12-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810 2600 3600 Routers Configuration Guides(V7)-R0707-6W30112-Security Configuration Guide
25-ARP attack protection configuration
25-ARP attack protection configuration 207.39 KB
Configuring ARP attack protection· 1
About ARP attack protection· 1
ARP attack protection tasks at a glance· 1
Configuring unresolvable IP attack protection· 1
About unresolvable IP attack protection· 1
Configuring ARP source suppression· 2
Configuring ARP blackhole routing· 2
Display and maintenance commands for unresolvable IP attack protection· 2
Example: Configuring unresolvable IP attack protection· 3
Configuring source MAC-based ARP attack detection· 4
About source MAC-based ARP attack detection· 4
Restrictions and guidelines· 4
Procedure· 4
Display and maintenance commands for source MAC-based ARP attack detection· 5
Example: Configuring source MAC-based ARP attack detection· 5
Configuring ARP packet source MAC consistency check· 6
Configuring ARP active acknowledgement 6
Configuring authorized ARP· 7
About authorized ARP· 7
Procedure· 7
Example: Configuring authorized ARP on a DHCP server 7
Example: Configuring authorized ARP on a DHCP relay agent 8
Configuring ARP attack detection· 9
About ARP attack detection· 9
Hardware compatibility with ARP attack detection· 10
Configuring user validity check· 10
Configuring ARP packet validity check· 11
Configuring ARP restricted forwarding· 12
Display and maintenance commands for ARP attack detection· 13
Example: Configuring user validity check· 13
Example: Configuring user validity check and ARP packet validity check· 15
Example: Configuring ARP restricted forwarding· 16
Configuring ARP scanning and fixed ARP· 18
Configuring ARP gateway protection· 19
About ARP gateway protection· 19
Restrictions and guidelines· 19
Procedure· 19
Configuring ARP filtering· 19
ARP filtering· 19
Procedure· 20
The device can provide multiple features to detect and prevent ARP attacks and viruses in the LAN. An attacker can exploit ARP vulnerabilities to attack network devices in the following ways:
·     Sends a large number of unresolvable IP packets to have the receiving device busy with resolving IP addresses until its CPU is overloaded. Unresolvable IP packets refer to IP packets for which ARP cannot find corresponding MAC addresses.
·     Sends a large number of ARP packets to overload the CPU of the receiving device.
·     Acts as a trusted user or gateway to send ARP packets so the receiving devices obtain incorrect ARP entries.
All ARP attack protection tasks are optional.
·     Preventing flood attacks
¡     Configuring unresolvable IP attack protection
¡     Configuring source MAC-based ARP attack detection
·     Preventing user and gateway spoofing attacks
¡     Configuring ARP packet source MAC consistency check
¡     Configuring ARP active acknowledgement
¡     Configuring authorized ARP
¡     Configuring ARP attack detection
¡     Configuring ARP scanning and fixed ARP
¡     Configuring ARP gateway protection
¡     Configuring ARP filtering
If a device receives a large number of unresolvable IP packets from a host, the following situations can occur:
·     The device sends a large number of ARP requests, overloading the target subnets.
·     The device keeps trying to resolve the destination IP addresses, overloading its CPU.
To protect the device from such IP attacks, you can configure the following features:
·     ARP source suppression—Stops resolving packets from an IP address if the number of unresolvable IP packets from the IP address exceeds the upper limit within 5 seconds. The device continues ARP resolution when the interval elapses. This feature is applicable if the attack packets have the same source addresses.
·     ARP blackhole routing—Creates a blackhole route destined for an unresolved IP address. The device drops all matching packets until the blackhole route is deleted. A blackhole route is deleted when its aging timer is reached or the route becomes reachable.
After a blackhole route is created for an unresolved IP address, the device immediately starts the first ARP blackhole route probe by sending an ARP request. If the resolution fails, the device continues probing according to the probe settings. If the IP address resolution succeeds in a probe, the device converts the blackhole route to a normal route. If an ARP blackhole route ages out before the device finishes all probes, the device deletes the blackhole route and does not perform the remaining probes.
This feature is applicable regardless of whether the attack packets have the same source addresses.
2.     Enable ARP source suppression.
arp source-suppression enable
By default, ARP source suppression is disabled.
3.     Set the maximum number of unresolvable packets that the device can process per source IP address within 5 seconds.
By default, the maximum number is 10.
Set the ARP blackhole route probe count to a big value, for example, 25. If the device fails to reach the destination IP address temporarily and the probe count is too small, all probes might finish before the problem is resolved. As a result, non-attack packets will be dropped. This setting can avoid such situation.
2.     Enable ARP blackhole routing.
arp resolving-route enable
By default, ARP blackhole routing is enabled.
3.     (Optional.) Set the number of ARP blackhole route probes for each unresolved IP address.
arp resolving-route probe-count count
The default setting is three probes.
4.      (Optional.) Set the interval at which the device probes ARP blackhole routes.
arp resolving-route probe-interval interval
The default setting is 1 second.
Display ARP source suppression configuration information.
display arp source-suppression
As shown in Figure 1, a LAN contains two areas: an R&D area in VLAN 10 and an office area in VLAN 20. Each area connects to the gateway (Device) through an access switch.
A large number of ARP requests are detected in the office area and are considered an attack caused by unresolvable IP packets. To prevent the attack, configure ARP source suppression or ARP blackhole routing.
Figure 1 Network diagram
·     If the attack packets have the same source address, configure ARP source suppression:
# Enable ARP source suppression.
[Device] arp source-suppression enable
# Configure the device to process a maximum of 100 unresolvable packets per source IP address within 5 seconds.
[Device] arp source-suppression limit 100
·     If the attack packets have different source addresses, configure ARP blackhole routing:
# Enable ARP blackhole routing.
[Device] arp resolving-route enable
This feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within 5 seconds exceeds a threshold, the device generates an ARP attack entry for the MAC address. If the ARP logging feature is enabled, the device handles the attack by using either of the following methods before the ARP attack entry ages out:
·     Monitor—Only generates log messages.
·     Filter—Generates log messages and filters out subsequent ARP packets from the MAC address.
To enable the ARP logging feature, use the arp check log enable command. For information about the ARP logging feature, see ARP configuration in Layer 3—IP Services Configuration Guide.
When an ARP attack entry ages out, ARP packets sourced from the MAC address in the entry can be processed correctly.
When you change the handling method from monitor to filter, the configuration takes effect immediately. When you change the handling method from filter to monitor, the device continues filtering packets that match existing attack entries.
You can exclude the MAC addresses of some gateways and servers from this detection. This feature does not inspect ARP packets from those devices even if they are attackers.
2.     Enable source MAC-based ARP attack detection and specify the handling method.
arp source-mac { filter | monitor }
3.     Set the threshold.
arp source-mac threshold threshold-value
By default, the threshold for source MAC-based ARP attack detection is 30.
4.     Set the aging timer for ARP attack entries.
arp source-mac aging-time time
By default, the lifetime is 300 seconds.
5.     (Optional.) Exclude specific MAC addresses from this detection.
arp source-mac exclude-mac mac-address&<1-10>
By default, no MAC address is excluded.
Display ARP attack entries detected by source MAC-based ARP attack detection.
In standalone mode:
display arp source-mac [ interface interface-type interface-number ]
In IRF mode:
display arp source-mac { interface interface-type interface-number | slot slot-number }
As shown in Figure 2, the hosts access the Internet through a gateway (Device). If malicious users send a large number of ARP requests to the gateway, the gateway might crash and cannot process requests from the clients. To solve this problem, configure source MAC-based ARP attack detection on the gateway.
Figure 2  Network diagram
# Enable source MAC-based ARP attack detection, and specify the handling method as filter.
[Device] arp source-mac filter
# Set the threshold to 30.
[Device] arp source-mac threshold 30
# Set the lifetime for ARP attack entries to 60 seconds.
[Device] arp source-mac aging-time 60
# Exclude MAC address 0012-3f86-e94c from this detection.
[Device] arp source-mac exclude-mac 0012-3f86-e94c
About ARP packet source MAC consistency check
This feature enables a gateway to filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body. This feature allows the gateway to learn correct ARP entries.
2.     Enable ARP packet source MAC address consistency check.
arp valid-check enable
By default, ARP packet source MAC address consistency check is disabled.
About ARP active acknowledgement
Configure this feature on gateways to prevent user spoofing.
ARP active acknowledgement prevents a gateway from generating incorrect ARP entries.
In strict mode, a gateway performs more strict validity checks before creating an ARP entry:
·     Upon receiving an ARP request destined for the gateway, the gateway sends an ARP reply but does not create an ARP entry.
·     Upon receiving an ARP reply, the gateway determines whether it has resolved the sender IP address:
¡     If yes, the gateway performs active acknowledgement. When the ARP reply is verified as valid, the gateway creates an ARP entry.
¡     If no, the gateway discards the packet.
2.     Enable the ARP active acknowledgement feature.
arp active-ack [ strict ] enable
For ARP active acknowledgement to take effect in strict mode, make sure ARP blackhole routing is enabled.
Authorized ARP entries are generated based on the DHCP clients' address leases on the DHCP server or dynamic client entries on the DHCP relay agent. For more information about DHCP server and DHCP relay agent, see Layer 3—IP Services Configuration Guide.
Use this feature to prevent user spoofing and to allow only authorized clients to access network resources.
2.     Enter interface view.
Supported interface types include Layer 3 Ethernet interface, Layer 3 Ethernet subinterface, Layer 3 aggregate interface, Layer 3 aggregate subinterface, and VLAN interface.
3.     Enable authorized ARP on the interface.
arp authorized enable
By default, authorized ARP is disabled.
As shown in Figure 3, configure authorized ARP on GigabitEthernet 1/0/1 of Device A (a DHCP server) to ensure user validity.
Figure 3 Network diagram
1.     Configure Device A:
# Specify the IP address for GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 10.1.1.1 24
# Configure DHCP.
[DeviceA] dhcp enable
[DeviceA] dhcp server ip-pool 1
[DeviceA-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.0
[DeviceA-dhcp-pool-1] quit
# Enter Layer 3 Ethernet interface view.
# Enable authorized ARP.
[DeviceA-GigabitEthernet1/0/1] arp authorized enable
2.     Configure Device B:
[DeviceB-GigabitEthernet1/0/1] ip address dhcp-alloc
# Display authorized ARP entry information on Device A.
[DeviceA] display arp all
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address       MAC address    SVLAN/VSI Interface/Link ID        Aging Type
10.1.1.2         0012-3f86-e94c --        GE1/0/1                  20    D
The output shows that IP address 10.1.1.2 has been assigned to Device B.
Device B must use the IP address and MAC address in the authorized ARP entry to communicate with Device A. Otherwise, the communication fails. Thus user validity is ensured.
As shown in Figure 4, configure authorized ARP on GigabitEthernet 1/0/2 of Device B (a DHCP relay agent) to ensure user validity.
Figure 4 Network diagram
# Configure DHCP.
[DeviceA-dhcp-pool-1] network 10.10.1.0 mask 255.255.255.0
[DeviceA-dhcp-pool-1] gateway-list 10.10.1.1
[DeviceA] ip route-static 10.10.1.0 24 10.1.1.2
# Enable DHCP.
[DeviceB] dhcp enable
# Specify the IP addresses of GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[DeviceB-GigabitEthernet1/0/1] ip address 10.1.1.2 24
[DeviceB-GigabitEthernet1/0/2] ip address 10.10.1.1 24
# Enable DHCP relay agent on GigabitEthernet 1/0/2.
[DeviceB-GigabitEthernet1/0/2] dhcp select relay
# Add the DHCP server 10.1.1.1 to DHCP server group 1.
[DeviceB-GigabitEthernet1/0/2] dhcp relay server-address 10.1.1.1
[DeviceB-GigabitEthernet1/0/2] arp authorized enable
# Enable recording of relay entries on the relay agent.
[DeviceB] dhcp relay client-information record
3.     Configure Device C:
<DeviceC> system-view
[DeviceC] ip route-static 10.1.1.0 24 10.10.1.1
[DeviceC-GigabitEthernet1/0/2] ip address dhcp-alloc
# Display authorized ARP information on Device B.
[DeviceB] display arp all
10.10.1.2        0012-3f86-e94c --        GE1/0/2                  20    D
The output shows that Device A assigned the IP address 10.10.1.2 to Device C.
Device C must use the IP address and MAC address in the authorized ARP entry to communicate with Device B. Otherwise, the communication fails. Thus the user validity is ensured.
ARP attack detection enables access devices to block ARP packets from unauthorized clients to prevent user spoofing and gateway spoofing attacks.
ARP attack detection provides the following features:
·     User validity check.
·     ARP packet validity check.
·     ARP restricted forwarding.
·     ARP attack detection logging.
If both ARP packet validity check and user validity check are enabled, the former one applies first, and then the latter applies.
Do not configure ARP attack detection together with ARP snooping. Otherwise, ARP snooping entries cannot be generated.
This feature/command is supported only on the following ports:
Hardware
Xxxx and port compatibility
MSR2600-6-X1, MSR2600-10-X1
Fixed Layer 2 Ethernet ports.
MSR3600-28, MSR3600-51, MSR3600-28-X1, MSR3600-28-X1-DP, MSR3600-51-X1, MSR3600-51-X1-DP
Routers installed with an Ethernet switching module
Layer 2 Ethernet ports on the following modules:
·     HMIM-8GSW.
·     HMIM-8GSWF.
·     HMIM-24GSW.
·     HMIM-24GSW-PoE.
·     SIC-4GSW.
For more information about the support of the routers for these modules, see H3C MSR Router Series Comware 7 Interface Module Guide.
About user validity check
User validity check does not check ARP packets received on ARP trusted interfaces. This feature compares the sender IP and sender MAC in the ARP packet received on an ARP untrusted interface with the matching criteria in the following order:
1.     User validity check rules.
¡     If a match is found, the device processes the ARP packet according to the rule.
¡     If no match is found or no user validity check rule is configured, proceeds to step 2.
2.     Static IP source guard bindings, 802.1X security entries, and DHCP snooping entries.
¡     If a match is found, the device forwards the ARP packet.
¡     If no match is found, the device discards the ARP packet.
Static IP source guard bindings are created by using the ip source binding command. For more information, see "Configuring IP source guard."
DHCP snooping entries are automatically generated by DHCP snooping. For more information, see Layer 3—IP Services Configuration Guide.
802.1X security entries record the IP-to-MAC mappings for 802.1X clients. After a client passes 802.1X authentication and uploads its IP address to an ARP attack detection enabled device, the device automatically generates an 802.1X security entry. The 802.1X client must be enabled to upload its IP address to the device. For more information, see "Configuring 802.1X."
When you configure user validity check, make sure one or more of the following items are configured:
·     User validity check rules.
·     Static IP source guard bindings.
·     DHCP snooping.
·     802.1X.
If none of the items is configured, all incoming ARP packets on ARP untrusted interfaces are discarded.
Specify an IP address, a MAC address, and a VLAN where ARP attack detection is enabled for an IP source guard binding. Otherwise, no ARP packets can match the IP source guard binding.
2.     (Optional.) Configure a user validity check rule.
arp detection rule rule-id { deny | permit } ip { ip-address [ mask ] | any } mac { mac-address [ mask ] | any } [ vlan vlan-id ]
By default, no user validity check rules are configured.
3.     Enter VLAN view.
vlan vlan-id
4.     Enable ARP attack detection.
arp detection enable
By default, ARP attack detection is disabled.
5.     (Optional.) Configure an interface that does not require ARP user validity check as a trusted interface.
a.     Return to system view.
b.     Enter interface view.
Supported interface types include Layer 2 Ethernet interface and Layer 2 aggregate interface.
c.     Configure the interface as a trusted interface excluded from ARP attack detection.
arp detection trust
By default, an interface is untrusted.
About ARP packet validity check
ARP packet validity check does not check ARP packets received on ARP trusted interfaces. To check ARP packets received on untrusted interfaces, you can specify the following objects to be checked:
·     src-mac—Checks whether the sender MAC address in the message body is identical to the source MAC address in the Ethernet header. If they are identical, the packet is forwarded. Otherwise, the packet is discarded.
·     dst-mac—Checks the target MAC address of ARP replies. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
·     ip—Checks the sender and target IP addresses of ARP replies, and the sender IP address of ARP requests. All-one or multicast IP addresses are considered invalid and the corresponding packets are discarded.
Before you configure ARP packet validity check, you must first configure user validity check. For more information about user validity check configuration, see "Configuring user validity check."
2.     Enter VLAN view.
vlan vlan-id
3.     Enable ARP attack detection.
4.     Enable ARP packet validity check.
b.     Enable ARP packet validity check and specify the objects to be checked.
By default, ARP packet validity check is disabled.
5.     (Optional.) Configure the interface that does not require ARP packet validity check as a trusted interface.
a.     Enter interface view.
b.     Configure the interface as a trusted interface excluded from ARP attack detection.
arp detection trust
About ARP restricted forwarding
ARP restricted forwarding does not take effect on ARP packets received on ARP trusted interfaces and forwards the ARP packets correctly. This feature controls the forwarding of ARP packets that are received on untrusted interfaces and have passed user validity check as follows:
·     If the packets are ARP requests, they are forwarded through the trusted interface.
·     If the packets are ARP replies, they are forwarded according to their destination MAC address. If no match is found in the MAC address table, they are forwarded through the trusted interface.
ARP restricted forwarding does not apply to ARP packets that use multiport destination MAC addresses.
Configure user validity check before you configure ARP restricted forwarding. For information about user validity check configuration, see "Configuring user validity check."
2.     Enter VLAN view.
vlan vlan-id
3.     Enable ARP restricted forwarding.
By default, ARP restricted forwarding is disabled.
Display the VLANs enabled with ARP attack detection.
display arp detection
Display statistics for packets dropped by ARP attack detection.
display arp detection statistics [ interface interface-type interface-number ]
Clear statistics for packets dropped by ARP attack detection.
reset arp detection statistics [ interface interface-type interface-number ]
As shown in Figure 5, configure Device B to perform user validity check based on 802.1X security entries for connected hosts.
Figure 5 Network diagram
1.     Add all interfaces on Device B to VLAN 10, and specify the IP address of VLAN-interface 10 on Device A. (Details not shown.)
2.     Configure the DHCP server on Device A, and configure DHCP address pool 0.
[DeviceA] dhcp server ip-pool 0
[DeviceA-dhcp-pool-0] network 10.1.1.0 mask 255.255.255.0
3.     Configure Host A and Host B as 802.1X clients and configure them to upload IP addresses for ARP attack detection. (Details not shown.)
4.     Configure Device B:
# Enable 802.1X.
[DeviceB] dot1x
[DeviceB-GigabitEthernet1/0/1] dot1x
[DeviceB-GigabitEthernet1/0/2] dot1x
# Add a local user test.
[DeviceB] local-user test
[DeviceB-luser-test] service-type lan-access
[DeviceB-luser-test] password simple test
[DeviceB-luser-test] quit
# Enable ARP attack detection for VLAN 10 to check user validity based on 802.1X entries.
[DeviceB] vlan 10
[DeviceB-vlan10] arp detection enable
# Configure the upstream interface as an ARP trusted interface. By default, an interface is an untrusted interface.
[DeviceB-vlan10] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] arp detection trust
# Verify that ARP packets received on interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are checked against 802.1X entries.
As shown in Figure 6, configure Device B to perform ARP packet validity check and user validity check based on static IP source guard bindings and DHCP snooping entries for connected hosts.
Figure 6 Network diagram
3.     Configure Host A (DHCP client) and Host B. (Details not shown.)
# Enable DHCP snooping.
[DeviceB] dhcp snooping enable
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] dhcp snooping trust
# Enable recording of client information in DHCP snooping entries on GigabitEthernet 1/0/1.
[DeviceB-GigabitEthernet1/0/1] dhcp snooping binding record
# Enable ARP attack detection for VLAN 10.
[DeviceB] vlan 10
# Configure the upstream interface as a trusted interface. By default, an interface is an untrusted interface.
# Configure a static IP source guard binding entry on interface GigabitEthernet 1/0/2 for user validity check.
[DeviceB-GigabitEthernet1/0/2] ip source binding ip-address 10.1.1.6 mac-address 0001-0203-0607 vlan 10
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[DeviceB] arp detection validate dst-mac ip src-mac
# Verify that Device B first checks the validity of ARP packets received on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2. If the ARP packets are confirmed valid, Device B performs user validity check by using the static IP source guard bindings and finally DHCP snooping entries.
As shown in Figure 7, configure ARP restricted forwarding on Device B where ARP attack detection is configured. Port isolation configured on Device B can take effect for broadcast ARP requests.
Figure 7 Network diagram
1.     Configure VLAN 10, add interfaces to VLAN 10, and specify the IP address of VLAN-interface 10 on Device A. (Details not shown.)
# Enable DHCP snooping, and configure GigabitEthernet 1/0/3 as a DHCP trusted interface.
# Enable ARP attack detection for user validity check.
[DeviceB] vlan 10
# Configure GigabitEthernet 1/0/3 as an ARP trusted interface.
# Configure a static IP source guard entry on interface GigabitEthernet 1/0/2.
# Configure port isolation.
[DeviceB] port-isolate group 1
[DeviceB-GigabitEthernet1/0/1] port-isolate enable group 1
[DeviceB-GigabitEthernet1/0/2] port-isolate enable group 1
After the configurations are completed, Device B first checks the validity of ARP packets received on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2. If the ARP packets are confirmed valid, Device B performs user validity check by using the static IP source guard bindings and finally DHCP snooping entries. However, ARP broadcast requests sent from Host A can pass the check on Device B and reach Host B. Port isolation fails.
# Enable ARP restricted forwarding.
[DeviceB] vlan 10
[DeviceB-vlan10] arp restricted-forwarding enable
[DeviceB-vlan10] quit
# Verify that Device B forwards ARP broadcast requests from Host A to Device A through the trusted interface GigabitEthernet 1/0/3. Host B cannot receive such packets. Port isolation operates correctly.
About ARP scanning and fixed ARP
ARP scanning is typically used together with the fixed ARP feature in small-scale and stable networks.
ARP scanning automatically creates ARP entries for devices in an address range. The device performs ARP scanning in the following steps:
1.     Sends ARP requests for each IP address in the address range.
2.     Obtains their MAC addresses through received ARP replies.
3.     Creates dynamic ARP entries.
Fixed ARP converts existing dynamic ARP entries (including those generated through ARP scanning) to static ARP entries. These static ARP entries are of the same attributes as the ARP entries that are manually configured. This feature prevents ARP entries from being modified by attackers.
IP addresses in existing ARP entries are not scanned.
ARP scanning will take some time. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
Due to the limit on the total number of static ARP entries, some dynamic ARP entries might fail the conversion.
The arp fixup command is a one-time operation. You can use this command again to convert the dynamic ARP entries learned later to static.
To delete a static ARP entry converted from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. You can also use the reset arp all command to delete all ARP entries or the reset arp static command to delete all static ARP entries.
3.     Trigger an ARP scanning.
arp scan [ start-ip-address to end-ip-address ]
4.     Return to system view.
5.     Convert existing dynamic ARP entries to static ARP entries.
arp fixup
Configure this feature on interfaces not connected with a gateway to prevent gateway spoofing attacks.
When such an interface receives an ARP packet, it checks whether the sender IP address in the packet is consistent with that of any protected gateway. If yes, it discards the packet. If not, it handles the packet correctly.
You can enable ARP gateway protection for a maximum of eight gateways on an interface.
Do not configure both the arp filter source and arp filter binding commands on an interface.
If ARP gateway protection works with ARP attack detection, ARP snooping, and ARP fast-reply, ARP gateway protection applies first.
3.     Enable ARP gateway protection for the specified gateway.
arp filter source ip-address
By default, ARP gateway protection is disabled.
ARP filtering
The ARP filtering feature can prevent gateway spoofing and user spoofing attacks.
An interface enabled with this feature checks the sender IP and MAC addresses in a received ARP packet against permitted entries. If a match is found, the packet is handled correctly. If not, the packet is discarded.
You can configure a maximum of eight permitted entries on an interface.
If ARP filtering works with ARP attack detection, ARP snooping, and ARP fast-reply, ARP filtering applies first.
3.     Enable ARP filtering and configure a permitted entry.
By default, ARP filtering is disabled.
