HomeSupportSwitchesH3C S6300 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10001-Fundamentals Configuration Guide
08-ISSU configuration
08-ISSU configuration 206.42 KB
Performing an ISSU·· 1
ISSU overview· 1
ISSU methods· 1
ISSU commands· 2
Preparing for ISSU· 2
Identifying availability of ISSU and licensing requirements· 2
Verifying the device operating status· 2
Preparing the upgrade images· 2
Identifying the ISSU method· 2
Verifying feature status· 3
Determining the upgrade procedure· 3
Understanding ISSU guidelines· 4
Logging in to the device through the console port 4
Saving the running configuration· 4
Performing an ISSU by using issu commands· 4
Upgrading a multichassis IRF fabric· 4
Upgrading a single-chassis IRF fabric· 6
Performing an ISSU by using install commands· 7
ISSU task list 7
Decompressing an .ipe file· 7
Installing or upgrading software images· 8
Uninstalling feature or patch images· 9
Rolling back the running software images· 9
Aborting a software activate/deactivate operation· 10
Committing software changes· 10
Verifying software images· 10
Removing inactive software images· 10
Displaying and maintaining ISSU· 11
Troubleshooting ISSU· 11
Failure to execute the issu load/issu run switchover/issu commit/install activate/install deactivate command  11
ISSU examples for using issu commands· 12
Software image upgrade to a compatible version· 12
Software image upgrade to an incompatible version· 14
Software image rollback example· 16
ISSU examples for using install commands· 18
Software image upgrade example· 18
Software image rollback example· 21
Software image patching example· 22
Performing an ISSU
ISSU overview
The In-Service Software Upgrade (ISSU) feature upgrades software with a minimum amount of downtime.
ISSU is implemented on the basis of the following design advantages:
·           Separation of service features from basic functions—Device software is segmented into boot, system, and feature images. The images can be upgraded individually.
·           Independence between service features—Features run independently. One feature can be added or upgraded without affecting the operation of the system or other features.
·           Support for hotfix—Patch images are available to fix system bugs without a system reboot.
·           Hardware redundancy—In an IRF fabric, one member device can be upgraded while other member devices are providing services.
For more information about images, see "Upgrading software."
ISSU methods
ISSU supports the following upgrade types:
·           Compatible upgrade—The running software version is compatible with the upgrade software version. This upgrade type supports the ISSU methods in Table 1.
·           Incompatible upgrade—The running software version is incompatible with the upgrade software version. The two versions cannot run concurrently.
This upgrade type supports only one upgrade method (also called incompatible upgrade). This  method requires a cold reboot. It is service disruptive if hardware redundancy is not available.
Table 1 ISSU methods for compatible upgrade
ISSU method
Incremental upgrade:
·          Service Upgrade
·          File Upgrade
Upgrades only segments that contain differences between the new and old software versions.
·          Service upgrade—Upgrades service features. The upgrade does not affect the operation of features that are not being upgraded.
·          File upgrade—Upgrades hidden system program files. The system can provide services during the upgrade.
ISSU Reboot
Reboots CPUs to complete software upgrade. During the reboot, the data plane can still forward traffic.
This method saves all data (running, configuration, and hardware) and status to memory before rebooting CPUs. For services that require regular communication with their peers, this method uses protocol agents to maintain their connectivity and status.
After the reboot, all data is restored to CPU.
Reboot
CAUTION CAUTION:
The Reboot method is service disruptive if the device stands alone. As a best practice, schedule the downtime carefully to minimize the upgrade impact on the services.
This method reboots both the control and data planes to complete the software upgrade.
ISSU commands
ISSU provides the install and issu command sets. After you identify the ISSU method, use Table 2 to choose the command set you want to use.
Table 2 Command set comparison
Item
issu commands
install commands
Upgrade types
·          Compatible.
·          Incompatible.
Compatible.
Patch install/uninstall
Not supported.
Supported.
Upgrade mode
Chassis by chassis.
Chassis by chassis.
Impact on the system
Large.
Small.
Technical skill requirements
Low.
As a best practice, use this command set.
High.
Administrators must have extensive system knowledge and understand the impact of each upgrade task on the network.
Preparing for ISSU
To perform a successful ISSU, make sure all the preparation requirements are met.
Read the software release notes to identify the following items:
·           Support of the device for ISSU.
·           Licensing requirements for the upgrade software images.
If the upgrade software images require licenses, make sure the device has the required licenses before ISSU. For more information about license installation, see "Managing licenses."
Use the display device command to verify that all member devices are operating correctly.
1.      Use the dir command to verify that all member devices has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. For more information, see "Managing the file system."
2.      Use FTP or TFTP to transfer upgrade image files to the root directory of any storage medium in the IRF fabric.
1.      Execute the display version comp-matrix file command for the upgrade image version.
2.      Check the Version compatibility list field.
¡  If the running software version is in the list, a compatible upgrade is required.
¡  If the running software version is not in the list, an incompatible upgrade is required.
3.      Identify the ISSU method:
¡  If a compatible upgrade is required, check the Upgrade Way field to identify the ISSU method. For more information about ISSU methods, see Table 1.
¡  If an incompatible upgrade is required, check the end of command output for the Incompatible upgrade string.
For service continuity during ISSU, configure the following feature settings:
Feature
Setting requirements
GR/NSR
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF.
BFD
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
IRF
Configure IRF bridge MAC persistence as follows:
·          Compatible upgradeConfigure the irf mac-address persistent timer or irf mac-address persistent always command.
·          Incompatible upgradeConfigure the irf mac-address persistent always command if the bridge MAC address is the MAC address of the device for which you want to execute the issu load command.
For an ISSU Reboot upgrade on a single-member IRF fabric, also verify that the following features are disabled:
Feature
Remarks
Spanning tree feature
If the spanning tree feature is enabled, service discontinuity might occur during the upgrade because the feature advertises the network topology change.
Dynamic Ethernet link aggregation
During an ISSU reboot, only static aggregation is supported, and dynamic aggregate interfaces might not be able to provide services.
CFD
If CFD is enabled, the CFD CC feature will be disabled during an ISSU reboot, which results in traffic abnormality.
DLDP
If DLDP is enabled, the peer device might consider a link a unidirectional link and shut down the port because it cannot receive probe packets.
Loop detection
If loop detection is enabled, the peer device might enable looped ports because of false loop removal detection.
1.      Use Table 2 to choose an upgrade command set, depending on the ISSU method.
2.      Identify the hardware redundancy condition.
ISSU can maintain service continuity only when the IRF fabric has multiple members and uses the ring topology.
IMPORTANT
IMPORTANT:
If hardware redundancy is not available, service discontinuity is not avoidable. Make sure you understand the impact of the upgrade on the network.
3.      Choose the correct procedure from the procedures described in "Performing an ISSU by using issu commands" or "Performing an ISSU by using install commands."
During an ISSU, use the following guidelines:
·           In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
·           Do not perform any of the following tasks during an ISSU:
¡  Reboot, add, or remove member devices.
¡  Execute commands that are not related to the ISSU.
¡  Modify, delete, or rename image files.
·           You cannot use both install and issu commands for an ISSU. However, you can use display issu commands with both command sets.
·           The following protocols will recalculate topology after an ISSU reboot if a peer keepalive timeout has occurred:
¡  Multicast protocolsPIM, IGMP, MLD, IGMP snooping, and MLD snooping.
¡  Routing protocolsOSPF, IS-IS, and BGP.
¡  FCoEFIP snooping and FSPF.
After an ISSU, you must log in to the device again before you can configure the device.
Log in to the device through the console port after you finish all the preparation tasks and understand all the ISSU guidelines. If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
Use the save command to save the running configuration.
The ISSU procedure varies depending on whether the IRF fabric has a single or multiple members.
Performing a compatible upgrade
For a compatible upgrade on a multichassis IRF fabric, upgrade a subordinate member first. Then, upgrade the master and the other subordinate members.
To perform a compatible upgrade:
Step
Remarks
1.      Enter system view.
N/A
2.      (Optional.) Set the automatic rollback timer.
issu rollback-timer minutes
By default, the automatic rollback timer is set to 45 minutes.
This timer starts when you execute the issu run switchover command. If you do not execute the issu accept or issu commit command before this timer expires, the system automatically rolls back to the original software images.
3.      Return to user view.
N/A
4.      Load the upgrade images as main startup software images on subordinate members.
·          Use .bin files:
issu load file { boot filename | system filename | feature filename&<1-30> } * slot slot-number&<1-9>
·          Use an .ipe file:
issu load file ipe ipe-filename slot slot-number&<1-9>
Specify the member ID of a subordinate member for the slot-number argument.
5.      Perform a master/subordinate switchover.
issu run switchover
N/A
6.      (Optional.) Accept the upgrade and delete the automatic rollback timer.
issu accept
N/A
7.      Upgrade the remaining members to complete the ISSU.
issu commit chassis chassis-number
IMPORTANT IMPORTANT:
After executing the command for one member, you must wait for the member to restart and join the IRF fabric before you execute the command for another member.
Repeat the issu commit command to upgrade the remaining members one by one, including the original master.
To manually roll back to the original software images during this ISSU process, use the issu rollback command.
For more information about rollback, see Fundamentals Command Reference.
Performing an incompatible upgrade
For an incompatible upgrade on a multichassis IRF fabric, upgrade one or more subordinate members first. As a best practice, upgrade half of the subordinate members first. Then, upgrade the master and the other subordinate members.
Perform this task in user view.
Step
Remarks
1.      Load the upgrade images as main startup software images on subordinate members.
·          Use .bin files:
·          Use an .ipe file:
As a best practice on a ring-topology IRF fabric, specify half of the subordinate members for this command to reduce service interruption. Make sure the specified subordinate members are physically connected.
2.      Perform a master/subordinate switchover to complete the ISSU process.
issu run switchover
To roll back to the original software images during this ISSU process, use the issu rollback command.
This ISSU process does not support automatic rollback.
3.      Verify that the ISSU is finished.
display issu state
If the ISSU state field displays Init, the ISSU is finished.
Performing a service upgrade or file upgrade
Step
Remarks
1.      Load the upgrade images as main startup software images.
·          Use .bin files:
·          Use an .ipe file:
Specify the member ID of the device for the slot-number argument.
2.      Complete the ISSU process.
issu commit slot slot-number
display issu state
Performing a reboot/ISSU reboot/incompatible upgrade
Step
Remarks
·          Use .bin files:
·          Use an .ipe file:
2.      Verify that the ISSU is finished.
display issu state
ISSU task list
Tasks at a glance
Remarks
(Optional.) Decompressing an .ipe file
To use install commands for upgrade, you must use .bin image files. If the upgrade file is an .ipe file, perform this task before you use install commands for upgrade.
(Required.) Perform one of the following tasks to update software:
·          Installing or upgrading software images
¡  Installing or upgrading images except for patches
¡  Installing patch images
·          Uninstalling feature or patch images
¡  Uninstalling feature images
¡  Uninstalling patch images
Perform an activate operation to install new images or upgrade existing images.
Perform an inactivate operation to uninstall feature or patch images.
An image is added to or removed from the current software image list when it is activated or deactivated.
(Optional.) Rolling back the running software images
Perform this task to roll back running software image status after activate or deactivate operations.
A commit operation removes all rollback points. You can perform this task only before software changes are committed.
(Optional.) Aborting a software activate/deactivate operation
You can perform this task while an image is being activated or deactivated.
This task is available only for service upgrade or file upgrade.
(Optional.) Committing software changes
This task updates the main startup image list with the changes.
If service upgrade or file upgrade is performed, you must perform this task for the changes to take effect after a reboot.
(Optional.) Verifying software images
Perform this task to verify that the software changes are correct.
(Optional.) Removing inactive software images
Perform this task to remove images
Step
1.      (Optional.) Identify images that are included in the .ipe file.
display install ipe-info
2.      Decompress the .ipe file.
install add ipe-filename medium-name:
Use one of the following methods to perform this task:
·           Chassis by chassis—Activate all the images on one member device, and then move to the next member device.
·           Image by image—Activate one image on all member devices before activating another image.
To install an image, you must begin with the master device. To upgrade an image, you must begin with a subordinate device.
You can install up to 32 .bin files on the device, including one boot image file, one system image file, and up to 30 feature or patch image files.
Step
1.      (Optional.) Identify the ISSU method and possible impacts of the upgrade.
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number test
2.      Activate images.
Before installing patch images, check whether the device is already running patch images.
·           If not, install patch images.
·           If yes, read the release notes to identify the functionality differences between the running patch images and the new patch images.
¡  If the new patch images cover all functions provided by the old patch images, loading the patch images overwrites the old patch images. After installing the new patch images, delete the old patch images from the storage medium to release the storage space.
¡  If the new patch images do not cover one or more functions provided by the old patch images, loading the patch images does not affect the old patch images. The device uses both the new patch images and the old patch images. Do not uninstall or delete the old patch images.
Activate patch images.
install activate patch filename { all | slot slot-number }
The uninstall operation only removes images from the current software image list. For the change to take effect after a reboot, you must perform a commit operation to remove the images from the main startup image list.
Uninstalled images are still stored on the storage medium. To permanently remove the images, execute the install remove command. For more information, see "Removing inactive software images."
Boot and system images cannot be uninstalled.
Deactivate feature images.
install deactivate feature filename&<1-30> slot slot-number
Deactivate patch images.
install deactivate patch { all | filename slot slot-number }
For each service or file upgrade performed through activate or deactivate operation, the system creates a rollback point. The rollback points are retained until any of the following event occurs:
·           An ISSU reboot or reboot upgrade is performed.
·           The install commit command is executed.
After an ISSU reboot or reboot upgrade is performed, you can roll back the running software images only to the status before any activate or deactivate operations are performed.
After a commit operation is performed, you cannot perform a rollback.
For a rollback to take effect after a reboot, you must perform a commit operation to update the main startup software image list.
To roll back the software, execute the following commands in user view:
Step
Remarks
1.      (Optional.) Display available rollback points.
display install rollback
A maximum of 50 rollback points are available for service and file upgrades. The earliest rollback point is removed if this limit has been reached when a rollback point is created.
2.      Roll back the software.
install rollback to { point-id | original }
N/A
This task is available only for service upgrade or file upgrade performed through activate or deactivate operation. After the operation is aborted, the system runs with the software images that it was running with before the operation.
Step
1.      Press Ctrl+C while a software image is being activated or deactivated.
N/A
2.      Abort a software activate/deactivate operation in user view.
install abort [ job-id ]
If the ISSU method is service upgrade or file upgrade for an activate or deactivate operation, the main startup image list does not update with the changes. The software changes are lost at reboot. For the changes to take effect after a reboot, you must commit the changes.
Remarks
Commit the software changes.
install commit
This command commits all software changes.
Perform this task to verify the following items:
·           Integrity—Verify that the boot, system, and feature images are integral.
·           Consistency—Verify that the same active images are running across the entire system.
·           Software commit status—Verify that the active images are committed as needed.
If an image is not integral, consistent, or committed, use the install activate, install deactivate, and install commit commands as appropriate to resolve the issue.
Verify software images.
install verify
Removing a software image deletes the image file permanently. You cannot use the install rollback to command after the operation.
Remove inactive software images.
install remove [ slot slot-number ] { filename | inactive }
The display issu state command applies only to an ISSU that uses the issu series commands. All the other display commands and all reset commands can be used during an ISSU, regardless of whether the install or issu commands are used.
Display version compatibility information.
Display ISSU status information.
display issu state
Display automatic rollback timer information.
display issu rollback-timer
Display active software images.
display install active [ slot slot-number ] [ verbose ]
Display inactive software images.
display install inactive [ slot slot-number ] [ verbose ]
Display main startup software images.
display install committed [ slot slot-number ] [ verbose ]
Display backup startup software images.
display install backup [ slot slot-number ] [ verbose ]
Display ongoing ISSU activate, deactivate, and rollback operations.
display install job
Display ISSU log entries.
display install log  [ verbose ]
Display software image file information.
display install package { filename | all } [ verbose ]
Display the software images included in an .ipe file.
display install ipe-info ipe-filename
Display rollback point information.
Display all software image files that include a specific component or file.
display install which { component name | file filename } [ slot slot-number ]
Clear ISSU log entries.
reset install log-history oldest log-number
Clear ISSU rollback points.
reset install rollback oldest point-id
Symptom
The following commands cannot be executed:
·           issu commandsissu load, issu run switchover, and issu commit.
·           install commandsinstall activate and install deactivate.
Solution
To resolve this issue:
1.      Use the display device command to verify that all cards are not in Fault state.
2.      Use the display system internal ha service-group command to verify that the Action field is 0 for each service.
3.      If the problem persists, contact H3C Support.
Upgrade requirements
As shown in Figure 1, the IRF fabric has two members.
Upgrade feature1 from R0201 to R0202. The two versions are compatible.
Figure 1 Network diagram
Upgrade procedure
# Save the running configuration.
<Sysname> save
# Download the image file that contains the feature1 image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-r0202.bin
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   256  100  256     0     0    764      0 --:--:-- --:--:-- --:--:--   810
# Display active software images.
<Sysname> display install active
Active packages on slot 1:
  flash:/boot-r0201.bin
  flash:/system-r0201.bin
  flash:/feature1-r0201.bin
Active packages on slot 2:
# Identify the ISSU method to be used for the upgrade and view the possible impact of the upgrade.
<Sysname> display version comp-matrix file feature flash:/feature1-r0202.bin
Feature image: flash:/feature1-r0202.bin
  Version:
  V700R001B31D002
  Version Compatibility List:
  V700R001B31D001
  V700R001B31D002
  Version Dependency System List:
  V700R001B31D001
  V700R001B31D002
  Slot                        Upgrade Way
  1                           Service Upgrade
  2                           Service Upgrade
Influenced service according to following table on slot 1:
         feature1
Influenced service according to following table on slot 2:
         feature1
The output shows that an incremental upgrade is recommended. The feature1 module will be rebooted during the upgrade process.
# Upgrade feature1 on the subordinate member.
<Sysname> issu load file feature flash:/feature1-r0202.bin slot 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/feature1-r0202.bin to slot2#flash:/feature1-r0202.bin......Done.
  Running Version             New Version
  Alpha 0201                  Alpha 0202
  Slot                        Upgrade Way
  2                           Service Upgrade
This operation might take several minutes, please wait...Done.
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
  Slot                        Switchover Way
  1                           Active standby process switchover
# Upgrade the feature on the original master.
<Sysname> issu commit slot 1
  Slot                        Upgrade Way
  1                           Service Upgrade
# Verify that both members are running the new image.
As shown in Figure 2, the IRF fabric has two members.
Upgrade feature1 from R0201 to R0202. The two versions are incompatible.
Figure 2 Network diagram
Upgrade procedure
<Sysname> save
# Download the image file that contains the R0202 feature1 image from the TFTP server.
  Version:
  V700R001B31D002
  V700R001B31D002
  V700R001B31D001
  V700R001B31D002
Incompatible upgrade.
The output shows that the two versions are incompatible. The cards will be rebooted for the upgrade.
  Slot                        Upgrade Way
  2                           Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
# Upgrade feature1 on the original master.
  Slot                        Upgrade Way
  1                           Reboot
Active packages on slot2:
Rollback requirement
As shown in Figure 3, the IRF fabric has two members.
Roll back feature1 from R0202 to R0201 after upgrading it from R0201 to R0202. The two versions are compatible.
Figure 3 Network diagram
Rollback procedure
<Sysname> save
100  256k  100  256k    0     0   764k      0 --:--:-- --:--:-- --:--:--  810k
  Version:
  V700R001B31D002
  V700R001B31D001
  V700R001B31D002
  V700R001B31D001
  V700R001B31D002
  Slot                        Upgrade Way
  1                           Service Upgrade
  2                           Service Upgrade
         feature1
         feature1
The output shows that an incremental upgrade is recommended, and the feature1 module will be rebooted during the upgrade process.
  Slot                        Upgrade Way
  2                           Service Upgrade
  Slot                        Switchover Way
# Roll back feature1 to R0201.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:Y
# Verify that both members are running the old image.
As shown in Figure 4, the IRF fabric has two members.
Figure 4 Network diagram
Upgrade procedure
<Sysname> save
# Download the .ipe file that contains the R0202 feature1 image from the TFTP server.
<Sysname> tftp 2.2.2.2 get feature1-r0202.ipe
# Decompress the .ipe file.
<Sysname> install add flash:/feature1-r0202.ipe flash:
# Identify the ISSU methods for the upgrade and view the possible impact of the upgrade.
<Sysname> install activate feature flash:/feature1-r0202.bin slot 2 test
  Slot                        Upgrade Way
  2                           Service Upgrade
         feature1
<Sysname> install activate feature flash:/feature1-r0202.bin slot 1 test
  Slot                        Upgrade Way
  1                           Service Upgrade
         feature1
The output shows that both members require a service upgrade and the feature1 module will be rebooted during the upgrade process.
# Activate the new feature1 image to upgrade feature1.
flash:/feature1-r0202.bin already exists on slot 2.
Overwrite it?[Y/N]:y
  Slot                        Upgrade Way
  2                           Service Upgrade
  Slot                        Upgrade Way
  1                           Service Upgrade
# Confirm the software change.
<Sysname> install commit
As shown in Figure 4, the IRF fabric has two members. The feature1 feature has been upgraded from R0201 to R0202, but the software change has not been confirmed.
Roll back feature1 from R0202 to R0201.
Rollback procedure
# Display available rollback points.
<Sysname> display install rollback
  Install rollback information 1 on slot 1:
    Updating from flash:/feature1-r0201.bin
             to flash:/feature1-r0202.bin.
  Install rollback information 2 on slot 2:
<Sysname> install rollback to original
Patching requirements
As shown in Figure 5, the IRF fabric has two members.
Patch the software images running on the members.
Figure 5 Network diagram
Patching procedure
# Download the patch images boot-patch.bin and system-patch.bin from the TFTP server to the root directory of the flash memory on the master.
<Sysname> tftp 2.2.2.2 get boot-patch.bin
  File will be transferred in binary mode
  Downloading file from remote TFTP server, please wait...|
  TFTP:     100752 bytes received in 11 second(s)
  File downloaded successfully.
<Sysname> tftp 2.2.2.2 get system-patch.bin
  TFTP:     100112 bytes received in 9 second(s)
  flash:/boot.bin
  flash:/system.bin
  flash:/boot.bin
  flash:/system.bin
The output shows that the patch images are not active.
# Activate the patch images on the member devices.
<Sysname> install activate patch flash:/boot-patch.bin slot 1
<Sysname> install activate patch flash:/system-patch.bin slot 1
<Sysname> install activate patch flash:/boot-patch.bin slot 2
<Sysname> install activate patch flash:/system-patch.bin slot 2
  flash:/boot.bin
  flash:/system.bin
  flash:/boot.bin
  flash:/system.bin
# Display the main startup software images.
<Sysname> display install committed
Committed packages on slot 1:
  flash:/boot.bin
  flash:/system.bin
Committed packages on slot 2:
  flash:/boot.bin
  flash:/system.bin
The output shows that the patch images have been specified as the startup software images.
