HomeSupportSwitchesH3C S6300 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10001-Fundamentals Configuration Guide
14-Preprovisioning feature configuration
14-Preprovisioning feature configuration 29.71 KB
Configuring preprovisioning
Preprovisioning allows you to preconfigure an offline module (an IRF member device that has not joined or has left the IRF fabric) and interfaces on the module.
With preprovisioning, you can configure a module before installing or attaching the module to the device. When the module comes online, the preprovisioned settings are applied. If the module goes offline, the existing preprovisioned settings are retained. You can continue to change the existing settings or add new settings. The final settings are applied when the module comes online again.
Enabling preprovisioning
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command does not display these interfaces until the module comes online.
After preprovisioning is enabled for a module, you can configure the module and its interfaces. To verify the preprovisioned settings, see "Displaying and maintaining preprovisioned settings." For the preprovisioned settings to survive a reboot, you must use the save command to save the settings to the next-startup configuration file.
When you disable preprovisioning on a slot, the device removes all preprovisioned commands from the slot.
To enable preprovisioning on a slot:
Step
Remarks
1.      Enter system view.
N/A
2.      Select the slot to preprovision and enter slot view.
slot slot-number
N/A
3.      Enable preprovisioning on the slot for an IRF member device.
provision model model
By default, preprovisioning is disabled.
You must make sure the specified model matches the model of the IRF member device you want to preprovision. If the model information does not match, the IRF member device cannot come online.
Execute display commands in any view. Execute reset commands in user view.
Display preprovisioned-commands application failure records.
display provision failed-config
Clear preprovisioned-commands application failure records.
reset provision failed-config
