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
Use reset wlan statistics to clear statistics of the specified AP or client, or all clients.
# Clear the radio statistics of AP1.
<Sysname> reset wlan statistics radio ap1
rts-threshold
rts-threshold size
undo rts-threshold
View
Radio policy view
Default level
2: System level
size: Length of frames for which the request to send (RTS) mechanism is used. The value is in the range of 0 to 2346 bytes.
Use rts-threshold to specify the RTS threshold length. If a frame is larger than this value, the RTS mechanism is used.
Use undo rts-threshold to restore the default.
By default, the RTS threshold is 2346 bytes.
RTS is used to avoid data collisions in a WLAN.
A small value causes RTS packets to be sent more often, consuming more of the available bandwidth. However, the more often RTS packets are sent, the quicker the system can recover from interference or collisions.
# Specify the RTS threshold as 2046 bytes.
[Sysname-wlan-rp-rp] rts-threshold 2046
service-template service-template-number [ vlan-id vlan-id1 [ vlan-id2 ] ] [ nas-port-id nas-port-id | nas-id nas-id ] [ ssid-hide ]
undo service-template service-template-number
View
Radio view
Default level
2: System level
service-template-number: Number of a service template in the range of 1 to 1024.
vlan-id vlan-id1 vlan-id2: Sets the ID of a VLAN to be bound, in the range of 1 to 1024. You can select two VLANs for QinQ application.
nas-port-id nas-port-id: Sets the ID of the NAS port to be bound. The ID is a case-insensitive string of 1 to 63 characters, without spaces.
nas-id nas-id: Sets the ID of the NAS to be bound. The ID is a case-insensitive string of 1 to 20 characters, without spaces.
ssid-hide: Sets to hide the SSID in beacon frames for the service bound to the AP. If you do not specify this keyword, whether the SSID is hidden or not depends on the beacon ssid-hide command.
Use service-template to map a service template to the current radio.
Use undo service-template to remove the mapping.
By default, no service template is mapped to a radio.
You can map multiple service templates to a radio.
# Map service template 1 to radio 1.
[Sysname-wlan-ap-ap3-radio-1] service-template 1
service-template { disable | enable }
undo service-template enable
View
Default level
2: System level
disable: Disables the service template.
enable: Enables the service template.
Use service-template enable to enable the service template.
Use service-template disable or undo service-template enable to disable the service template.
By default, the service template is disabled.
# Enable service template 1.
[Sysname-wlan-st-1] ssid clear
[Sysname-wlan-st-1] authentication-method open-system
[Sysname-wlan-st-1] service-template enable
short-gi enable
short-gi enable
undo short-gi enable
View
Radio view
Default level
2: System level
None
Use short-gi enable to enable the short GI function.
Use undo short-gi enable to disable the short GI function.
By default, the short GI function is enabled.
Delays may occur during receiving radio signals due to factors like multi-path reception. Therefore, a subsequently sent frame may interfere with a previously sent frame. The GI function is used to avoid such interference.
The GI interval in 802.11a/g is 800 us. The short GI function can be configured for 802.11n. This can shorten the GI interval to 400 ns, which increases the data speed by 10 percent.
# Disable the short GI function.
[sysname] wlan ap ap3 model WA2620-AGN
[sysname-wlan-ap-ap3] radio 1 type dot11an
[sysname-wlan-ap-ap3-radio-1] undo short-gi enable
short-retry threshold count
undo short-retry threshold
View
Radio policy view
Default level
2: System level
count: Number of times the AP can send a short unicast frame (less than the RTS threshold) if no acknowledgment is received for it. The value is in the range of 1 to 15.
Use short-retry threshold to specify the maximum number of attempts to transmit a frame less than the RTS threshold.
Use undo short-retry threshold to restore the default.
By default, the short retry threshold is 7.
# Specify the short retry threshold as 10.
[Sysname-wlan-rp-rp] short-retry threshold 10
shut-all-led enable
shut-all-led enable
undo shut-all-led enable
View
AP template view
Default level
2: System level
None
Use shut-all-led enable to shut down all LEDs on all the online APs of the current AP template.
Use undo shut-all-led enable to restore the default.
By default, all LEDs on all the online APs of the current AP template light based on AP status.
# Shut down all LEDs on all the online APs of AP template ap5.
<Sysname>system-view
[Sysname]wlan ap ap5 model WA2620-AGN
[Sysname-wlan-ap-ap5]shut-all-led enable
ssid
ssid ssid-name
undo ssid
View
Default level
2: System level
ssid-name: Name of the service set identifier, a case-sensitive string of 1 to 32 characters that can contain letters, digits, underlines, and spaces.
Use ssid to set the SSID for the current service template.
Use undo ssid to remove the SSID.
By default, no SSID is set for the service template.
An SSID must be as unique as possible. For security, the company name must not be contained in the SSID. Meanwhile, it is not recommended to use a long random string as the SSID, because a long random string only adds payload to the header field, without any improvement to wireless security.
# Set the SSID as firstfloor for service template 1.
[Sysname-wlan-st-1] ssid firstfloor
trap enable
trap enable
undo trap enable
View
AP template view
Default level
2: System level
None
Use trap enable to enable traps for the AP.
Use undo trap enable to disable traps for the AP.
By default, traps are disabled.
# Enable traps for the AP.
<AC>system-view
[AC]wlan ap ap2 model WA2610-AGN id 2
[AC-wlan-ap-ap2] trap enable
[AC-wlan-ap-ap2]device-detection enable
[AC-wlan-ap-ap2]
#Nov 19 14:10:30:003 2009 H3C WMAC/4/AP WorkMode Changed: Work mode of AP change
d:1.3.6.1.4.1.2011.10.2.75.2.3.0.1<h3cDot11APMtWorkModeChgTrap> Serial ID:210235
A35XB09B000008 WorkMode: 3
wlan country-code
wlan country-code code
undo wlan country-code
View
Default level
2: System level
code: Specifies a global country code. See Table 11.
Table 11 Country code information
Country
Code
Country
Code
Andorra
AD
Korea, Republic of Korea
KR
United Arab Emirates
AE
Kenya
KE
Albania
AL
Kuwait
KW
Armenia
AM
Kazakhstan
KZ
Australia
AU
Lebanon
LB
Argentina
AR
Liechtenstein
LI
Australia
AT
Sri Lanka
LK
Azerbaijan
AZ
Lithuania
LT
Bosnia and Herzegovina
BA
Luxembourg
LU
Belgium
BE
Latvia
LV
Bulgaria
BG
Libyan
LY
Bahrain
BH
Morocco
MA
Brunei Darussalam
BN
Monaco
MC
Bolivia
BO
Moldova
MD
Brazil
BR
Macedonia
MK
Bahamas
BS
Macau
MO
Belarus
BY
Martinique
MQ
Belize
BZ
Malta
MT
Canada
CA
Mauritius
MU
Switzerland
CH
Mexico
MX
Cote d'ivoire
CI
Malay Archipelago
MY
Chile
CL
Namibia
NA
China
CN
Nigeria
NG
Colombia
CO
Nicaragua
NI
Costarica
CR
Netherlands
NL
Serbia
RS
Norway
NO
Cyprus
CY
New Zealand
NZ
Czech Republic
CZ
Oman
OM
Germany
DE
Panama
PA
Denmark
DK
Peru
PE
Dominica
DO
Poland
PL
Algeria
DZ
Philippines
PH
Ecuador
EC
Pakistan
PK
Estonia
EE
Puerto Rico
PR
Egypt
EG
Portugal
PT
Spain
ES
Paraguay
PY
Faroe Islands
FO
Qatar
QA
Finland
FI
Romania
RO
France
FR
Russian Federation
RU
Britain
GB
Saudi Arabia
SA
Georgia
GE
Sweden
SE
Gibraltar
GI
Singapore
SG
Greenland
GL
Slovenia
SI
Guadeloupe
GP
Slovak
SK
Greece
GR
San Marino
SM
Guatemala
GT
Salvador
SV
Guyana
GY
Syrian
SY
Honduras
HN
Thailand
TH
Hong Kong
HK
Tunisia
TN
Croatia
HR
Turkey
TR
Hungary
HU
Trinidad and Tobago
TT
Iceland
IS
, Province of China
TW
India
IN
Ukraine
UA
Indonesia
ID
United States of America
US
Ireland
IE
Uruguay
UY
Israel
IL
Uzbekistan
UZ
Iraq
IQ
The Vatican City State
VA
Italy
IT
Venezuela
VE
Iran
IR
Virgin Islands
VI
Jamaica
JM
Vietnam
VN
Jordan
JO
Yemen
YE
Japan
JP
South Africa
ZA
Democratic People's Republic of Korea
KP
Zimbabwe
ZW
Use wlan country-code to specify the global country code.
Use undo wlan country-code to restore the default.
By default, the global country code is CN.
·     The country code determines characteristics such as the power level, total number of channels. You must set the correct country code or area code for a WLAN device (AC or AP).
·     If an AP is configured with a country code in AP template view or has a fixed country code, changing the global country code does not affect the country code of the AP.
# Specify the country code as US.
[Sysname] wlan country-code us
wlan link-test
wlan link-test mac-address
View
Default level
1: Monitor level
mac-address: MAC address of a client. Only clients that have been associated with the AP can be RFPinged.
Use wlan link-test to RFPing a client.
# Perform an RFPing operation to the client with the MAC address 000f-e201-0101.
<Sysname> wlan link-test 000f-e201-0101
Testing link to 000f-e201-0101, press CTRL_C to break......
                                Link Status
 RTT: Round trip time
 MAC Address: 000f-e201-0101
 No.    Rate(Mbps)  TxCnt   RxCnt   RSSI    Retries     RTT(ms)
 0      1           5       2       62      0           0
 1      2           5       5       10      0           0
 2      5.5         5       5       10      0           1
 3      6           5       5       10      0           0
 4      9           5       5       11      0           0
 5      11          5       5       11      0           0
 6      12          5       5       10      0           0
 7      18          5       5       10      0           0
 8      24          5       5       11      0           0
 9      36          5       5       11      0           0
 10     48          5       5       10      0           0
 11     54          5       5       11      0           0
Table 12 RFPing operation results
No./MCS
·     The No. field is displayed for an RFPing operation to a non 802.11n client, indicating the rate index of the client.
·     The MCS field is displayed for an RFPing operation to an 802.11n client, indicating the MCS value of the client.
Rate(Mbps)
Rate for the radio interface to send ping packets
TxCnt
Number of ping packets sent by the radio interface
RxCnt
Number of ping packets received by the radio interface from the client
RSSI
Received signal strength indicator (RSSI),
Retries
Number of retries when the radio interface failed to send ping packets
RTT(ms)
Round-trip time (RTT) from the time when the radio interface send a ping packet to the time when it receives a response from the client
wlan radio
wlan radio { disable | enable } { all | dot11a | dot11an | dot11b | dot11g | dot11gn | radio-policy radio-policy-name }
View
Default level
2: System level
disable: Disables WLAN radios.
enable: Enables WLAN radios.
all: Enables or disables all the WLAN radios.
dot11a: Enables or disables 802.11a WLAN radios.
dot11an: Enables or disables 802.11an WLAN radios.
dot11b: Enables or disables 802.11b WLAN radios.
dot11g: Enables or disables 802.11g WLAN radios.
dot11gn: Enables or disables 802.11gn WLAN radios.
radio-policy radio-policy-name: Specifies a radio policy, a case-insensitive string of 1 to 15 characters that can contain letters, digits and underscores but not spaces.
Use wlan radio enable to enable WLAN radios.
Use wlan radio disable to disable WLAN radios.
By default, no wlan radio is enabled.
# Enable all the radios.
[Sysname] wlan radio enable all
# Enable 802.11g radios.
[Sysname] wlan radio enable dot11g
wlan radio-policy
wlan radio-policy radio-policy-name
undo wlan radio-policy radio-policy-name
View
Default level
2: System level
radio-policy-name: Name of a radio policy, a case-insensitive string of 1 to 15 characters that can contain letters, digits and underlines but not spaces.
Use wlan radio-policy to create a radio policy, or enter radio policy view, or both. A radio policy is a set of radio attributes. If the radio policy is mapped to a radio, the radio will have all the attributes configured in the radio policy.
A WLAN radio policy includes the following attributes:
·     Radio policy name
·     Fragmentation threshold (Bytes)
·     Beacon interval (TU)
·     RTS threshold (Bytes)
·     DTIM period (Beacon Intervals)
·     Long retry threshold
·     Short retry threshold
·     Maximum Rx duration (ms)
·     Maximum Tx duration (ms)
·     The maximum duration that the frames received by the AP can be kept in the buffer (ms)
Use undo wlan radio-policy to delete the radio policy, and all related configurations.
If the radio-policy is mapped with a radio, it cannot be directly deleted before it is un-mapped.
By default, the default radio policy default_rp is mapped with a WLAN radio.
# Create a radio policy named radio1.
wlan radio-policy auto-create
undo wlan radio-policy auto-create
View
Default level
2: System level
Use wlan radio-policy auto-create to enable automatic creation of radio policies.
Use undo wlan radio-policy auto-create to disable automatic creation of radio policies.
By default, automatic creation of radio policies is disabled.
# Enable automatic creation of radio policies.
[Sysname] wlan radio-policy auto-create
# Disable automatic creation of radio policies.
[Sysname] undo wlan radio-policy auto-create
wlan service-template service-template-number { clear | crypto }
undo wlan service-template service-template-number
View
Default level
2: System level
service-template-number: Number of the service template, in the range of 1 to 1024.
clear: Sets the current service template type to clear, which means data is sent in clear text after the template is mapped to an AP.
crypto: Sets the current service template type to crypto, which means data is sent in cipher text after the template is mapped to an AP.
Use wlan service-template to create a service template and enter service template view. If the service template exists, then you can directly enter service template view.
Use undo wlan service-template to delete the service template. If the specified service template is mapped to a radio, it cannot be directly deleted before it is un-mapped.
No service template is configured by default.
You cannot change an existing service template to another type. To do so, you must delete the service template, and configure a new service template with the new type.
# Create service template 1.
[Sysname] wlan service-template 1 crypto
AC-AP tunnel configuration commands
ac
ac { host-name host-name | ip ip-address | ipv6 ipv6-address }
undo ac { host-name | ip { ip-address | all } | ipv6 { ipv6-address | all } }
View
AP configuration view
Default level
2: System level
host-name host-name: Specifies the host name of an AC, a case-insensitive string of 1 to 255 characters. The string can contain letters, digits, "-", "_" and ".", and must contain at least one letter.
ip ip-address: Specifies the IPv4 address of an AC.
ipv6 ipv6-address: Specifies the IPv6 address of an AC.
all: Removes the IPv4/IPv6 addresses of all ACs.
Use ac to specify an AC so that the AP can discover the AC.
Use undo ac to remove the AC configuration.
By default, no AC is specified for the AP.
You can specify at most three ACs' IP addresses, three ACs' IPv6 addresses, and an AC's host name for the AP.
The wlan ap-provision ac command takes effect for all APs, and the ac command in AP configuration view takes effect for the specified AP. If you configure both commands, the configuration in AP configuration view takes effect for the AP.
Related commands: wlan ap-provision ac.
# Specify the AC 192.168.100.11 so that AP 1 can discover the AC.
[Sysname] wlan ap ap1 model WA2100
[Sysname-wlan-ap-ap1] provision
[Sysname-wlan-ap-ap1-prvs] ac ip 192.168.100.11
ap-name
ap-name name
undo ap-name
View
AP template view
Default level
2: System level
name: AP name, a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces..
Use ap-name to specify the name for the AP.
Use undo ap-name to clear the name of the AP.
By default, no AP name is specified.
# Set the name for an AP as admin.
[Sysname-ap-ap1] ap-name admin
backup-ac
backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo backup-ac { ip | ipv6 }
View
AP template view
View
Default level
2: System level
ipv4-address: Specifies an IPv4 address for a backup AC.
Ipv6-address: Specifies an IPv6 address for a backup AC.
Use backup-ac to specify an IPv4/IPv6 backup AC.
Use undo backup-ac to remove the IPv4/IPv6 backup ACs.
By default, the global backup AC, if specified, is used by the AP.
The backup AC configured in AP template view takes precedence over that configured in system view.
# Specify the backup AC at 192.168.1.2 for AP 1.
[Sysname] wlan backup-ac ip 192.168.1.1
[Sysname-wlan-ap-ap1] backup-ac ip 192.168.1.2
cir
cir committed-information-rate [ cbs committed-burst-size ]
undo cir
View
AP template view
Default level
2: System level
cir committed-information-rate: Committed information rate in kbps, in the range of 40 to 1000000.
cbs committed-burst-size: Committed burst size in bytes, in the range of 2500 to 62500000. By default, the CBS is the number of bytes transmitted in 500 ms at the rate of CIR.
Use cir to set the CIR for packets sent from AC to AP.
Use undo cir to restore the default.
By default, no CIR is set for an AP.
For more information about CIR, see ACL and QoS Command Reference.
# Set the CIR to 60 kbps, and CBS to 3000 bytes for the AP.
[Sysname] wlan ap ap_001 model wa2100
[Sysname-wlan-ap-ap_001] cir 60 cbs 3000
cpu-usage threshold
cpu-usage threshold integer
View
AP template view
Default level
3: Manage level
integer: An integer in the range of 0 to 100.
Use cpu-usage threshold to set the CPU usage threshold of the AP. If the CPU usage of the AP exceeds the threshold, the AP generates an alarm.
By default, the default CPU usage threshold of the AP is 90.
# Set the CPU usage threshold of AP 3 to 95.
[Sysname-wlan-ap-ap3] cpu-usage threshold 95
data-tunnel encryption enable
undo data-tunnel encryption enable
View
Default level
2: System level
None
Use data-tunnel encryption enable to configure the AP to use IPsec to encrypt the data tunnel.
Use undo data-tunnel encryption enable to remove the configuration.
By default, the AP does not encrypt the data tunnel.
Related commands: tunnel encryption ipsec pre-shared-key.
# Configure the AP to use IPsec to encrypt the data tunnel.
[Sysname-wlan-ap-ap1-prvs] tunnel encryption ipsec pre-shared-key simple 12345
[Sysname-wlan-ap-ap1-prvs] data-tunnel encryption enable
description
View
AP template view
Default level
2: System level
text: Description for the AP, a string of 1 to 64 characters. A description string can be entered in uppercase as well as lower case and can have special characters and spaces, but spaces at the beginning and end of the description string are discarded if given.
Use description to set a description for an AP.
Use undo description to clear the description of an AP.
By default, no description is set for an AP.
# Set a description for an AP.
[Sysname-ap-ap1] description L3-office
display wlan ap
display wlan ap { all | name ap-name } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the information of all the APs.
name ap-name: Displays information about the AP. An AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
verbose: Displays the detailed information.
Use display wlan ap to display the information of a specified AP or all APs.
# Display the configuration information of AP1.
<Sysname> display wlan ap name ap1
                                  AP Profile
State : I = Idle,   J = Join, JA = JoinAck,   IL = ImageLoad
        C = Config, R = Run,  KU = KeyUpdate, KC = KeyCfm
 AP Name                               State  Model           Serial-ID
 ap                                    R/M   WA2620-AGN       210235A35V0088000005
Table 13 Command output
Current state of the AP:
·     IdleIdle
·     JJoin
·     JAJoin acknowledge
·     ILThe AP is downloading the version.
·     CConfiguration exchange. This state is an instantaneous state. It indicates that the AC is delivering configuration file to the fit AP, and the fit AP is collecting radio information through the radio interface and reporting to the AC.
·     RThe AP is operating. It indicates that the AP has associated with the AC. This field also indicates the active/standby state of the AC. Run/M indicates the AC is an active AC, and Run/B indicates the AC is a standby AC.
·     KUKey update
·     KCKey update confirm
# Display the detailed configuration information of AP1.
<Sysname> display wlan ap name ap1 verbose
                         AP Profile: ap1
 APID                          : 1
 AP System Name                : Not Configured
 Map Configuration             : Not Configured
 State                         : Run
 Up Time(hh:mm:ss)             : 00:01:04
 Model                         : WA2620-AGN
 Serial-ID                     : 210235A35V0088000005
 IP Address                    : 192.168.100.99
 H/W Version                   : Ver.A
 S/W Version                   : V100R001B96D001
 Boot-Rom Version              : 1.20
 Description                   : Not Configured
 Connection Type               : Master
 Peer AC MAC Address           : -NA-
 Priority Level                : 4
 Echo Interval(s)              : 10
 Statistics report Interval(s) : 50
 Cir(Kbps)                     : -NA-
 Cbs(Bytes)                    : -NA-
 Jumboframe Threshold          : Disable
 Transmitted control packets   : 372
 Received control packets      : 372
 Transmitted data packets      : 104
 Received data packets         : 370
 Configuration Failure Count   : 0
 Last Failure Reason           :
 Last Reboot Reason            : Tunnel Initiated
 Latest IP Address             : 192.168.100.99
 Tunnel Down Reason            : Neighbor Dead Timer Expire
 Connection Count              : 3
 AP Mode                       : Split
 AP operation mode             : Normal
 Portal Service                : Disable
 Device Detection              : Disable
 Maximum Number of Radios      : 2
 Current Number of Radios      : 2
 Client Keep-alive Interval    : Disable
 Client Idle Interval(s)       : 3600
 Broadcast-probe Reply Status  : Enable
 Radio 1:
   Basic BSSID                 : 000f-e233-9000
   Current BSS Count           : 1
   Running Clients Count       : 0
   Wireless Mode               : 11an
   Client Dot11n-only          : Disabled
   Channel Band-width          : 20/40MHz
   Secondary Channel Offset    : SCA
   HT Protection Mode          : no protection
   Short GI for 20MHz          : Not supported
   Mandatory MCS Set           :
   Support MCS Set             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
   A-MSDU                      : Enabled
   A-MPDU                      : Enabled
   Configured Channel          : auto<149>
   Configured Power (dBm)      : 24
   Interference (%)            : -NA-
   Channel Load (%)            : -NA-
   Utilization (%)             : -NA-
   Co-channel Neighbor Count   : -NA-
   Channel Health              : -NA-
   Radio Policy                : 257
   Service Template            : 1
   SSID                      : office
   Port                      : WLAN-DBSS0:6
   Mesh Policy                 : default_mp_plcy
   ANI Support                 : Enable
   Admin State                 : UP
   Physical State              : UP
   Operational Rates (Mbps):
     6                         : mandatory
     9                         : supported
     12                        : mandatory
     18                        : supported
     24                        : mandatory
     36                        : supported
     48                        : supported
     54                        : supported
   Radar detected Channels     : None
   Antenna Type                : TLB-5000-2HW 2dBi Omni Antenna
   Resource Using Ratio (%)    : 0
   Noise Floor (dBm)           : 0
 Radio 2:
   Basic BSSID                 : 000f-e233-9010
   Running Clients Count       : 1
   Secondary Channel Offset    : SCN
   Short GI for 40MHz          : Not supported
   Mandatory MCS Set           :
   A-MSDU                      : Enabled
   A-MPDU                      : Enabled
   Configured Channel          : auto<11>
   Configured Power (dBm)      : 19
   Preamble Type               : short
   Radio Policy                : 258
     SSID                      : office
     Port                      : WLAN-DBSS0:7
   11g Protection              : Disable
   Admin State                 : UP
   Physical State              : UP
     1                         : mandatory
     2                         : mandatory
     5.5                       : mandatory
     6                         : supported
     9                         : supported
     11                        : mandatory
     12                        : supported
     18                        : supported
     24                        : supported
     36                        : supported
     48                        : supported
     54                        : supported
   Antenna Type                : TLB-2400-2HW 2dBi Omni Antenna
Table 14 Command output
AP System Name
Access point name
Map Configuration
Configuration file mapped to the AP
·     ImageDownloadThe AP is downloading the version. If the ImageDownload state persists, check the following: 1) The version of the fit AP saved on the AC matches with the version that the AC requires; 2) The space of the flash is enough.
·     IdleThe AP is idle. If the Idle state persists, check the following: 1) If the fields of Latest IP Address and Tunnel Down Reason are displayed as -NA-, it indicates that the AP has never connected to the AC successfully. You must check the network cable, power supply of the fit AP, and the AP serial number if the serial number was manually input. 2) If the fields of Latest IP Address and Tunnel Down Reason are displayed as other contents, it indicates that the AP has connected to the AC successfully. See the output of the Tunnel Down Reason field for the detailed reason.
·     RunThe AP is operating. It indicates that the AP has connected to the AC successfully.
·     ConfigThe AC is delivering configuration file to the fit AP, and the fit AP is collecting radio information through the radio interface and reporting to the AC. This state is an instantaneous state.
Up Time
Time duration for which the AP has been connected to the AC. NA indicates no AP is connected to the AC.
Model
AP Model name
Serial-ID
Serial ID of the AP
IP Address
IP address of the AP
H/W Version
Hardware version of the AP
S/W Version
Software version of the AP
Boot-Rom version
Boot ROM version of the AP.
Description of the AP
Connection Type
AP connection type: "Master" or "Backup"
Peer AC MAC Address
Peer AC MAC address when dual-AC mode is adopted
Priority Level
AP connection priority
Echo Interval
Interval for sending echo requests in seconds
Interval for sending statistics information messages
Count of configuration request message failures
Last Failure Reason
Last configuration request failure reason
Last Reboot Reason
Last reboot reason of the AP:
·     NormalThe AP was powered off.
·     CrashThe AP crashed, and the information is needed for analysis.
·     Tunnel InitiatedThe reset wlan ap command is executed on the AC (the Tunnel Down Reason is displayed as Reset AP).
·     Tunnel Link FailureThe fit AP rebooted abnormally because an error occurred when the AP was establishing a connection with the AC.
Latest IP Address
IP address of the last AP
Tunnel Down Reason
The CAPWAP tunnel between the AC and the AP is down when one of the following occurs:
·     Neighbor Dead Timer ExpireThe AC does not receive an Echo request from the AP within three times the handshake interval.
·     Response Timer ExpireThe AC sends a control packet to the AP but does not receive any response within the specified waiting time.
·     Reset APThe AP is rebooted by the execution of a command on the AC.
·     AP Config ChangeThe corresponding configurations are modified on the AC.
·     No ReasonOther reasons.
Connection Count
Connection count between the AP and AC. This field is reset in one of the following situations:
·     The AC is rebooted.
·     You re-configure an AP template after deleting the old one.
The reset wlan ap command does not reset the connection count.
AP Mode
Mode supported by the AP. Currently only the split MAC mode is supported.
AP operation mode
Operation mode of AP. Currently Normal and Monitor modes are supported.
Device Detection
Whether device detection is enabled or not.
Maximum number of radios supported by the AP.
Number of radios in use on the AP.
Interval to detect clients segregated from the system due to various reasons such as power failure or crash, and disconnect them from the AP
If the client is idle for more than the specified interval, or, if the AP does not receive any data from the client within the specified interval, the client is removed from the network.
Whether the AP is enabled to respond to broadcast probe requests or not.
Basic BSSID
MAC address of the radio
Current BSS Count
Number of BSSs present in the radio
Number of running clients. If wireless mode is 11g, it displays the count of 11b stations and count of 11g stations
Wireless Mode
Client Dot11n-only
·     EnabledOnly 802.11n clients can be associated with the AP.
·     Disabled802.11a/b/g/n clients can be associated with the AP.
Secondary channel offset
Secondary channel information for 802.11n radio mode:
·     SCA (Second Channel Above)The AP operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel.
·     SCB (Second Channel Below)The AP operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel.
·     SCNThe AP operates in 20 MHz bandwidth mode.
HT protection mode
802.11n protection modes:
·     no protection mode(0)The clients associated with the AP, and the wireless devices within the coverage of the AP operate in 802.11n mode, and all the clients associated with the AP operate in either 40 MHz or 20 MHz mode.
·     Non-member mode(1)The clients associated with the AP operate in 802.11n mode, but non-802.11n wireless devices exist within the coverage of the AP,
·     20 MHz mode(2)The radio mode of the AP is 40 MHz. The clients associated with the AP and the wireless devices within the coverage of the AP operate in 802.11n mode, and at least one 802.11n client operating in 20 MHz mode is associated with the radio of the AP.
·     Non-HT mix mode(3)All situations except the above three.
Short GI for 20MHz
Whether the AP supports short GI when it operates in 20 MHz mode.
Short GI for 40MHz
Whether the AP supports short GI when it operates in 40 MHz mode.
Mandatory MCS Set
Mandatory MCS set for the AP
Supported MCS Set
Supported MCS set for the AP
Configured Channel
Operating channel:
·     If the channel is manually configured, the configured channel number is displayed.
·     If the channel is automatically selected, auto(channel) is displayed, where channel is the optimal channel automatically selected by the AC.
Transmission power on the radio.
Interference
Interference observed on the operating channel in percentage
Channel Load
Load observed on the operating channel in percentage
Utilization
Utilization rate of the operating channel in percentage
Number of neighbors found on the operating channel
Channel Health
Health of the channel  such as good or bad based on the configured thresholds
Preamble Type
Type of preamble the AP can support such as short or long
Radio-Policy
Radio policy
SSID
SSID with which the client associates
Port
WLAN-DBSS interface associated with the service template
Admin State
Administrative state of the radio
Physical State
Physical state of the radio
Channels on which radar signals are detected
display wlan ap address
display wlan ap { all | name ap-name } address [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the address information of all APs.
name ap-name: Displays the address information of the AP. An AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
address: Displays the address information of the specified AP.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display wlan ap address to display information about a specified AP or all APs.
# Display the address information for all APs.
<Sysname> display wlan ap all address
 Total Number of APs configured           : 3
 Total Number of configured APs connected : 3
 Total Number of auto APs connected       : 0
                                  AP Address
 AP Name                          IP Address                     MAC Address
 ap1                              1.1.1.5                    ... 000b-6b8f-fc6a
 ap2                              2001::1                    ... 000f-e000-0052
 ap3                              2.2.2.2                    ... 000f-e200-0000
Table 15 Command output
All APs configured through the AP template
All online APs that are configured on the AC
All online APs that are automatically connected to the AC
IP Address
IP address of the AP. If the AP is not online, the field displays -NA-.
MAC Address
MAC address of the AP. If the AP is not online, the field displays -NA-.
display wlan ap radio
display wlan ap { all | name ap-name } radio [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the radio information of all APs.
name ap-name: Displays the radio information of the specified AP. An AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
radio: Displays the radio information of the AP.
Use display wlan ap radio to display information about a specified AP or all APs.
# Display the radio information for all APs.
Sysname> display wlan ap all radio
                                  AP Radio
 AP Name                          Radio ID        Channel        Tx Power (dBm)
 ap1                              2               1              20
 ap2                              2               6              19
 ap3                              2               11             20
Table 16 Command output
AP Name
AP name
Radio ID
ID of the radio associated with the client
Channel
Working channel of the radio
Tx Power (dBm)
Maximum transmission rate of the radio
display wlan ap reboot-log
display wlan ap reboot-log name ap-name [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
name ap-name: Displays the reboot log information of the AP. An AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
Use display wlan ap reboot-log to display the reboot log information of the AP. This command is useful to see crash details if any crash occurred on the AP. The AP specified in the command must be in the running state.
# Display the reboot log information of an AP named ap1.
<Sysname> display wlan ap reboot-log name ap1
.Debug information is not available on AC
 Do you wish to start debug data downloading from AP [Y/N]:y
 Downloading debug data. Please wait...
 Please enter the same command again to view details
display wlan ap-model
display wlan ap-model { all | name ap-name } [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
all: Displays all model information.
name ap-name: Displays the model information of the AP. An AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
Use display wlan ap-model to display the model information of a specified AP or all the APs.
The display wlan ap-model all command can be used to view all the AP model information in the order of AP model alias.
# Display information about model WA2100.
<Sysname> display wlan ap-model name WA2100
         AP Model : WA2100
 Alias       : WA2100
 Vendor Name : H3C
 Vendor ID   : -NA-
 Radio Count : 1
 Radio1 :
  Mode         : 802.11a/b/g
  Default Mode : 802.11g
  BSS Count    : 16
 Version Support List :
  Hardware Version Ver.A :
   Software Version : V100R001B96D001
   Image Name       : WA2100.bin
  Hardware Version Ver.B :
  Hardware Version Ver.C :
  Hardware Version Ver.D :
Table 17 Command output
Alias
Alias of the AP model
Vendor Name
Vendor name of the AP model
Vendor ID
Vendor ID of the AP model
Radio Count
Total number of radios for the AP model
Mode
Supported radio modes such as 802.11a and 802.11b.
Default Mode
Default radio mode
BSS Count
Maximum number of BSSs supported
Hardware Version
Hardware Version of the AP model
Boot Version
Boot Version of the AP model
Software Version
Software Version of the AP model
Image Name
AP image file name which is a complete file name.
dns domain
dns domain domain-name
undo dns domain
View
AP provision view
Default Level
2: System level
domain-name: Specifies a domain name for the DNS server. It is a case-insensitive string of 1 to 238 characters separated by dots and can contain letters, digits, hyphens, and underlines.
Use dns domain to specify a domain name for the AP.
Use undo dns domain to remove the configuration.
By default, no domain name is specified for the AP.
You can specify at most one domain name for the AP.
The wlan ap-provision dns domain command takes effect on all APs, and the dns domain command in AP provision view takes effect on the specified AP. If you configure both commands, the configuration in AP provision view applies to the specified AP.
Related commands: wlan ap-provision dns domain.
# Specify the domain name for AP 1 as com.
[Sysname-wlan-ap-ap1-prvs] dns domain com
dns server
dns server { ip ip-address | ipv6 ipv6-address }
undo dns server { ip | ipv6 }
View
AP provision view
Default Level
2: System level
ip ip-address: Specifies the IPv4 address of the DNS server.
ipv6 ip-address: Specifies the IPv6 address of the DNS server.
Use dns server to specify a DNS server for the AP.
Use undo dns server to remove the DNS server for the AP.
By default, no DNS server is specified for the AP.
You can specify at most one IPv4 DNS server and one IPv6 DNS server.
The wlan ap-provision dns server command takes effect on all APs, and the dns server command in AP provision view takes effect on the specified AP. If you configure both commands, the configuration in AP provision view applies to the specified AP.
Related commands: wlan ap-provision dns server.
# Specify the IPv4 address of the DNS server as 192.168.100.123.
[Sysname-wlan-ap-ap1-prvs] dns server ip 192.168.100.123
echo-interval
echo-interval interval
undo echo-interval
View
AP template view
Default level
2: System level
interval: Interval for sending echo requests, in the range of 5 to 80 seconds.
Use echo-interval to set the interval for sending echo requests.
Use undo echo-interval to restore the default.
There is a keep-live mechanism between AP and AC, which is used to confirm whether the control channel is working or not. To keep the control channel alive, an AP periodically sends echo requests to an AC. The AC responds to echo requests by sending echo responses.
By default, the echo interval is 10 seconds.
# Set an echo interval of 15 seconds for AP3.
[Sysname] wlan ap ap3 model WA2100
[Sysname-wlan-ap-ap3] echo-interval 15
gateway
gateway { ip ip-address | ipv6 ipv6-address }
undo gateway { ip | ipv6 | all }
View
Default level
2: System level
ip ip-address: Specifies the IPv4 address of the gateway.
ipv6 ipv6-address: Specifies the IPv6 address of the gateway.
all: Removes all IP addresses of gateways.
Use gateway to specify a gateway for the AP.
Use undo gateway to remove gateway configuration.
By default, no gateway is specified for the AP.
You can specify an IPv4 gateway and an IPv6 gateway for the AP at most.
# Specify the gateway 192.168.100.1 for AP 1.
[Sysname-wlan-ap-ap1-prvs] gateway ip 192.168.100.1
hybrid-remote-ap enable
undo hybrid-remote-ap enable
View
AP template view
Default level
3: Management level
None
Use hybrid-remote-ap enable to enable hybrid mode for the AP. When the connection between an AP in hybrid mode and the AC is terminated, the AP automatically enables local forwarding mode (disregarding whether local forwarding is configured on the AC) to forward packets for associated clients, but it does not accept new association requests from clients. When the AP re-establishes a CAPWAP connection with the AC, the AP automatically switches back to centralized forwarding mode, and logs out all clients associated with it.
Use undo hybrid-remote-ap enable to restore the default.
By default, hybrid mode is disabled.
·     Before you enable hybrid mode for an AP, H3C recommends that you disable online user handshake function if 802.1X authentication is used.
·     Do not use the remote AP function together with the WLAN mesh function.
# Enable hybrid mode for AP 1.
[Sysname] wlan ap ap1 model wa2100
[Sysname-ap-ap1] hybrid-remote-ap enable
ip address
ip address ip-address { mask | mask-length }
undo ip address
View
Default level
2: System level
ip-address: IP address of the management VLAN interface of the AP, in dotted decimal notation.
mask: Subnet mask in dotted decimal notation.
mask-length: Subnet mask length, the number of consecutive ones in the mask. It is in the range of 0 to 32.
Use ip address to configure the IP address of the management VLAN interface of the AP.
Use undo ip address to remove the IP address of the management VLAN interface of the AP.
By default, no IP address is specified for the management VLAN interface of an AP.
The management VLAN of the AP must be VLAN 1.
# Configure the IP address of the management VLAN interface of AP 1 as 192.168.100.100/24.
[Sysname-wlan-ap-ap1-prvs] ip address 192.168.100.100 24
ipv6 address
undo ipv6 address
View
Default level
2: System level
ipv6-address: IPv6 address of the management VLAN interface of the AP.
prefix-length: Prefix length, in the range of 1 to 128.
Use ipv6 address to configure the IPv6 address of the management VLAN interface of the AP.
Use undo ipv6 address to remove the IPv6 address of the management VLAN interface of the AP.
By default, no IPv6 address is specified for the management VLAN interface of the AP.
# Configure the IPv6 address of the management VLAN interface of AP 1 as 2001::1/64.
[Sysname-wlan-ap-ap1-prvs] ipv6 address 2001::1/64
jumboframe enable
jumboframe enable value
undo jumboframe enable
View
AP template view
Default level
2: System level
value: Maximum size of jumbo frames, in the range of 1500 to 1748 bytes.
Use jumboframe enable to set the maximum size of jumbo frames.
Use undo jumboframe enable to restore the default.
By default, the jumbo frame support is disabled.
# Set the maximum jumbo frame size to 1500 bytes.
[Sysname-ap-ap1] jumboframe enable 1500
map-configuration
map-configuration filename
undo map-configuration
View
AP template view
filename: Name of the build run configuration file in the flash. Using command "dir" in user view, you can know the list of files in the flash. A file name consists of 1 to 32 characters.
Use map-configuration to map a configuration file to the AP.
Use undo map-configuration to remove the mapping.
By default, no file is mapped to the AP.
The commands in the configuration file specified with the map-configuration command must be in their complete form.
# Map file filename1 to the AP.
[Sysname-wlan-ap-ap1] map-configuration filename1.txt
memory-usage threshold
memory-usage threshold integer
View
AP template view
Default level
3: Manage level
Use memory-usage threshold to set the memory usage threshold of the AP. If the memory usage of the AP exceeds the threshold, the AP generates an alarm.
By default, the default memory usage threshold of the AP is 90.
# Set the memory usage threshold of AP 3 to 30.
[Sysname-wlan-ap-ap3]memory-usage threshold 30
priority level
priority level priority
undo priority level
View
AP template view
priority: AP connection priority, in the range of 0 to 7. The higher the value, the higher the priority.
Use priority level to configure the connection priority for the AP.
Use undo priority level to restore the default.
If the connection priority is 7, the AC is considered as the primary AC for the AP.
By default, the connection priority of an AP is 4.
# Configure the connection priority for ap3.
[Sysname-wlan-ap-ap3] priority level 1
provision
provision
undo provision
View
AP template view
Default level
2: System level
None
Use provision to create and enter AP configuration view.
Use undo provision to remove the AP configuration view and all configurations in the view.
By default, no AP configuration view is created.
After you create the AP configuration view, the device automatically adds the vlan untagged 1 command.
# Create and enter the configuration view for AP 1.
reset wlan ap
reset wlan ap { all | name ap-name }
View
Default level
1: Monitor level
all: Resets all the APs connected to the current AC.
name ap-name: Resets the specified AP. An AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
Use reset wlan ap to reset a specified AP or all the APs.
# Reset an AP named ap1.
<Sysname> reset wlan ap name ap1
reset wlan ap provision
reset wlan ap provision { all | name ap-name }
View
Default level
2: System level
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
Use reset wlan ap provision to remove the wlan_ap_cfg.wcfg file of the specified AP or all APs.
This command takes effect only on APs in the Run state.
# AP 1 has been connected to the AC. Remove the wlan_ap_cfg.wcfg file of AP 1.
<Sysname> reset wlan ap provision name ap1
reset wlan ap reboot-log
reset wlan ap reboot-log { all | name ap-name }
View
Default level
1: Monitor level
all: Clears the reboot log information for all APs.
name ap-name: Clears the reboot log information for the AP. An AP name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
Use reset wlan ap reboot-log to clear the AP reboot log information of all APs or a specific AP.
# Clear the AP reboot log information of an AP named ap1.
<Sysname> reset wlan ap reboot-log name ap1
save wlan ap provision
save wlan ap provision { all | name ap-name }
View
Default level
2: System level
Use save wlan ap provision to save the configuration in AP configuration view to the wlan_ap_cfg.wcfg file of the specified AP or all APs.
·     This command takes effect only on APs in the Run state. It does not take effect on APs that establish a CAPWAP connection with the AC after you execute the save wlan ap-provision command.
·     After you execute the save wlan ap-provision command, you must restart the specified AP to validate the configuration.
·     After restart, the AP executes the configuration file, the wlan_ap_cfg.wcfg file, and the configuration file specified by the map-configuration command in turn. Make sure the wlan_ap_cfg.wcfg file and the configuration file specified by the map-configuration command are correct because wrong configurations may make the three configuration files overwrite or conflict with one another.
CAUTION
CAUTION:
After you execute the save wlan ap provision command on the AC, the configuration is saved to the wlan_ap_cfg.wcfg file of the specified AP. When the wlan_ap_cfg.wcfg file takes effect, the AP can only be managed by the AC specified by the ac or wlan ap-provision ac command. Make sure the correct AC is specified' otherwise, the AP cannot be managed by the specified AC, and you have to log in to the AP to modify its configuration.
Related commands: map-configuration, reset wlan ap provision, and reset wlan ap.
# AP 1 has established a CAPWAP connection with the AC. Save the configuration in AP configuration view to the wlan_ap_cfg.wcfg file of AP 1.
<Sysname> save wlan ap provision name ap1
serial-id
serial-id { text | auto }
undo serial-id
View
AP template view
Default level
2: System level
text: Serial ID of an AP. It is a case-sensitive string of 1 to 32 characters that can contain special characters except question marks. All input letters are changed to uppercase letters by the system.
auto: Enables auto serial ID configuration for a generic auto AP template.
Use serial-id to set a serial ID for an AP. The serial ID is the unique identity of the AP. If the AP has connected to the AC, changing or deleting its serial ID will render the AP tunnel down. The AP needs to discover the AC to connect again.
Use undo serial-id to restore the default.
By default, no serial ID is configured for an AP.
# Set the serial ID as 210235A29G007C000020 for AP 1.
[Sysname-wlan-ap-ap1] serial-id 210235A29G007C000020
tunnel encryption ipsec pre-shared-key { cipher | simple } key
undo tunnel encryption ipsec pre-shared-key
View
Default level
2: System level
cipher: Specifies a ciphertext key.
simple: Specifies a plaintext key.
key: Encryption key. It is a case-sensitive string of 1 to 128 characters for a plaintext key, or a case-sensitive string of 1 to 201 characters for a ciphertext key.
Use tunnel encryption ipsec pre-shared-key to configure the AP to use IPsec to encrypt the control tunnel.
Use undo tunnel encryption ipsec pre-shared-key to remove the configuration.
By default, the AP does not encrypt the control tunnel.
This command only enables the AP to encrypt the control tunnel. To enable the AP to encrypt the data tunnel, use the data-tunnel encryption enable command. The undo tunnel encryption ipsec pre-shared-key command removes the configuration for both data tunnel encryption and control tunnel encryption.
Related commands: data-tunnel encryption enable.
# Configure the AP to use plaintext key 12345 to encrypt the control tunnel.
[Sysname] wlan ap ap1 model WA2620-AGN
vlan pvid
vlan pvid vlan-id
undo vlan pvid
View
Default level
2: System level
vlan-id: Default VLAN ID of the Ethernet interface on the AP. It is in the range of 1 to 4094.
Use vlan pvid to configure the default VLAN ID of the Ethernet interface on the AP.
Use undo vlan pvid to restore the default.
By default, the default VLAN ID of the Ethernet interface on an AP is 1.
# Configure the default VLAN ID of the Ethernet interface on AP 1 as 5.
[Sysname-wlan-ap-ap1-prvs] vlan pvid 5
vlan tagged
vlan tagged vlan-id-list
undo vlan tagged vlan-id-list
View
Default level
2: System level
vlan-id-list: Specifies a list of VLANs whose packets are sent tagged on the Ethernet interface of the AP. It is in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>, where vlan-id is in the range of 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs.
Use vlan tagged to configure a list of VLANs whose packets are sent tagged on the Ethernet interface of the AP.
Use undo vlan tagged to remove the configuration.
By default, no packets are sent tagged on the Ethernet interface on the AP.
# Configure packets in VLAN 6 are sent tagged on the Ethernet interface on AP 1.
[Sysname-wlan-ap-ap1-prvs] vlan tagged 6
vlan untagged
vlan untagged vlan-id-list
undo vlan untagged vlan-id-list
View
Default level
2: System level
vlan-id-list: Specifies a list of VLANs whose packets are sent untagged on the Ethernet interface of the AP. It is in the format of vlan-id-list = { vlan-id1 [ to vlan-id2 ] }& <1-10>, where vlan-id is in the range of 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs.
Use vlan untagged to configure a list of VLANs whose packets are sent untagged on the Ethernet interface of the specified AP.
By default, no packets are sent untagged on the Ethernet interface on the AP.
# Configure packets in VLAN 7 are sent untagged on the Ethernet interface of AP 1.
[Sysname-wlan-ap-ap1-prvs] vlan untagged 7
wlan ap
wlan ap ap-name model model-name [ id ap-id ]
undo wlan ap ap-name
View
Default level
2: System level
ap-name: Name of the AP, a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
model model-name: Specifies the model number of the AP.
id ap-id: ID of the AP, which ranges from 1 to the maximum number of APs supported. If this parameter is not configured, the AC automatically assigns an ID to the AP.
Use wlan ap to create a new AP template and enter AP template view. If the AP template exists, using the command enters its view.
Use undo wlan ap to remove a specific AP template. If the AP is connected to the AC, the undo wlan ap command will disconnect the AP from the AC.
# Create an AP template named ap1 and its model is WA2100.
wlan apdb
wlan apdb model-name hardware-version software-version
undo wlan apdb model-name hardware-version
View
Default level
2: System level
model-name: AP model name.
hardware-version: Fit AP hardware version name.
software-version: Fit AP software version name.
Use wlan apdb to designate the software version of a given AP model with a given hardware version.
Use undo wlan apdb to restore the default.
By default, the software versions of a fit AP and AC must be consistent.
# Designate the software version of a given AP model with a given hardware version.
[Sysname] wlan apdb wa2100 Ver.C V100R001B96D001
wlan ap-execute
wlan ap-execute ap-name conversion-to-fatap
View
Default level
3: Manage level
ap-name: Name of the AP, which is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
conversion-to-fatap: Changes the fit AP to a fat AP.
Use wlan ap-execute to convert a fit AP to a fat AP.
CAUTION
CAUTION:
Download the fat AP's software to the AC before configuring the command. Otherwise, the AC cannot change the fit AP to a fat AP.
#.Convert AP ap1_003 to a fat AP.
[Sysname] wlan ap-execute ap1_003 conversion-to-fatap
wlan ap-provision ac { host-name host-name | ip ip-address | ipv6 ipv6-address }
undo wlan ap-provision ac { host-name | ip { ip-address | all } | ipv6 { ipv6-address | all } }
View
Default level
2: System level
host-name host-name: Specifies the host name of a global AC. It is a case-insensitive string of 1 to 255 characters that can contain letters, digits, "-", "_" or ".", and must contain at least one letter.
ip ip-address: Specifies the IPv4 address of a global AC.
ipv6 ipv6-address: Specifies the IPv6 address of a global AC.
all: Removes the IPv4/IPv6 addresses of all global ACs.
Use wlan ap-provision ac to specify a global AC so that all APs can discover the AC.
Use undo wlan ap-provision ac to remove the configuration.
By default, no global AC is specified.
The wlan ap-provision ac command takes effect on all APs, and the ac command in AP configuration view takes effect on the specified AP. If you configure both commands, the configuration in AP configuration view is preferred by the specified AP.
You can specify at most three ACs' IP addresses, three ACs' IPv6 addresses, and an AC's host name for all APs.
Related commands: ac.
# Specify the global AC 192.168.100.11 so that all APs can discover the AC.
[Sysname] wlan ap-provision ac ip 192.168.100.11
wlan ap-provision dns domain domain-name
undo wlan ap-provision dns domain
View
Default Level
2: System level
domain-name: Specifies a domain name. It is a case-insensitive string of 1 to 238 characters separated by dots. It can contain letters, digits, hyphens, and underlines.
Use wlan ap-provision dns domain to specify a global domain name.
Use undo wlan ap-provision dns domain to remove the configuration.
By default, no global domain name is specified.
You can specify at most one global domain name.
Related commands: dns domain.
# Specify the global domain name as com.
[Sysname] wlan ap-provision dns domain com
wlan ap-provision dns server { ip ip-address | ipv6 ipv6-address }
undo wlan ap-provision dns server { ip | ipv6 }
View
Default Level
2: System level
ip ip-address: Specifies the IPv4 address of a global DNS server.
ipv6 ip-address: Specifies the IPv6 address of a global DNS server.
Use wlan ap-provision dns server to specify a global DNS server.
Use undo wlan ap-provision dns server to remove the configuration.
By default, no global DNS server is specified.
You can specify at most one global IPv4 DNS server and one global IPv6 DNS server.
Related commands: dns server.
# Specify the IPv4 address of the global DNS server as 192.168.100.124.
[Sysname] wlan ap-provision dns server ip 192.168.100.124
wlan auto-ap enable
wlan auto-ap enable
undo wlan auto-ap enable
View
Default level
2: System level
None
Use wlan auto-ap enable to enable the auto AP function.
Use undo wlan auto-ap enable to restore the default.
By default, the auto AP function is disabled.
The auto AP feature allows an AP to automatically connect to an AC. When you deploy a wireless network with many APs, the auto AP function avoids configuration of many AP serial IDs, simplifying configuration.
Related commands: serial-id and wlan auto-ap persistent.
# Enable the auto AP function
[Sysname] wlan auto-ap enable
wlan auto-ap persistent { all | name auto-ap-name [ new-ap-name ] }
View
Default level
2: System level
all: All connected auto APs.
name auto-ap-name: Name of a connected auto AP.
new-ap-name: New name of the AP. It is a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces.
Use wlan auto-ap persistent name auto-ap-name new-ap-name to convert a specified auto AP to a configured AP with a specified new name.
Use wlan auto-ap persistent name auto-ap-name to convert a specified auto AP to a configured AP with the existing auto AP name.
Use wlan auto-ap persistent all to convert all connected auto APs to configured APs with existing auto AP names.
# Convert a connected auto AP to a configured AP with a new name.
[Sysname] wlan auto-ap persistent name auto_apm1_001 ap2
# Convert a connected auto AP to a configured AP that uses the existing auto AP name.
# Convert all connected auto APs to configured APs that use existing auto AP names.
[Sysname] wlan auto-ap persistent all
wlan backup-ac
wlan backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo wlan backup-ac { ip | ipv6 }
View
ip ipv4-address: Specifies the IPv4 address of the backup AC.
ipv6 ipv6-address: Specifies the IPv6 address of the backup AC.
Use wlan backup-ac to specify the backup AC.
Use undo wlan backup-ac to remove the configuration.
By default, no backup AC address exists.
# Configure a backup AC.
wlan lwapp discovery-policy
wlan lwapp discovery-policy unicast
undo wlan lwapp discovery-policy
View
Default level
2: System level
unicast: Configures the AC to accept only unicast discovery requests from an AP.
Use wlan lwapp discovery-policy to set the discovery policy type used in the discovery process. If you configure the discovery policy as unicast, broadcast discovery packets are discarded.
Use undo wlan lwapp discovery-policy to restore the default.
By default, the LWAPP discovery policy is broadcast.
# Set the LWAPP discovery policy type as unicast.
[Sysname] wlan lwapp discovery-policy unicast
User isolation commands
display user-isolation statistics
display user-isolation statistics [ vlan vlan-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id: Displays the user isolation statistics of the specified VLAN. The VLAN ID is in the range of 1 to 4094.
Use display user-isolation statistics to display the user isolation statistics of the specified VLAN or all VLANs. If no VLAN is specified, the user isolation statistics of all VLANs are displayed.
# Display the user isolation statistics of VLAN 3.
<Sysname> display user-isolation statistics vlan 3
                  User-Isolation Table
  VLAN      Status       Drops           Permit-MAC
  4         Enabled      0
  6         Disabled     0               0023-89a2-3d4d
 ---- Number of enabled/disabled VLANs: 1/1  ----
Table 18 Command output
VLAN
ID of the VLAN where user isolation is enabled
Status
Enabled or disabled
Drops
Number of dropped packets in the VLAN
Permit-MAC
Permitted MAC address list of the VLAN
reset user-isolation statistics
reset user-isolation statistics [ vlan vlan-id ]
View
User View
Default level
1: Monitor level
vlan vlan-id: ID of a VLAN, in the range of 1 to 4094.
Use reset user-isolation statistics to clear the user isolation statistics of the specified VLAN or all VLANs. If no VLAN is specified, the user isolation statistics of all VLANs are cleared.
# Clear the user isolation statistics of VLAN 1.
<Sysname> reset user-isolation statistics vlan 1
user-isolation enable
undo user-isolation enable
View
Service template view
Default Level
2: System level
None
Use user-isolation enable to enable SSID-based user isolation for the service template.
Use undo user-isolation enable to restore the default.
By default, SSID-based user isolation is disabled.
# Enable SSID-based user isolation for service template 1.
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] user-isolation enable
user-isolation permit broadcast
undo user-isolation permit broadcast
View
Default level
2: System level
None
Use user-isolation permit broadcast to permit broadcasts and multicasts from wired users to wireless users.
Use undo user-isolation permit broadcast to isolate broadcasts and multicasts from wired users to wireless users.
By default, broadcasts and multicasts from wired users to wireless users are permitted, and broadcasts and multicasts from wireless users to wireless users are isolated.
# Isolate broadcasts and multicasts from wired users to wireless users.
[Sysname] user-isolation permit broadcast
user-isolation vlan enable
user-isolation vlan vlan-list enable
undo user-isolation vlan vlan-list enable
View
Default level
2: System level
vlan-list: VLAN list. This argument is expressed in the format of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
Use user-isolation vlan enable to enable user isolation on the specified VLAN(s).
Use undo user-isolation vlan enable to disable user isolation on the specified VLAN(s).
By default, user isolation is disabled in a VLAN.
# Enable user isolation on VLAN 1.
[Sysname] user-isolation vlan 1 enable
user-isolation vlan permit-mac
user-isolation vlan vlan-list permit-mac mac-list
undo user-isolation vlan vlan-list permit-mac { mac-list |all }
View
Default level
2: System level
vlan-list: Enables user isolation for the specified VLAN(s). This argument is expressed in the format of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id is in the range of 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
mac-list: List of permitted MAC addresses. You can configure up to 16 permitted MAC addresses. Broadcast MAC addresses or multicast MAC addresses cannot be included.
all: Deletes all the permitted MAC addresses of the specified VLAN(s).
Use user-isolation vlan permit-mac to add permitted MAC addresses in the specified VLAN(s).
Use undo user-isolation vlan permit-mac to delete the specified or all permitted MAC addresses in the specified VLAN(s).
By default, no permitted MAC addresses are specified.
# Configure permitted MAC addresses 00bb-ccdd-eeff and 0022-3344-5566 in VLAN 1.
[Sysname] user-isolation vlan 1 permit-mac 00bb-ccdd-eeff 0022-3344-5566
AP group configuration commands
ap
ap template-name-list
undo ap template-name-list
View
AP group view
Default level
2: System level
template-name-list: A list of AP templates. Up to 10 AP templates can be included in the list. An AP template name is a case-insensitive string of 1 to 32 characters that can contain letters, digits, and underlines.
Use ap to add specified APs into the AP group.
Use undo ap to delete specified APs from the AP group. If no AP is specified, the command removes all APs from the AP group.
By default, no AP is added into the AP group.
The command does not check whether the specified APs exist. Using the ap command repeatedly can add multiple APs in the AP group until the maximum number is reached. On a device, one AP can be included in multiple AP groups.
# Add AP 10 and AP 101 into AP group 10.
<System> system-view
[System] wlan ap-group 10
[System-ap-group10] ap ap10 ap101
description
description string
View
AP group view
Default level
2: System level
string: A string of 1 to 15 characters that can include letters [a-z,A-Z] and underscores.
Use description to configure a description for the AP group.
Use undo description to delete the description for the AP group.
No description is configured for the AP group by default.
A newly configured description overwrites the previous description (if any).
# Configure a description of marketing for AP group 10.
[System-ap-group10] description marketing
display wlan ap-group
display wlan ap-group [ group-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-id: ID of an AP group. The value range varies depending on the device model. For related information, see About the WX Series Access Controllers Command References.
Use display wlan ap-group to display AP group information. If no AP group is specified, the command displays information about all AP groups.
# Display information about AP group 10.
<Sysname> display wlan ap-group 10
                        AP Group Information
AP-Group  ID        :10
Description         :market
Access AP Lists     :ap1,                ap2,
                     ap3,                ap4,
                     ap5,                ap6
Table 19 Command output
AP-Group ID
AP group ID
Description of the AP group
Access AP Lists
Permitted APs
wlan ap-group
wlan ap-group group-id
undo wlan ap-group [ group-id ]
View
Default level
2: System level
group-id: ID of the AP group. The value range varies depending on the device model. For related information, see About the WX Series Access Controllers Command References.
Use wlan ap-group to create an AP group and enter AP group view. If the specified AP group has been created, using the command enters AP group view only.
Use undo wlan ap-group to remove a specified AP group, or all AP groups if no AP group is specified.
# Create AP group 10.
[Sysname] wlan ap-group 10
[Sysname-ap-group10]
wlan permit-ap-group
wlan permit-ap-group group-id
undo wlan permit-ap-group [ group-id ]
View
User profile view
Default level
2: System level
Use wlan permit-ap-group to apply a specified AP group in the user profile, which can have multiple AP groups applied.
Use undo wlan permit-ap-group to remove a specified AP group from the user profile or all AP groups from the user profile if no AP group is specified.
By default, no AP group is applied in the user profile.
# Apply AP group 10 in user profile management.
[Sysname] user-profile management
[Sysname-user-profile-management] wlan permit-ap-group 10
SSID-based access control configuration commands
wlan permit-ssid
wlan permit-ssid ssid-name
undo wlan permit-ssid [ ssid-name ]
View
User profile view
Default level
2: System level
ssid-name: Name of a permitted SSID, a case-sensitive string of 1 to 32 characters that can contain letters, digits, underscores, and spaces. The maximum number of permitted SSIDs in a user profile varies depending on the device model. For related information, see About the WX Series Access Controllers Command References.
Use wlan permit-ssid to specify a permitted SSID for a user profile.
Use undo wlan permit-ssid to remove a permitted SSID or all permitted SSIDs.
By default, no permitted SSID is specified for a user profile, and a client can access any available SSID.
# Specify permitted SSID VIPguest for user profile management.
[System] user-profile management
[System-user-profile-management] wlan permit-ssid VIPguest
Uplink detection commands
wlan uplink track
wlan uplink track track-entry-number
undo wlan uplink track
View
Default level
2: System level
track track-entry-number: Number of the track entry to be detected, in the range of 1 to 1024.
Use wlan uplink track to specify a track entry for uplink detection.
Use undo wlan uplink track to remove the configuration.
By default, no track entry is specified for uplink detection.
# Specify a track entry for uplink detection.
<Sysname> system
[Sysname] wlan uplink track 1
AC hot backup configuration commands
display hot-backup state
display hot-backup state [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
Use display hot-backup state to display the AC hot backup state. Support for this command depends on your AC model. For related information, see About the WX Series Access Controllers Command References.
# Display the AC hot backup state.
[Sysname]display hot-backup state
Vlan ID                : 21
Domain ID           : 1
Link State            : Connect
Peer Board MAC : 000f-e212-ff02
Peer Board State : Normal
Table 20 Command output
Vlan ID
ID of the VLAN to which the ports are assigned
Domain ID
Domain to which the AC belongs
Link State
AC link state:
·     Close—Not connected.
·     Init—Being connection.
·     Connect—Connected.
Peer Board MAC
MAC address of the peer AC
Peer Board State
Status of the peer AC:
·     Normal
·     Abnormal
·     Unknown
hot-backup enable
hot-backup enable [ domain domain-id ] *
undo hot-backup enable
View
Default level
2: System level
domain domain-id: Domain ID of the AC. It is in the range of 1 to 16 and defaults to 1.
Use hot-backup enable to enable the AC hot backup function.
Use undo hot-backup enable to disable the AC hot backup function.
You can manually configure the domain to which the AC belongs.
By default, the AC hot backup function is disabled.
·     Executing the hot-backup command repeatedly on an AC enabled with hot backup does not take effect.
·     Executing the undo hot-backup command repeatedly on an AC disabled with hot backup does not take effect.
·     Support for the hot-backup command depends on the device model. For related information, see About the WX Series Access Controllers Command References.
# Enable the AC hot backup function.
[Sysname]hot-backup enable
hot-backup enable successfully.
hot-backup hellointerval
hot-backup hellointerval hellointerval
View
Default level
2: System level
hellointerval: Sets the interval for sending heartbeat messages, in milliseconds. The default value is 2000 milliseconds. The value range depends on your AC model. For related information, see About the WX Series Access Controllers Command References.
Use hot-backup hellointerval to set the interval for sending heartbeat messages. If the master AC or backup AC does not receive any heartbeat packets from the peer within three heartbeat intervals, it considers the peer device disconnected.
# Set the heartbeat interval to 100 milliseconds.
[Sysname]hot-backup hellointerval 100
hot-backup vlan
hot-backup vlan vlan-id
View
Default level
2: System level
vlan vlan-id: Sets the ID of the VLAN to which the port connected to another AC belongs. A vlan-id is in the range of 1 to 4094.
Use hot-backup vlan to set the ID of the VLAN to which the port connected to another AC belongs. Support for this command depends on your AC model. For related information, see About the WX Series Access Controllers Command References.
By default, the port connected to the other AC belongs to VLAN 1.
# Set the ID of the VLAN to which the port connected to another AC belongs to 5.
[Sysname]hot-backup vlan 5
wlan backup-ac switch-delay
wlan backup-ac switch-delay time
undo wlan backup-ac switch-delay
View
Default level
2: System level
time: Sets the delay for an AP to switch from a master AC to a backup AC. The value is in the range of 0 to 600 seconds.
Use wlan backup-ac switch-delay to set the delay for an AP to switch from a master AC to a backup AC.
Use undo wlan backup-ac switch-delay to remove the configuration.
By default, the delay for an AP to switch from a master AC to a backup AC is 5 seconds.
# Set the delay for an AP to switch from a master AC to a backup AC to 10 seconds.
[Sysname] wlan backup-ac switch-delay 10
