03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS6300 SeriesReference GuidesCommand ReferencesH3C S6300 Switch Series Command References-Release 243x-6W10003-Layer 2—LAN Switching Command Reference
01-Ethernet interface commands
01-Ethernet interface commands 194.08 KB
Common Ethernet interface commands
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
The expected bandwidth of an interface affects the following items:
·     Bandwidth assignment with CBQ. For more information, see ACL and QoS Configuration Guide.
·     Link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth of Ten-GigabitEthernet 1/0/1 to 1000 kbps.
[Sysname-Ten-GigabitEthernet1/0/1] bandwidth 1000
speed
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to restore the default.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth. For example, the value range of the max-pps argument for a 40-GE interface is 0 to 59524000.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression feature limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both storm-constrain and broadcast-suppression can suppress broadcast storm on a port. The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
For the traffic suppression result to be determined, do not configure both the storm constrain broadcast command and the broadcast-suppression command on an interface.
When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
·     If the configured value is smaller than 64, the value of 64 takes effect.
·     If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
For the suppression threshold that takes effect, see the prompt on the device.
# Set the broadcast suppression threshold to 10000 kbps on Ten-GigabitEthernet1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
The actual value is 10048 on port Ten-GigabitEthernet1/0/1 currently.
·     multicast-suppression
·     unicast-suppression
default
Use default to restore the default settings for an Ethernet interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] default
description
Use description to change the description of an interface.
The description of an interface is the interface name plus Interface (for example, Ten-GigabitEthernet1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Change the description of Ten-GigabitEthernet 1/0/1 to lanswitch-interface.
[Sysname-Ten-GigabitEthernet1/0/1] description lanswitch-interface
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
This command displays traffic statistics within a statistics polling interval specified by the flow-interval command.
To clear the Ethernet interface traffic statistics, use the reset counters interface command. For more information, see "reset counters interface."
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and an interface number, this command displays traffic statistics of the specified interface.
# Display inbound traffic statistics for all Ten-GigabitEthernet interfaces.
<Sysname> display counters inbound interface ten-gigabitethernet
Interface                Total (pkts)    Broadcast (pkts)    Multicast (pkts)  Err (pkts)
XGE1/0/1                        100                100                  0              0
XGE1/0/2                          0                  0                  0              0
XGE1/0/3                   Overflow           Overflow           Overflow       Overflow
XGE1/0/4                          0                  0                  0              0
 Overflow: More than 14 digits (7 digits for column "Err").
       --: Not supported.
Abbreviated interface name.
Total (pkts)
Total number of packets received or sent through the interface.
Broadcast (pkts)
Total number of broadcast packets received or sent through the interface.
Multicast (pkts)
Total number of multicast packets received or sent through the interface.
Err (pkts)
Total number of error packets received or sent through the interface.
The command displays Overflow if any of the following cases applies:
·     The data length of an Err field value is greater than 7 decimal digits.
·     The data length of a non-Err field value is greater than 14 decimal digits.
--: Not supported
The statistical item is not supported.
·     flow-interval
·     reset counters interface
display counters rate
Use display counters rate to display traffic rate statistics of interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
The statistics cover only interfaces in up state.
If you specify an interface type, this command displays traffic rate statistics for all up interfaces of the specified type.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
You can use the flow-interval command to set the statistics polling interval.
# Display the inbound traffic rate statistics for all Ten-GigabitEthernet interfaces.
<Sysname> display counters rate inbound interface ten-gigabitethernet
Interface                   Total (pps)       Broadcast (pps)       Multicast (pps)
XGE1/0/1                           200                   --                    --
XGE1/0/2                           300                   --                    --
XGE1/0/3                           300                   --                    --
 Overflow: More than 14 digits.
       --: Not supported.
Total (pkts/sec)
Average rate (in pps) of receiving or sending packets during the statistics polling interval.
Broadcast (pkts/sec)
Average rate (in pps) of receiving or sending broadcast packets during the statistics polling interval.
Multicast (pkts/sec)
Average rate (in pps) of receiving or sending multicast packets during the statistics polling interval.
Overflow: more than 14 decimal digits
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits.
--: not supported
·     flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
display ethernet statistics slot slot-number
slot slot-number: Displays the Ethernet module statistics on the specified device. The slot-number argument specifies the IRF member device by its member ID.
# Display the Ethernet module statistics on IRF member 1.
<Sysname>display ethernet statistics slot 1
ETH receive packet statistics:
    Totalnum        : 28259          ETHIINum     : 22328
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 5931           UnknownNum   : 0
    ForwardNum      : 22922          ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 0              ErrSrcMAC    : 0
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 412            VLANOutNum   : 0
    FastOutNum      : 181            L2OutNum     : 6351
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQosTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
Statistics about the Ethernet packets received on the Ethernet module.
Totalnum
Total number of received packets:
·     ETHIINum—Number of packets encapsulated by using Ethernet-II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISIS—Number of packets encapsulated by using IS-IS.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets.
·     MPLS—Number of MPLS packets.
·     ISIS—Number of IS-IS packets.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.
·     MbufRelayNum—Number of packets transparently sent.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module:
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQosTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
reset ethernet statistics
display interface
Use display interface to display Ethernet interface information.
display interface [ interface-type ] [ brief [ down | description ] ]
display interface [ interface-type [ interface-number ] ] [ brief [ description ] ]
down: Displays information about interfaces in the down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of that type.
If you specify both the interface type and interface number, this command displays information about the specified interface.
# Display detailed information about Layer 2 interface Ten-GigabitEthernet 1/0/1.
<Sysname> display interface ten-gigabitethernet 1/0/1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 00e0-fc00-5932
Description: Ten-GigabitEthernet1/0/1 Interface
Bandwidth: 10000000kbps
Loopback is not set
Media type is stack wire, port hardware type is STACK_SFP_PLUS
10Gbps-speed mode, full-duplex mode
Flow-control is not enabled
Maximum frame length: 10000
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 Untagged VLANs: 1
Port priority: 0
Last link flapping: Never
 Peak input rate: 0 bytes/sec, at 2011-01-01 04:43:29
 Peak output rate: 0 bytes/sec, at 2011-01-01 04:43:29
 Last 300 second input:  0 packets/sec 0 bytes/sec 0%
 Last 300 second output:  0 packets/sec 0 bytes/sec 0%
 Input (total):  1 packets, 336 bytes
          0 unicasts, 0 broadcasts, 1 multicasts, 0 pauses
 Input (normal):  1 packets, - bytes
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (total): 2 packets, 664 bytes
          0 unicasts, 0 broadcasts, 2 multicasts, 0 pauses
 Output (normal): 2 packets, - bytes
          0 lost carrier, - no carrier
Current state
Physical link state of the Ethernet interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The Ethernet interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through parameter negotiation on the link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
·     DOWN (DLDP DOWN)—The data link layer protocol of the interface is down because DLDP detected that the link was unidirectional.
·     DOWN (LAGG DOWN)—The data link layer protocol of the interface is down because the aggregate interface does not have Selected ports.
·     DOWN (OAM DOWN)—The data link layer protocol of the interface is down because OAM detected remote link failures.
·     DOWN (DLDP and LAGG DOWN)—The data link layer protocol of the interface is shut down by DLDP and LAGG.
·     DOWN (DLDP and OAM DOWN)—The data link layer protocol of the interface is shut down by DLDP and OAM.
·     DOWN (OAM and LAGG DOWN)—The data link layer protocol of the interface is shut down by OAM and LAGG.
·     DOWN (DLDP, OAM and LAGG DOWN)—The data link layer protocol of the interface is shut down by DLDP, OAM, and LAGG.
Ethernet framing format. PKTFMT_ETHNT_2 indicates that the frames are encapsulated in Ethernet II framing format.
hardware address
MAC address of the interface.
Bandwidth
Expected bandwidth of the interface.
Loopback is set internal
An internal loopback test is running on the Ethernet interface.
Loopback is set external
An external loopback test is running on the Ethernet interface.
Loopback is not set
No loopback test is running on the Ethernet interface.
10Mbps-speed mode
The interface is operating at 10 Mbps.
100Mbps-speed mode
The interface is operating at 100 Mbps.
1000Mbps-speed mode
The interface is operating at 1000 Mbps.
10Gbps-speed mode
The interface is operating at 10 Gbps.
40Gbps-speed mode
The interface is operating at 40 Gbps.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
half-duplex mode
The interface is operating in half duplex mode.
full-duplex mode
The interface is operating in full duplex mode.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is configured with a speed by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is configured with a duplex mode by using the duplex command.
Maximum Ethernet frame length allowed on the interface.
The interface allows jumbo frames to pass through.
Broadcast max-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast max-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the Ethernet interface.
MDI type
Cable type (depending on your configuration):
·     automdix.
·     mdi.
·     mdix.
Port link-type
Link type of the interface (depending on your configuration):
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
Port priority
Priority of the interface.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when the reset counters interface command was last used to clear statistics on the interface. Never indicates that the reset counters interface command was never used since the device was started.
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
Average rate of inbound traffic in the last 300 seconds, in pps and Bps, and the ratio of the actual rate to the maximum interface rate.
A hyphen (-) indicates that the statistical item is not supported.
Average rate of outbound traffic in the last 300 seconds, in pps and Bps, and the ratio of the actual rate to the maximum interface rate.
Input(total)
Inbound traffic statistics (in packets and bytes) for the interface. All inbound normal and abnormal packets and normal pause frames were counted.
Number of inbound unicast packets, number of inbound broadcasts, number of inbound multicasts, and number of inbound pause frames.
Input(normal)
Inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
Number of inbound normal unicast packets, number of inbound normal broadcasts, number of inbound normal multicasts, and number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames shorter than 64 bytes, in correct format, and containing valid CRCs.
giants
Number of inbound frames larger than the maximum frame length supported on the interface.
·     For an Ethernet interface that does not permit jumbo frames, giants refer to frames larger than 1536 bytes (without VLAN tags) or 1540 bytes (with VLAN tags).
·     For an Ethernet interface that permits jumbo frames, giants refer to frames larger than the maximum length of Ethernet frames that are allowed to pass through, which is configured when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, jabber frames refer to CRC error frames greater than 1536 bytes (without VLAN tags) or 1540 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, jabber frames refer to CRC error frames greater than the maximum length of Ethernet frames that are allowed to pass through the interface.
·     Symbol error frames—Frames that contained at least one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receive buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total)
Outbound traffic statistics (in packets and bytes) for the interface. All outbound normal and abnormal packets and normal pause frames were counted.
Number of outbound unicast packets, number of outbound broadcasts, number of outbound multicasts, and number of outbound pause frames.
Output(normal)
Outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
Number of outbound normal unicast packets, number of outbound normal broadcasts, number of outbound normal multicasts, and number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmit buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
# Display brief information about all interfaces.
Protocol: (s) – spoofing
InLoop0              UP   UP(s)    --
Loop0                UP   UP(s)    --
M-GE0/0/0            UP   UP       192.168.0.65
NULL0                UP   UP(s)    --
REG0                 DOWN --       --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
The brief information of interfaces in bridge mode:
Speed: (a) - auto
Interface              Link Speed   Duplex Type PVID Description
XGE1/0/2               DOWN auto    A      A    1
XGE1/0/3               UP   10G(a)  F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
XGE1/0/4               DOWN auto    A      A    1
XGE1/0/5               DOWN auto    A      A    1
XGE1/0/6               UP   10G(a)  F(a)   A    1
XGE1/0/7               DOWN auto    A      A    1
XGE1/0/8               UP   10G(a)  F(a)   A    1
XGE1/0/9               UP   10G(a)  F(a)   A    999
# Display brief information about Ten-GigabitEthernet 1/0/3, including the complete interface description.
<Sysname> display interface ten-gigabitethernet 1/0/3 brief description
Speed: (a) - auto
XGE1/0/3               UP   10G(a)  F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
XGE1/0/2               DOWN Not connected
XGE1/0/4               DOWN Not connected
XGE1/0/5               DOWN Not connected
XGE1/0/7               DOWN Not connected
Table 5 Command output
Brief information of interfaces in route mode:
Brief information about Layer 3 interfaces.
·     ADM—The interface has been shut down by the network administrator. To recover its physical layer state, run the undo shutdown command.
·     Stby—The interface is a standby interface.
If the data link layer protocol of an interface is up, but its link is an on-demand link or not present at all, this field displays UP (s), where s represents the spoofing flag. This attribute is typical of interface Null 0 and loopback interfaces.
Interface name.
Link
Physical link state of the interface:
·     UP—The link is up.
·     DOWN—The link is physically down.
·     ADM—The link has been administratively shut down. To recover its physical state, run the undo shutdown command.
Protocol
Link layer protocol state of the interface:
·     UP.
·     DOWN.
·     UP(s)—The link of the interface is an on-demand link or not present at all.
Primary IP
Primary IP address of the interface. A hyphen (-) indicates that the interface is not configured with an IP address.
Partial or complete interface description configured by using the description command:
·     If you do not specify the description keyword for the display interface brief command, the Description field displays only the first 27 characters of the interface description.
·     If you specify the description keyword for the display interface brief command, the field displays the complete interface description.
Brief information about Layer 2 interfaces.
Speed: (a) - auto
If the speed of an interface is automatically negotiated, its speed attribute includes the autonegotiation flag, indicated by the letter a in parentheses.
If the duplex mode of an interface is automatically negotiated, its duplex mode attribute includes the following options:
·     (a)/A—Autonegotiation.
·     H—Half negotiation.
·     F—Full negotiation.
Type: A - access; T - trunk; H – hybrid
Link type options for Ethernet interfaces.
Speed
Interface rate, in bps.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The port is manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—When an aggregate interface is shut down, the physical state of all member ports of the aggregate interface becomes DOWN.
·     DOWN (Loopback detection down)—The port is shut down because the loopback detection module has detected loops.
·     DOWN ( Monitor-Link uplink down )—The port is shut down because the monitor link module has detected that the uplink is down.
·     MAD ShutDown—After an IRF split, the state of all interfaces except the excluded ports in the IRF in recovery state is set to DOWN.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Storm-Constrain—The port is shut down because the unknown unicast traffic, multicast traffic, or broadcast traffic exceeds the upper limit.
·     STP DOWN—The port is shut down by the STP BPDU guard function.
·     Port Security Disabled—The port is shut down by the intrusion detection mechanism because the port receives illegal packets.
·     Standby—The interface is in the Standby state.
display packet-drop
Use display packet-drop to display information about packets dropped on an interface or multiple interfaces.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
interface-type: Specifies an interface type. If you do not specify an interface type, this command displays information about dropped packets on all the interfaces on the device.
interface-number: Specifies an interface number. If you specify an interface type only, this command displays information about dropped packets on the specified type of interfaces.
summary: Displays the summary of dropped packets on all interfaces.
# Display information about dropped packets on Ten-GigabitEthernet 1/0/1.
<Sysname> display packet-drop interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1:
Packets dropped due to full GBP or insufficient bandwidth: 301
Packets dropped due to Fast Filter Processor (FFP): 261
Packets dropped due to STP non-forwarding state: 321
Packets dropped due to insufficient data buffer. Input dropped: 0 Output dropped: 0
# Display the summary of dropped packets on all interfaces.
<Sysname> display packet-drop summary
All interfaces:
Table 6 Command output
Packets that are dropped because the buffer is used up or the bandwidth is insufficient.
Packets that are filtered out.
Packets that are dropped because STP is in the non-forwarding state.
Packets that are dropped because of insufficient data buffer.
Statistics about the outgoing packets dropped due to FFP or STP are not collected.
display priority-flow-control
Use display priority-flow-control to display the PFC information and frame statistics for an interface.
display priority-flow-control interface [ interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, the command displays the PFC information and frame statistics for all Ethernet interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, the command displays the PFC information and frame statistics for all Ethernet interfaces of the specified type.
# Display the PFC information and frame statistics for all Ethernet interfaces.
<Sysname> display priority-flow-control interface
Interface           AdminMode  OperMode  Dot1pList   Prio  Recv       Send
XGE1/0/1            Disabled   Disabled  0,2-3,5-6
XGE1/0/2            Auto       Enabled   0-1,3-4,6-7 0     4294967295 4294967295
                                                     5     23         0
                                                     7     5          0
XGE1/0/3            Enabled    Enabled   0-2,4-5,7   0     178        43
                                                     1     234        112
                                                     4     13         0
                                                     5     1572       0
                                                     7     110        0
XGE1/0/4            Auto       Disabled  1-2,4-5,7
Table 7 Command output
Abbreviated name of the interface.
AdminMode
Administrative PFC status:
·     Disabled—PFC is disabled for the interface.
·     Auto—The interface is configured to autonegotiate the PFC status with the remote end.
·     Enabled—PFC is enabled for the interface.
OperMode
Operative PFC status:
·     Disabled—PFC is disabled.
·     Enabled—PFC is enabled.
Dot1pList
802.1p priorities that are enabled with PFC. 802.1p priority values 0 through 7 are available.
Prio
An 802.1p priority is displayed only when the 802.1p priority is enabled with PFC and the interface has received or sent packets with the 802.1p priority.
Recv
Number of received frames.
Send
Number of sent frames.
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default duplex mode of the Ethernet interface.
duplex { auto | full | half }
undo duplex
Ethernet interfaces autonegotiate the duplex mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode, so that the interface can receive and transmit packets at the same time.
half: Configures the interface to operate in half duplex mode, so that the interface can only receive or transmit packets at a given time. Copper ports operating at 1000 Mbps or 10 Gbps and fiber ports do not support this keyword.
# Configure Ten-GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-Ten-GigabitEthernet1/0/1] duplex full
eee enable
IMPORTANT
IMPORTANT:
Fiber ports do not support this command.
Use eee enable to enable EEE.
Use undo eee enable to restore the default.
eee enable
undo eee enable
EEE is disabled.
With the EEE function, a link-up port enters the low power state if it has not received any packet for a certain period of time. The time period depends on the chip specifications and is not configurable. When a packet arrives later, the port enters the normal state.
# Enable EEE on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] eee enable
flow-control
CAUTION
CAUTION:
Configuring generic flow control on an Ethernet interface will cause link-up and link-down events before the interface finally stays up.
Use flow-control to enable TxRx mode generic flow control on an Ethernet interface.
Use undo flow-control to disable generic flow control on the Ethernet interface.
flow-control
undo flow-control
Generic flow control is disabled on an Ethernet interface.
To implement flow control on a link, enable the generic flow control function at both ends of the link.
TxRx mode generic flow control enables an Ethernet interface to perform the following actions:
·     Receive common pause frames from its peer.
·     Send common pause frames to notify its peer of congestions.
With the flow-control command configured, an interface can both send and receive flow control frames:
·     When congested, the interface sends a flow control frame to its peer.
·     Upon receiving a flow control frame from the peer, the interface suspends sending packets.
# Enable TxRx mode generic flow control on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] flow-control
flow-control receive enable
CAUTION
CAUTION:
Use flow-control receive enable to enable Rx mode generic flow control on an Ethernet port.
Use undo flow-control to disable generic flow control on an Ethernet interface.
undo flow-control
Rx flow control is disabled on Ethernet interfaces.
With the flow-control receive enable command configured, an interface can receive, but not send, flow control frames. When the interface receives a flow control frame from its peer, it suspends sending packets to the peer. When traffic congestion occurs on the interface, it cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
# Enable Rx mode generic flow control on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the interface statistics polling interval.
Use undo flow-interval to restore the default interval.
flow-interval interval
undo flow-interval
The interface statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval, in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] flow-interval 100
interface
Use interface to enter interface view.
# Enter Ten-GigabitEthernet 1/0/1 interface view.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
jumboframe enable [ value ]
The device allows jumbo frames within 10000 bytes to pass through.
value: Sets the maximum length of Ethernet frames that are allowed to pass through. The value range is 1536 to 10000 bytes.
If you set the value argument multiple times, the most recent configuration takes effect.
# Enable jumbo frames to pass through Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
link-delay [ msec ] delay-time [ mode { up | updown } ]
undo link-delay
Each time the physical link of a port goes up or comes down, the interface immediately reports the change to the CPU.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 indicates that physical state changes are immediately reported to the CPU and are not suppressed.
·     If you do not specify the msec keyword, the value range for this argument is 0 to 30 seconds.
·     If you specify the msec keyword, the value range for this argument is 0 to 10000 milliseconds, and the value must be a multiple of 100.
mode up: Suppresses the link-up events.
mode updown: Suppresses both the link-up and link-down events.
When the link-delay delay-time command is configured:
·     The link-down event is not reported to the CPU unless the interface is still down when the suppression interval (delay-time) expires.
·     The link-up event is immediately reported.
When the link-delay delay-time mode up command is configured:
·     The link-up event is not reported to the CPU unless the interface is still up when the suppression interval (delay-time) expires.
·     The link-down event is immediately reported.
When the link-delay delay-time mode updown command is configured:
On a port, if you configure the link-delay command multiple times, the most recent configuration takes effect.
Do not configure this command on a port with RRPP, spanning tree protocols, or Smart Link enabled.
# Set the link-down event suppression interval to 8 seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] link-delay 8
# Set the link-up event suppression interval to 800 milliseconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] link-delay msec 800 mode up
loopback
Use loopback to perform a loopback test on an Ethernet interface.
external: Performs an external loopback test on the Ethernet interface.
internal: Performs an internal loopback test on the Ethernet interface.
If an Ethernet interface does not work correctly, you can perform a loopback test on it to identify the problem.
An Ethernet interface in a loopback test does not forward data traffic.
On an administratively shut down Ethernet interface (displayed as in ADM or Administratively DOWN state), you cannot perform an internal or external loopback test.
The speed, duplex, mdix-mode, and shutdown commands are not available during a loopback test.
During a loopback test, the Ethernet interface operates in full duplex mode. When the loopback test is complete, the port returns to its duplex setting.
# Perform an internal loopback test on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] loopback internal
Loop internal succeeded!
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to restore the default.
multicast-suppression { ratio | pps max-pps | kbps max-kbps } [ unknown ]
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth. For example, the value range of the max-pps argument for a 40-GE interface is 0 to 59524000.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
unknown: Suppresses only the unknown multicast traffic.
The multicast storm suppression feature limits the size of multicast traffic (including known and unknown multicast) to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both storm-constrain and multicast-suppression can suppress multicast storm on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress multicast traffic.
For the traffic suppression result to be determined, do not configure both the storm constrain multicast command and the multicast-suppression command on an interface.
# Set the multicast storm suppression threshold to 10000 kbps on Ten-GigabitEthernet1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] multicast-suppression kbps 10000
·     broadcast-suppression
port auto-power-down
IMPORTANT
IMPORTANT:
Use port auto-power-down to enable auto power-down on an Ethernet interface.
Use undo port auto-power-down to restore the default.
Auto power-down is disabled on Ethernet interfaces.
When the auto power-down function is enabled on an interface and the interface has been down for a certain period of time, both of the following events occur:
·     The switch automatically stops supplying power to the interface.
·     The interface enters the power save mode.
When the interface comes up, both of the following events occur:
·     The switch automatically restores the power supply to the interface.
·     The interface enters its normal state.
# Enable auto power-down on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port auto-power-down
port up-mode
Use port up-mode to forcibly bring up a fiber port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
Fiber ports are not forcibly brought up. The physical state of the fiber port is determined by the physical state of the optical fibers.
CAUTION
CAUTION:
The following operations on a fiber port will cause link updown events before the port finally stays up:
·     Configure the port up-mode command and the speed or duplex command at the same time.
·     Install or remove fiber links or transceiver modules after you forcibly bring up the fiber port.
You can use this command to forcibly bring up a fiber Ethernet port, and enable the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
After you forcibly bring up an Ethernet fiber port, the fiber port stays physically up whether or not a transceiver module or fiber connections are present for the port.
Copper ports do not support this command.
The port up-mode command is mutually exclusive with either of the shutdown and loopback commands.
# Forcibly bring up fiber port Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] port up-mode
Use priority-flow-control to enable PFC on an Ethernet interface through automatic negotiation or forcibly.
Use undo priority-flow-control to disable PFC on the interface.
priority-flow-control { auto | enable }
PFC is disabled on Ethernet interfaces.
auto: Specifies PFC in auto mode. In this mode, the Ethernet interface automatically negotiates the PFC status with its peer.
enable: Forcibly enables PFC.
If you enable PFC and configure the priority-flow-control no-drop dot1p dot1p-list command on both ends, the local port processes a received packet as follows when network congestion occurs:
·     If PFC is enabled for the 802.1p priority carried in the packet, the local port perform the following tasks:
¡     Accepts the packet.
¡     Notifies the peer to stop sending packets carrying the 802.1p priority until the congestion is removed.
·     If PFC is disabled for the 802.1p priority carried in the packet, the local port drops the packet.
# Configure Ten-GigabitEthernet 1/0/1 to automatically negotiate with its peer to enable PFC.
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control auto
Use priority-flow-control no-drop dot1p to enable PFC for 802.1p priorities on an Ethernet interface.
Use undo priority-flow-control no-drop dot1p to restore the default.
PFC is disabled for all 802.1p priorities.
dot1p-list: Specifies an 802.1p priority (or dot1p priority) list to identify flows that are subject to PFC(for example: 1,3-5). A hyphen (-) connects two numeric values, which together indicate a continuous value range. Different values or value ranges are separated with commas (,). You can configure up to 16 characters for this argument.
You can enable PFC for certain 802.1p priorities at the two ends of a link. When network congestion occurs, the local device checks the PFC status for the 802.1p priority carried in each arriving packet. The device processes the packet depending on the PFC status as follows:
·     If PFC is enabled for the 802.1p priority, the local device accepts the packet and sends a PFC pause frame to the peer. The peer stops sending packets carrying this 802.1p priority for an interval as specified in the PFC pause frame. This process is repeated until the congestion is removed.
·     If PFC is disabled for the 802.1p priority, the local port drops the packet.
The relationship between the PFC function and the generic flow control function is shown in Table 8.
Table 8 The relationship between the PFC function and the generic flow control function
flow-control
priority-flow-control enable
Remarks
Unconfigurable
Configured
Configured
You cannot enable flow control by using the flow-control command on a port where PFC is enabled and PFC is enabled for the specified 802.1p priority values.
Configured
Configurable
Unconfigurable
·     On a port configured with the flow-control command, you can enable PFC, but you cannot enable PFC for specific 802.1p priorities.
·     Enabling both generic flow control and PFC on a port disables the port from sending common or PFC pause frames to inform the peer of congestion conditions. However, the port can still handle common and PFC pause frames from the peer.
When you configure PFC, follow these guidelines:
·     As a best practice to ensure correct operations of IRF and other protocols, do not enable PFC for 802.1p priorities 0, 6, and 7.
·     Perform the same PFC configuration on all ports that traffic travels through.
For more information about the 802.1p priority, priority trust mode, and port priority, see ACL and QoS Configuration Guide.
# Configure Ten-GigabitEthernet 1/0/1 to automatically negotiate with the peer port to enable PFC, and enable PFC for 802.1p priority 5.
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control no-drop dot1p 5
·     priority-flow-control
·     flow-control
·     flow-control receive enable
Use reset counters interface to clear the Ethernet interface statistics.
reset counters interface [ interface-type [ interface-number ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify only the interface type, this command clears statistics for all interfaces of that type.
If you specify both the interface type and the interface number, this command clears statistics for the specified interface.
# Clear the statistics of Ten-GigabitEthernet 1/0/1.
<Sysname> reset counters interface ten-gigabitethernet 1/0/1
·     display interface
·     display counters interface
·     display counters rate interface
Use reset ethernet statistics to clear the Ethernet module statistics.
reset ethernet statistics slot slot-number
slot slot-number: Clears the Ethernet module statistics on the specified device. The slot-number argument specifies the IRF member device by its member ID.
# Clear the Ethernet module statistics on IRF member 6.
<Sysname> reset ethernet statistics slot 6
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics on an interface or multiple interfaces.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, this command clears dropped packet statistics on all the interfaces on the device.
interface-number: Specifies an interface number. If you do not specify this argument, the command clears dropped packet statistics on all interfaces of the specified type.
# Clear dropped packet statistics on Ten-GigabitEthernet 1/0/1.
<Sysname> reset packet-drop interface ten-gigabitethernet 1/0/1
# Clear dropped packet statistics on all interfaces.
display packet-drop
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
Ethernet interfaces are in up state.
You might need to shut down and then bring up an Ethernet interface to make some interface configurations take effect.
# Shut down and then bring up Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] shutdown
[Sysname-Ten-GigabitEthernet1/0/1] undo shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 1000 | 10000 | 40000 | auto }
undo speed
An Ethernet interface negotiates a speed with its peer.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
40000: Sets the interface speed to 40000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module.
Support of an interface for the keywords depends on the interface type. For more information, use the speed ? command in interface view.
In auto mode, Ethernet interfaces do not support negotiating a speed of 10 Mbps or 100 Mbps.
# Configure Ten-GigabitEthernet 1/0/1 to autonegotiate the speed.
[Sysname-Ten-GigabitEthernet1/0/1] speed auto
speed auto
unicast-suppression
Use unicast-suppression to enable unknown unicast storm suppression and set the unknown unicast storm suppression threshold.
Use undo unicast-suppression to restore the default.
Ethernet interfaces do not suppress unknown unicast traffic.
ratio: Sets the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth. For example, the value range of the max-pps argument for a 40-GE interface is 0 to 59524000.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The unknown unicast storm suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both storm-constrain and unicast-suppression can suppress unknown unicast storm on a port. The unicast-suppression command uses the chip to physically suppress unknown unicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress unknown unicast traffic.
For the traffic suppression result to be determined, do not configure both the storm constrain unicast command and the unicast-suppression command on an interface.
# Set the unknown unicast storm suppression threshold to 10000 kbps on Ten-GigabitEthernet1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] unicast-suppression kbps 10000
using fortygige
Use using fortygige to combine four 10-GE breakout interfaces that are split from a 40-GE interface into a 40-GE interface.
Use undo using fortygige to cancel the configuration.
using fortygige
A 40-GE interface is not split and operates as a single interface.
10-GE breakout interface view
If you need higher bandwidth, you can combine four 10-GE breakout interfaces that are split from a 40-GE interface into a 40-GE interface. To make this command take effect on the four 10-GE breakout interfaces, execute this command on only one of the 10-GE breakout interfaces.
After this command is successfully configured, the system prompts you to reboot your device. You must reboot the device and then the system deletes the four 10-GE breakout interface and creates the combined 40-GE interface.
# Combine 10-GE breakout interfaces Ten-GigabitEthernet 1/0/16:1 through Ten-GigabitEthernet 1/0/16:4 into a 40-GE interface.
<System> system-view
[System] interface Ten-GigabitEthernet1/0/16:1
[System-Ten-GigabitEthernet1/0/16:1] using fortygige
The interfaces Ten-GigabitEthernet1/0/16:1 through Ten-GigabitEthernet1/0/16:4 will be deleted. Continue? [Y/N]:y
Reboot the member device to make the configuration take effect.
using tengige
using tengige
Use using tengige to split a high-bandwidth interface into multiple 10-GE breakout interfaces.
Use undo using tengige to cancel the configuration.
using tengige
undo using tengige
A high-bandwidth interface is not split and operates as a single interface.
40-GE interface view
To improve the port density, reduce the cost, and improve the network flexibility, you can split a high-bandwidth interface into multiple 10-GE breakout interfaces.
The 10-GE breakout interfaces support the same configuration and attributes as common 10-GE interfaces, except that they are numbered in a different way.
After this command is successfully configured, the system prompts you to reboot your device. You must reboot the device and then the system deletes the 40-GE interface and creates four 10-GE breakout interfaces.
# Split 40-GE interface FortyGigE 1/0/16 into four 10-GE breakout interfaces.
[System] interface fortygige 1/0/16
[System-FortyGigE1/0/16] using tengige
The interface FortyGigE1/0/16 will be deleted. Continue? [Y/N]:y
using fortygige
Layer 2 Ethernet interface commands
display storm-constrain
Use display storm-constrain to display storm control settings and statistics.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast: Displays broadcast storm control settings and statistics.
multicast: Displays multicast storm control settings and statistics.
unicast: Displays unknown unicast storm control settings and statistics.
If you do not specify any keywords, this command displays all storm control settings on all storm control-enabled interfaces.
# Display the storm control settings on all storm control-enabled ports.
<Sysname> display storm-constrain
Abbreviation: BC - broadcast; MC - multicast; UC – unicast
               FW - forwarding
Flow Statistic Interval: 5 (in seconds)
Port       Type  Lower   Upper     Unit   CtrlMode  Status     Trap  Log  SwitchNum
XGE1/0/1    BC   12345   3456      pps    block     FW          on   off   0
XGE1/0/2    MC   43      100       ratio  block     block       on   off   1
XGE1/0/3    MC   100     200       kbps   shutdown  shutdown    off  on    10
XGE1/0/4    UC   200     300       kbps   shutdown  normal      off  on    33
XGE1/0/5    BC   500     1500      pps    N/A       normal      on   on    0
Table 9 Command output
Traffic polling interval (in seconds) of the storm control module.
Port
Abbreviated port name.
Type of traffic subjected to storm control:
·     BC—Broadcast packets.
·     MC—Multicast packets.
·     UC—Unknown unicast packets.
Lower
Lower storm control threshold, in pps, kbps, or percentage.
Upper
Upper storm control threshold, in pps, kbps, or percentage.
Unit
Storm control threshold unit:
·     pps.
·     kbps.
·     percentage.
CtrlMode
Protective action (block or shutdown) taken on the port when the upper threshold is reached. N/A indicates that no protective action is configured.
Status
Packet forwarding status:
·     FW—The port is forwarding traffic correctly.
·     shutdown—The port has been shut down.
·     block—The port drops the type of traffic.
Trap
Status of the storm control threshold event trap switch:
·     on—The port sends threshold event traps.
·     off—The port does not send threshold event traps.
Log
Status of the storm control threshold event log switch:
·     on—The port sends threshold event log messages.
·     off—The port does not send threshold event log messages.
SwitchNum
Number of forwarding state changes of the interface.
When the SwitchNum count reaches 65535, it resets automatically.
mdix-mode
IMPORTANT
IMPORTANT:
·     Fiber ports do not support this command.
·     10-GE copper ports support only the automdix mode.
Use mdix-mode to configure the Medium Dependent Interface Cross-Over (MDIX) mode of an Ethernet interface.
Use undo mdix-mode to restore the default.
mdix-mode { automdix | mdi | mdix }
undo mdix-mode
Ethernet interfaces operate in automdix mode.
automdix: Specifies that the interface negotiates pin roles with its peer.
mdi: Specifies that pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
mdix: Specifies that pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
# Configure Ten-GigabitEthernet 1/0/1 to operate in automdix mode.
[Sysname-Ten-GigabitEthernet1/0/1] mdix-mode automdix
port bridge enable
Use port bridge enable to enable bridging on a Layer 2 Ethernet interface.
Use undo port bridge enable to disable bridging on a Layer 2 Ethernet interface.
port bridge enable
Bridging is disabled on Layer 2 Ethernet interfaces.
When a packet arrives at an interface, the device looks up the destination MAC address of the packet in the MAC address table. If an entry is found and the outgoing interface is the same as the incoming interface, the device drops the packet.
After you configure this command on the Ethernet interface, the device forwards such packets rather than drop them.
# Enable bridging on Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1.
[Sysname] interface ten-gigabitethernet1/0/1
[Sysname-Ten-GigabitEthernet1/0/1] port bridge enable
port connection-distance
Use port connection-distance to set the interface connection distance.
Use undo port connection-distance to restore the default.
port connection-distance { 300 | 10000 | 20000 | 40000 }
The interface connection distance is 10000 meters.
300: Sets the interface connection distance to 300 meters.
10000: Sets the interface connection distance to 10000 meters.
20000: Sets the interface connection distance to 20000 meters.
40000: Sets the interface connection distance to 40000 meters.
When two directly connected interfaces communicate, they use the buffer area to buffer the received data. A longer interface connection distance requires a greater buffer area.
Perform this task to modify the buffer area size by setting the interface connection distance.
Configure this command based on the network conditions because the buffer area size is limited.
# Set the interface connection distance to 20000 meters.
[Sysname-Ten-GigabitEthernet1/0/1] port connection-distance 20000
storm-constrain
Use storm-constrain to enable broadcast, multicast, or unknown unicast storm control on an Ethernet port.
Use undo storm-constrain to disable storm control.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast | unicast }
Traffic storm control is disabled.
all: Disables storm control for all types of packets: broadcast, multicast, and unknown unicast.
broadcast: Enables or disables broadcast storm control.
multicast: Enables or disables multicast storm control.
unicast: Enables or disables unknown unicast storm control.
pps: Sets storm control thresholds in pps.
kbps: Sets storm control thresholds in kbps.
ratio: Sets storm control thresholds as a percentage of the transmission capacity of the interface.
upperlimit: Sets the upper threshold, in pps, kbps, or percentage.
lowerlimit: Sets the lower threshold, in pps, kbps, or percentage.
After you configure this command, the device collects the statistics of a particular type of traffic at the specified interval, which can be configured by using the storm-constrain interval command. When a particular type of traffic exceeds its upper threshold, the interface takes a certain action, which can be configured by using the storm-constrain control command.
The storm-constrain, broadcast-suppression, multicast-suppression, and unicast-suppression commands can suppress storm on a port.
·     The storm-constrain command uses software to suppress traffic, and affects the device performance to a certain extent.
·     The broadcast-suppression, multicast-suppression, and unicast-suppression commands use the chip to physically suppress traffic, and have less influence on the device performance than the storm-constrain command.
On the same type of traffic, do not configure the storm constrain command and either of the broadcast-suppression, multicast-suppression, and unicast-suppression commands at the same time. Otherwise, the traffic suppression result is not determined.
When configuring this command, make sure upperlimit is greater than lowerlimit.
# Enable unknown unicast storm control on Ten-GigabitEthernet 1/0/1, setting the upper and lower thresholds to 200 pps and 150 pps.
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain unicast pps 200 150
# Enable broadcast storm control on Ten-GigabitEthernet 1/0/2, setting the upper and lower thresholds to 2000 kbps and 1500 kbps.
[Sysname-Ten-GigabitEthernet1/0/2] storm-constrain broadcast kbps 2000 1500
# Enable multicast storm control on Ten-GigabitEthernet 1/0/3, setting the upper and lower thresholds to 80% and 15%.
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] storm-constrain multicast ratio 80 15
·     storm-constrain control
·     storm-constrain interval
Use storm-constrain control to set the protective action to take on an Ethernet interface when a type of traffic (unknown unicast, multicast, or broadcast) exceeds the upper storm control threshold.
Use undo storm-constrain control to restore the default.
No action is taken on an Ethernet interface when a type of traffic exceeds the upper storm control threshold.
block: Blocks this type of traffic, while forwarding other types of traffic. Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic is detected dropping below the lower threshold, the port begins to forward the traffic.
shutdown: Shuts down automatically. The interface shuts down automatically and stops forwarding any traffic. When the blocked traffic is detected dropping below the lower threshold, the port does not forward the traffic. To bring up the interface, use the undo shutdown command or disable the storm control function.
# Configure Ten-GigabitEthernet 1/0/1 to block the traffic detected crossing the upper storm control threshold.
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain control block
·     storm-constrain
storm-constrain enable log
Use storm-constrain enable log to enable an Ethernet interface to log storm control threshold events.
Use undo storm-constrain enable log to disable log sending.
An interface generates logs when monitored traffic exceeds the upper threshold or falls below the lower threshold.
# Enable Ten-GigabitEthernet 1/0/1 to generate logs when it detects storm control threshold events.
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain enable log
storm-constrain enable trap
Use storm-constrain enable trap to enable an Ethernet interface to send storm control threshold event traps.
Use undo storm-constrain enable trap to disable trap sending.
An interface sends out traps when monitored traffic exceeds the upper threshold or falls below the lower threshold.
# Enable Ten-GigabitEthernet 1/0/1 to send traps when it detects storm control threshold events.
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain enable trap
Use storm-constrain interval to set the traffic polling interval of the storm control module.
Use undo storm-constrain interval to restore the default.
storm-constrain interval seconds
The storm control module polls traffic statistics every 10 seconds.
seconds: Sets the traffic polling interval of the storm control module. The value range is 1 to 300 seconds.
The interval set by the storm-constrain interval command is specific to storm control. To set the statistics polling interval of an interface, use the flow-interval command.
For network stability, use the default or a higher polling interval.
# Set the traffic statistics polling interval of the storm control module to 60 seconds.
[Sysname] storm-constrain interval 60
·     storm-constrain
virtual-cable-test
IMPORTANT
IMPORTANT:
Use virtual-cable-test to test the cable connection of an Ethernet interface and display the test results.
virtual-cable-test
If the link of an Ethernet interface is up, testing its cable connection will cause the link to go down and then up.
The test result is for reference only. The cable length detection error is up to 5 m (about 16 ft).
If a test item is not available, a hyphen (-) is displayed.
# Test the cable connection of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] virtual-cable-test
Cable status: abnormal(open), 140 metre(s)
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: - db
Table 10 Command output
Cable status
Cable status:
·     Normal—The cable is in good condition.
·     Abnormal—The cable is abnormal.
·     Abnormal (open)—An open circuit is detected.
·     Abnormal (short)—A short circuit is detected.
·     Failure—The test failed.
n metres
If the cable connection is working correctly, this field displays the total length of the cable.
If the cable connection fails, this field displays the length from the local port to the faulty point.
