01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX Series Access Controllers Command References(R3308 R2308)-6W10701-Fundamentals Command Reference
07-License Management Commands
07-License Management Commands 87.10 KB
display license
display license ap [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ap: Displays information about AP licenses registered with the access controller.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display license to display information about AP licenses, including their license keys, activation keys, and the maximum number of online APs.
# Display AP licenses registered with the access controller.
<Sysname> display license ap
No. SN                       License Key          Activation Key       AP Number
 1  210235A35JB05B000432     0E60F01DD07102DE532C 0D52EE737B54801DE699 32
 2  210235A35JB05B000432     AC09B720407102CBA657 0C3E25FC6FEA1021B933 32
 3  210235A35JB05B000432     6C5AC902A07102682A41 A15054E026AB0CBC3583 32
No. Serial number                               AP Number    Available Time Left
 1  jS6HJ-fnDvq-x9Kpu-CYm@G-$i2mf-@mSNV-JKDU9          32          0
 2  wejnX-rvapn-/K6W9-umsAw-DjAuH-MWPug-emn+q          32    Forever
 3  yUBB@-/F2ez-AyM/w-nX/XV-uZp$R-:beSz-q5h89          32    Forever
No.
License number.
SN
Serial number of the access controller.
License Key
License key of a standard license.
To get the License Key,you can purchase the software license certificate.
Activation Key
Activation key.
To get the activation key, purchase the software license certificate, and log in to the H3C website to register the license by using the license key, device serial number, and checksum in the correct format.
You can get the serial number and checksum of the access controller by using the display device serial-number command.
AP Number
Number of online APs permitted by the license.
Serial Number
Serial number of an enhanced license.
Available Time Left
Remaining lifetime of the license.
license append
license append license-key activation-key
View
Default level
2: System level
license-key: Specifies the license key of a standard license. You get a license key when you purchase a permanent standard license or get or trial standard license.
activation-key: Specifies the activation key for the license. To obtain an activation key for a standard license, you must use the license key to register the license on the H3C website. For more information about registering standard licenses, see H3C WX Series Access Controllers License Registration and Activation Guide.
Use license append to register a standard license with the access controller.
After registering a license, reboot the access controller to validate the license.
An AP license represents a certain number of online APs supported by the access controller. You can increase the number of supported online APs by adding AP licenses until the maximum number of online APs that the access controller can support is reached.
Support for this command depends on the device model. For the command matrixes, see About the WX Series Access Controllers Command References.
# Register a standard license with the access controller.
[Sysname] license append 2DAB078A707102F6E499 8156824B365F5FAAB822
The license is added successfully. To make it take effect, reboot the device.
license register
license register ap serial-number
View
Default level
3: Manage level
serial-number: Specifies the active-key of an enhanced AP license, in the format of XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX, where X represents a character. Valid characters include letters (case-sensitive), digits, plus signs (+), and forward slashes (/).
Use license register to register an enhanced AP license with the access controller.
To get an active-key, purchase the software license certificate, and log in to the H3C website to register the license by using the license key, device serial number, and checksum in the correct format.
An enhanced license does not require an activation key as does a standard license.
NOTE
# Register an enhanced AP license with the access controller.
<Sysname> license register ap M4rVZ-AijZx-$MmwG-A4Z2S-@iVNV-tcex5-jRCtR
Info: Register successfully.
