| 03-Dial program commands | 100.74 KB |
The following compatibility matrix shows the support of hardware platforms for dial programs:
Hardware |
Dial program compatibility |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK: Yes for only number substitution MSR810-LMS-EA: No |
MSR810-LMS, MSR810-LUS |
No |
MSR2600-6-X1 |
No |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
No |
MSR3610-I-DP, MSR3610-IE-DP |
No |
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC |
Yes |
Yes |
MSR3610-G, MSR3620-G |
No |
To support dial programs, some device models require the Voice Software License. For more information, see license management in Fundamentals Configuration Guide.
caller-group
Use caller-group to configure a voice entity to permit or deny calls from numbers in a subscriber group.
Use undo caller-group to remove the configuration.
caller-group { deny | permit } group-id
undo caller-group { { deny | permit } group-id | all }
A voice entity permits all calling numbers.
POTS entity view
VoIP entity view
IVR entity view
deny: Denies calls from numbers in a subscriber group.
permit: Permits calls from numbers in a subscriber group.
group-id: Specifies a subscriber group by its ID in the range of 1 to 2147483647.
all: Specifies all subscriber groups.
# Configure VoIP entity 1 to permit calls from numbers in subscriber group 1.
[Sysname] voice-setup
[Sysname-voice] dial-program
[Sysname-voice-dial] entity 1 voip
[Sysname-voice-dial-entity1] caller-group permit 1
subscriber-group
caller-permit
Use caller-permit to configure a voice entity to permit calling numbers.
Use undo caller-permit to remove the configuration.
caller-permit caller-string
undo caller-permit { caller-string | all }
POTS entity view
VoIP entity view
IVR entity view
all: Specifies all the configured calling numbers.
caller-string: Specifies a string of 1 to 31 characters in the format of { [ + ] string [ $ ] }| $. The voice entity uses the string to match calling numbers. The following describes the symbols in the format:
· Plus sign (+): If the plus sign (+) is at the beginning of the string, the string indicates an E.164 standard number. For example, +110022 indicates that 110022 is an E.164 standard number.
· Dollar sign ($): Can be used only at the end of the string. The calling number must exactly match the portion of the string before the dollar sign. When the string contains only a dollar sign ($), the permitted calling number is null. If the string has no dollar sign, the calling numbers starting with the string are permitted. For example, the caller-permit 20 command permits all calling numbers starting with 20.
· string: Consists of characters that can include digits 0 through 9, and pound sign (#), asterisk (*), dot (.), exclamation point (!), plus sign (+), percent sign (%), brackets ([ ]), parentheses (()), and hyphen (-). Brackets ([ ]) or parentheses (( )) each are two characters, and any other symbol is one character.
Table 1 Description of characters in a string
0-9 |
Digits 0 through 9. |
Pound sign (#) or asterisk (*) |
Indicates a valid digit. |
Dot (.) |
Wildcard, which can match any valid digit. For example, 555…. can match any 7-digit number beginning with 555. |
Exclamation point (!) |
Indicates that the preceding subexpression appears zero or one time. For example, 56!1234 can match 51234 and 561234. |
Plus sign (+) |
Indicates that the preceding subexpression appears one or more times. For example, 9876(54)+ can match 987654, 98765454, 9876545454, and so on. |
Percent sign (%) |
Indicates that the preceding subexpression appears zero or more times. For example, 9876(54)% can match 9876, 987654, 98765454, 9876545454, and so on. |
Hyphen (-) |
Connects two digits to indicate a range of numbers, for example, [1-9] indicates 1 to 9 inclusive. The hyphen (-) can appear only in brackets ([ ]). |
Brackets ([ ]) |
Indicates a range. Only numbers 0 through 9 are allowed in the range. For example, [1-36] matches 1, 2, 3, or 6. |
Parentheses (( )) |
Indicates a string of characters. For example, (123) indicates the character string 123. It is usually used together with signs such as exclamation point (!), percent sign (%), and plus sign (+). For example, 408(12)+ can match the character string 40812 or 408121212, but not 408 (that is, the string 12 must appear a minimum of one time). |
NOTE: · An exclamation point (!), plus sign (+), or percent sign (%) must follow a valid digit or digit string. · To use brackets ([ ]) and parentheses (( )) together, use them in the form of "( [ ] )". The "( ( ) )", "[ [ ] ]", and "[ ( ) ]" forms are not allowed. |
You can configure a maximum of 32 permitted calling numbers for a voice entity.
# Configure VoIP entity 2 to permit calls from number 1000 and from numbers starting with 20.
[Sysname-voice-dial] entity 2 voip
[Sysname-voice-dial-entity2] caller-permit 1000$
[Sysname-voice-dial-entity2] caller-permit 20
description
Use description to configure a description for a subscriber group.
No description is configured for a subscriber group.
Subscriber group view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description of international for subscriber group 10.
[Sysname-voice-dial] subscriber-group 10
[Sysname-voice-dial-group10] description international
dial-prefix
Use dial-prefix to configure a dial prefix for a POTS entity.
Use undo dial-prefix to restore the default.
dial-prefix string
undo dial-prefix
No dial prefix is configured for a POTS entity.
POTS entity view
string: Specifies a dial prefix, a string of 1 to 31 characters. Valid characters are digits 0 through 9, comma (,), pound sign (#), and asterisk (*).
Table 2 Description of characters in the string argument
Character |
0-9 |
Comma (,) |
One comma represents a pause of 500 milliseconds and it can be positioned anywhere in a number. |
After you configure a dial prefix, the device adds the prefix before each called number. If the called number exceeds 31 digits, the device sends only the first 31 digits.
# Specify a dial prefix of 0 for POTS entity 3.
[Sysname-voice-dial] entity 3 pots
[Sysname-voice-dial-entity3] dial-prefix 0
match-template
dial-program
Use dial-program to enter dial program view.
Use undo dial-program to remove all the settings from dial program view.
dial-program
undo dial-program
Voice view
# Enter dial program view.
dot-match
Use dot-match to configure a dot match rule.
Use undo dot-match to restore the default.
dot-match { end-only | left-right | right-left }
undo dot-match
The dot match rule is end-only.
Number-substitute view
end-only: Matches the digits that correspond to the ending dots (.) in the input template.
left-right: Matches from left to right the digits that correspond to the dots in the input template. The number of matching digits is the number of dots in the output template.
right-left: Matches from right to left the digits that correspond to the dots in the input template. The number of matching digits is the number of dots in the output template.
NOTE: The input and output templates are configured using the rule command. |
The dots here are virtual match digits. Virtual match digits refer to those matching the variable part such as dot (.), plus sign (+), percent sign (%), exclamation point (!), and brackets ([]) in a regular expression. For example, when 1255 is matched with the regular expression 1[234]55, the virtual match digit is 2, when matched with the regular expression 125+, the virtual match digit is 5, and matched with the regular expression 1..5, the virtual match digits are 25.
# Set the dot match rule to right-left for number substitution rule list 20.
[Sysname-voice-dial] number-substitute 20
[Sysname-voice-dial-substitute20] dot-match right-left
rule
entity hunt
Use entity hunt to configure a voice entity selection order.
Use undo entity hunt to restore the default.
entity hunt hunt-number
undo entity hunt
The hunt-number is 0.
Dial program view
hunt-number: Specifies a hunt number in the range of 0 to 7. A hunt number corresponds to a voice entity selection order that includes selection rules.
0: Specifies longest match, voice entity priority, random selection.
1: Specifies longest match, voice entity priority, least recent use.
2: Specifies voice entity priority, longest match, random selection.
3: Specifies voice entity priority, longest match, least recent use.
4: Specifies least recent use, longest match, voice entity priority.
5: Specifies least recent use, voice entity priority, longest match.
6: Specifies random selection.
7: Specifies least recent use.
Selection rule |
Longest match |
Selects the voice entity that matches (from left to right) the most digits of the dialed number. |
Voice entity priority |
Selects the voice entity with the highest priority (configured by using the priority command). |
Random selection |
Selects a voice entity in a random manner. |
Least recent use |
Selects the voice entity that has waited for the longest time since being last selected. |
If the first rule matches multiple voice entities, the second rule applies, and so on.
# Specify the voice entity selection order determined by hunt number 3.
[Sysname-voice-dial] entity hunt 3
priority
first-rule
Use first-rule to configure the preferred number substitution rule.
Use undo first-rule to restore the default.
first-rule id
undo first-rule
No preferred number substitution rule exists.
id: Specifies the preferred number substitution rule by its ID in the range of 0 to 31.
The system first uses the preferred number substitution rule to match the number. If the match fails or the preferred number substitution rule is not configured, the system uses other rules in the order of sequence numbers.
# Specify rule 4 in number substitution list 20 as the preferred number substitution rule.
[Sysname-voice-dial-substitute20] rule 4 663 3
[Sysname-voice-dial-substitute20] first-rule 4
rule
match-template
Use match-template to configure a calling number match template for a subscriber group.
Use undo match-template to delete calling number match templates for a subscriber group.
match-template match-string
undo match-template { match-string | all }
No calling number match templates are configured for a subscriber group.
all: Specifies all calling number match templates.
match-string: Specifies a calling number match string of 1 to 31 characters in the format of { [ + ] string [ $ ] }| $. The following describes the characters in the format:
· Dollar sign ($): Can be used only at the end of the string. The calling number must exactly match the portion of the string before the dollar sign. When the string contains only a dollar sign ($), the permitted calling number is null. If the string has no dollar sign, the calling numbers starting with the string are permitted. For example, the match-template 20 command permits all calling numbers starting with 20.
Table 4 Description of characters in a string
Character |
0-9 |
Dot (.) |
Plus sign (+) |
Percent sign (%) |
Hyphen (-) |
Connects two digits to indicate a range of numbers, for example, [1-9] indicates 1 to 9, inclusive. The hyphen (-) can appear only in brackets ([ ]). |
Brackets ([ ]) |
Parentheses (( )) |
Indicates a string of characters. For example, (123) indicates the character string 123. It is usually used together with signs such as exclamation point (!), percent sign (%), and plus sign (+). For example, 408(12)+ can match the character string 40812 or 408121212, but not 408 (the string 12 must appear a minimum of one time). |
# Configure the calling number match template 1… for subscriber group 2 to match 4-digit calling numbers starting with 1.
[Sysname-voice-dial] subscriber-group 2
[Sysname-voice-dial-group2] match-template 1…
max-conn
Use max-conn to set the maximum number of calls allowed by a voice entity.
Use undo max-conn to restore the default.
max-conn max-number
undo max-conn
The number of calls allowed by a voice entity is not limited.
POTS entity view
VoIP entity view
IVR entity view
max-number: Specifies the maximum number of calls allowed by a voice entity, in the range of 0 to 120.
# Set the maximum number of calls allowed by VoIP entity 10 to 5.
[Sysname-voice-dial] entity 10 voip
[Sysname-voice-dial-entity10] max-conn 5
number-match
Use number-match to configure a global number match mode.
Use undo number-match to restore the default.
number-match { longest | shortest }
undo number-match
Shortest match is used.
Dial program view
longest: Specifies longest match.
shortest: Specifies shortest match.
# Specify longest match.
[Sysname-voice-dial] number-match longest
terminator
number-substitute
Use number-substitute to create a number substitution rule list and enter its view, or enter the view of an existing number substitution rule list.
Use undo number-substitute to delete number substitution rule lists.
number-substitute list-number
undo number-substitute { list-number | all }
No number substitution rule lists exist.
Dial program view
list-number: Specifies an ID for the number substitution rule list, in the range of 1 to 2147483647.
all: Specifies all number substitution rule lists.
#Create a number substitution rule list and enter number-substitute view.
[Sysname-voice-dial] number-substitute 1
[Sysname-voice-dial-substitute1]
priority
Use priority to set a priority for a voice entity.
Use undo priority to restore the default.
priority priority
undo priority
The priority for a voice entity is 0.
POTS entity view
VoIP entity view
IVR entity view
priority: Specifies a priority in the range of 0 to 10. The smaller the value, the higher the priority.
If a number matches multiple voice entities, the device selects the voice entity with the highest priority.
# Set the priority to 5 for POTS entity 10.
[Sysname-voice-dial] entity 10 pots
[Sysname-voice-dial-entity10] priority 5
private-line
Use private-line to configure private line auto ring-down (PLAR).
Use undo private-line to disable PLAR.
private-line string
undo private-line
PLAR is disabled.
FXS/FXO/E&M interface view
Digital voice interface view
string: Specifies the called number, which is a string of 1 to 31 characters that can include digits 0 through 9, asterisk (*), and pound sign (#).
PLAR enables the subscriber line to automatically call the specified called number when the phone goes off-hook.
# Enable PLAR for the called number 1000.
[Sysname] subscriber-line2/1/1
[Sysname-subscriber-line2/1/1] private-line 1000
rule
Use rule to configure a number substitution rule.
Use undo rule to remove number substitution rules.
rule id input-template output-template [ number-type input-number-type output-number-type | numbering-plan input-numbering-plan output-numbering-plan ] *
undo rule { id | all }
No number substitution rules exist.
all: Specifies all number substitution rules.
id: Specifies an ID for the substitution rule, in the range of 0 to 31.
input-template: Configures an input template of 1 to 31 characters in the format of [ ^ ] [ + ] string [ $ ]. The following describes the signs in the format:
· Caret (^): Indicates the match begins with the first character of the string.
· Dollar sign ($): Indicates that the last digit of a number must match the last character of the string.
· string: Consists of characters that can include digits 0 through 9, and pound sign (#), asterisk (*), dot (.), exclamation point (!), and percent sign (%).
Table 5 Description of characters in a string
Character |
Meaning |
0-9 |
Digits from 0 through 9. |
Dot (.) |
Percent sign (%) |
NOTE: An exclamation point (!) or percent sign (%) must follow a valid digit or digit string. |
output-template: Configures an output template, which is a string of 1 to 31 characters that can include digits 0 through 9, pound sign (#), asterisk (*), plus sign (+) and dot (.). The first character can be a plus sign (+). Table 5 describes these characters.
number-type: Specifies input and output number types.
input-template-type: Specifies an input number type. Table 6 describes the values for this argument.
Number type |
abbreviated |
Abbreviated number. |
any |
Any number. |
international |
International number. |
national |
National number that is not in the local network. |
network |
Service network number. |
reserved |
Reserved number. |
subscriber |
Local network number. |
unknown |
Number of an unknown type. |
output-template-type: Specifies an output number type. Table 7 describes the values for this argument.
Number type |
abbreviated |
international |
national |
network |
reserved |
Reserved number. |
subscriber |
unknown |
numbering-plan: Specifies input and output numbering plans.
input-numbering-plan: Specifies an input numbering plan. Table 8 describes the values for this argument.
Numbering plan |
any |
Any numbering plan. |
data |
Data numbering plan. |
isdn |
ISDN telephone numbering plan. |
national |
National numbering plan. |
private |
Private numbering plan. |
reserved |
Reserved numbering plan. |
telex |
Telex numbering plan. |
unknown |
Unknown numbering plan. |
output-numbering-plan: Specifies an output numbering plan. Table 9 describes the values for this argument.
Table 9 Output numbering plans
Numbering plan |
data |
isdn |
national |
private |
reserved |
telex |
unknown |
The following describes the functions of dots in the input-template and output-template arguments:
· Dots in the output-template argument are invalid if the dot match rule is end-only.
If you set the dot match rule to end-only by using the dot-match command, the dots in the output-template argument are invalid. The digits matching the dots at the end of the input template are added to the end of the output number.
For example, suppose you configure the following commands on the calling router where number substitution has been configured for called numbers:
[Sysname-voice-dial-substitute1] dot-match end-only
[Sysname-voice-dial-substitute1] rule 0 ^..10...$ ...267410.
If you dial the number 9810765, the number that matches the input template is 765, and the output number is 267410765.
· Extra dots in the output-template argument are discarded.
· If you set the dot match rule to right-left or left-right by using the dot-match command, and the output template has more dots than the input template, all digits matching the dots in the input template replace the corresponding dots in the output template from left to right, and the remaining dots in the output template are discarded.
[Sysname-voice-dial-substitute1] dot-match right-left
[Sysname-voice-dial-substitute1] rule 0 ^..10...$ ..267410..
If you dial the number 9810765, the number that matches the input template is 8765, and the output number is 8726741065.
# Configure a number substitution rule for number substitution rule list 1. The input template is ^..01...$, and the output template is ...1.
[Sysname-voice-dial-substitute1] rule 0 ^..01...$ ...1
dot-match
first-rule
substitute (Voice dial-program view)
substitute (Voice entity view/Voice subscriber-line view)
send-number
Use send-number to configure the number sending mode.
Use undo send-number to restore the default.
send-number { digit-number | all | truncate }
undo send-number
The truncate mode is used.
POTS entity view
digit-number: Specifies the number of digits (extracted from the end of a number) to be sent, in the range of 0 to 31. It must be no greater than the total number of digits in the called number.
all: Sends all the digits of a called number.
truncate: Sends a truncated called number. When the match-template command configured on the voice entity contains dots (.), only the digits that match the dots are sent.
# Configure POTS entity 10 to send all the digits of called numbers.
[Sysname-voice-dial-entity10] send-number all
match-template
subscriber-group
Use subscriber-group to create a subscriber group and enter its view, or enter the view of an existing subscriber group.
Use undo subscriber-group to delete subscriber groups.
subscriber-group group-id
undo subscriber-group { group-id | all }
No subscriber groups exist.
Dial program view
group-id: Specifies a subscriber group ID in the range of 1 to 2147483647.
You can create a maximum of 10 subscriber groups.
# Create subscriber group 1 and enter its view.
[Sysname-voice-dial-group1]
substitute (voice entity view, voice interface view)
Use substitute to apply a number substitution rule list to the calling or called numbers on a voice entity or a voice interface.
Use undo substitute to remove the application.
substitute { called | calling } list-number
undo substitute { called | calling }
No number substitution rule list is applied to a voice entity (the voice entity does not perform number substitution).
POTS/VoIP/IVR entity view
Voice interface view
called: Applies the number substitution rule to called numbers.
calling: Applies the number substitution rule to calling numbers.
list-number: Specifies a number substitution rule list by its number in the range of 1 to 2147483647.
# Apply number substitution rule list 6 to called numbers on POTS entity 10.
[Sysname-voice-dial-entity10] substitute called 6
# Apply number substitution rule list 6 to called numbers on voice interface 2/1/1.
[Sysname-voice] subscriber-line2/1/1
[Sysname-voice-line2/1/1] substitute called 6
number-substitute
rule
substitute (dial program view)
Use substitute to apply a number substitution rule list to the calling or called numbers of incoming or outgoing calls.
substitute { incoming-call | outgoing-call } { called | calling } list-number
undo substitute { incoming-call | outgoing-call } { called | calling } { list-number | all }
No number substitution rule list is applied (no number substitution is performed).
Dial program view
incoming-call: Applies the number substitution rule list to incoming calls.
outgoing-call: Applies the number substitution rule list to outgoing calls.
called: Applies the number substitution rule list to called numbers.
calling: Applies the number substitution rule list to calling numbers.
You can apply a maximum of 32 number substitution rule lists.
# Apply number substitution rule list 5 to the called numbers of incoming calls.
[Sysname-voice-dial] substitute incoming-call called 5
# Apply number substitution rule lists 5, 6, and 8 to the called numbers of outgoing calls.
[Sysname-voice-dial] substitute outgoing-call called 5
[Sysname-voice-dial] substitute outgoing-call called 6
[Sysname-voice-dial] substitute outgoing-call called 8
number-substitute
rule
terminator
Use terminator to configure a dial terminator.
Use undo terminator to restore the default.
terminator character
undo terminator
No dial terminator is configured.
Dial program view
character: Specifies a dial terminator, a single character that can be a digit, pound sign (#), or asterisk (*).
The dial terminator identifies the end of a number. The device immediately places a call upon receiving the dial terminator.
Do not configure a character included in a called number as a dial terminator.
# Specify the pound sign (#) as the dial terminator.
[Sysname-voice-dial] terminator #
