| 07-Device Management Commands | 218.29 KB |
clock datetime
Use clock datetime to set the system time and date.
clock datetime time date
Default command level
3: Manage level
time: Specifies a time, in the hh:mm:ss format. The hh value ranges from 00 to 23, the mm value ranges from 00 to 59, and the ss value ranges from 00 to 59. Zeros can be omitted, unless you specify 00:00:00.
date: Specifies a date, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value ranges from 2000 to 2035, the MM value ranges from 1 to 12, and the DD value ranges from 1 to 31.
You can leave the ss field blank when you specify the time parameters.
# Set the current system time to 14:10:20 08/01/2005.
<Sysname> clock datetime 14:10:20 8/1/2005
# Set the current system time to 00:06:00 01/01/2007.
<Sysname> clock datetime 0:6 2007/1/1
· clock summer-time one-off
· clock summer-time repeating
· clock timezone
· display clock
Use clock summer-time one-off to adopt daylight saving time from the start-time of the start-date to the end-time of the end-date. Daylight saving time adds the add-time to the standard time of the device.
Use undo clock summer-time to cancel the configuration of the daylight saving time.
clock summer-time zone-name one-off start-time start-date end-time end-date add-time
Daylight saving time is disabled and the UTC time zone applies.
3: Manage level
zone-name: Specifies a daylight saving time schedule by a zone name, a case-sensitive string of 1 to 32 characters.
start-time: Specifies a start time, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
start-date: Specifies a start date, in the MM/DD/YYYY or YYYY/MM/DD format.
end-time: Specifies an end time, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
end-date: Specifies an end date, in the MM/DD/YYYY or YYYY/MM/DD format.
add-time: Specifies a time to be added to the standard time of the device, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
The interval between start-time start-date and end-time end-date must be longer than one day and shorter than one year. If the current system time is in the specified daylight saving days, the add-time value automatically adds to the system time.
To verify the setting, use the display clock command.
The timestamps in system messages are adjusted in reference to the time zone and daylight saving schedule.
# Set the system time ahead one hour for the period between 06:00:00 on 08/01/2011 and 06:00:00 on 09/01/2011.
[Sysname] clock summer-time abc1 one-off 6 08/01/2011 6 09/01/2011 1
· clock datetime
· clock timezone
· display clock
Use clock summer-time repeating to set a recurring daylight saving schedule.
clock summer-time zone-name repeating start-time start-date end-time end-date add-time
Daylight saving time is disabled and UTC time zone applies.
3: Manage level
start-date: Specifies a start date, which can be set in the following ways:
· Enter the year, month and date at one time, in the MM/DD/YYYY or YYYY/MM/DD format.
· Enter the year, month and date one by one, separated by spaces. The year ranges from 2000 to 2035; the month can be January, February, March, April, May, June, July, August, September, October, November or December; the start week can be the first, second, third, fourth, fifth or last week of the month; the start date is Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday.
end-date: Specifies an end date, which can be set in the following ways:
· Enter the year, month and date one by one, separated by spaces. The year ranges from 2000 to 2035; the month can be January, February, March, April, May, June, July, August, September, October, November or December; the end week can be the first, second, third, fourth, fifth or last week of the month; the end date is Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday.
# Set the system time ahead one hour every year after 2011 (inclusive) for the period from August 1 at 06:00:00 to September 1 at 06:00:00.
[Sysname] clock summer-time abc2 repeating 06:00:00 08/01/2011 06:00:00 09/01/2011 01:00:00
· clock datetime
· clock timezone
· display clock
clock timezone
Use clock timezone to set the local time zone.
Use undo clock timezone to restore the local time zone to the default UTC time zone.
undo clock timezone
The local time zone is UTC zone.
3: Manage level
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds a specified offset to UTC.
minus: Subtracts a specified offset to UTC.
zone-offset: Specifies an offset to the UTC, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
# Set the local time zone to add five hours to UTC time.
[Sysname] clock timezone z5 add 5
· clock datetime
· display clock
configure-user count
Use configure-user count to configure the maximum number of users allowed to enter system view at the same time.
Use undo configure-user count to restore the default.
configure-user count number
2: System level
number: Specifies the maximum number of concurrent users, in the range of 1 to 6.
Two users are allowed to enter system view by default.
When multiple users enter system view to configure certain attribute, only the last configuration applies.
When the number of users has already reached the limit, other users can not enter system view.
# Configure to allow up to four users to enter system view concurrently.
[Sysname] configure-user count 4
display configure-user
copyright-info enable
Use copyright-info enable to enable displaying the copyright statement.
Use undo copyright-info enable to disable displaying the copyright statement.
This feature is enabled.
3: Manage level
# Enable displaying the copyright statement.
[Sysname] copyright-info enable
· When a Telnet user logs in, the following statement appears:
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<Sysname>
· When a console user quits user view, the following message appears:
User interface con0 is available.
Please press ENTER.
# Disable displaying the copyright statement.
[Sysname] undo copyright-info enable
· When a Telnet user logs in, the user view prompt appears:
<Sysname>
Please press ENTER.
display clock
Use display clock to display the system time and date.
display clock [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
The current system time and date are decided by the clock datetime, clock summer-time one-off, or clock summer-time repeating, and clock timezone commands. For more information about how the system time and date are decided, see Fundamentals Configuration Guide.
# Display the system time and date.
<Sysname> display clock
09:41:23 UTC Thu 12/15/2005
· clock datetime
· clock timezone
Use display configure-user to display the users that have logged in to the device but are not in user view.
display configure-user [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the users that have logged into the system but are not in user view.
<Sysname> display configure-user
The information of current configuration user(s):
Idx UI Delay Type Userlevel
+ 178 VTY 0 01:10:16 TEL 3
+ 179 VTY 1 00:00:00 TEL 3
Following are more details.
VTY 0 :
VTY 1 :
+ : User-interface is active.
F : User-interface is active and work in async mode.
The information of current configuration user(s) |
Information of the users that have logged in and are not in user view. |
Idx |
Absolute ID of the user interface. |
UI |
Type and relative ID of the user interface that the user used for login. |
Delay |
Delay between the last CLI input and the execution of the display configure-user command, in the format hh:mm:ss. |
Type |
User type, Telnet or SSH. |
Userlevel |
User level, level 0 (visit level), level 1 (monitor level), level 2 (system level), or level 3 (manage level). |
Following are more details. |
Detailed information about the login user. |
Location |
IP address of the login user. |
+ : User-interface is active. |
User interface that is being used. |
F : User-interface is active and work in async mode. |
User interface that is being used and operating in asynchronous mode. |
display copyright
Use display copyright to display the software and hardware copyright statements.
display copyright [ | { begin | exclude | include } regular-expression ]
1: Monitor level
With this command, you can view the software and hardware copyright statements, and third-party software license agreements.
# Display the software and hardware copyright statements. (The output is omitted here.)
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display CPU usage statistics.
display cpu-usage [ entry-number [ offset ] [ verbose ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
entry-number: Number of entries to be displayed, which ranges from 1 to 60.
offset: Offset between the serial number of the first CPU usage rate record to be displayed and that of the last CPU usage rate record to be displayed. It ranges from 0 to 59.
For example, the idx of the latest statistics record is 12. If the offset is set to 3, the system will display the statistics records from the one with the idx of 9, where idx represents the serial number of the period for the statistics, and its value ranges from 0 to 60 cyclically. The system collects CPU usage rates periodically, and the system records the average CPU usage rate during this period, and the idx value is added by 1 automatically.
verbose: Displays the average CPU usage statistics for each task in the specified period. If this keyword is not provided, this command displays the brief information of the CPU usage statistics.
The system regularly (typically at 60-second intervals) collects CPU usage statistics and saves the statistical results in the history record area. The maximum number of records that can be saved depends on your device model.
The display cpu-usage entry-number command displays entry-number latest records, starting from the latest record. The display cpu-usage entry-number offset command displays number latest records, starting from the last (offset+1)th record.
# Display the current CPU usage statistics.
<Sysname> display cpu-usage
Unit CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
Unit CPU usage |
CPU usage rates. |
1% in last 5 seconds |
After a boot, the system calculates and records the average CPU usage rate every five seconds. This field displays the average CPU usage rate in the last five seconds. |
1% in last 1 minute |
After a boot, the system calculates and records the average CPU usage rate every one minute. This field displays the average CPU usage rate in the last minute. |
1% in last 5 minutes |
After a boot, the system calculates and records the average CPU usage rate every five minutes. This field displays the average CPU usage rate in the last five minutes. |
display cpu-usage history
Use display cpu-usage history to display historical CPU usage statistics in charts.
display cpu-usage history [ task task-id ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
task task-id: Displays the historical CPU usage statistics for the specified task, where task-id represents the task number. If the task-id argument is not provided, this command displays the historical CPU usage statistics for the entire system (the CPU usage rates of the entire system is the sum of CPU usage rates of all tasks).
If no argument is provided, this command displays the historical CPU usage statistics for the whole system.
The system regularly collects CPU usage statistics and saves the statistics in the history record area. The display cpu-usage history command displays the CPU usage statistics for the last 60 minutes in axes, where:
· The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step, whichever is closer. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
· The horizontal axis represents the time.
· Consecutive pound signs (#) indicate the CPU usage at a specific time. The value on the vertical axis for the topmost # sign at a specific time represents the CPU usage at that time.
# Display historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage last 60 minutes(SYSTEM)
The output shows the historical CPU usage statistics (with the task name SYSTEM) in the last 60 minutes:
· 5%: 12 minutes ago
· 10%: 13 minutes ago
· 15%: 14 minutes ago
· 10%: 15 minutes ago
· 5%: 16 and 17 minutes ago
· 10%: 18 minutes ago
· 5%: 19 minutes ago
· 2% or lower than 2%: other time
display device
Use display device to display device information.
display device [ verbose ] [ | { begin | exclude | include } regular-expression ]
2: System level
verbose: Displays detailed information.
# Display device information.
<Sysname> display device
Slot No. Board Type Status Max Ports
1 WA4620i-ACN Board Normal 5
Status |
Status: · Fault—Cannot start normally because an error occurred. · Normal—Operating normally. |
Table 4 Max Ports |
Table 5 Maximum number of physical ports supported. |
display device manuinfo
Use display device manuinfo to display the electronic label data for the device.
display device manuinfo [ | { begin | exclude | include } regular-expression ]
3: Manage level
An electronic label is a profile of a device and contains the permanent configuration including the serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during debugging or testing.
This command displays part of the electronic label data.
# Display the electronic label data for the device.
<Sysname> display device manuinfo
DEVICE_NAME:WA4620i-ACN
DEVICE_SERIAL_NUMBER:210236A35VA10A482300
MAC_ADDRESS: 70F9-6DFB-1300
MANUFACTURING_DATE:2012-05-24
VENDOR_NAME:H3C
display diagnostic-information
Use display diagnostic-information to display or save running status data for multiple feature modules.
display diagnostic-information [ | { begin | exclude | include } regular-expression ]
1: Monitor level
For diagnosis or troubleshooting, you can use separate display commands to collect running status data module by module, or use the display diagnostic-information command to bulk collect running data for multiple modules.
# Save running status data for multiple feature modules.
Save or display diagnostic information (Y=save, N=display)?[Y/N]y
Please input the file name(*.diag)[flash:/default.diag]:aa.diag
Diagnostic information is outputting to flash:/aa.diag.
Please wait...
Save succeeded.
To view the content of file aa.diag, execute the more.aa.diag command in user view, in combination of the Page Up and Page Down keys.
# Display running status data for multiple feature modules.
08:54:16 UTC Fri 11/15/2008
display environment
Use display environment to display temperature information, including the current temperature and temperature thresholds of cards.
display environment [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display temperature information.
<Sysname> display environment
System Temperature information (degree centigrade):
SlotNo Temperature Lower limit Upper limit
1 35 5 70
display job
Use display job to display information about scheduled jobs configured by using the job command.
display job [ job-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
job-name: Specifies the job name, which is a string of 1 to 32 characters.
If no job is specified, this command displays information about all scheduled jobs.
# Display detailed information about the scheduled job saveconfig.
<Sysname> display job saveconfig
Job name: saveconfig
Specified view: monitor
Time 1: Execute command save 1.cfg after 40 minutes
The output shows that the current configuration will be automatically saved to the configuration file 1.cfg in 40 minutes.
Table 6 Command output
Job name |
Name of the scheduled job. |
Specified view |
View containing the commands in the job. |
Time timeID |
Execution time of each command in the job. |
Execute command |
Command string. |
· job
· time
· view
display memory
Use display memory to display memory usage statistics.
display memory [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display memory usage statistics.
<Sysname> display memory
System Total Memory(bytes): 187547920
Total Used Memory(bytes): 57525268
Used Rate: 30%
Table 7 Command output
System Total Memory(bytes) |
Total size of the system memory (in bytes) |
Total Used Memory(bytes) |
Size of the memory used (in bytes) |
Used Rate |
Percentage of the memory used to the total memory. |
display reboot-type
Use display reboot-type to display the mode of the last reboot.
display reboot-type [ | { begin | exclude | include } regular-expression ]
2: System level
# Display the mode of the last reboot.
<Sysname> display reboot-type
The rebooting type this time is: Cold
The output shows that the last reboot mode is Cold boot (cold boot will restart a device by powering it on). (The display of Warm represents a warm boot, which means to restart a device by using the commands like reboot).
display schedule job
Use display schedule job to display the job configured by using the schedule job command.
display schedule job [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the configuration of the job configured by using the schedule job command.
<Sysname> display schedule job
Specified command: execute 1.bat
Specified view: system view
Executed time: at 12:00 10/31/2007 (in 0 hours and 16 minutes)
If you change the system time within 16 minutes after you execute the schedule job command, the scheduled task becomes invalid. Then, if you execute the display schedule job command again, the command displays nothing.
Table 8 Command output
Specified command |
Command to be executed. |
Specified view |
View for the command to be executed. |
Executed time |
Execution time of the command and the difference between the current system time and scheduled time. |
schedule job
display schedule reboot
Use display schedule reboot to display the reboot schedule.
display schedule reboot [ | { begin | exclude | include } regular-expression ]
3: Manage level
# Display the reboot schedule.
<Sysname> display schedule reboot
System will reboot at 16:00:00 03/10/2006 (in 2 hours and 5 minutes).
· schedule reboot at
· schedule reboot delay
display system-failure
Use display system-failure to display the exception handling method.
display system-failure [ | { begin | exclude | include } regular-expression ]
3: Manage level
# Display the exception handling method.
<Sysname> display system-failure
System failure handling method: reboot
system-failure
display version
Use display version to display system version information, including the system software version, chassis model, and basic MPU and interface card data.
display version [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display system version information.
<Sysname> display version
header
Use header to create a banner.
Use undo header to clear a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
2: System level
legal: Configures the banner displayed before a user inputs the username and password to access the CLI.
login: Configures the banner displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner displayed before the legal banner appears.
shell: Configures the banner displayed before a user accesses user view.
text: Banner message, which can be input in two formats. For more information, see Fundamentals Configuration Guide.
Banners are greeting or alert messages that the system displays during the login process of a user.
# Configure banners.
[Sysname] header legal %
Welcome to incoming(header incoming)%
Welcome to legal (header legal)%
[Sysname] header login %
Welcome to login(header login)%
[Sysname] header motd %
Welcome to motd(header motd)%
[Sysname] header shell %
Welcome to shell(header shell)%
In this example, the percentage sign (%) is the starting and ending characters of text. Entering % after the displayed test quits the header command. As the starting and ending characters, % is not part of the banners.
# Verify the configuration by using Telnet. (The login authentication is not configured.)
Press Y or ENTER to continue, N to exit.
<Sysname>
# Verify the configuration by using Telnet. (Password authentication is configured.)
Login authentication
Password:
<Sysname>
job
Use job to create a job or enter job view.
Use undo job to delete a scheduled job.
job job-name
undo job job-name
No job is created.
3: Manage level
job-name: Specifies the name for a job, a string of 1 to 32 characters.
You can add commands in job view to execute at certain times.
You can use the job command to create multiple jobs.
# Create the job saveconfiguration or enter its view.
[Sysname] job saveconfiguration
[Sysname-job-saveconfiguration]
· time
· view
reboot
Use reboot to reboot the device.
reboot
3: Manage level
CAUTION: · Device reboot can interrupt network services. · If the main system software image file has been corrupted or does not exist, the device cannot reboot. You must re-specify a main system software image file, or power off the device and then power it on so the system can reboot with the backup system software image file. |
For data security, if you are performing file operations at the reboot time, the system does not reboot.
# Reboot the device.
<Sysname> reboot
reset unused porttag
Use reset unused porttag to clear unused 16-bit interface indexes.
1: Monitor level
A confirmation is required when you execute this command. The command will not run if you enter N to cancel the operation or fail to make a confirmation within 30 seconds.
# Clear unused 16-bit interface indexes.
<Sysname> reset unused porttag
Current operation will delete all unused port tag(s). Continue? [Y/N]:y
<Sysname>
schedule job
Use schedule job to schedule a job in the non-modular approach.
Use undo schedule job to remove the scheduled job.
schedule job { at time1 [ date ] | delay time2 } view view-name command
3: Manage level
at time1 [ date ]: Specifies the time and/or date to execute a command.
· time1: Sets time to execute the command, in the hh:mm format. The hh value ranges from 0 to 23, and the mm value ranges from 0 to 59.
· date: Sets the date to execute the command, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value ranges from 2000 to 2035, the MM value ranges from 1 to 12, and the DD value ranges from 1 to 31.
delay time2: Runs the job after a delay. The time2 argument specifies the delay in one of the following formats:
· hh:mm format—The hh value ranges from 0 to 720, and the mm value ranges from 0 to 59. When the hh value is 720, the mm value cannot be more than 0.
· mm format—It ranges from 0 to 432000 minutes, with 0 indicating that the command is executed immediately.
view view: Specifies the view in which the command is executed. The view argument represents the view name, and it can take only one of the following keywords:
· shell—Represents user view.
· system—Represents system view.
command: Command to execute.
You can schedule a job to automatically run a command or a set of commands without administrative interference. The commands in a job are polled every minute. When the scheduled time for a command is reached, the job automatically executes the command. If a confirmation is required while the command is running, the system automatically enters Y or Yes. If characters are required, the system automatically enters a default character string or an empty character string when no default character string is available.
Follow these guidelines when you schedule a job in the non-modular approach:
· You can schedule only one job and run only one command in this approach. If you perform the schedule job command multiple times, the last configuration takes effect.
· To have the command successfully executed, check that the specified view and command are valid. The system does not verify their validity.
· If you specify both the time1 and date arguments, the execution time or date must be later than the current system time or date.
· If you specify the time1 argument, but not the date argument:
? When time1 is earlier than the current system time, the command runs at time1 the next day.
? When time1 is later than the current system time, the command runs at time1 of the current day.
· The interval between the scheduled time and the current system time cannot exceed 720 hours, or 30 days.
· Changing any clock setting can cancel the job set by using the schedule job command.
· After job execution, the configuration interface, view, and user status that you have before job execution restore even if the job has run a command that changes the user interface (for example, telnet, ftp, and ssh2), the view (for example, system-view and quit), or the user status (for example, super).
# Schedule a job to execute the batch file 1.bat in system view in 60 minutes (assuming that the current time is 11:43).
<Sysname> schedule job delay 60 view system execute 1.bat
Info: Command execute 1.bat in system view will be executed at 12:43 10/31/2007 (in 1 hours and 0 minutes).
# Schedule a job to execute the batch file 1.bat in system view at 12:00 (assuming that the current time is 11:43).
<Sysname> schedule job at 12:00 view system execute 1.bat
Info: Command execute 1.bat in system view will be executed at 12:00 10/31/2007 (in 0 hours and 16 minutes).
schedule reboot at
Use schedule reboot at to schedule a device reboot to occur at a specific time and date.
Use undo schedule reboot to disable the scheduled reboot function.
schedule reboot at hh:mm [ date ]
The scheduled reboot function is disabled.
3: Manage level
hh:mm: Specifies a reboot time, in the hh:mm format. The hh value ranges from 0 to 23, and the mm value ranges from 0 to 59.
date: Specifies a reboot date, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value ranges from 2000 to 2035, the MM value ranges from 1 to 12, and the DD value ranges from 1 to 31.
CAUTION: · Device reboot can interrupt network services. · Changing any clock setting can cancel the reboot schedule. |
The interval between the reboot date and the current date cannot exceed 30 x 24 hours, or 30 days.
When no reboot date is specified:
· If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
· If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you configure the schedule reboot at command multiple times, the last configuration takes effect. The schedule reboot at command and the schedule reboot delay command overwrite each other, and whichever is configured last takes effect.
The alert "REBOOT IN ONE MINUTE" appears one minute before the reboot time.
# Configure the switch to reboot at 12:00 AM. This example assumes that the current time is 11:43.
<Sysname> schedule reboot at 12:00
Reboot system at 12:00 06/06/2006(in 0 hour(s) and 16 minute(s))
confirm? [Y/N]:
Enter y at the prompt. If you have used the terminal logging command to enable the log display function (enabled by default) on the terminal, the system automatically displays a reboot schedule log message.
<Sysname>
%Jun 6 11:43:11:629 2006 Sysname CMD/4/REBOOT:
vty0(192.168.1.54): Set schedule reboot parameters at 11:43:11 06/06/2006, and system will reboot at 12:00 06/06/2006.
Use schedule reboot delay to schedule a device reboot to occur after a delay.
schedule reboot delay { hh:mm | mm }
3: Manage level
hh:mm: Specifies a delay for the device reboot, in the hh:mm format. The hh value ranges from 0 to 720, and the mm value ranges from 0 to 59. When the hh value is 720, the mm value cannot be more than 0.
mm: Specifies a delay for the device reboot in minutes, which ranges from 0 to 43200.
The reboot delay cannot exceed 30 x 24 x 60 minutes, or 30 days.
The device supports only one device reboot schedule. If you configure the schedule reboot delay command multiple times, the last configuration takes effect. The schedule reboot at command and the schedule reboot delay command overwrite each other, and whichever is configured last takes effect.
# Schedule a device reboot in 88 minutes. This example assumes that the current time is 11:48 on June 6, 2006.
<Sysname> schedule reboot delay 88
Reboot system at 13:16 06/06/2006(in 1 hour(s) and 28 minute(s)). confirm? [Y/N]:
<Sysname>
%Jun 6 11:48:44:860 2006 Sysname CMD/4/REBOOT:
vty0(192.168.1.54): Set schedule reboot parameters at 11:48:44 06/06/2006, and system will reboot at 13:16 06/06/2006.
schedule reboot at
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is the device model name.
2: System level
sysname: Name of the device, which is a string of 1 to 64 characters.
A device name identifies a device in a network and works as the user view prompt at the CLI. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
system-failure
Use system-failure to configure the exception handling method.
Use undo system-failure to restore the default.
system-failure { maintain | reboot }
undo system-failure
The system adopts the reboot method to handle exceptions.
3: Manage level
maintain: Specifies that when the system detects any software abnormality, it maintains the current situation, and does not take any measure to recover itself.
reboot: Specifies that when the system detects any software abnormality, it recovers itself through automatic reboot.
# Set the exception handling method to reboot.
[Sysname] system-failure reboot
time at
Use time at to add a command to run at a specific time and date in the job schedule.
Use undo time to remove a command from the job schedule.
time time-id at time date command command
time time-id { one-off | repeating } at time [ month-date month-day | week-day week-daylist ] command command
undo time time-id
Job view
3: Manage level
time timeid: Time setting entry, an integer that ranges from 1 to 10.
at time: Specifies an execution time, in the hh:mm format, where the hh value ranges from 0 to 23 and the mm value ranges from 0 to 59.
one-off: Specifies that the specified command is executed for once.
repeating: Specifies a recurring time schedule.
date: Specifies an execution date, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value ranges from 2000 to 2035, the MM value ranges from 1 to 12, and the DD value ranges from 1 to 31. The specified execution date must be ahead of the current date.
month-date month-day: Specifies the date for executing the command. month-day specifies the date, and ranges from 1 to 31.
week-day week-daylist: Specifies the day or days for executing the command. The week-daylist argument specifies one day or up to seven days, which can be any combination of Sun, Mon, Tue, Wed, Thu, Fri, and Sat. For example, to have a command executed on Monday, you can enter week-day Mon; to have a command executed on Friday and Saturday, enter week-day Fri Sat. Use a space between every two days for separation.
command command: Specifies the command to be automatically executed, in the text format. The command must be executable in the view specified by the view command. Otherwise this command cannot be automatically executed. Therefore, ensure the correctness of the configuration.
The commands in a job must be in the same view.
Every job can have up to 10 commands.
The time ID (time-id) must be unique in a job. If two time and command bindings have the same time ID, the one configured last takes effect.
Changing a clock setting does not affect the schedule set by using the time at command.
Use Table 9 when you add commands in a job.
Table 9 Command schedule options
Command |
time timeid at time date command command |
Schedules a command to run at a specific time and date. The time or date must be later than the current system time or date. |
time timeid one-off at time command command |
Schedules a command to run at a specific time on the current day. If the specified time has passed, the command runs the next day. The command runs only once. |
time timeid one-off at time month-date month-day command command |
Schedules a command to run at a specific day in the current month. If the specified time or day has passed, the command runs in the next month. The command runs only once. |
time timeid one-off at time week-day week-daylist command command |
Schedules a command to run at a specific time on a specific day or days in the current week. If the specified time or day has passed, the command runs in the next week. The command runs only once. |
time timeid repeating at time command command |
Schedules a command to run at a specific time every day. |
time timeid repeating at time month-date month-day command command |
Schedules a command to run on a specific day every month. |
time timeid repeating at time week-day week-daylist command command |
Schedules a command to run at a specific time in a specific day or days every week. |
# Schedule a job to save the configuration file a.cfg at 3:00 on May 18, 2009.
[Sysname-job-saveconfig] view monitor
[Sysname-job-saveconfig] time 1 at 3:00 2009/05/18 command save a.cfg
# Schedule a job to save the configuration file at 12:00 every day.
[Sysname-job-saveconfig] time 1 repeating at 12:00 command save a.cfg
# Schedule a job to save the configuration file at 8:00 AM on 5th in the current month, which might be executed in the second month if the time has passed.
[Sysname-job-saveconfig] time 1 one-off at 8:00 month-date 5 command save a.cfg
# Schedule a job to save the configuration file at 8:00 AM on 5th every month.
[Sysname-job-saveconfig] time 1 repeating at 8:00 month-date 5 command save a.cfg
# Schedule a job to save the configuration file at 8:00 AM on Friday and Saturday in the current week, which might be delayed to the next week if the time has passed.
[Sysname-job-saveconfig] time 1 one-off at 8:00 week-day fri sat command save a.cfg
# Schedule a job to save the configuration file at 8:00 every Fridays and Saturdays.
[Sysname-job-saveconfig] time 1 repeating at 8:00 week-day fri sat command save a.cfg
· job
· view
time delay
Use time delay to add a command to run after a delay in the job schedule.
time time-id { one-off | repeating } delay time command command
undo time time-id
Job view
3: Manage level
delay time: Specifies the delay time for executing the command, in the hh:mm format or mm format.
· When the time argument is in the hh:mm format, the hh value ranges from 0 to 720, and the mm value ranges from 0 to 59. When the hh value is 720, the mm value can be only 00.
· When the time argument is in the mm format, the mm value ranges from 1 to 43,200. That is, the maximum value of the delay timer is 30 days.
command command: Specifies the command to be automatically executed, in the text format. The specified command must be a complete command without interactive input.
The commands in a scheduled job must be in the same view.
Changing a clock setting does not affect the schedule set by using the time delay command.
Use Table 10 when you add commands in a job.
Table 10 Command schedule options
Command |
time timeid one-off delay time2 command command |
Schedules a command to run after a delay time. The command runs only once. |
time timeid repeating delay time2 command command |
Schedules a command to run every the delay time. |
NOTE: · The commands in a scheduled job must be in the same view. · Every job can have up to 10 commands. · The time ID (time-id) must be unique in a job. If two time and command bindings have the same time ID, the one configured last takes effect. · Changing a clock setting does not affect the schedule set by using the time delay command. |
# Save the configuration file five minutes later.
[Sysname-job-saveconfig] time 1 one-off delay 5 command save a.cfg
# Save the configuration file every five minutes.
[Sysname-job-saveconfig] time 1 repeating delay 5 command save a.cfg
· job
· view
view
Use view to specify a view for a job.
Use undo view to remove the view of a job.
view view-name
undo view
No view is specified for a job.
Job view
3: Manage level
view-name: Specifies a view in which commands in the job run. A view name is a string of 1 to 90 characters.
Every job can have only one view. If you specify multiple views, the one specified the last takes effect.
Enter a view name in its complete form and make sure the view name is available on the device. Most commonly used view names include monitor for user view, system for system view, GigabitEthernetx/x/x for Ethernet interface view, and Vlan-interfacex for VLAN interface view.
# Specify system view for the job creatvlan.
[Sysname] job creatvlan
[Sysname-job-creatvlan] view system
· job
· time
