11-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10011-Network Management and Monitoring Configuration Guide
00-Preface
00-Preface 83.89 KB
Preface
This configuration guide describes the network management and monitoring configuration procedures. It describes how to view the system information, collect traffic statistics, assess the network performance, synchronize time for all devices with clocks in your network, and use the ping, tracert, and debug commands to check and debug the current network connectivity.
·           Audience
·           Conventions
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners.
·           Field technical support and servicing engineers.
·           Network administrators working with the S6300 switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
To access the most up-to-date H3C product documentation, go to the H3C website at
http://www.h3c.com.hk
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
[email protected]
We appreciate your comments.
