03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS6300 SeriesReference GuidesCommand ReferencesH3C S6300 Switch Series Command References-Release 243x-6W10003-Layer 2—LAN Switching Command Reference
14-Cut-through forwarding commands
14-Cut-through forwarding commands 27.11 KB
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to restore the default.
cut-through enable
Cut-through forwarding is disabled.
A cut-through forwarding-enabled switch forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the switch and enhances forwarding performance.
# Enable cut-through forwarding on the switch.
[Sysname] cut-through enable
