04-Layer 3—IP Services Configuration Guide
HomeSupportSwitchesH3C S6300 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10004-Layer 3—IP Services Configuration Guide
06-Fast forwarding configuration
06-Fast forwarding configuration 32.91 KB
Configuring fast forwarding
Overview
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields: source IP address, source port number, destination IP address, destination port number, and protocol number. After the first packet of a flow is forwarded through the routing table, fast forwarding creates an entry for the flow and uses the entry to forward subsequent packets of the flow.
Fast forwarding can process fragmented IP packets, but it does not fragment IP packets.
Configuration procedure
To configure fast forwarding:
Step
Remarks
1.      Enter system view.
N/A
2.      Enable fast-forwarding load sharing.
ip fast-forwarding load-sharing
By default, fast-forwarding load sharing is enabled.
3.      Configure the aging time of fast forwarding entries.
ip fast-forwarding aging-time aging-time
By default, the aging time is 30 seconds.
Displaying and maintaining fast forwarding
Display fast forwarding table information.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
Display fast forwarding table information about fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
Display the aging time of fast forwarding entries.
display ip fast-forwarding aging-time
Clear fast forwarding table information.
reset ip fast-forwarding cache [ slot slot-number ]
