| 04-File Management Commands | 130.89 KB |
NOTE: · The storage medium type available with your device can be flash, CF card, or some other types depending on your device model. For more information, see About the WX Series Access Controllers Configuration Guides. · In the following examples, the current working directory is the root directory of the storage medium on the device. · For the qualified filename formats, see Fundamentals Configuration Guide. |
cd
cd { directory | .. | / }
View
Default level
3: Manage level
directory: Name of the target directory, in the format of [drive:/]path. For the detailed introduction to the drive and path arguments, see Fundamentals Configuration Guide. If no drive information is provided, the argument represents a folder or subfolder in the current directory.
..: Returns to an upper directory. If the current working directory is the root directory, or if no upper directory exists, the current working directory does not change when the cd .. command is executed. This argument does not support command online help.
/: Returns to the root directory of the storage medium. This keyword does not support command line online help.
Use cd to change the current working directory.
# Enter the test folder after logging in to the device.
<Sysname> cd test
# Return to the upper directory. (A space is required after the keyword cd.)
<Sysname> cd ..
# Return to the root directory.
<Sysname> cd /
After you change the current directory using the cd command, you can use the pwd command to view the path of the current working directory.
copy
copy fileurl-source fileurl-dest
View
Default level
3: Manage level
fileurl-source: Name of the source file.
fileurl-dest: Name of the target file or folder.
Use copy to copy a file.
If you specify a target folder, the system will copy the file to the specified folder and use the name of the source file as the file name.
# Copy file testcfg.cfg in the current folder and save it as testbackup.cfg.
<Sysname> copy testcfg.cfg testbackup.cfg
Copy cfa0:/test.cfg to cfa0:/testbackup.cfg?[Y/N]:y
%Copy file cfa0:/test.cfg to cfa0:/testbackup.cfg...Done.
# Copy file 1.cfg in the test folder on the CF card to the testbackup folder in the first partition of the CF card, and save it as 1backup.cfg.
<Sysname> copy cfa0:/test/1.cfg cfa0:/testbackup/1backup.cfg
Copy cfa0:/test/1.cfg to cfa0:/testbackup/1backup.cfg?[Y/N]:y
%Copy file cfa0:/test/1.cfg to cfa0:/testbackup/1backup.cfg...Done.
crypto-digest
crypto-digest sha256 file file-url
View
Default level
2: System level
sha256: Specifies the SHA-256 algorithm.
file file-url: Name of a file.
Use crypto-digest to compute the digest of a specified file.
The computed digest is used to verify the correctness and integrity of the file to prevent the file from being tampered with. For example, you can use the command to compute the digest of the software image file of a device, and compare the digest with that on the web site of the device vendor to verify whether the file is valid.
# Use the SHA-256 algorithm to compute the digest of the file 1.cfg.
<Sysname> crypto-digest sha256 file 1.cfg
Computing digest...
SHA256 digest(1.cfg)=
7bcb92458222f91f9a09a807c4c4567efd4d5dc4e4abc06c2a741df7045433eb
delete
delete [ /unreserved ] file-url
View
Default level
3: Manage level
/unreserved: Permanently deletes the specified file, and the deleted file can never be restored.
file-url: Name of the file to be deleted. Asterisks (*) are acceptable as wildcards. For example, to remove files with the extension of .txt in the current directory, you may use the delete *.txt command.
Use delete file-url to temporarily delete a file. The deleted file is saved in the recycle bin. To restore it, use the undelete command.
The dir /all command displays the files deleted from the current directory and moved to the recycle bin. These files are enclosed in pairs of square brackets [ ]. To remove the files from the recycle bin, use the reset recycle-bin command.
Use delete /unreserved file-url to permanently delete a file. The deleted file cannot be restored. Use it with caution.
CAUTION: If you delete two files with the same filename in different directories, only the last one is retained in the recycle bin. |
# Remove file tt.cfg from the current directory.
<Sysname> delete tt.cfg
Delete cfa0:/tt.cfg? [Y/N]:y
%Delete file cfa0:/tt.cfg...Done.
dir
dir [ /all ] [ file-url | /all-filesystems ]
View
Default level
3: Manage level
/all: Displays all files and folders in the current directory, including hidden files, hidden folders, files moved from the current directory to the recycle bin. Files in the recycle bin are enclosed in square brackets [ ].
file-url: Displays the specified file. Asterisks (*) are acceptable as wildcards. For example, to display files with the .txt extension in the current directory, you may use the dir *.txt command.
/all-filesystems: Displays files and folders in the root directory of all storage media on the device.
Use dir to display files or folders.
If no parameter is specified, the command displays all visible files and folders in the current directory.
# Display information about all files and folders.
<Sysname> dir /all
Directory of cfa0:/
0 -rw- 20669704 Jan 12 2011 15:17:24 wx5004.bin
1 -rwh 739 Jan 27 2011 16:36:52 private-data.txt
2 drw- - May 17 2010 11:11:32 logfile
3 -rw- 2686 Jan 27 2011 16:36:50 system.xml
4 -rw- 10329 May 18 2010 08:01:54 command.txt
5 -rw- 1433 Jan 27 2011 14:49:12 startup.cfg
6 -rwh 716 Jan 19 2011 20:01:04 hostkey
7 -rwh 572 Jan 19 2011 20:01:04 serverkey
8 drw- - Jan 21 2011 14:11:52 test
9 -rw- 1695 Jan 27 2011 16:36:50 [test.cfg]
252904 KB total (232664 KB free)
[ ] indicates this file is in the recycle bin.
# Display files and folders in the root directory of all storage media on the device.
<Sysname> dir /all-filesystems
Directory of cfa0:/
1 drw- - May 17 2010 11:11:32 logfile
2 -rw- 2686 Jan 27 2011 16:36:50 system.xml
3 -rw- 10329 May 18 2010 08:01:54 command.txt
4 -rw- 1433 Jan 27 2011 14:49:12 startup.cfg
5 drw- - Jan 21 2011 14:11:52 test
Directory of |
Current working directory. |
d |
Indicates a directory. If this field does not exist, it indicates a file. |
r |
Indicates that the file or directory is readable. |
w |
Indicates that the file or directory is writable. |
h |
Indicates that the file or directory is hidden. |
Indicates that the file is in the recycle bin. |
execute
execute filename
View
Default level
2: System level
filename: Name of a batch file with a .bat extension. You can use the rename command to change the suffix of the configuration file to .bat to use it as a batch file.
Use execute to execute the specified batch file.
Batch files are command line files. Executing a batch file is to execute a set of command lines in the file.
Do not include invisible characters in a batch file. If an invisible character is found during the execution, the batch process will abort and the commands that have been executed cannot be cancelled.
Not every command in a batch file is sure to be executed. For example, if a certain command is not correctly configured, the command will fail to be executed, and the system skips this command and goes to the next one.
The configuration generated after a batch file is executed will not be backed up to the standby main board automatically.
Each configuration command in a batch file must be a standard configuration command, meaning that the valid configuration information can be displayed with the display current-configuration command.
# Execute the batch file test.bat in the root directory.
[Sysname] execute test.bat
file prompt
file prompt { alert | quiet }
View
Default level
3: Manage level
alert: Enables the system to warn you about operations that may bring undesirable results such as file corruption or data loss.
quiet: Disables the system from warning you about any operation.
Use file prompt to set a prompt mode for file operations.
By default, the prompt mode is alert, which is recommended to avoid mis-operations.
When the prompt mode is set to quiet, the system does not warn for any file operation.
# Set the file operation prompt mode to alert.
[Sysname] file prompt alert
fixdisk
fixdisk device
View
Default level
3: Manage level
device: Storage medium name.
Use fixdisk to restore the space of a storage medium when it becomes unavailable because of some abnormal operation.
# Restore the space of the CF card.
<Sysname> fixdisk cfa0:
%Fixdisk cfa0: completed.
format
format device [ FAT16 | FAT32 ]
View
Default level
3: Manage level
device: Name of a storage medium (for example flash or cf).
FAT16: Formats a storage medium using the FAT16 format. FAT16 does not support Tab matching but needs to be input completely if used, and is not applicable to a flash card.
FAT32: Formats a storage medium using the FAT32 format. FAT32 does not support Tab matching but needs to be input completely if used, and is not applicable to a flash card.
Use format to format a storage medium.
CAUTION: Formatting a storage medium results in loss of all the files on the storage medium and these files cannot be restored. In particular, if a startup configuration file exists on a storage medium, formatting the storage medium results in loss of the startup configuration file. |
# Format the CF card using the FAT16 format.
<Sysname> format cfa0: FAT16
mkdir
mkdir directory
View
Default level
3: Manage level
directory: Name of a folder.
Use mkdir to create a folder under a specified directory on the storage medium.
The name of the folder to be created must be unique in the specified directory. Otherwise, you will fail to create the folder in the directory.
To use this command to create a folder, the specified directory must exist. For example, to create folder cfa0:/test/mytest, the test folder must exist. Otherwise, you will fail to create the mytest folder.
# Create a folder named test in the current directory.
<Sysname> mkdir test
%Created dir cfa0:/test
# Create folder test/subtest in the current directory.
<Sysname> mkdir test/subtest
%Created dir cfa0:/test/subtest
more
more file-url
View
Default level
3: Manage level
file-url: File name.
Use more to display the contents of the specified file. It indicates that there are more lines that the screen can display.
Pressing Enter displays the next line.
Pressing Space displays the next screen.
Pressing Ctrl+C or any other key exits the display.
This command is valid only for text files.
# Display the contents of file test.txt.
<Sysname> more test.txt
Welcome to H3C.
# Display the contents of file testcfg.cfg.
<Sysname> more testcfg.cfg
version 5.20, Beta 1201, Standard
sysname Sysname
vlan 2
return
<Sysname>
move
move fileurl-source fileurl-dest
View
Default level
3: Manage level
Use move to move a file.
If you specify a target folder, the system will move the source file to the specified folder, with the file name unchanged.
You cannot move files between storage media of different types.
# Move file cfa0:/test/sample.txt to cfa0:/, and save it as 1.txt.
<Sysname> move test/sample.txt 1.txt
Move cfa0:/test/sample.txt to cfa0:/1.txt?[Y/N]:y
% Moved file cfa0:/test/sample.txt to cfa0:/1.txt
# Move file b.cfg to the subfolder test2.
<Sysname> move b.cfg test2
Move cfa0:/b.cfg to cfa0:/test2/b.cfg?[Y/N]:y
%Moved file cfa0:/b.cfg to cfa0:/test2/b.cfg.
pwd
pwd
View
Default level
3: Manage level
None
Use pwd to display the current path.
# Display the current path.
<Sysname> pwd
cfa0:
rename
rename fileurl-source fileurl-dest
View
Default level
3: Manage level
fileurl-source: Name of the source file or folder.
Use rename to rename a file or folder. The target file name must be unique in the current path.
# Rename file sample.txt as sample.bat.
<Sysname> rename sample.txt sample.bat
Rename cfa0:/sample.txt to cfa0:/sample.bat? [Y/N]:y
% Renamed file cfa0:/sample.txt to cfa0:/sample.bat
reset recycle-bin
reset recycle-bin [ /force ]
View
Default level
3: Manage level
/force: Deletes all files in the recycle bin, including files that cannot be deleted by the command without the /force keyword.
Use reset recycle-bin to permanently delete the files in the recycle bin in the current directory.
If a file is corrupted, you may not be able to delete the file using the reset recycle-bin command. Use the reset recycle-bin /force command to delete the corrupted file in the recycle bin forcibly.
The delete file-url command only moves a file to the recycle bin. To permanently delete the file in the recycle bin, use the reset recycle-bin command in the original directory of the file.
The reset recycle-bin command deletes files in the current directory and in the recycle bin. If the original path of the file to be deleted is not the current directory, use the cd command to enter the original directory of the file, and then execute the reset recycle-bin command.
# Delete file b.cfg in the current directory and in the recycle bin.
1. Display all the files in the recycle bin and in the current directory.
<Sysname> dir /all
Directory of cfa0:/
252904 KB total (232660 KB free)
//The output shows that the current directory is cfa0:, and the file test.cfg is in the recycle bin.
2. Delete file test.cfg in the current directory and in the recycle bin.
<Sysname> reset recycle-bin
Clear cfa0:/~/ test.cfg ?[Y/N]:y
%Cleared file cfa0:/~/ test.cfg...
3. In directory cfa0:, check whether the file test.cfg in the recycle bin is deleted.
<Sysname> dir /all
Directory of cfa0:/
252904 KB total (232668 KB free)
// The output shows that file cfa0:/test.cfg is deleted permanently.
# Delete file aa.cfg in the subdirectory test and in the recycle bin.
1. Enter the subdirectory
<Sysname> cd test/
2. Display all the files in the subfolder test.
<Sysname> dir /all
Directory of cfa0:/test/
0 drw- - Jan 27 2011 16:16:24 mytest
1 -rw- 1433 Jan 27 2011 17:05:56 testb
2 -rw- 1433 Jan 27 2011 17:13:12 [aa.cfg]
// The output shows that only one file exists in the folder, and the file has been moved to the recycle bin.
3. Permanently delete file test/aa.cfg.
Clear cfa0:/test/~/aa.cfg ?[Y/N]:y
%Cleared file cfa0:/test/~/aa.cfg...
rmdir
rmdir directory
View
Default level
3: Manage level
directory: Name of the folder.
Use rmdir to remove a folder.
The folder must be an empty one. If not, delete all files and subfolders under it with the delete command.
After you execute the rmdir command successfully, the files in the recycle bin in the folder will be automatically deleted.
# Remove folder mydir.
<Sysname> rmdir mydir
Rmdir cfa0:/mydir?[Y/N]:y
%Removed directory cfa0:/mydir.
undelete
undelete file-url
View
Default level
3: Manage level
file-url: Name of the file to be restored.
Use undelete to restore a file from the recycle bin.
If another file with the same name exists in the same path, the system prompts you whether to overwrite the original file.
# Restore file a.cfg in directory cfa0: from the recycle bin.
<Sysname> undelete a.cfg
Undelete cfa0:/a.cfg?[Y/N]:y
%Undeleted file cfa0:/a.cfg.
# Restore file b.cfg in directory cfa0:/test from the recycle bin.
<Sysname> undelete cfa0:/test/b.cfg
Undelete cfa0:/test/b.cfg?[Y/N]:y
%Undeleted file cfa0:/test/b.cfg.
Or, you can use the following steps to restore file cfa0:/test/b.cfg.
<Sysname> cd test
<Sysname> undelete b.cfg
