- 07-Security Configuration Guide
- 01-Security Overview
- 02-AAA Configuration
- 03-802.1X Configuration
- 04-MAC Authentication Configuration
- 05-Port Security Configuration
- 06-Public Key Configuration
- 07-PKI Configuration
- 08-SSH Configuration
- 09-SSL Configuration
- 10-User Isolation Configuration
- 11-Portal Configuration
- 12-IPsec Configuration
| 08-SSH Configuration | 370.93 KB |
Configuring the device as an SSH server
SSH server configuration task list
Generating local RSA key pairs
Enabling the SSH server function
Enabling the SFTP server function
Configuring the user interfaces for SSH clients
Configuring a client's host public key
Setting the SSH management parameters
Configuring the device as an Stelnet client
Stelnet client configuration task list
Specifying a source IP address or source interface for the Stelnet client
Enabling and disabling first-time authentication
Establishing a connection to an Stelnet server
Configuring the device as an SFTP client
SFTP client configuration task list
Specifying a source IP address or source interface for the SFTP client
Establishing a connection to an SFTP server
Terminating the connection with the SFTP server
Configuring the device as an SCP client
SCP client configuration task list
Transferring files with an SCP server
Displaying and maintaining SSH
Stelnet configuration examples
Password authentication enabled Stelnet server configuration example
Publickey authentication enabled Stelnet server configuration example
Password authentication enabled Stelnet client configuration example
Publickey authentication enabled Stelnet client configuration example
Password authentication enabled SFTP server configuration example
Publickey authentication enabled SFTP client configuration example
Overview
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH implements remote login and file transfer securely over an insecure network.
SSH uses the typical client/server model, establishing a channel to protect data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
The device can not only work as an SSH server to provide services to SSH clients, but can also work as an SSH client to allow users to establish SSH connections with a remote SSH server. When acting as an SSH server, the device supports SSH and SSH1. When acting as an SSH client, the device supports SSH2 only.
The device supports the following SSH applications:
· Stelnet—Provides secure and reliable network terminal access services. Through Stelnet, a user can log in to a remote server securely. Stelnet protects devices against attacks such as IP spoofing and plain text password interception. The device can act as both the Stelnet server and Stelnet client.
· SFTP—Based on SSH2, SFTP uses the SSH connection to provide secure file transfer. The device can serve as the SFTP server, allowing a remote user to log in to the SFTP server for secure file management and transfer. The device can also serve as an SFTP client, enabling a user to log in from the device to a remote device for secure file transfer.
· SCP—Based on SSH2, SCP offers a secure approach to copying files. The device can act as the SCP server, allowing a user to log in to the device for file upload and download. The device can also act as an SCP client, enabling a user to log in from the device to a remote server for secure file transfer.
How SSH works
This section uses SSH2 as an example.
To establish an SSH connection and communicate with each other through the connection, an SSH client and an SSH server go through the stages listed in Table 1. For more information about these stages, see SSH Technology White Paper.
Table 1 Stages of secure session establishment
Stages |
Connection establishment |
The SSH server listens to the connection requests on port 22. After a client initiates a connection request, the server and the client establish a TCP connection. |
Version negotiation |
The two parties determine a version to use after negotiation. |
Algorithm negotiation |
SSH supports multiple algorithms. Based on the local algorithms, the two parties determine the key exchange algorithm for generating session keys, the encryption algorithm for encrypting data, public key algorithm for digital signature and authentication, and the HMAC algorithm for protecting data integrity. |
Key exchange |
The two parties use the Diffie-Hellman (DH) exchange algorithm to dynamically generate the session key for protecting data transfer and the session ID for identifying the SSH connection. In this stage, the client authenticates the server as well. |
Authentication |
The SSH server authenticates the client in response to the client's authentication request. |
Session request |
After passing authentication, the client sends a session request to the server to request the establishment of a session (Stelnet, SFTP, or SCP). |
Interaction |
After the server grants the request, the client and the server start to communicate with each other in the session. In the interaction stage, you can execute commands from the client by pasting the commands in text format (the text must be within 2000 bytes). The commands must be available in the same view. Otherwise, the server might not be able to execute the commands correctly. If you want to execute commands of more than 2000 bytes, you can save the commands in a configuration file, upload it to the server through SFTP, and use it to restart the server. |
SSH authentication
When the device acts as an SSH server, it supports the following authentication methods:
· Password authentication—The SSH server uses AAA for authentication of the client. During password authentication, the SSH client encrypts its username and password, encapsulates them into an authentication request, and sends the request to the server. After receiving the request, the SSH server decrypts the request to get the username and password in plain text, checks the validity of the username and password locally or by a remote AAA server, and then informs the client of the authentication result.
· Publickey authentication—The server authenticates the client by verifying the digital signature of the client. During publickey authentication, the client sends the server a publickey authentication request that contains its username, public key, and publickey algorithm information (or the digital certificate that carries the public key information). The server examines whether the public key is valid. If the public key is invalid, the authentication fails. If the public key is valid, the server verifies the digital signature of the client by using the public key of the client. The device supports using the publickey algorithm RSA to generate or verify the digital signature.
A client can send public key information to the device that acts as the server for validity check in either of the following methods:
¡ The client directly sends the user's public key information to the server, and the server checks the validity of the user's public key.
¡ The client sends the user's public key information to the server through a digital certificate, and the server checks the validity of the digital certificate. When acting as a client, the device does not support this method.
· Password-publickey authentication—The server requires clients that run SSH2 to pass both password authentication and publickey authentication. However, if a client runs SSH1, it only needs to pass either authentication.
· Any authentication—The server requires the client to pass either of password authentication and publickey authentication.
In a password authentication process, if the remote AAA server requires the user for a password secondary authentication, it sends the SSH server an authentication response with a prompt. The prompt is transparently transmitted to the client, and displayed on the client to notify the user to enter a specified password. After the user enters the correct password and passes validity check by the remote AAA server, the device returns an authentication success message to the client.
NOTE: Only clients that run SSH2 or a later version support password secondary authentication that is initiated by the AAA server. |
You can configure the device as an Stelnet server, SFTP server, or SCP server. Because the configuration procedures are similar, the SSH server represents the Stelnet server, SFTP server, and SCP server unless otherwise specified.
Task |
Remarks |
Required. |
Required for Stelnet, SFTP and SCP servers. |
Required only for SFTP server. |
Required. |
Required if publickey authentication is configured for users and the clients directly send the public keys to the server for validity check. |
Configuring the PKI domain of the client certificate |
See "Configuring PKI." Required if publickey authentication is configured for users and the clients send the public keys to the server through digital certificates for validity check. The PKI domain must have the CA certificate to verify the client certificate. |
Required for publickey authentication users and optional for other authentication users. |
Optional. |
RSA key pairs are required for generating the session key and session ID in the key exchange stage, and are also used by a client to authenticate the server. When a client tries to communicate with a server, it compares the public key that it receives from the server with the server public key that it saved locally. If the keys are consistent, the client uses the locally saved server's public key to decrypt the digital signature received from the server. If the decryption succeeds, the server passes the authentication.
The public-key local create rsa command generates a server RSA key pair and a host RSA key pair. Each of the key pairs consists of a public key and a private key. The RSA server key pair is used only in SSH1 to encrypt the session key for secure transmission of the session key. It is not used in SSH2, because no session key transmission is required in SSH2.
To generate local RSA key pairs on the SSH server:
Step |
Command |
Remarks |
system-view |
N/A |
2. Generate RSA key pairs. |
public-key local create rsa |
By default, no RSA key pairs exist. |
The SSH server function on the device allows clients to communicate with the device through SSH.
When the device acts as an SCP server, only one SCP user is allowed to access to the SCP server at one time.
To enable the SSH server function:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable the SSH server function. |
ssh server enable |
Disabled by default. |
This SFTP server function enables clients to log in to the SFTP server through SFTP.
When the device functions as the SFTP server, only one client can access the SFTP server at one time.
To enable the SFTP server function:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the SFTP server function. |
sftp server enable |
An SSH client accesses the device through a VTY user interface. You must configure the user interfaces for SSH clients to allow SSH login. The configuration takes effect only for the clients logging in after the configuration.
IMPORTANT: Before you configure a user interface to support SSH, you must configure its authentication mode to scheme. Otherwise, the protocol inbound command fails. |
To configure the user interface for SSH clients:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter VTY user interface view. |
user-interface vty number [ ending-number ] |
N/A |
3. Set the login authentication mode to scheme. |
authentication-mode scheme |
By default, the authentication mode is password. |
4. Configure the user interface to support SSH login. |
protocol inbound { all | ssh } |
Optional. By default, Telnet and SSH are supported. |
For more information about the authentication-mode and protocol inbound commands, see Fundamentals Command Reference.
This configuration task is only necessary if publickey authentication is configured for users and the clients directly send the public key to the server for authentication.
During a publickey authentication for a client, the server first compares the SSH username and host public key received from the client with those saved locally. If they are the same, the server checks the digital signature that the client sends. The client generates the digital signature by using the private key that is paired with the client's host public key.
You must configure the client's RSA host public key on the server, and specify the associated host private key on the client to generate the digital signature, so that the client can pass publickey authentication with correct digital signature. If the device serves as a client, the associated host private key is specified by the specified public key algorithm.
You can manually configure the public key of an SSH client on the server, or import it from the public key file:
· Manual configuration—Type or copy the client host public key on the client to the SSH server. The host public key must be in the DER encoding format, which has not been converted.
· Importing from the public key file—Upload the client's host public key file (in binary) to the server (for example, through FTP or TFTP), and import the uploaded file to the server. During the import process, the server automatically converts the public key in the public key file to a string in PKCS format.
Manually configured client host public keys must be in the specified format. If you use the device to act as the client, you can use the display public-key local public command to view the host public key and copy its contents to the server. A host public key obtained in other ways might be in incorrect format and cannot be saved on the server. H3C recommends that you configure a client public key by importing it from a public key file.
You can configure up to 20 SSH client public keys on an SSH server.
Configuring a client public key manually
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter public key view. |
public-key peer keyname |
N/A |
3. Enter public key code view. |
public-key-code begin |
N/A |
4. Configure a client's host public key. |
Enter the content of the host public key |
Spaces and carriage returns are allowed between characters. |
5. Return to public key view and save the configured host public key. |
public-key-code end |
When you exit public key code view, the system automatically saves the public key. |
6. Return to system view. |
peer-public-key end |
N/A |
Importing a client public key from a public key file
Step |
Command |
system-view |
2. Import the public key from a public key file. |
public-key peer keyname import sshkey filename |
For more information about client public key configuration, see "Managing public keys."
Configuring an SSH user
To configure an SSH user that uses publickey authentication, you must perform the procedure in this section.
To configure an SSH user that uses password authentication, whether together with publickey authentication or not, you must configure a local user account by using the local-user command for local authentication, or configure an SSH user account on an authentication server, for example, a RADIUS server, for remote authentication.
For password-only SSH users, you do not need to perform the procedure in this section to configure them unless you want to use the display ssh user-information command to display all SSH users, including the password-only SSH users, for centralized management.
Configuration guidelines
· You can set the service type to Stelnet, SFTP, or SCP.
· You can enable one of the following authentication modes for the SSH user:
¡ Password—The user must pass password authentication.
¡ Publickey authentication—The user must pass publickey authentication.
¡ Password-publickey authentication—As an SSH2.0 user, the user must pass both password and publickey authentication. As an SSH1 user, the user must pass either password or publickey authentication.
¡ Any—The user can use either password authentication or publickey authentication.
· All authentication methods, except password authentication, require a client's host public key or digital certificate to be specified.
¡ If a client directly sends the user's public key information to the server, the server must specify the client's public key and the specified public key must already exist. For more information about public keys, see "Configuring a client's host public key."
¡ If a client sends the user's public key information to the server through a digital certificate, the server must specify the PKI domain for verifying the client certificate. For more information about configuring a PKI domain, see "Configuring PKI." To make sure the authorized SSH users pass the authentication, the specified PKI domain must have the proper CA certificate.
· If publickey authentication, whether with password authentication or not, is used, the command level accessible to the user is set by the user privilege level command on the user interface. If only password authentication is used, the command level accessible to the user is authorized by AAA.
· SSH1 does not support SFTP or SCP. For an SSH1 client, you must set the service type to stelnet or all.
· For an SFTP SSH user, the working folder depends on the authentication method:
¡ If only password authentication is used, the working folder is authorized by AAA.
¡ If publickey authentication, whether with password authentication or not, is used, the working folder is set by using the ssh user command.
· If you change the authentication mode or public key for an SSH user that has logged in, the change takes effect only at the next login of the user.
To configure an SSH user and specify the service type and authentication method:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an SSH user, and specify the service type and authentication method. |
type and authentication method for Stelnet users: ·
type and authentication method for all users, SCP or SFTP users: |
Use either command. |
The SSH management parameters can be set to improve the security of SSH connections. The SSH management parameters include:
· Compatibility between the SSH server and SSH1 clients.
· RSA server key pair update interval, applicable to users using SSH1 client.
· SSH user authentication timeout period. This parameter is used to reject a connection if the authentication for the connection is not completed before the timeout period expires.
· Maximum number of SSH authentication attempts. This parameter is used to prevent malicious password cracking.
· SFTP connection idle timeout period. Once the idle period of an SFTP connection exceeds the specified threshold, the system automatically tears the connection down.
To set the SSH management parameters:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable the SSH server to support SSH1 clients. |
ssh server compatible-ssh1x enable |
Optional. By default, the SSH server supports SSH1 clients. |
3. Set the RSA server key pair update interval. |
ssh server rekey-interval hours |
Optional. By default, the interval is 0, and the RSA server key pair is not updated. |
4. Set the SSH user authentication timeout period. |
ssh server authentication-timeout time-out-value |
Optional. 60 seconds by default. |
5. Set the maximum number of SSH authentication attempts. |
ssh server authentication-retries times |
Optional. 3 by default. Authentication fails if the number of authentication attempts (including both publickey and password authentication) exceeds the upper limit. |
6. Configure the SFTP connection idle timeout period. |
sftp server idle-timeout time-out-value |
Optional. 10 minutes by default. |
This section describes how to configure the device as an Stelnet client.
Task |
Remarks |
Specifying a source IP address or source interface for the Stelnet client |
Optional. |
Optional. |
Required. |
By default, an Stelnet client uses the IP address of the outbound interface specified by the route to the Stelnet server as the source IP address to communicate with the Stelnet server. You can change the source IP address or specify a source interface for the client.
To make sure the Stelnet client and the Stelnet server can communicate with each other, and to improve the manageability of Stelnet clients in the authentication service, H3C recommends that you specify a loopback interface as the source interface.
To specify a source IP address or source interface for the Stelnet client:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a source IP address or source interface for the Stelnet client. |
Specify a source IPv4 address or source interface for the Stelnet
client: ·
Specify a source IPv6 address or source interface for the Stelnet client: |
Use either approach. |
When the device works as an SSH client and connects to the SSH server, you can configure whether the device supports first-time authentication.
When a client not configured with the server host public key access the server for the first time:
· If first-time authentication is disabled, the client refuses to access the server. To enable the client to access the server, you must configure the server host public key locally and specify the public key name for authentication on the client in advance.
· If first-time authentication is enabled, the client accesses the server, and saves the host public key on the client. When accessing the server again, the client uses the saved server host public key to authenticate the server.
In a secure network, first-time authentication simplifies client configuration, but also brings some potential security risks.
Enabling first-time authentication
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable first-time authentication. |
ssh client first-time enable |
Optional. Enabled by default. |
Disabling first-time authentication
Step |
Command |
Remarks |
system-view |
N/A |
2. Disable first-time authentication. |
undo ssh client first-time |
3. Configure the server host public key. |
The method for configuring the server host public key on the client is similar to that for configuring client public key on the server. |
4. Specify the host public key name of the server. |
ssh client authentication server server assign publickey keyname |
N/A |
You can launch the Stelnet client to establish a connection to an Stelnet server, and specify the public key algorithm, the preferred encryption algorithm, the preferred HMAC algorithm, and the preferred key exchange algorithm.
To establish a connection to an Stelnet server:
Task |
Command |
Remarks |
Establish a connection to an Stelnet server. |
Establish a connection to an IPv4 server: ·
Establish a connection to an IPv6 server: |
Use either command in user view. |
This section describes how to configure the device as an SFTP client.
Task |
Remarks |
Specifying a source IP address or source interface for the SFTP client |
Optional. |
Optional. |
Required. |
Optional. |
Optional. |
Optional. |
Optional. |
By default, an SFTP client uses the IP address of the outbound interface specified by the route to the SFTP server as the source IP address to communicate with the SFTP server. You can change the source IP address or specify a source interface for the client.
To make sure the SFTP client and the SFTP server can communicate with each other, and to improve the manageability of SFTP clients in the authentication service, H3C recommends that you specify a loopback interface as the source interface.
To specify a source IP address or interface for the SFTP client:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a source IP address or interface for the SFTP client. |
Specify a source IPv4 address or interface for the SFTP client: ·
Specify a source IPv6 address or interface for the SFTP client: |
You can launch the SFTP client to establish a connection to an SFTP server, and specify the public key algorithm, the preferred encryption algorithm, preferred HMAC algorithm, and preferred key exchange algorithm.
After the connection is established, you can directly enter SFTP client view on the server to perform directory and file operations.
To establish a connection to an SFTP server:
Task |
Command |
Remarks |
Establish a connection to an SFTP server and enter SFTP client view. |
Establish a connection to an IPv4 SFTP server: ·
Establish a connection to an IPv6 SFTP server: |
Working with SFTP directories
SFTP directory operations include:
· Changing or displaying the current working directory
· Displaying files under a specified directory or the directory information
· Changing the name of a specified directory on the server
· Creating or deleting a directory
To work with the SFTP directories:
Step |
Command |
Remarks |
1. Enter SFTP client view. |
For more information, see "Establishing a connection to an SFTP server." |
N/A |
2. Change the working directory of the remote SFTP server. |
cd [ remote-path ] |
Optional. |
3. Return to the upper-level directory. |
cdup |
Optional. |
4. Display the current working directory on the SFTP server. |
pwd |
Optional. |
5. Display files under a specified directory. |
· dir [ -a | -l ] [ remote-path ] · ls [ -a | -l ] [ remote-path ] |
Optional. The dir command functions as the ls command. |
6. Change the name of a specified directory on the SFTP server. |
rename oldname newname |
Optional. |
7. Create a new directory on the SFTP server. |
mkdir remote-path |
Optional. |
8. Delete one or more directories from the SFTP server. |
rmdir remote-path&<1-10> |
Optional. |
Working with SFTP files
· Changing the name of a file
· Downloading a file
· Uploading a file
· Displaying a list of the files
· Deleting a file
To work with SFTP files:
Step |
Command |
Remarks |
N/A |
2. Change the name of a specified file on the SFTP server. |
rename old-name new-name |
Optional. |
3. Download a file from the remote server and save it locally. |
get remote-file [ local-file ] |
Optional. |
4. Upload a local file to the SFTP server. |
put local-file [ remote-file ] |
Optional. |
5. Display the files under a specified directory. |
6. Delete one or more directories from the SFTP server. |
· delete remote-file&<1-10> · remove remote-file&<1-10> |
Optional. The delete command functions as the remove command. |
Displaying help information
Use the help command to display all commands or the help information of an SFTP client command, including the command format and parameters.
To display all commands or the help information of an SFTP client command:
Step |
Command |
2. Display all commands or the help information of an SFTP client command. |
help [ all | command-name ] |
Step |
Command |
Remarks |
N/A |
2. Terminate the connection with the SFTP server and return to user view. |
· bye · exit · quit |
Use any of the commands. These three commands function in the same way. |
This section describes how to configure the device as an SCP client.
Task |
Remarks |
Optional. |
Required. |
Task |
Command |
Remarks |
Connect to the SCP server, and transfer files with the server. |
Upload a file to the SCP server: ·
Download a file from the SCP server: |
Task |
Command |
Remarks |
Display the source IP address or interface configured for the SFTP client. |
display sftp client source [ | { begin | exclude | include } regular-expression ] |
Available in any view. |
Display the source IP address or interface information configured for the Stelnet client. |
display ssh client source [ | { begin | exclude | include } regular-expression ] |
Display SSH server status information or session information on an SSH server. |
display ssh server { status | session } [ | { begin | exclude | include } regular-expression ] |
Display the mappings between SSH servers and their host public keys on an SSH client. |
display ssh server-info [ | { begin | exclude | include } regular-expression ] |
Display information about one or all SSH users on an SSH server. |
display ssh user-information [ username ] [ | { begin | exclude | include } regular-expression ] |
Display the public keys of the local key pairs. |
display public-key local rsa public [ | { begin | exclude | include } regular-expression ] |
Display the public keys of the SSH peers. |
display public-key peer [ brief | name publickey-name ] [ | { begin | exclude | include } regular-expression ] |
This section provides examples of configuring Stelnet.
Network requirements
As shown in Figure 1:
· The AP acts as the Stelnet server and uses password authentication.
· The username and password of the client are saved on the AP.
Establish an Stelnet connection between the client and the AP, so you can log in to the AP to configure and manage the AP.
Configuration procedure
1. Configure the Stelnet client:
a. Run PuTTYGen.exe, select SSH-2 RSA and click Generate.
Figure 2 Generating a key pair on the client
b. Keep moving the mouse during the key generating process, but do not place the mouse over the green progress bar shown in Figure 3. Otherwise, the progress bar stops moving and the key pair generating process stops.
c. After the key pair is generated, click Save public key to save the public key.
Figure 4 Saving a key pair on the client
d. Enter a file name (key.pub in this example), and click Save.
e. On the page as shown in Figure 4, click Save private key to save the private key.
A confirmation dialog box appears.
f. Click Yes.
A file saving window appears.
g. Enter a file name (private.ppk in this example), and click Save.
h. Transmit the public key file to the server through FTP or TFTP. (Details not shown.)
2. Configure the Stelnet server:
# Enable the SSH server function.
<AP> system-view
[AP] ssh server enable
# Configure an IP address for VLAN-interface 2. This address is the destination address of the SSH connection.
[AP] vlan2
[AP-vlan2] quit
[AP] interface vlan-interface 2
[AP-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[AP-Vlan-interface2] quit
# Set the authentication mode for the user interfaces to AAA.
[AP] user-interface vty 0 4
[AP-ui-vty0-4] authentication-mode scheme
# Set the protocol that a remote user uses for login as SSH.
[AP-ui-vty0-4] protocol inbound ssh
[AP-ui-vty0-4] quit
# Create a local user client001, set the password to aabbcc and specify the service type ssh for the user, and set the user command privilege level to 3.
[AP] local-user client001
[AP-luser-client001] password simple aabbcc
[AP-luser-client001] service-type ssh
[AP-luser-client001] authorization-attribute level 3
[AP-luser-client001] quit
# (Optional.) Create an SSH user client001. Specify the service type as stelnet and the authentication method as password for the user.
[AP] ssh user client001 service-type stelnet authentication-type password
3. Configuration the wireless service:
# Create a WLAN-BSS interface.
<AP> system-view
[AP] interface wlan-bss 1
# Set the link type to hybrid for WLAN-BSS 1, set the PVID of WLAN-BSS 1 to VLAN 2, and assign WLAN-BSS 1 to VLAN 2 as an untagged member.
[AP-WLAN-BSS1] port link-type hybrid
[AP-WLAN-BSS1] port hybrid pvid vlan 2
[AP-WLAN-BSS1] port hybrid vlan 2 untagged
[AP-WLAN-BSS1] quit
# Configure a clear type WLAN service template that adopts open-system authentication, and enable the template.
[AP] wlan service-template 1 clear
[AP-wlan-st-1] ssid service
[AP-wlan-st-1] authentication-method open-system
[AP-wlan-st-1] service-template enable
[AP-wlan-st-1] quit
# On WLAN-Radio 1/0/1, bind service template 1 to WLAN-BSS 1.
[AP] interface wlan-radio 1/0/1
[AP-WLAN-Radio1/0/1] radio-type dot11ac
[AP-WLAN-Radio1/0/1] service-template 1 interface wlan-bss 1
[AP-WLAN-Radio1/0/1] quit
4. Establish a connection with the Stelnet server:
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses an Stelnet client that runs PuTTY version 0.58.
To establish a connection with the Stelnet server:
a. Launch PuTTY.exe to enter the following interface, as shown in Figure 5.
Figure 5 Specifying the host name (or IP address)
b. In the Host Name (or IP address) field, enter the IP address of the server (192.168.1.40).
c. Click Open.
d. In the dialog box that appears, enter the correct username (client001) and password (aabbcc) to log in to the AP.
As shown in Figure 6, the AP acts as the Stelnet server, and it uses publickey authentication and the RSA public key algorithm.
Configuration considerations
In the server configuration, the client public key is required. Use the client software to generate RSA key pairs on the client before configuring the Stelnet server.
a. Launch PuTTYGen.exe, select SSH-2 RSA and click Generate.
Figure 7 Generating a key pair on the client
b. Keep moving the mouse during the key generating process, but do not place the mouse over the green progress bar shown in Figure 8. Otherwise, the progress bar stops moving and the key pair generating process stops.
Figure 9 Saving a key pair on the client
e. On the page as shown in Figure 9, click Save private key to save the private key.
f. Click Yes.
# Generate RSA key pairs.
<AP> system-view
[AP] public-key local create rsa
NOTES: If the key modulus is greater than 512,
It will take a few minutes.
Press CTRL+C to abort.
Input the bits of the modulus[default = 1024]:1024
Generating Keys...
[AP] vlan2
[AP-vlan2] quit
# Set the user command privilege level to 3.
[AP-ui-vty0-4] user privilege level 3
[AP-ui-vty0-4] quit
# Import the client's public key from file key.pub and name it AP001.
[AP] public-key peer AP001 import sshkey key.pub
# Create an SSH user client002. Specify service type as stelnet and the authentication type as publickey for the user, and assign the public key AP001 to the user.
[AP] ssh user client002 service-type stelnet authentication-type publickey assign publickey AP001
3. Establish a connection with the Stelnet server:
a. Launch PuTTY.exe to enter the following interface, as shown in Figure 10.
Figure 10 Specifying the host name (or IP address)
c. Select Connection > SSH > Auth from the navigation tree.
The window as shown in Figure 11 appears.
d. Click Browse… to bring up the file selection window, navigate to the private key file and click OK.
Figure 11 Specifying the private key file
e. In the window shown in Figure 11, click Open.
f. In the dialog box that appears, enter the correct username (client002) to log in to the AP.
As shown in Figure 12:
· The switch acts as the Stelnet server and uses password authentication.
· The username and password of the client are saved on the switch.
Establish an Stelnet connection between the AP and the switch, so you can log in to the switch to configure and manage the switch.
1. Configure the switch (the Stelnet server):
# Create RSA key pairs.
<Switch> system-view
[Switch] public-key local create rsa
[Switch] ssh server enable
# Assign an IP address to VLAN-interface 2, which the SSH client uses as the destination IP address for SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[Switch-Vlan-interface2] quit
[Switch] user-interface vty 0 4
[Switch-ui-vty0-4] authentication-mode scheme
[Switch-ui-vty0-4] protocol inbound ssh
[Switch-ui-vty0-4] quit
[Switch] local-user client001
[Switch-luser-client001] password simple aabbcc
[Switch-luser-client001] service-type ssh
[Switch-luser-client001] authorization-attribute level 3
[Switch-luser-client001] quit
# (Optional.) Create an SSH user client001. Specify the service type as stelnet and the authentication type as password for user.
[Switch] ssh user client001 service-type stelnet authentication-type password
2. Configure the AP (the Stelnet client):
<AP> system-view
[AP-Vlan-interface2] ip address 192.168.1.56 255.255.255.0
[AP] quit
¡ If the client support first-time authentication, you can directly establish a connection from the client to the server.
# Establish an SSH connection to server 192.168.1.40.
<AP> ssh2 192.168.1.40
Username: client001
Trying 192.168.1.40 ...
Press CTRL+K to abort
Connected to 192.168.1.40 ...
The Server is not authenticated. Continue? [Y/N]:y
Do you want to save the server public key? [Y/N]:n
Enter password:
After you enter the correct username, you can log into the switch successfully.
¡ If the client does not support first-time authentication, you must perform the following configurations.
# Disable first-time authentication.
[AP] undo ssh client first-time
# Configure the host public key of the SSH server. You can get the server host public key by using the display public-key local rsa public command on the server.
[AP] public-key peer key1
[AP-pkey-public-key] public-key-code begin
[AP-pkey-key-code]308201B73082012C06072A8648CE3804013082011F0281810
0D757262C4584C44C211F18BD96E5F0
[AP-pkey-key-code]61C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE
65BE6C265854889DC1EDBD13EC8B274
[AP-pkey-key-code]DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B0
6FD60FE01941DDD77FE6B12893DA76E
[AP-pkey-key-code]EBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B3
68950387811C7DA33021500C773218C
[AP-pkey-key-code]737EC8EE993B4F2DED30F48EDACE915F0281810082269009E
14EC474BAF2932E69D3B1F18517AD95
[AP-pkey-key-code]94184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD35D02
492B3959EC6499625BC4FA5082E22C5
[AP-pkey-key-code]B374E16DD00132CE71B020217091AC717B612391C76C1FB2E
88317C1BD8171D41ECB83E210C03CC9
[AP-pkey-key-code]B32E810561C21621C73D6DAAC028F4B1585DA7F42519718CC
9B09EEF0381840002818000AF995917
[AP-pkey-key-code]E1E570A3F6B1C2411948B3B4FFA256699B3BF871221CC9C5D
F257523777D033BEE77FC378145F2AD
[AP-pkey-key-code]D716D7DB9FCABB4ADBF6FB4FDB0CA25C761B308EF53009F71
01F7C62621216D5A572C379A32AC290
[AP-pkey-key-code]E55B394A217DA38B65B77F0185C8DB8095522D1EF044B465E
8716261214A5A3B493E866991113B2D
[AP-pkey-key-code]485348
[AP-pkey-key-code] public-key-code end
[AP-pkey-public-key] peer-public-key end
# Specify the host public key for the SSH server (192.168.1.40) as key1.
[AP] ssh client authentication server 192.168.1.40 assign publickey key1
[AP] quit
# Establish an SSH connection to the server 192.168.1.40.
Username: client001
Trying 192.168.1.40
Connected to 192.168.1.40..
Enter password:
After you enter the correct username and password, you can log in to the switch successfully.
As shown in Figure 13, the switch acts as the Stelnet server, and it uses publickey authentication and the RSA public key algorithm.
In the server configuration, the client public key is required. Generate RSA key pairs on the client before configuring the Stelnet server.
1. Configure the AP (the Stelnet client):
<AP> system-view
# Export the RSA public key to the file key.pub.
[AP] public-key local export rsa ssh2 key.pub
[AP] quit
# Transmit the public key file key.pub to the server through FTP or TFTP. (Details not shown.)
2. Configure the switch (the Stelnet server):
# Configure an IP address for VLAN-interface 2, which the SSH client uses as the destination for SSH connection.
[Switch-ui-vty0-4] user privilege level 3
# Import the peer public key from the file key.pub and name it AP001.
[Switch] public-key peer AP001 import sshkey key.pub
# Create an SSH user client002. Specify the authentication type as publickey for the user, and assign the public key AP001 to the user.
[Switch] ssh user client002 service-type stelnet authentication-type publickey assign publickey AP001
3. Establish an SSH connection to the server (192.168.1.40).
Username: client002
SFTP configuration examples
As shown in Figure 14:
· The AP acts as the SFTP server and uses password authentication.
Establish an SFTP connection between the client and the AP, so you can log in to the AP to manage and transfer files.
1. Configure the AP (the SFTP server):
# Enable the SFTP server function.
[Switch] sftp server enable
# Configure an IP address for VLAN-interface 2, which the SSH client uses as the destination IP address of the SSH connection.
[Switch-Vlan-interface2] ip address 192.168.0.1 255.255.255.0
# Set the authentication mode on the user interfaces to AAA.
# Create a local user client002, and set the password to aabbcc and specify the service type ssh for the user.
[AP] local-user client002
[AP-luser-client002] password simple aabbcc
[AP-luser-client002] service-type ssh
[AP-luser-client002] quit
# Create an SSH user client002. Specify the service type as sftp and the authentication method as password for the user.
[AP] ssh user client002 service-type sftp authentication-type password
2. Configure the client (the SFTP client):
There are many kinds of SFTP client software. The following takes the PSFTP of Putty Version 0.58 as an example. The PSFTP supports only password authentication.
To establish a connection with the remote SFTP server:
a. Run the psftp.exe to launch the client interface as shown in Figure 15, and enter the following command:
open 192.168.1.45
b. Enter username client002 and password aabbcc as prompted to log in to the SFTP server.
Figure 15 SFTP client interface
As shown in Figure 16, the switch acts as the SFTP server, and it uses publickey authentication and the RSA public key algorithm.
Establish an SFTP connection between the AP and the switch, so you can log in to the switch to manage and transfer files.
In the server configuration, the client public key is required. Generate RSA key pairs on the client before configuring the SFTP server.
1. Configure the AP (the SFTP client):
<AP> system-view
[AP-Vlan-interface2] ip address 192.168.0.2 255.255.255.0
# Export the host public key to file pubkey.
[AP] public-key local export rsa ssh2 pubkey
[AP] quit
# Transmit the public key file pubkey to the server through FTP or TFTP. (Details not shown.)
2. Configure the switch (the SFTP server):
# Configure an IP address for VLAN-interface 2, which the client uses as the destination for SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.45 255.255.255.0
# Set the authentication mode of the user interfaces to AAA.
# Import the peer public key from the file pubkey and name it AP001.
[Switch] public-key peer AP001 import sshkey pubkey
# Create an SSH user client001. Specify the service type sftp and the authentication method publickey for the user. Assign the public key AP001 and working folder flash:/ to the user.
[Switch] ssh user client001 service-type sftp authentication-type publickey assign publickey AP001 work-directory flash:/
3. Establish a connection to the SFTP server:
# Establish a connection to the remote SFTP server and enter SFTP client view.
<AP> sftp 192.168.0.1 identity-key rsa
Input Username: client001
Trying 192.168.0.1 ...
Connected to 192.168.0.1 ...
sftp-client>
# Display files under the current directory of the server, delete the file named z, and check if the file has been deleted successfully.
sftp-client> dir
-rwxrwxrwx 1 noone nogroup 1759 Aug 23 06:52 config.cfg
-rwxrwxrwx 1 noone nogroup 225 Aug 24 08:01 pubkey2
-rwxrwxrwx 1 noone nogroup 283 Aug 24 07:39 pubkey
drwxrwxrwx 1 noone nogroup 0 Sep 01 06:22 new
-rwxrwxrwx 1 noone nogroup 225 Sep 01 06:55 pub
-rwxrwxrwx 1 noone nogroup 0 Sep 01 08:00 z
sftp-client> delete z
The following File will be deleted:
/z
Are you sure to delete it? [Y/N]:y
This operation may take a long time.Please wait...
File successfully Removed
sftp-client> dir
# Add a directory named new1 and check if it has been created successfully.
sftp-client> mkdir new1
New directory created
sftp-client> dir
drwxrwxrwx 1 noone nogroup 0 Sep 02 06:30 new1
# Rename directory new1 to new2 and check if the directory has been renamed successfully.
sftp-client> rename new1 new2
File successfully renamed
sftp-client> dir
drwxrwxrwx 1 noone nogroup 0 Sep 02 06:33 new2
# Download the file pubkey2 from the server and change the name to public.
sftp-client> get pubkey2 public
Remote file:/pubkey2 ---> Local file: public
Downloading file successfully ended
# Upload the local file pu to the server, save it as puk, and check if the file has been uploaded successfully.
sftp-client> put pu puk
Local file:pu ---> Remote file: /puk
Uploading file successfully ended
sftp-client> dir
-rwxrwxrwx 1 noone nogroup 283 Sep 02 06:35 pub
-rwxrwxrwx 1 noone nogroup 283 Sep 02 06:36 puk
sftp-client>
# Terminate the connection to the remote SFTP server.
sftp-client> quit
Bye
Connection closed.
<AP>
SCP configuration example
As shown in Figure 17:
· The switch uses the password authentication method.
· The client's username and password are saved on the switch.
Establish an SCP connection between the AP and the switch, so you can log in to the switch to transfer files.
1. Configure the SCP server:
Generating Keys...
# Configure an IP address for VLAN-interface 2, which the client will use as the destination for SCP connection.
# Set the authentication mode of the user interface to AAA.
# Enable the user interface to support SSH.
# Create a local user named client001, and set the password to aabbcc and specify the service type ssh for the user.
# (Optional.) Create an SSH user client001. Specify the service type as scp and the authentication method password for the user.
[Switch] ssh user client001 service-type scp authentication-type password
2. Configure an IP address for VLAN-interface 2 on the SCP client:
<AP> system-view
[AP] quit
3. Connect to the SCP server, download the file remote.bin from the server, and save it locally with the name local.bin.
<AP> scp 192.168.0.1 get remote.bin local.bin
Username: client001
Enter password:
18471 bytes transfered in 0.001 seconds.
