| 00-Preface | 99.23 KB |
The H3C Access Points documentation set includes eight command references. These references describe the commands and command syntax options available for the H3C Access Points.
NOTE: The interface types and output information might vary by device model. |
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C Access Points
Conventions
This section describes the conventions used in the documentation.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card. |
Documentation feedback
We appreciate your comments.
