04-Layer 3—IP Services Configuration Guide
HomeSupportSwitchesH3C S6300 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10004-Layer 3—IP Services Configuration Guide
12-IPv6 fast forwarding configuration
12-IPv6 fast forwarding configuration 37.52 KB
Configuring IPv6 fast forwarding
Overview
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields:
·           Source IPv6 address.
·           Destination IPv6 address.
·           Source port number.
·           Destination port number.
·           Protocol number.
·           VPN instance name.
After the first packet of a flow is forwarded through the routing table, fast forwarding creates an entry for the flow and uses the entry to forward subsequent packets of the flow.
Configuration procedure
To configure IPv6 fast forwarding:
Step
Remarks
1.      Enter system view.
N/A
2.      Enable IPv6 fast-forwarding load sharing.
ipv6 fast-forwarding load-sharing
By default, IPv6 fast-forwarding load sharing is enabled.
3.      Set the aging time of IPv6 fast forwarding entries.
ipv6 fast-forwarding aging-time aging-time
By default, the aging time of IPv6 fast forwarding entries is 30 seconds.
Displaying and maintaining IPv6 fast forwarding
Display IPv6 fast forwarding table information.
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
Display the aging time of the IPv6 fast forwarding entry.
display ipv6 fast-forwarding aging-time
Clear IPv6 fast forwarding table information.
reset ipv6 fast-forwarding cache [ slot slot-number ]
