| 05-WLAN RRM Commands | 257.94 KB |
WLAN RRM configuration commands
display wlan mesh calibrate-channel history
display wlan rrm-calibration-group
dot11a calibrate-channel pronto
dot11a calibrate-channel self-decisive
dot11a calibrate-power self-decisive
dot11a calibrate-power threshold
dot11bg calibrate-channel pronto
dot11bg calibrate-channel self-decisive
dot11bg calibrate-power pronto
dot11bg calibrate-power self-decisive
dot11bg calibrate-power threshold
dot11bg interference-threshold
mesh calibrate-channel self-decisive
WLAN load balancing configuration commands
display wlan load-balance-group
Band navigation configuration commands
band-navigation balance access-denial
band-navigation balance session
band-navigation enable (AP template view)
band-navigation enable (WLAN RRM view)
band-navigation rssi-threshold
ap radio
ap ap-name radio radio-number
undo ap { ap-name [ radio radio-number ] | all }
View
Radio group view
Default level
2: System level
ap-name: Name of an AP, a case-insensitive string of 1 to 32 characters that can contain letters, digits, underlines, square brackets, slashes, and hyphens, but not spaces. The specified AP must exist.
radio-number: Number of a radio of the AP. The value range depends on your device model.
all: Removes all radios in the radio group.
Use ap radio to add a radio of an AP to the radio group.
Use undo ap to remove radios in the radio group.
By default, no radio exists in the radio group.
If you do not specify the radio radio-number and all options, the undo ap command removes all radios of the specified AP in the radio group.
One radio can belong to only one radio group.
# Add radio 2 of AP 1 to radio group 10.
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rc-group-10] ap ap1 radio 2
# Remove all radios in radio group 10.
[Sysname-wlan-rc-group-10] undo ap all
# Remove all radios of AP 1 in radio group 10.
[Sysname-wlan-rc-group-10] undo ap ap1
# Remove radio 2 of AP 1 in radio group 10.
[Sysname-wlan-rc-group-10] undo ap ap1 radio 2
autochannel-set avoid-dot11h
undo autochannel-set
View
WLAN RRM view
Default level
2: System level
None
Use autochannel-set avoid-dot11h to set the channel set to non-dot11h channels. Only the non-dot11h channels belonging to the country code are scanned during initial channel selection and one of them is selected.
Use undo autochannel-set avoid-dot11h to restore the default.
By default, the channel set involves all channels of the country code.
The default setting of the autochannel-set avoid-dot11h command depends on the scan channel command.
Related commands: scan channel.
# Scan non-dot11h channels.
[Sysname] wlan rrm
[Sysname-wlan-rrm] autochannel-set avoid-dot11h
channel holddown-time
channel holddown-time minutes
undo channel holddown-time
View
Radio group view
Default level
2: System level
minutes: Channel holddown time, within which, the channel of any radio in the radio group keeps unchanged after a one-time, auto, or initial DFS operation. The value is in the range of 10 to 1440, in minutes.
Use channel holddown-time to set the channel holddown time for the radio group.
Use undo channel holddown-time to restore the default.
By default, the channel holddown time is 720 minutes.
If the AC detects any radar signals on the channel of any radio in the radio group within the specified holddown time, the AC immediately selects a new channel for the radio and resets the holddown timer.
# Set the channel holddown time for radio group 10 to 600 minutes.
[Sysname-wlan-rc-group-10] channel holddown-time 600
description
View
Radio group view
Default level
2: System level
text: Description of the radio group, a case-sensitive string of 1 to 64 characters that can contain letters, digits and underlines.
Use description to configure the description of the radio group.
By default, the radio group has no description.
# Configure the description of radio group 10 as office.
[Sysname-wlan-rc-group-10] description office
display wlan ap rrm-history
display wlan ap { all | name ap-name } rrm-history [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the RRM history information of all APs.
name ap-name: Displays the RRM history information of the AP. It is a case-insensitive string of 1 to 32 characters that can contain letters, digits, and underlines, square brackets, slashes, and hyphens, but not spaces.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display wlan ap name ap-name rrm-history to display RRM history information about an AP.
Use display wlan ap all rrm-history to display the details of the latest three channel changes and power changes applied on all APs or a specified AP. The output includes time of the change, reason of the change, and the power and interference parameters.
# Display the RRM history information of AP1.
<Sysname> display wlan ap name ap1 rrm-history
AP RRM History
Flags : I - Interference, P - Packets discarded, F - Retransmission,
R - Radar, C - Coverage, O - Others
AP RRM History : ap1
Radio : 1 Basic BSSID : 000f-e2ff-7700
Chl Power Load Util Intf PER Retry Reason Date Time
(dBm) (%) (%) (%) (%) (%) (yyyy-mm-dd) (hh:mm:ss)
Before 6 20 24 2 21 11 18 -P---- 2008-01-07 17:31:50
After 1 20 9 0 8 0 27 - - -
Before 1 20 54 1 53 11 15 IP---- 2008-01-08 12:19:50
After 6 20 10 0 10 3 29 - - -
Before 6 20 29 1 28 21 20 -P---- 2008-01-08 12:59:50
After 1 20 30 0 29 2 24 - - -
Radio |
Radio ID of the AP |
Basic BSSID |
MAC address of the AP |
Chl |
Channel on which the radio operates before/after the change of channel or power |
Power |
Power of the radio before/after the change of channel or power |
Load |
Load observed on the radio in percentage before/after the change of channel or power |
Util |
Utilization of the radio in percentage before/after the change of channel or power |
Intf |
Interference observed on the radio in percentage before/after the change of channel or power |
PER |
Packet error rate, which is the duration of invalid packets that include CRC errors and physical errors over the medium |
Retry |
Percentage of retransmission happened on the radio before/after the change of channel or power |
Reason |
Reason for the change of channel or power, such as Interference, packets discarded, retransmission, radar or coverage |
Date |
Date when the channel or power change occurred |
Time |
Time when the channel or power change occurred |
display wlan ap rrm-status
display wlan ap { all | name ap-name } rrm-status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the RRM profile information of radios of all APs.
name ap-name: Displays the RRM profile information of radios of an AP. It is a case-insensitive string of 1 to 32 characters that can contain letters, digits, and underlines, square brackets, slashes, and hyphens, but not spaces.
Use display wlan ap { all | name apname } rrm-status to display the RRM profile information of each radio on all APs or a specified AP, including the channel on which the AP is operating, the power level of the AP, interference observed, and the number of neighbors.
On an AC, if RRM is not enabled, or the AP works on a fixed channel, when you execute the command, only the channel on which the AP is operating and the power level of the AP are displayed. Other information such as interference observed and the number of neighbors are not displayed. If RRM is enabled, it means that dynamic power selection or automatic dynamic frequency selection is enabled.
# Display RRM profile information for AP1.
<Sysname> display wlan ap name ap1 rrm-status
AP RRM Profile : ap1
Channel : 6 (Good) Tx Power (dBm) : 20
Chl NbrCnt Load Util Intf PER Retry Radar
1 6 33 - 33 1 - -
6 6 25 0 25 8 0 -
11 4 48 - 48 5 - -
Nbr-BasicBSSID Chl Intf SignalStrength Type
(%) (dBm)
000f-e20c-4080 6 8 -69 Unmanaged
000f-e211-2220 6 0 -63 Unmanaged
000f-e232-5500 6 1 -79 Unmanaged
000f-e23e-e740 1 1 -71 Unmanaged
000f-e23e-e760 1 1 -63 Unmanaged
000f-e25d-f3c0 11 0 -59 Unmanaged
000f-e25d-f420 1 2 -89 Unmanaged
000f-e267-9990 1 8 -80 Unmanaged
000f-e267-9b10 11 0 -65 Unmanaged
000f-e26c-2980 6 0 -85 Unmanaged
000f-e26e-5f00 11 0 -63 Unmanaged
000f-e274-1020 6 5 -60 Unmanaged
000f-e299-5510 1 2 -78 Unmanaged
000f-e2c0-0120 1 4 -76 Unmanaged
000f-e2ff-ee10 6 1 -74 Unmanaged
5055-5555-5500 11 41 -67 Unmanaged
Radio |
Basic BSSID |
Channel |
Channel on which the radio operates |
Tx Power |
Current transmit power of the radio |
Chl |
Channel number |
NbrCnt |
Neighbor count, or, the number of neighbors found on the channel |
Load |
Load observed on the channel in percentage |
Util |
Utilization of the channel in percentage |
Intf |
Interference observed on the channel in percentage |
PER |
Packet error rate observed on the channel in percentage |
Retry |
Percentage of retransmission happened on the channel |
Radar |
Radar detection status |
Nbr-BasicBSSID |
MAC address of the neighbor AP |
SignalStrength |
Signal strength of the AP in dBm |
Type |
Type of the AP, managed or unmanaged |
display wlan mesh calibrate-channel history [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display wlan mesh calibrate-channel history to display mesh auto DFS history information.
# Display mesh auto DFS history information
<Sysname> display wlan mesh calibrate-channel history
Mesh RRM History
Mesh-ID: outdoor Number of Radios: 2
AP Radio Chl(After/Before) Date/Time
mpp 1 149/auto 2009-10-10/13:16:19
mpp 1 153/149 2009-10-10/13:19:22
map 1 149/auto 2009-10-10/13:17:1
map 1 153/149 2009-10-10/13:19:24
display wlan rrm
display wlan rrm [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display wlan rrm to display basic RRM configuration information.
# Display RRM configuration information.
<Sysname> display wlan rrm
RRM Configuration
11a Configured Rates (Mbps)
Mandatory : 6, 12, 24
Supported : 9, 18, 36, 48, 54
Multicast : -NA-
Disabled : -NA-
11b Configured Rates (Mbps)
Mandatory : 1, 2
Supported : 5.5, 11
Multicast : -NA-
Disabled : -NA-
11g Configured Rates (Mbps)
Mandatory : 1, 2, 5.5, 11
Supported : 6, 9, 12, 18, 24, 36, 48, 54
Multicast : -NA-
Disabled : -NA-
11g Protection : Enabled
Scan Configuration
Scan Type : Passive
Channel Mode : Auto
Report-Interval (s) : 10
11a Configuration
Automatic Channel Selection : Enabled
Automatic Power Selection : Enabled
Calibration Mode-Channel : -NA-
Mesh Calibration Mode-Channel: -NA-
Calibration Mode-Power : -NA-
Calibration Interval (min) : 10
Interference Threshold (%) : 50
Tolerance Level (%) : 20
Adjacency Factor : 3
CRC-Error Threshold (%) : 20
Power Threshold (dBm) : -65
Minimum Power (dBm) : 1
max-bandwidth (kbps) : 30000
11bg Configuration
Calibration Interval (min) : 8
CRC-Error Threshold (%) : 11
11b Configuration
max-bandwidth (kbps) : 7000
11g Configuration
11g Protection : Disabled
11g Protection Mode : CTS-to-Self
11n Configuration
Mandatory Maximum MCS : -NA-
Supported Maximum MCS : 76
Multicast MCS : -NA-
11n Protection : Disabled
11n Protection Mode : CTS-to-Self
max-bandwidth (kbps) : 180000
11h configuration
Spectrum Management : Enabled
Power Constraint (dBm) : 5
Channel Set : All
Load Balance Configuration
Load Balancing Mode : Disabled
Mandatory |
Rates that at least one of the APs is required to support. |
Supported |
Additional rates supported by the client or AP. |
Multicast |
Multicast rate, which must be selected from mandatory rates. |
Disabled |
Rates at which an AP does not transmit data. |
Channel Mode |
If the channel mode is auto, only regulatory domain channels are scanned. If the mode is all, all channels in the band are scanned for rouge detection. |
Report-Interval (s) |
Report interval set with the scan report-interval command. |
Automatic Channel Selection |
Automatic channel selection, which can be enabled or disabled. |
Automatic Power Selection |
Automatic power selection, which can be enabled or disabled. |
Calibration Mode-Channel |
Dynamic frequency selection (DFS): · Self-decisive—Automatic DFS. · Pronto—One-time DFS. · -NA-—Not configured. |
Mesh Calibration Mode-Channel |
· Self-decisive—Mesh auto DFS. · Pronto—Mesh one-time DFS. · -NA-—Not configured. |
Calibration Mode-Power |
Transmit power control (TPC): · Self-decisive—Automatic TPC. · Pronto—One-time TPC. · -NA-—Not configured. |
Calibration Interval (min) |
Calibration interval. |
Interference Threshold (%) |
Channel interference threshold. |
Tolerance Level (%) |
Tolerance factor. |
Adjacency Factor |
Adjacency factor. |
CRC-Error Threshold (%) |
CRC-Error threshold. |
Power Threshold (dBm) |
Power adjustment threshold in dBm. |
Minimum Power (dBm) |
Minimum transmission power in dBm. |
11n Protection |
802.11n protection: Enabled or Disabled. |
11n Protection Mode |
802.11n protection mode, which can be CTS-to-Self and RTS/CTS. |
Spectrum Management |
802.11a spectrum management, which can be enabled or disabled. |
Power Constraint (dBm) |
Power constraint for all 802.11a radios, which is set with the power-constraint command. |
Channel Set |
All or Non-dot11h. |
Load Balance Configuration |
Load balance configuration. |
Load Balancing Mode |
If load balancing is disabled, this field is "Disabled" and the below two fields (threshold and gap) are absent. |
Session Threshold (users) |
Session threshold. If the load balancing mode is set to "traffic", the field is replaced by "Traffic Threshold (%)". |
Session Gap (users) |
The value of session gap. If the load balancing mode is set to "traffic", the field is replaced by "Traffic Gap (%)". |
display wlan rrm-calibration-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-id: ID of a radio group.
all: Displays the configuration of all radio groups.
Use display wlan rrm-calibration-group to display radio group configuration information.
# Display configuration information about radio group 10.
<Sysname> display wlan rrm-calibration-group 10
RRM Calibration Group Information
Group ID : 10
Description : office
Channel holddown time : 720 (in minutes)
Power holddown time : 60 (in minutes)
Group members : ap4-radio2,
ap3-radio2,
dot11a
dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
View
WLAN RRM view
Default level
2: System level
disabled-rate: Specifies disabled rates.
mandatory-rate: Specifies mandatory rates.
multicast-rate: Specifies multicast rates, at which the AP sends multicasts to clients. Multicasts rates must be selected from the mandatory rates.
supported-rate: Specifies supported rates.
rate-value: Specifies a radio rate, which can be one of the following:
· 6 Mbps
· 9 Mbps
· 12 Mbps
· 18 Mbps
· 24 Mbps
· 36 Mbps
· 48 Mbps
· 54 Mbps
Use dot11a to configure 802.11a rates.
Use undo dot11a to restore the default 802.11a rates.
By default:
· Disabled rates—None.
· Mandatory rates—6, 12, and 24.
· Multicast rates—Automatically selected from the mandatory rates.
· Supported rates—9, 18, 36, 48, and 54.
# Configure 802.11a rates (disabled: 12; supported: 6; multicast: 18).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a disabled-rate 12
[Sysname-wlan-rrm] dot11a supported-rate 6
[Sysname-wlan-rrm] dot11a multicast-rate 18
dot11a adjacency-factor
dot11a adjacency-factor neighbor
undo dot11a adjacency-factor
View
WLAN RRM view
Default level
2: System level
neighbor: Specifies the maximum number of neighbors. The value is in the range of 1 to 16.
Use dot11a adjacency-factor to set the maximum number of neighbors for 802.11a, and specify that when the maximum neighbor number is reached, the neighbor AP that has the minimum power among neighbors performs power detection.
Use undo dot11a adjacency-factor to restore the default.
By default, the maximum number of neighbors is 3, and when the maximum neighbor number is reached, the AP with the minimum power among all neighbors performs power detection.
Related commands: dot11a calibrate-power threshold.
# Set the maximum number of neighbors for 802.11a to 7, and specify that when the maximum neighbor number is reached. the AP with the minimum power among the neighbors performs power detection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a adjacency-factor 7
undo dot11a calibrate-channel
View
WLAN RRM view
Default level
2: System level
None
Use dot11a calibrate-channel to configure channel detection to configure dynamic channel selection for 802.11a.
Use undo dot11a calibrate-channel to restore the default.
Channel detection is not configured by default.
With dynamic channel selection enabled, the maximum power depends on the last selected channel.
# Configure 802.11a channel detection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel
dot11a calibrate-channel pronto ap { all | name apname radio radio-num }
View
WLAN RRM view
Default level
2: System level
all: Specifies all APs.
name apname: Specifies an AP.
radio radio-num: Specifies a radio of the AP.
Use dot11a calibrate-channel pronto ap to configure one-time DFS for an AP or all APs of 802.11a. The result of DFS is applied to the APs at the next calibration interval.
By default, one-time DFS is not configured.
This command cannot be undone.
# Configure one-time DFS for all 802.11a APs.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel pronto ap all
undo dot11a calibrate-channel self-decisive
View
WLAN RRM view
Default level
2: System level
None
Use dot11a calibrate-channel self-decisive to configure automatic DFS (channel detection is also configured) for all APs.
Use undo dot11a calibrate-channel self-decisive to restore the default.
By default, auto-DFS is disabled.
# Enable auto-DFS for all APs at the calibration interval for 802.11a.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel self-decisive
undo dot11a calibrate-power
View
WLAN RRM view
Default level
2: System level
None
Use dot11a calibrate-power to configure power detection to configure dynamic power selection.
Use undo dot11a calibrate-power to restore the default.
By default, power detection is not configured.
# Configure 802.11a power detection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power
dot11a calibrate-power min
dot11a calibrate-power min tx-power
undo dot11a calibrate-power min
View
WLAN RRM view
Default level
2: System level
tx-power: Minimum 802.11a radio transmission power, in the range of 1 to 20 dBm.
Use dot11a calibrate-power min to configure the minimum 802.11a radio transmission power.
Use undo dot11a calibrate-power min to restore the default.
By default, the minimum 802.11a radio transmission power is 1 dBm.
# Set the minimum 802.11a radio transmission power to 10 dBm.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power min 10
dot11a calibrate-power pronto
dot11a calibrate-power pronto ap { all | name apname radio radio-num }
View
WLAN RRM view
Default level
2: System level
Use dot11a calibrate-power pronto ap to configure one-time TPC for an AP or all APs. The result of TPC is applied to the APs at the next calibration interval. This command cannot be undone.
By default, one-time TPC is not configured.
# Configure one-time TPC for radio 1 of AP 1 in 802.11a mode.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power pronto ap name ap1 radio 1
undo dot11a calibrate-power self-decisive
View
WLAN RRM view
Default level
2: System level
None
Use dot11a calibrate-power self-decisive to configure automatic TPC (power detection is also configured) for all APs.
Use undo dot11a calibrate-power self-decisive to restore the default.
By default, automatic TPC is disabled.
# Enable automatic TPC for all APs at the calibration interval.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power self-decisive
dot11a calibrate-power threshold value
undo dot11a calibrate-power threshold
View
WLAN RRM view
Default level
2: System level
value: Power adjustment threshold, in the range of 50 to 90 dBm. The value range indicates that the power of the AP is in the range of –90 to –50.
Use dot11a calibrate-power threshold to configure the power adjustment threshold for 802.11a radios.
Use undo dot11a calibrate-power threshold to restore the default.
By default, the power adjustment threshold for 802.11a radios is 65.
Related commands: dot11a adjacency-factor.
# Set the power adjustment threshold to 70.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power threshold 70
dot11a calibration-interval
dot11a calibration-interval minutes
undo dot11a calibration-interval
View
WLAN RRM view
Default level
2: System level
minutes: Calibration interval, in the range of 3 to 180 minutes.
Use dot11a calibration-interval to set the calibration interval for 802.11a.
Use undo dot11a calibration-interval to restore the default value.
By default, the calibration interval is 8 minutes.
RRM algorithms run periodically at the calibration interval for transmit power control or dynamic frequency selection.
The calibration interval takes effect for mesh network optimization, channel calibration, and power calibration.
# Set the calibration interval to 10 minutes for 802.11a.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibration-interval 10
dot11a crc-error-threshold
dot11a crc-error-threshold percent
undo dot11a crc-error-threshold
View
WLAN RRM view
Default level
2: System level
percent: Threshold, in the range of 10 to 100 percentage.
Use dot11a crc-error-threshold to set the CRC error threshold value for 802.11a.
Use undo dot11a crc-error-threshold to restore the default for 802.11a.
The default CRC error threshold is 20%.
# Set the CRC error threshold for 802.11a to 50%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a crc-error-threshold 50
dot11a exclude-channel
dot11a exclude-channel channel-list
undo dot11a exclude-channel { channel-list | all }
View
WLAN RRM view
Default level
2: System level
channel-list: Specifies a channel list, in the format of channel-list = { channel }& <1-10>, where channel represents a 5-GHz channel supported by the AP and &<1-10> indicates that you can specify up to 10 channels.
all: Specifies all channels.
Use dot11a exclude-channel to configure the 5-GHz channel exclusion list.
Use undo dot11a exclude-channel to remove the channels in the 5-GHz channel list.
By default, no channels exist in the channel exclusion list.
# Add channels 149 and 153 to the 5-GHz channel exclusion list.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 149 153
dot11a interference-threshold
dot11a interference-threshold percent
undo dot11a interference-threshold
View
WLAN RRM view
Default level
2: System level
percent: Channel interference threshold, in the range of 40 to 100 percentage.
Use dot11a interference-threshold to set the channel interference threshold value for 802.11a.
Use undo dot11a interference-threshold to restore the default for 802.11a.
The default interference threshold for 802.11a is 50%.
When channel adjustment is enabled, a new channel is selected when either the interference threshold is exceeded on the current channel.
# Set the channel interference threshold for 802.11a to 60%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a interference-threshold 60
dot11a max-bandwidth
dot11a max-bandwidth 11a-bandwidth
undo dot11a max-bandwidth
View
WLAN RRM view
Default level
2: System level
11a-bandwidth: Maximum 802.11a bandwidth, in the range of 16 to 30000 kbps.
Use dot11a max-bandwidth to configure the maximum 802.11a bandwidth.
Use undo dot11a max-bandwidth to restore the default.
By default, the maximum 802.11a bandwidth is 30000 kbps.
# Configure the maximum 802.11a bandwidth as 15000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a max-bandwidth 15000
dot11a tolerance-level
dot11a tolerance-level percentage
undo dot11a tolerance-level
View
WLAN RRM view
Default level
2: System level
percentage: Tolerance level in percentage, in the range of 15 to 45.
Use dot11a tolerance-level to set the tolerance factor for the band.
Use undo dot11a tolerance-level to restore the default.
The default tolerance factor is 20.
A new channel is selected when the interference threshold is exceeded on the current channel. However, the new channel is not applied until the quality of the current channel is worse than that of the new channel by the tolerance threshold.
# Set the tolerance level for 802.11a to 25.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a tolerance-level 25
dot11b
dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
View
WLAN RRM view
Default level
2: System level
multicast-rate: Specifies multicast rates, at which the AP send multicasts to clients. Multicasts rates must be selected from the mandatory rates.
· 1 Mbps
· 2 Mbps
· 5.5 Mbps
· 11 Mbps
Use dot11b to configure 802.11b rates.
Use undo dot11b to restore the default rates.
By default:
· Mandatory rates—1 and 2.
· Supported rates—5.5 and 11.
# Configure 802.11b rates (disabled: 1; supported: 11 multicast rate: 11).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b disabled-rate 1
[Sysname-wlan-rrm] dot11b supported-rate 11
[Sysname-wlan-rrm] dot11b multicast-rate 11
dot11b max-bandwidth
dot11b max-bandwidth 11b-bandwidth
undo dot11b max-bandwidth
View
WLAN RRM view
Default level
2: System level
11b-bandwidth: Maximum 802.11b bandwidth, in the range of 16 to 7000 kbps.
Use dot11b max-bandwidth to configure the maximum 802.11b bandwidth.
Use undo dot11b max-bandwidth to restore the default.
By default, the maximum 802.11b bandwidth is 7000 kbps.
# Configure the maximum 802.11b bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b max-bandwidth 6000
dot11bg adjacency-factor
dot11bg adjacency-factor neighbor
undo dot11bg adjacency-factor
View
WLAN RRM view
Default level
2: System level
Use dot11bg adjacency-factor to set the maximum number of neighbors for 802.11b/g, and specify that when the maximum neighbor number is reached, the neighbor AP that has the minimum power among neighbors performs power detection.
Use undo dot11bg adjacency-factor to restore the default.
Related commands: dot11bg calibrate-power threshold.
# Set the maximum number of neighbors for 802.11b/g to 7, and specify that when the maximum neighbor number is reached, the AP with the minimum power among the neighbors performs power detection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg adjacency-factor 7
undo dot11bg calibrate-channel
View
WLAN RRM view
Default level
2: System level
None
Use dot11bg calibrate-channel to configure channel detection to enable dynamic channel selection for 802.11b/g.
Use undo dot11bg calibrate-channel to restore the default.
By default, channel detection is not configured.
# Configure channel detection for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel
dot11bg calibrate-channel pronto ap { all | name apname radio radio-num }
View
WLAN RRM view
Default level
2: System level
Use dot11bg calibrate-channel pronto ap to configure one-time DFS for an AP or all APs of 802.11b/g. The result of DFS is applied to the APs at the next calibration interval.
# Configure one-time DFS for radio 1 of AP1 in 802.11b/g mode.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel pronto ap name ap1 radio 1
undo dot11bg calibrate-channel self-decisive
View
WLAN RRM view
Default level
2: System level
None
Use dot11bg calibrate-channel self-decisive to configure automatic DFS (channel detection is also configured).
Use undo dot11bg calibrate-channel self-decisive to restore the default.
By default, auto-DFS is not configured.
# Configure auto-DFS for all APs.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel self-decisive
undo dot11bg calibrate-power
View
WLAN RRM view
Default level
2: System level
None
Use dot11bg calibrate-power to configure power detection to enable dynamic power selection for 802.11b/g.
Use undo dot11bg calibrate-power to restore the default.
# Configure 802.11b/g power detection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power
dot11bg calibrate-power min
dot11bg calibrate-power min tx-power
undo dot11bg calibrate-power min
View
WLAN RRM view
Default level
2: System level
tx-power: Minimum 802.11b/g radio transmission power, in the range of 1 to 20 dBm.
Use dot11bg calibrate-power min to configure the minimum 802.11b/g radio transmission power.
Use undo dot11bg calibrate-power min to restore the default.
By default, the minimum 802.11b/g radio transmission power is 1 dBm.
# Set the minimum 802.11b/g radio transmission power to 10 dBm.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power min 10
dot11bg calibrate-power pronto ap { all | name apname radio radio-num }
View
WLAN RRM view
Default level
2: System level
name apname: Specifies an AP, case-insensitive string of 1 to 32 characters.
Use dot11bg calibrate-power pronto ap to configure one-time TPC for an AP or all APs. The result of TPC is applied to the APs at the next calibration interval.
# Configure one-time TPC for all APs in 802.11b/g mode.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power pronto all
undo dot11bg calibrate-power self-decisive
View
WLAN RRM view
Default level
2: System level
None
Use dot11bg calibrate-power self-decisive to configure automatic TPC (power detection is also configured) for all APs.
Use undo dot11bg calibrate-power self-decisive to restore the default.
By default, automatic TPC is not configured.
# Configure automatic TPC for all APs at the calibration interval.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power self-decisive
dot11bg calibrate-power threshold value
undo dot11bg calibrate-power threshold
View
WLAN RRM view
Default level
2: System level
Use dot11bg calibrate-power threshold to configure the power adjustment threshold for 802.11b/g radios.
Use undo dot11bg calibrate-power threshold to restore the default.
By default, the power adjustment threshold for 802.11b/g radios is 65.
Related commands: dot11bg adjacency-factor.
# Set the power adjustment threshold for 802.11b/g radios to 70.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power threshold 70
dot11bg calibration-interval
dot11bg calibration-interval minutes
undo dot11bg calibration-interval
View
WLAN RRM view
Default level
2: System level
Use dot11bg calibration-interval to set the calibration interval for 802.11b/g.
Use undo dot11bg calibration-interval to restore the default.
# Set the calibration interval to 10 minutes for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibration-interval 10
dot11bg crc-error-threshold
dot11bg crc-error-threshold percent
undo dot11bg crc-error-threshold
View
WLAN RRM view
Default level
2: System level
Use dot11bg crc-error-threshold to set the CRC error threshold value for 802.11b/g.
Use undo dot11bg crc-error-threshold to restore the default for 802.11b/g.
# Set the CRC error threshold to 50% for 802.11b/g.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg crc-error-threshold 50
dot11bg exclude-channel
dot11bg exclude-channel channel-list
undo dot11bg exclude-channel { channel-list | all }
View
WLAN RRM view
Default level
2: System level
Use dot11bg exclude-channel to configure the 2.4-GHz channel exclusion list.
Use undo dot11bg exclude-channel to remove the channels in the 2.4-GHz channel list.
# Add channels 2 and 3 to the 2.4-GHz channel exclusion list.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 2 3
dot11bg interference-threshold percent
undo dot11bg interference-threshold
View
WLAN RRM view
Default level
2: System level
Use dot11bg interference-threshold to set the channel interference threshold value for 802.11b/g.
Use undo dot11bg interference-threshold to restore the default for 802.11b/g.
The default interference threshold is 50%.
# Set the channel interference threshold to 60% for 802.11b/g.
[Sysname] wlan rrm
dot11bg tolerance-level
dot11bg tolerance-level percentage
undo dot11bg tolerance-level
View
WLAN RRM view
Default level
2: System level
Use dot11bg tolerance-level to set the tolerance factor for the band.
Use undo dot11bg tolerance-level to restore the default.
# Set the tolerance-level for 802.11b/g to 25.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg tolerance-level 25
dot11g
dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
View
WLAN RRM view
Default level
2: System level
multicast-rate: Specifies multicast rates, which are the rates at which the AP send multicasts to clients. Multicasts rates must be selected from the mandatory rates.
· 1 Mbps
· 2 Mbps
· 5.5 Mbps
· 6 Mbps
· 9 Mbps
· 11 Mbps
· 12 Mbps
· 18 Mbps
· 24 Mbps
· 36 Mbps
· 48 Mbps
· 54 Mbps
Use dot11g to configure 802.11g rates.
Use undo dot11g to restore the default rates.
By default:
· Mandatory rates—1, 2, 5.5 and 11.
· Supported rates—6, 9, 12, 18, 24, 36, 48 and 54.
# Configure 802.11g rates (disabled: 2, 36; supported: 54; multicast rate: 11).
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g disabled-rate 2 36
[Sysname-wlan-rrm] dot11g supported-rate 54
[Sysname-wlan-rrm] dot11g multicast-rate 11
dot11g max-bandwidth
dot11g max-bandwidth 11g-bandwidth
undo dot11g max-bandwidth
View
WLAN RRM view
Default level
2: System level
11g-bandwidth: Maximum 802.11g bandwidth in kbps. It is in the range of 16 to 30000 kbps.
Use dot11g max-bandwidth to configure the maximum 802.11g bandwidth.
Use undo dot11g max-bandwidth to restore the default.
By default, the maximum 802.11g bandwidth 30000 kbps.
# Configure the maximum 802.11g bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g max-bandwidth 6000
dot11g protection enable
undo dot11g protection enable
View
WLAN RRM view
Default level
2: System level
None
Use dot11g protection enable to enable 802.11g protection.
Use undo dot11g protection enable to restore the default.
By default, 802.11g protection is disabled.
# Enable 802.11g protection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection enable
dot11g protection-mode
dot11g protection-mode { cts-to-self | rts-cts }
undo dot11g protection-mode
View
WLAN RRM view
Default level
2: System level
cts-to-self: Specifies the Clear to Send (CTS)-to-Self mode.
rts-cts: Specifies the Request to Send (RTS)/CTS mode.
Use dot11g protection-mode to configure the 802.11g protection mode.
Use undo dot11g protection-mode to restore the default.
By default, the 802.11g protection mode is CTS-to-Self.
# Configure the 802.11g protection mode as RTS/CTS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection-mode rts-cts
dot11n mandatory maximum-mcs
dot11n mandatory maximum-mcs index
undo dot11n mandatory maximum-mcs
View
RRM view
Default level
2: System level
index: Specifies the maximum MCS index for 802.11n mandatory rates, in the range of 0 to 76.
Use dot11n mandatory maximum-mcs to specify the maximum MCS index for 802.11n mandatory rates.
Use undo dot11n mandatory maximum-mcs to remove the configuration.
No maximum MCS index is specified for 802.11n mandatory rates by default.
If you configure the client dot11n-only command for a radio, you must configure the maximum MCS index for 802.11n mandatory rates.
# Specify the maximum MCS index for 802.11n mandatory rates as 15.
<sysname> system-view
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n mandatory maximum-mcs 15
dot11n max-bandwidth
dot11n max-bandwidth 11n-bandwidth
undo dot11n max-bandwidth
View
WLAN RRM view
Default level
2: System level
11a-bandwidth: Maximum 802.11n bandwidth, in the range of 16 to 180000 kbps.
Use dot11n max-bandwidth to configure the maximum 802.11n bandwidth.
Use undo dot11n max-bandwidth to restore the default.
By default, the maximum 802.11n bandwidth is 18000 kbps.
# Configure the maximum 802.11n bandwidth as 6000 kbps.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n max-bandwidth 6000
dot11n multicast-rate
dot11n multicast-rate index
undo dot11n multicast-rate
View
RRM view
Default level
2: System level
index: Specifies the maximum MCS index for 802.11n multicast rates, in the range of 0 to 76.
Use dot11n multicast-rate to specify the maximum MCS index for 802.11n multicast rates.
Use undo dot11n multicast-rate to remove the configuration.
By default, the maximum MCS index for 802.11n multicast rates is not configured.
The multicast MCS is adopted only when all the clients use 802.11n.
If a non 802.11n client exists, multicast traffic is transmitted at a mandatory MCS data rate.
If you configure a multicast MCS index greater than the maximum MCS index supported by the radio, the maximum MCS index is adopted.
When the multicast MCS takes effect, the corresponding data rates defined for 20 MHz are adopted no matter whether the 802.11n radio operates in 40 MHz mode or in 20 MHz mode.
# Specify the maximum MCS index for 802.11n multicast rates as 76.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n multicast-rate 76
dot11n protection enable
undo dot11n protection enable
View
WLAN RRM view
Default level
2: System level
None
Use dot11n protection enable to enable 802.11n protection.
Use undo dot11n protection enable to restore the default.
By default, 802.11n protection is disabled.
# Enable 802.11n protection.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection enable
dot11n protection-mode
dot11n protection-mode { cts-to-self | rts-cts }
undo dot11n protection-mode
View
WLAN RRM view
Default level
2: System level
Use dot11n protection-mode to configure the 802.11n protection mode.
Use undo dot11n protection-mode to restore the default.
By default, the 802.11n protection mode is CTS-to-Self.
# Configure the 802.11n protection mode as RTS/CTS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection-mode rts-cts
dot11n support maximum-mcs
dot11n support maximum-mcs index
undo dot11n support maximum-mcs
View
RRM view
Default level
2: System level
index: Specifies the maximum MCS index for 802.11n supported rates, in the range of 0 to 76.
Use dot11n support maximum-mcs to specify the maximum MCS index for 802.11n supported rates.
Use undo dot11n support maximum-mcs to restore the default.
By default, the maximum MCS index for 802.11n supported rates is 76.
The specified maximum MCS index for 802.11n supported rates must be no less than the specified maximum MCS index for 802.11n mandatory rates.
# Specify the maximum MCS index for 802.11n supported rates as 25.
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n support maximum-mcs 25
undo mesh calibrate-channel
View
WLAN RRM view
Default level
2: System level
None
Use mesh calibrate-channel to enable mesh channel monitoring for mesh auto DFS.
Use undo mesh calibrate-channel to restore the default.
By default, mesh channel monitoring is not enabled.
# Enable mesh channel monitoring.
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel
mesh calibrate-channel pronto
mesh calibrate-channel pronto mesh-profile { mesh-profile-number | all }
View
WLAN RRM view
Default level
2: System level
mesh-profile-number: Specifies a mesh profile by its number, in the range of 1 to 32.
all: Specifies mesh profiles.
Use mesh calibrate-channel pronto to configure one-time mesh DFS for a specific or all mesh profiles. The result of DFS is applied to the mesh profiles at the next calibration interval.
By default, one-time mesh DFS is not configured.
# Configure one-time DFS for all mesh profiles.
[Sysname] wlan rrm
undo mesh calibrate-channel self-decisive
View
WLAN RRM view
Default level
2: System level
None
Use mesh calibrate-channel self-decisive to enable automatic DFS (mesh channel monitoring also needs to be enabled).
Use undo mesh calibrate-channel self-decisive to restore the default.
By default, automatic mesh DFS is disabled.
# Enable automatic mesh DFS.
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel self-decisive
power-constraint
power-constraint power-constraint
undo power-constraint
View
WLAN RRM view
Default level
2: System level
power-constraint: Power constraint value in dBm, in the range of 0 to 30.
Use power-constraint to configure the power constraint for all 802.11a clients. Before you configure power constraint, enable spectrum management first. After you configure power constraint, the transmit power for 802.11a clients is the current transmit power minus power-constraint.
Use undo power-constraint to restore the default.
The default power constraint is 0 dBm for 802.11a clients.
Related commands: spectrum-management enable.
# Configure the power constraint for 802.11a clients as 5 dBm.
[Sysname] wlan rrm
[Sysname-wlan-rrm] power-constraint 5
power holddown-time
power holddown-time minutes
undo power holddown-time
View
Radio group view
Default level
2: System level
minutes: Power holddown time, within which, the power of any radio in the radio group keeps unchanged after each power adjustment (automatic and one-time). The value is in the range of 10 to 1440, in minutes.
Use power holddown-time to set the power holddown time for the radio group.
Use undo power holddown-time to restore the default.
By default, the power holddown time is 60 minutes.
# Set the power holddown time of radio group 10 to 600 minutes.
[Sysname-wlan-rc-group-10] power holddown-time 600
scan channel
scan channel { all | auto }
undo scan channel
View
WLAN RRM view
Default level
2: System level
all: Sets the scan mode to all. When this option is set, all the channels of the radio are scanned.
auto: Sets the scan mode to auto. When this option is set, all channels of the country code being set are scanned.
Use scan channel to set the scan mode.
Use undo scan channel to restore the default.
By default, the scan mode is auto.
# Set the scan mode to all.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan channel all
scan report-interval seconds
undo scan report-interval
View
WLAN RRM view
Default level
2: System level
seconds: Interval for sending scan reports to the AC, in the range of 5 to 120 seconds.
Use scan report-interval to set the scan report interval.
Use undo scan report-interval to restore the default.
The default scan report interval is 10 seconds.
# Set the scan report interval to 20 seconds.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan report-interval 20
scan type
scan type { active | passive }
undo scan type
View
WLAN RRM view
Default level
2: System level
active: Sets the active scanning mode.
passive: Sets the passive scanning mode.
Use scan type to set the scan type.
Use undo scan type to restore the default.
By default, the scan type is passive.
# Set the scan type to active.
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan type active
undo spectrum-management enable
View
WLAN RRM view
Default level
2: System level
None
Use spectrum-management enable to enable spectrum management for 802.11a radios.
Use undo spectrum-management enable to restore the default.
By default, spectrum management for 802.11a radios is disabled.
When spectrum management is enabled, the WLAN sub-system advertises power capabilities of the AP and power constraints applicable to all devices in the BSS based on regulatory domain specification.
# Enable spectrum management.
[Sysname] wlan rrm
[Sysname-wlan-rrm] spectrum-management enable
wlan rrm
wlan rrm
View
Default level
2: System level
None
Use wlan rrm to enter WLAN RRM view.
# Enter WLAN RRM view.
[Sysname] wlan rrm
[Sysname-wlan-rrm]
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { group-id | all }
View
Default level
2: System level
group-id: ID of a radio group. The value range depends on your device model.
all: Removes all radio groups.
Use wlan rrm-calibration-group to create a radio group, and enter RRM radio group view.
Use undo wlan rrm-calibration-group to remove one or all radio groups.
By default, no radio group exists.
# Create radio group 10.
ap radio
View
Load balancing group view
Default level
2: System level
all: Removes all radios in the load balancing group.
Use ap radio to add a radio of an AP to the load balancing group.
Use undo ap to remove radios in the load balancing group.
By default, no radio exists in the load balancing group.
If you do not provide the radio radio-number and all parameters, the undo ap command removes all the radios of the specified AP in the load balancing group.
# Add radio 2 of AP 1 to load balancing group 10.
[Sysname] wlan load-balance-group 10
[Sysname-wlan-lb-group-10] ap ap1 radio 2
# Remove all radios in load balancing group 10.
[Sysname-wlan-lb-group-10] undo ap all
# Remove all radios of AP 1 in load balancing group 10.
[Sysname-wlan-lb-group-10] undo ap ap1
# Remove radio 2 of AP 1 in load balancing group 10.
[Sysname-wlan-lb-group-10] undo ap ap1 radio 2
description
View
Default level
2: System level
text: Description of the load balancing group, a case-sensitive string of 1 to 64 characters that can contain letters, digits and underlines.
Use description to configure the description of the load balancing group.
Use undo description to remove the description of the load balancing group.
By default, the load balancing group has no description.
# Configure the description of load balancing group 10 as marketing.
[Sysname-wlan-lb-group10] description marketing
display wlan load-balance-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-id: ID of a load balancing group. The value range depends on your device model.
all: Displays the configuration of all load balancing groups.
Use display wlan load-balance-group to display load balancing group configuration information.
# Display configuration information about load balancing group 10.
<Sysname> display wlan load-balance-group 10
Load Balance Group Information
Group ID : 10
Description : AA
Group members : ap5-radio2,
ap4-radio2,
ap3-radio2,
ap2-radio2,
load-balance access-denial
load-balance access-denial access-denial
undo load-balance access-denial
View
WLAN RRM view
Default command level
2: System level
access-denial: Maximum denial count of client association requests, in the range of 2 to 10.
Use load-balance access-denial to configure the maximum denial count of association requests sent by a client.
Use undo load-balance access-denial to restore the default.
By default, the maximum denial count is 10.
# Configure the maximum denial count of client association requests as 4.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance access-denial 4
load-balance rssi-threshold
load-balance rssi-threshold rssi-threshold
undo load-balance rssi-threshold
View
WLAN RRM view
2: System level
rssi-threshold: Band navigation RSSI threshold, in the range of 5 to 100.
Use load-balance rssi-threshold to configure the load balancing RSSI threshold.
Use undo load-balance rssi-threshold to restore the default.
By default, the load balancing RSSI threshold is 25.
# Configure the load balancing RSSI threshold as 40.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance rssi-threshold 40
load-balance session
load-balance session value [ gap gap-value ]
undo load-balance
View
WLAN RRM view
Default level
2: System level
value: Session threshold, or, the number of maximum sessions, in the range of 2 to 40.
gap gap-value: Session gap threshold, which is in the range of 1 to 8 and defaults to 4.
Use load-balance session to configure session-mode load balancing. Load balancing is carried out when the session threshold and session gap are reached.
Use undo load-balance to remove the configuration.
By default, load balancing is disabled.
# Configure the session threshold as 7.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance session 7
# Configure the session threshold as 7 and the session gap threshold as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance session 7 gap 5
load-balance traffic
load-balance traffic value [ gap gap-value ]
undo load-balance
View
WLAN RRM view
Default level
2: System level
value: Traffic threshold, in the range of 10 to 80 percentage.
gap gap-value: Traffic gap threshold, which is in the range of 10 to 40 percentage and defaults to 20 percentage.
Use load-balance traffic to configure traffic-mode load balancing. Load balancing is carried out when the traffic threshold and session gap are reached.
The 802.11g protection feature occupies bandwidth, affecting forwarding performance. If you configure load balancing after you enable 802.11g protection, you need to lower the traffic gap threshold.
Related commands: dot11g protection enable.
# Configure the traffic threshold as 50%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance traffic 50
# Configure the traffic threshold as 20% and the traffic gap threshold as 25%.
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance traffic 20 gap 25
wlan load-balance-group group-id
undo load-balance-group { group-id | all }
View
Default Level
2: System level
all: Removes all load balancing groups.
Use wlan load-balance-group to create a load balancing group, and enter load balancing group view.
Use undo wlan load-balance-group to remove one or all load balancing groups.
By default, no load balancing group exists.
# Create load balancing group 10.
band-navigation aging-time
band-navigation aging-time aging-time
undo band-navigation aging-time
View
WLAN RRM view
2: System level
aging time: Client information aging time, in the range of 10 to 600 seconds.
Use band-navigation aging-time to configure the client information aging time.
Use undo band-navigation aging-time to restore the default.
By default, the client information aging time is 180 seconds.
# Configure the client information aging time as 50 seconds.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation aging-time 50
WLAN RRM view
2: System level
access-denial: Maximum denial count of client association requests, in the range of 1 to 10.
Use band-navigation balance access-denial to configure the maximum denial count of association requests sent by a 5 GHz-capable client.
Use undo band-navigation balance access-denial to restore the default.
By default, association requests sent by a 5 GHz-capable client are not denied.
If a client has been denied more than the maximum times on the 5-GHz radio, the AP considers that the client is unable to associate to any other AP, and allows the 5-GHz radio to accept the client.
# Configure the maximum denial count of client association requests as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance access-denial 5
band-navigation balance session session [ gap gap ]
undo band-navigation balance session
WLAN RRM view
2: System level
session: Band navigation load balancing session threshold for the 5GHz band, in the range of 2 to 40.
gap: Band navigation load balancing session gap, which is the number of clients on the 5-GHz band minus the number of clients on the 2.4-GHz band. It is in the range of 1 to 8.
Use band-navigation balance session to configure the band navigation load balancing session threshold and session gap.
Use undo band-navigation balance session to restore the default.
By default, band navigation is disabled.
# Configure the session threshold as 10 and session gap as 5.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance session 10 gap 5
undo band-navigation enable
View
AP template view
2: System level
None
Use band-navigation enable to enable band navigation for an AP.
Use undo band-navigation enable to disable band navigation for an AP.
By default, band navigation is enabled on an AP.
Band navigation takes effect on an AP only when it is enabled both globally and for the AP.
# Enable band navigation for AP 1.
[Sysname] wlan ap ap1 model WA2620E-AGN
[Sysname-wlan-ap-ap1] band-navigation enable
View
WLAN RRM view
2: System level
None
Use band-navigation enable to enable band navigation globally.
Use undo band-navigation enable to disable band navigation globally.
By default, band navigation is disabled globally.
Band navigation takes effect on an AP only when it is enabled both globally and for the AP..
# Enable band navigation globally.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation enable
band-navigation rssi-threshold rssi-threshold
undo band-navigation rssi-threshold
View
WLAN RRM view
2: System level
Use band-navigation rssi-threshold to configure the band navigation RSSI threshold.
Use undo band-navigation rssi-threshold to restore the default.
By default, the band navigation RSSI threshold is 15.
An AP directs a client to its 5-GHz radio only when the AP detects that the RSSI of the client is higher than the band navigation RSSI threshold.
# Configure the band navigation RSSI threshold as 40.
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation rssi-threshold 40
