| 00-Preface | 88.07 KB |
Preface
The H3C WA4320X Access Points Installation Guide guides you through the installation of your AP. It covers product overview, preparing for installation, installing the AP, logging in to the AP, and LEDs and ports.
This preface includes:
· Audience
· About the H3C WA4320X access controller documentation set
Audience
· Network planners.
· Network administrators working with the WA4320X APs.
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card. |
Port numbering in examples
The port numbers in the documentation are for illustration only and might be unavailable on your device.
The H3C WA4320X access controller documentation set includes the following categories of documents:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Hardware specifications and installation |
Compliance and safety manual |
Provides regulatory information and the safety instructions that must be followed during installation. |
Installation guide |
Provides a complete guide to hardware installation and hardware specifications. |
H3C Pluggable SFP [SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Configuration examples |
Describe typical network scenarios and provide configuration examples and instructions. |
Operations and maintenance |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the following links to obtain different categories of product documentation:
[Technical Support > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support > Software Download] – Provides the documentation released with the software version.
Technical support
Documentation feedback
We appreciate your comments.
