08-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WA Series Access Points Configuration Guides(R1507P09)-6W10108-Network Management and Monitoring Configuration Guide
05-Information Center Configuration
05-Information Center Configuration 170.51 KB
Overview
The information center collects and classifies system information as follows:
·          Receives system information including log, trap, and debug information from source modules.
·          Outputs the information to different information channels, according to output rules.
·          Outputs information to different destinations, based on channel-to-destination associations.
Figure 1 Information center diagram
By default, the information center is enabled. It affects system performance to some degree when processing large amounts of information. If the system resources are insufficient, disable the information center to save resources.
Classification of system information
System information falls into the following types:
·          Log information—Describes user operations and interface state changes.
·          Trap information—Describes device faults such as authentication and network failures.
·          Debug information—Displays device running status for troubleshooting.
Source modules refer to protocol modules, board drivers, and configuration modules which generate system information. You can classify, filter, and output system information based on source modules. To view the supported source modules, use the info-center source ? command.
System information levels
System information is classified into eight severity levels, from 0 through 7 in descending order. The device outputs the system information with a severity level that is higher than or equal to the specified level. For example, if you configure an output rule with a severity level of 6 (informational), information that has a severity level from 0 to 6 is output.
Table 1 System information levels
Severity
Severity value
Corresponding keyword in commands
Emergency
0
The system is unusable. For example, the system authorization has expired.
emergencies
Alert
1
Action must be taken immediately to solve a serious problem. For example, traffic on an interface exceeds the upper limit.
alerts
Critical
2
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails or the fan tray fails.
critical
Error
3
Error condition. For example, the link state changes or a storage card is unplugged.
errors
Warning
4
Warning condition. For example, the device is being logged into through the Web interface, or the memory resources are used up.
warnings
Notification
5
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
notifications
Informational
6
Informational message. For example, a command or a ping operation is executed.
informational
Debug
7
Debug message.
debugging
Output channels and destinations
Table 2 shows the output channels and destinations.
The system supports ten channels. By default, channels 0 through 6 are configured with channel names and output destinations. You can change these default settings as needed. You can also configure channels 7 through 9 and associate them with specific output destinations as needed.
You can use the info-center channel name command to change the name of an information channel.
Each output destination receives information from only one information channel, but each information channel can output information to multiple output destinations.
Table 2 Default information channels and output destinations
Channel number
Default channel name
Default output destination
System information received by default
0
console
Console
Log, trap and debug information
1
monitor
Monitor terminal
2
loghost
Log host
3
trapbuffer
Trap buffer
Trap information
4
logbuffer
Log buffer
Log information
5
snmpagent
SNMP module
Trap information
6
channel6
Web interface
Log information
7
channel7
Not specified
Log, trap, and debug information
8
channel8
Not specified
9
channel9
Not specified
Default output rules of system information
A default output rule specifies the system information source modules, information type, and severity levels for an output destination. Table 3 shows the default output rules.
Table 3 Default output rules
Destination
System information source modules
Log
Trap
Debug
Output switch
Severity
Output switch
Severity
Output switch
Severity
Console
All supported modules
Enabled
Informational
Enabled
Debug
Enabled
Debug
Monitor terminal
Enabled
Informational
Enabled
Debug
Enabled
Debug
Log host
Enabled
Informational
Enabled
Debug
Disabled
Debug
Trap buffer
Disabled
Informational
Enabled
Informational
Disabled
Debug
Log buffer
Enabled
Informational
Disabled
Debug
Disabled
Debug
SNMP module
Disabled
Debug
Enabled
Informational
Disabled
Debug
Web interface
Enabled
Debug
Enabled
Debug
Disabled
Debug
System information formats
The format of system information varies with output destinations. The following shows the original format of system information, which may be different from what you see. The actual format depends on the log resolution tool you use.
The format of system information displayed on the Web interface depends on the Web interface.
Table 4 System information formats
Output destination
Format
Example
Console, monitor terminal, logbuffer, trapbuffer, or SNMP module
timestamp sysname module/level/digest: content
%Jun 26 17:08:35:809 2008 Sysname SHELL/4/LOGIN: VTY login from 1.1.1.1.
Log host
·         H3C format:
<PRI>timestamp Sysname %%vvmodule/level/digest: source content
·         UNICOM format:
<PRI>timestamp Sysname vvmodule/level/serial_number: content
·         H3C format:
<189>Oct 9 14:59:04 2009 Sysname %%10SHELL/5/SHELL_LOGIN(l): VTY logged in from 192.168.1.21.
·         UNICOM format:
?   <186>Oct 13 16:48:08 2000 Sysname 10IFNET/2/210231a64jx073000020: log_type=port;content=Vlan-interface1 link status is DOWN.
?  <186>Oct 13 16:48:08 2000 Sysname 10IFNET/2/210231a64jx073000020: log_type=port;content=Line protocol on the interface Vlan-interface1 is DOWN.
Table 5 describes the fields in the system information.
Table 5 System information field description
PRI (priority)
The priority is calculated by using this formula: facility*8+level, where:
·         facility is the facility name. It can be configured with info-center loghost. It is used to identify different log sources on the log host, and to query and filter logs from specific log sources.
·         level ranges from 0 to 7. See Table 1 for more information.
Note that the priority field is available only for information that is sent to the log host.
Timestamp
The timestamp records the time when the log was generated.
Logs sent to the log host and those sent to the other destinations have different precisions, and their timestamp formats are configured with different commands. For more information, see Table 7 and Table 7.
Sysname (host name or host IP address)
·         If the system information that is sent to a log host is in the UNICOM format, and the info-center loghost source command is configured, the sysname field is displayed as the IP address of the device that generated the system information.
·         If the system information is in the H3C format, the field is displayed as the system name of the device that generated the system information. You can use the sysname command to modify the local system name. For more information, see Fundamentals Command Reference.
%% (vendor ID)
This field indicates that the information was generated by an H3C device.
It exists only in logs sent to a log host.
vv (version information)
This field identifies the version of the log, and has a value of 10.
It exists only in logs sent to the log host.
Module
This field specifies source module name. You can execute the info-center source ? command in system view to view the module list.
Level (severity)
System information is divided into eight severity levels, from 0 to 7. See Table 1 for more information about severity levels. You cannot change the system information levels generated by modules. However, you can use the info-center source command to control the output of system information based on severity levels.
Digest
This field briefly describes the content of the system information. It contains a string of up to 32 characters.
For system information destined to the log host:
·         If the string ends with (l), the information is log information.
·         If the string ends with (t), the information is trap information.
·         If the string ends with (d), the information is debug information.
Serial Number
This field indicates the serial number of the device that generated the system information. It is displayed only if the system information sent to the log host is in the UNICOM format.
source
This optional field identifies the source of the information, typically the IP address of the log sender. It is displayed only if the system information is sent to a log host in H3C format.
content
This field contains the content of the system information.
Table 6 Timestamp precisions and configuration commands
Item
Destined to the log host
Destined to the console, monitor terminal, and log buffer
Precision
Seconds
Milliseconds
Command used to set the timestamp format
info-center timestamp loghost
Table 7 Description of the timestamp parameters
Timestamp parameters
Example
boot
Time since system startup, in the format of xxx.yyy. xxx represents the higher 32 bits, and yyy represents the lower 32 bits, of milliseconds elapsed.
System information sent to all destinations other than log host supports this parameter.
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
0.109391473 is a timestamp in the boot format.
date
Current date and time, in the format of mm dd hh:mm:ss:xxx yyy.
All system information supports this parameter.
%May 30 05:36:29:579 2003 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
May 30 05:36:29:579 2003 is a timestamp in the date format.
iso
Timestamp format stipulated in ISO 8601.
Only system information that is sent to the log host supports this parameter.
<189>2003-05-30T06:42:44 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully.
2003-05-30T06:42:44 is a timestamp in the iso format.
none
No timestamp is included.
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
no-year-date
Current date and time without year information, in the format of mm dd hh:mm:ss:xxx.
Only the system information that is sent to the log host supports this parameter.
<189>May 30 06:44:22 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully.
May 30 06:44:22 is a timestamp in the no-year-date format.
Information center configuration task list
Remarks
Outputting system information to the console
Optional.
Outputting system information to the monitor terminal
Optional.
Outputting system information to a log host
Optional.
Outputting system information to the trap buffer
Optional.
Outputting system information to the log buffer
Optional.
Outputting system information to the SNMP module
Optional.
Outputting system information to the Web interface
Optional.
Enabling synchronous information output
Optional.
Disabling an interface from generating link up/down logging information
Optional.
Configurations for the information output destinations function independently.
Step
Remarks
1.       Enter system view.
N/A
2.       Enable the information center.
info-center enable
Optional.
Enabled by default.
3.       Specify a name for a channel identified by its number.
info-center channel channel-number name channel-name
Optional.
See Table 2 for default channel names.
4.       Configure an output channel for the console.
info-center console channel { channel-number | channel-name }
Optional.
By default, system information is output to the console through channel 0 (console).
5.       Configure an output rule for the console.
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state } * | log { level severity | state state } * | trap { level severity | state state } * ] *
Optional.
See "Default output rules of system information."
6.       Configure the timestamp format.
info-center timestamp { debugging | log | trap } { boot | date | none }
Optional.
By default, the timestamp format for log, trap and debug information is date.
7.       Return to user view.
N/A
8.       Enable system information output to the console.
terminal monitor
Optional.
The default setting is enabled.
9.       Enable the display of system information on the console.
·         Enable the display of debug information on the console:
terminal debugging
·         Enable the display of log information on the console:
terminal logging
·         Enable the display of trap information on the console:
terminal trapping
Optional.
By default, the console displays log and trap information, and discards debug information.
Monitor terminals refer to terminals that log in to the device through the AUX, VTY, or TTY user interface.
To output system information to the monitor terminal:
Step
Remarks
N/A
info-center enable
Optional.
Enabled by default.
Optional.
4.       Configure an output channel for the monitor terminal.
info-center monitor channel { channel-number | channel-name }
Optional.
By default, system information is output to the monitor terminal through channel 1 (known as monitor).
5.       Configure an output rule for the monitor terminal.
Optional.
Optional.
N/A
8.       Enable system information output to the monitor terminal.
terminal monitor
The default setting is disabled.
You must execute this command before you can enable the display of debugging, log, and trap information on the monitor terminal.
9.       Enable the display of system information on the monitor terminal.
·         Enable the display of debug information on the monitor terminal:
terminal debugging
·         Enable the display of log information on the monitor terminal:
terminal logging
·         Enable the display of trap information on the monitor terminal:
terminal trapping
Optional.
By default, the monitor terminal displays log and trap information, and discards debug information.
Step
Remarks
N/A
info-center enable
Optional.
Enabled by default.
Optional.
4.       Configure an output rule for the log host.
Optional.
5.       Specify the source IP address for output log information.
Optional.
By default, the source IP address of output log information is the primary IP address of the matching route' egress interface.
info-center timestamp loghost { date | iso | no-year-date | none }
Optional.
date by default.
7.       Set the system information format
·         Set the format to UNICOM:
info-center format unicom
·         Set the format to H3C:
undo info-center format
Optional.
Use either approach.
H3C by default.
8.       Specify a log host and configure related parameters.
info-center loghost host-ipv4-address [ port port-number ] [ channel { channel-number | channel-name } | facility local-number ] *
By default, no log host or related parameters are specified.
If no channel is specified when outputting system information to a log host, the system uses channel 2 (loghost) by default.
The value of the port-number argument must be the same as the value configured on the log host. Otherwise, the log host cannot receive system information.
The trap buffer only receives trap information, and discards log and debug information.
To output system information to the trap buffer:
Step
Remarks
N/A
info-center enable
Optional.
Enabled by default.
Optional.
4.       Configure an output channel for the trap buffer and set the buffer size.
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ] *
Optional.
By default, system information is output to the trap buffer through channel 3 (known as trapbuffer) and the default buffer size is 256.
5.       Configure an output rule for the trap buffer.
Optional.
Optional.
The timestamp format for log, trap and debug information is date by default.
The log buffer only receives log information, and discards trap and debug information.
To output system information to the log buffer:
Step
Remarks
N/A
info-center enable
Optional.
Enabled by default.
Optional.
4.       Configure an output channel for the log buffer and set the buffer size.
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ] *
Optional.
By default, system information is output to the log buffer through channel 4 (known as logbuffer) and the default buffer size is 512.
5.       Configure an output rule for the log buffer.
Optional.
Optional.
The SNMP module only receives trap information, and discards log and debug information.
To monitor the device running status, trap information is usually sent to the SNMP network management system (NMS). For this purpose, you must configure output of traps to the SNMP module, and set the trap sending parameters for the SNMP module. For more information about SNMP, see "Configuring SNMP."
To output system information to the SNMP module:
Step
Remarks
N/A
info-center enable
Optional.
Enabled by default.
Optional.
4.       Configure an output channel for the SNMP module.
info-center snmp channel { channel-number | channel-name }
Optional.
By default, system information is output to the SNMP module through channel 5 (known as snmpagent).
5.       Configure an output rule for the SNMP module.
Optional.
Optional.
The Web interface only receives log information, and discards trap and debug information.
This feature allows you to control whether to output system information to the Web interface and, if so, which system information can be output to the Web interface. The Web interface provides abundant search and sorting functions. If you output system information to the Web interface, you can view the system information by clicking corresponding tabs after logging in to the device through the Web interface.
To output system information to the Web interface:
Step
Remarks
N/A
info-center enable
Optional.
Enabled by default.
Optional.
4.       Configure an output channel for the Web interface.
info-center syslog channel { channel-number | channel-name }
Optional.
By default, system information is output to the Web interface through channel 6.
5.       Configure an output rule for the Web interface.
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state }* | log { level severity | state state }* | trap { level severity | state state }* ]*
Optional.
Optional.
The output of system logs interrupts ongoing configuration operations. You have to find the previously input commands before the logs. Synchronous information output can show the previous input after log output and a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
If system information, such as log information, is output before you input any information under the current command line prompt, the system does not display the command line prompt after the system information output.
If system information is output when you are inputting some interactive information (non Y/N confirmation information), the system displays your previous input in a new line but does not display the command line prompt.
To enable synchronous information output:
Step
Remarks
N/A
2.       Enable synchronous information output.
info-center synchronous
Disabled by default.
By default, all interfaces generate link up or link down log information when the state changes. In some cases, you might want to disable specific interfaces from generating this information. For example:
·          You are concerned only about the states of some interfaces. In this case, you can use this function to disable other interfaces from generating link up and link down log information.
·          An interface is unstable and continuously outputs log information. In this case, you can disable the interface from generating link up and link down log information.
Use the default setting in normal cases to avoid affecting interface status monitoring.
To disable an interface from generating link up/down logging information:
Step
Remarks
N/A
2.       Enter Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, or VLAN interface view.
N/A
3.       Disable the interface from generating link up or link down logging information.
undo enable log updown
By default, all interfaces generate link up and link down logging information when the state changes.
Displaying and maintaining information center
Remarks
Display information about information channels.
display channel [ channel-number | channel-name ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display information center configuration information.
display info-center [ | { begin | exclude | include } regular-expression ]
Display the state and the log information of the log buffer.
display logbuffer [ reverse ] [ level severity | size buffersize ] * [ | { begin | exclude | include } regular-expression ]
Display a summary of the log buffer.
display logbuffer summary [ level severity ] [ | { begin | exclude | include } regular-expression ]
Display the state and the trap information of the trap buffer.
display trapbuffer [ reverse ] [ size buffersize ] [ | { begin | exclude | include } regular-expression ]
Clear the log buffer.
reset logbuffer
Available in user view.
Clear the trap buffer.
reset trapbuffer
Information center configuration examples
Outputting log information to the console
Network requirements
Configure the AP to send ARP and IP log information that has a severity level of at least informational to the console.
Figure 2 Network diagram
Configuration procedure
# Enable the information center.
<AP> system-view
[AP] info-center enable
# Use channel console to output log information to the console. (This step is optional because it is the default setting.)
[AP] info-center console channel console
# Disable all modules from outputting log, trap, and debug information to channel console.
[AP] info-center source default channel console debug state off log state off trap state off
To avoid output of unnecessary information, disable all modules from outputting log, trap, and debug information to the specified channel (console in this example) before you configure an output rule.
# Configure an output rule to enable ARP and IP modules to output log information that has a severity level of at least informational to the console.
[AP] info-center source arp channel console log level informational state on
[AP] info-center source ip channel console log level informational state on
[AP] quit
# Enable the display of log information on the console. (This function is enabled by default.)
<AP> terminal monitor
Info: Current terminal monitor is on.
<AP> terminal logging
Info: Current terminal logging is on.
Now, if the ARP and IP modules generate log information, the information center automatically sends the log information to the console.
Outputting log information to a UNIX log host
Configure the AP to send ARP and IP log information that has a severity level of at least informational to the UNIX log host at 1.2.0.1/16.
Figure 3 Network diagram
Before the configuration, make sure the AP and the log host can reach each other. (Details not shown.)
1.        Configure the AP:
<AP> system-view
# Specify the log host 1.2.0.1/16, use channel loghost to as the output channel (optional, loghost by default), and specify local4 as the logging facility.
[AP] info-center loghost 1.2.0.1 channel loghost facility local4
# Disable all modules from outputting log, trap, and debug information to channel loghost.
[AP] info-center source default channel loghost debug state off log state off trap state off
To avoid output of unnecessary information, disable all modules from outputting log, trap, and debug information to the specified channel (loghost in this example) before you configure an output rule.
# Configure an output rule to allow ARP and IP modules to output log information that has a severity level of at least informational to the log host.
[AP] info-center source arp channel loghost log level informational state on trap state off
[AP] info-center source ip channel loghost log level informational state on trap state off
2.        Configure the log host:
The following configurations were performed on Solaris which has similar configurations to the UNIX operating systems implemented by other vendors.
a.    Log in to the log host as a root user.
b.    Create a subdirectory named Device in directory /var/log/, and then create file info.log in the Device directory to save logs from Device.
# mkdir /var/log/Device
c.     Edit the file syslog.conf in directory /etc/ and add the following contents.
local4.info    /var/log/Device/info.log
In this configuration, local4 is the name of the logging facility that the log host uses to receive logs. info is the informational level. The UNIX system records log information that has a severity level of at least informational to the file /var/log/Device/info.log.
Be aware of the following issues while editing file /etc/syslog.conf:
·      Comments must be on a separate line and must begin with a pound sign (#).
·      No redundant spaces are allowed after the file name.
The logging facility name and the information level specified in the /etc/syslog.conf file must be identical to those configured on the AP by using the info-center loghost and info-center source commands. Otherwise the log information might not be output properly to the log host.
d.    Display the process ID of syslogd, kill the syslogd process, and then restart syslogd using the –r option to make the new configuration take effect.
# ps -ae | grep syslogd
147
# kill -HUP 147
# syslogd -r &
Now, the system can output log information to the log host.
Outputting log information to a Linux log host
Configure the AP to send log information that has a severity level of at least informational to the Linux log host at 1.2.0.1/16.
Figure 4 Network diagram
Before the configuration, make sure the AP and the log host can reach other. (Details not shown.)
<AP> system-view
# Specify the host 1.2.0.1/16 as the log host, use the channel loghost as the output channel (optional, loghost by default), and specify local5 as the logging facility.
[AP] info-center loghost 1.2.0.1 channel loghost facility local5
# Configure an output rule to allow all modules to output log information that has a severity level of at least informational to the log host.
[AP] info-center source default channel loghost log level informational state on debug state off trap state off
To avoid output of unnecessary information, disable all modules from outputting debug and trap information to the specified channel (loghost in this example) in the output rule.
b.    Create a subdirectory named Device in the directory /var/log/, and create file info.log in the Device directory to save logs of Device.
c.     Edit the file syslog.conf in the directory /etc/ and add the following contents.
local5.info    /var/log/Device/info.log
In this configuration, local5 is the name of the logging facility used by the log host to receive logs. info is the information level. The Linux system will record the log information with severity level equal to or higher than informational to file /var/log/Device/info.log.
147
# kill -9 147
# syslogd -r &
Make sure the syslogd process is started with the -r option on a Linux log host.
