04-Layer 2 - LAN Switching Configuration Guide
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release757X-6W10004-Layer 2 - LAN Switching Configuration Guide
07-QinQ configuration
07-QinQ configuration 162.83 KB
Configuring QinQ
This document uses the following terms:
·     CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
·     SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
Overview
802.1Q-in-802.1Q (QinQ) adds an 802.1Q tag to 802.1Q tagged customer traffic. It enables a service provider to extend Layer 2 connections across an Ethernet network between customer sites.
QinQ provides the following benefits:
·     Enables a service provider to use a single SVLAN to convey multiple CVLANs for a customer.
·     Enables customers to plan CVLANs without conflicting with SVLANs.
·     Enables customers to keep their VLAN assignment schemes unchanged when the service provider changes its VLAN assignment scheme.
·     Allows different customers to use overlapping CVLAN IDs. Devices in the service provider network make forwarding decisions based on SVLAN IDs instead of CVLAN IDs.
How QinQ works
As shown in Figure 1, a QinQ frame transmitted over the service provider network carries the following tags:
·     CVLAN tag—Identifies the VLAN to which the frame belongs when it is transmitted in the customer network.
·     SVLAN tag—Identifies the VLAN to which the QinQ frame belongs when it is transmitted in the service provider network. The service provider allocates the SVLAN tag to the customer.
The devices in the service provider network forward a tagged frame according to its SVLAN tag only. The CVLAN tag is transmitted as part of the frame's payload.
Figure 1 Single-tagged Ethernet frame header and double-tagged Ethernet frame header
As shown in Figure 2, customer A has remote sites CE 1 and CE 4. Customer B has remote sites CE 2 and CE 3. The CVLANs of the two customers overlap. The service provider assigns SVLANs 3 and 4 to customers A and B, respectively.
When a tagged Ethernet frame from CE 1 arrives at PE 1, the PE tags the frame with SVLAN 3. The double-tagged Ethernet frame travels over the service provider network until it arrives at PE 2. PE 2 removes the SVLAN tag of the frame, and then sends the frame to CE 4.
Figure 2 Typical QinQ application scenario
QinQ implementations
QinQ is enabled on a per-port basis. The link type of a QinQ-enabled port can be access, hybrid, or trunk. The QinQ tagging behaviors are the same across these types of ports.
A QinQ-enabled port tags all incoming frames (tagged or untagged) with the PVID tag.
·     If an incoming frame already has one tag, it becomes a double-tagged frame.
·     If the frame does not have any 802.1Q tags, it becomes a frame tagged with the PVID.
QinQ provides the most basic VLAN manipulation method to tag all incoming frames (tagged or untagged) with the PVID tag. To perform advanced VLAN manipulations, use VLAN mappings or QoS policies as follows:
·     To add different SVLANs for different CVLAN tags, use one-to-two VLAN mappings.
·     To replace the SVLAN ID, CVLAN ID, or both IDs for an incoming double-tagged frame, use two-to-two VLAN mappings.
·     QinQ and two-to-two mappings are mutually exclusive. The device does not support adding an SVLAN tag on a QinQ-enabled port and then modifying the CVLAN and SVLAN IDs.
·     To use criteria other than the CVLAN ID to match packets for SVLAN tagging, use the QoS nest action. The QoS nest action can also be used with other actions in the same traffic behavior.
·     To set the 802.1p priority in SVLAN tags, use the priority marking action as described in "Setting the 802.1p priority in SVLAN tags."
For more information about VLAN mappings, see "Configuring VLAN mapping." For more information about QoS, see ACL and QoS Configuration Guide.
Protocols and standards
·     IEEE 802.1Q, IEEE Standard for Local and Metropolitan Area Networks-Virtual Bridged Local Area Networks
·     IEEE 802.1ad, IEEE Standard for Local and Metropolitan Area Networks-Virtual Bridged Local Area Networks-Amendment 4: Provider Bridges
When you configure QinQ, follow these restrictions and guidelines:
·     The inner 802.1Q tag of QinQ frames is treated as part of the payload. As a best practice to ensure correct transmission of QinQ frames, set the MTU to a minimum of 1504 bytes for each port on their forwarding path. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a VLAN tag.
·     You can use a QoS policy, a VLAN mapping, and QinQ on a port for VLAN tag manipulation. If their settings conflict, the QoS policy has the highest priority, the VLAN mapping has the medium priority, and QinQ has the lowest priority.
Enabling QinQ
Enable QinQ on customer-side ports of PEs. A QinQ-enabled port tags an incoming frame with its PVID.
Before you enable or disable QinQ on a port, you must remove any VLAN mappings on the port.
To enable QinQ:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
3.     Enable QinQ.
qinq enable
By default, QinQ is disabled.
Configuring transparent transmission for VLANs
You can exclude a VLAN (for example, the management VLAN) from the QinQ tagging action on a customer-side port. This VLAN is called a transparent VLAN.
An interface configured with both QinQ and transparent VLAN transmission does not support Layer 3 forwarding.
To ensure successful transmission for a transparent VLAN, follow these configuration guidelines:
·     Set the link type of the port to trunk or hybrid, and assign the port to the transparent VLAN.
·     Do not configure any other VLAN manipulation actions for the transparent VLAN on the port.
·     Make sure all ports on the traffic path permit the transparent VLAN to pass through.
·     If you use both transparent VLANs and VLAN mappings on an interface, the transparent VLANs cannot be the following VLANs:
¡     Original or translated VLANs of one-to-one, one-to-two, and many-to-one VLAN mappings.
¡     Original or translated outer VLANs of two-to-two VLAN mappings.
Configuration procedure
To enable transparent transmission for a list of VLANs:
Step
Remarks
N/A
N/A
3.     Set the port link type.
port link-type { hybrid | trunk }
By default, the link type of a port is access.
4.     Configure the port to allow packets from its PVID and the transparent VLANs to pass through.
·     For the hybrid port:
·     For the trunk port:
By default, a trunk port allows packets only from VLAN 1 to pass through. A hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
5.     Specify transparent VLANs.
qinq transparent-vlan vlan-id-list
By default, transparent transmission is not configured for any VLANs.
Configuring the TPID for VLAN tags
TPID identifies a frame as an 802.1Q tagged frame. The TPID value varies by vendor. On an H3C device, the TPID in the 802.1Q tag added on a QinQ-enabled port is 0x8100 by default, in compliance with IEEE 802.1Q. In a multi-vendor network, make sure the TPID setting is the same between directly connected devices so 802.1Q tagged frames can be identified correctly.
TPID settings include CVLAN TPID and SVLAN TPID.
A QinQ-enabled port uses the CVLAN TPID to match incoming tagged frames. An incoming frame is handled as untagged if its TPID is different from the CVLAN TPID.
SVLAN TPIDs are configurable on a per-port basis. A service provider-side port uses the SVLAN TPID to replace the TPID in outgoing frames' SVLAN tags and match incoming tagged frames. An incoming frame is handled as untagged if the TPID in its outer VLAN tag is different from the SVLAN TPID.
For example, a PE device is connected to a customer device that uses the TPID 0x8200 and to a provider device that uses the TPID 0x9100. For correct packet processing, you must set the CVLAN TPID and SVLAN TPID to 0x8200 and 0x9100 on the PE, respectively.
The TPID field is at the same position as the EtherType field in an untagged Ethernet frame. To ensure correct packet type identification, do not set the TPID value to any of the values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86dd
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88cc
802.1X
0x888e
802.1ag
0x8902
Cluster
0x88a7
Reserved
0xfffd/0xfffe/0xffff
Configuring the TPID for CVLAN tags
Perform this task on the PE device.
To configure the TPID value for CVLAN tags:
Step
Remarks
N/A
2.     Configure the TPID for CVLAN tags.
qinq ethernet-type customer-tag hex-value
The default setting is 0x8100.
Configuring the TPID for SVLAN tags
Perform this task on the service provider-side ports of PEs.
To configure the TPID value for SVLAN tags:
Step
Remarks
N/A
N/A
3.     Configure the TPID for SVLAN tags.
qinq ethernet-type service-tag hex-value
The following methods are supported in a QoS policy for setting the 802.1p priority in SVLAN tags:
·     Mark the 802.1p priority in SVLAN tags based on the CVLAN IDs or 802.1p priority in CVLAN tags.
·     Copy the 802.1p priority in CVLAN tags to SVLAN tags.
For more information about QoS policy commands, see ACL and QoS Command Reference.
To set the 802.1p priority in SVLAN tags:
Step
Remarks
N/A
2.     Create a traffic class and enter its view.
By default, no traffic classes exist.
3.     Configure CVLAN match criteria.
·     Match CVLAN IDs:
if-match customer-vlan-id vlan-id-list
·     Match 802.1p priority:
if-match customer-dot1p dot1p-value&<1-8>
N/A
4.     Return to system view.
N/A
5.     Create a traffic behavior and enter its view.
By default, no traffic behaviors exist.
6.     Configure a priority marking action for SVLAN tags.
·     Replace the priority in the SVLAN tags of matching frames with the configured priority:
remark dot1p dot1p-value
·     Copy the 802.1p priority in the CVLAN tag to the SVLAN tag:
By default, the device copies the 802.1p priority in the CVLAN tag to the SVLAN tag.
7.     Return to system view.
N/A
8.     Create a QoS policy and enter its view.
qos policy policy-name
By default, no QoS policies exist.
9.     Specify the traffic behavior for the traffic class in the QoS policy.
classifier classifier-name behavior behavior-name
N/A
10.     Return to system view.
N/A
11.     Enter Layer 2 Ethernet interface view.
N/A
12.     Configure the port to trust the 802.1p priority in incoming frames.
qos trust dot1p
This step is required if the remark dot1p command is configured and is optional if the remark dot1p customer-dot1p-trust command is configured.
13.     Enable QinQ.
qinq enable
N/A
14.     Apply the QoS policy to the inbound direction of the port.
N/A
Displaying and maintaining QinQ
Display QinQ-enabled ports.
display qinq [ interface interface-type interface-number ]
QinQ configuration examples
Basic QinQ configuration example
Network requirements
As shown in Figure 3:
·     The service provider assigns VLAN 100 to Company A's VLANs 10 through 70.
·     The service provider assigns VLAN 200 to Company B's VLANs 30 through 90.
·     The devices between PE 1 and PE 2 in the service provider network use a TPID value of 0x8200.
Configure QinQ on PE 1 and PE 2 to transmit traffic in VLANs 100 and 200 for Company A and Company B, respectively.
For the QinQ frames to be identified correctly, set the SVLAN TPID to 0x8200 on the service provider-side ports of PE 1 and PE 2.
Figure 3 Network diagram
1.     Configure PE 1:
# Configure Ten-GigabitEthernet 1/1/1 as a trunk port, and assign it to VLAN 100.
<PE1> system-view
[PE1] interface ten-gigabitethernet 1/1/1
[PE1-Ten-GigabitEthernet1/1/1] port link-type trunk
[PE1-Ten-GigabitEthernet1/1/1] port trunk permit vlan 100
# Set the PVID of Ten-GigabitEthernet 1/1/1 to VLAN 100.
[PE1-Ten-GigabitEthernet1/1/1] port trunk pvid vlan 100
# Enable QinQ on Ten-GigabitEthernet 1/1/1.
[PE1-Ten-GigabitEthernet1/1/1] qinq enable
[PE1-Ten-GigabitEthernet1/1/1] quit
# Configure Ten-GigabitEthernet 1/1/2 as a trunk port, and assign it to VLANs 100 and 200.
[PE1] interface ten-gigabitethernet 1/1/2
[PE1-Ten-GigabitEthernet1/1/2] port link-type trunk
[PE1-Ten-GigabitEthernet1/1/2] port trunk permit vlan 100 200
# Set the TPID value in the SVLAN tags to 0x8200 on Ten-GigabitEthernet 1/1/2.
[PE1-Ten-GigabitEthernet1/1/2] qinq ethernet-type service-tag 8200
[PE1-Ten-GigabitEthernet1/1/2] quit
# Configure Ten-GigabitEthernet 1/1/3 as a trunk port, and assign it to VLAN 200.
[PE1] interface ten-gigabitethernet 1/1/3
[PE1-Ten-GigabitEthernet1/1/3] port link-type trunk
[PE1-Ten-GigabitEthernet1/1/3] port trunk permit vlan 200
# Set the PVID of Ten-GigabitEthernet 1/1/3 to VLAN 200.
[PE1-Ten-GigabitEthernet1/1/3] port trunk pvid vlan 200
# Enable QinQ on Ten-GigabitEthernet 1/1/3.
[PE1-Ten-GigabitEthernet1/1/3] qinq enable
[PE1-Ten-GigabitEthernet1/1/3] quit
2.     Configure PE 2:
# Configure Ten-GigabitEthernet 1/1/1 as a trunk port, and assign it to VLAN 200.
<PE2> system-view
[PE2] interface ten-gigabitethernet 1/1/1
[PE2-Ten-GigabitEthernet1/1/1] port link-type trunk
[PE2-Ten-GigabitEthernet1/1/1] port trunk permit vlan 200
# Set the PVID of Ten-GigabitEthernet 1/1/1 to VLAN 200.
[PE2-Ten-GigabitEthernet1/1/1] port trunk pvid vlan 200
[PE2-Ten-GigabitEthernet1/1/1] qinq enable
[PE2-Ten-GigabitEthernet1/1/1] quit
[PE2] interface ten-gigabitethernet 1/1/2
[PE2-Ten-GigabitEthernet1/1/2] port link-type trunk
[PE2-Ten-GigabitEthernet1/1/2] port trunk permit vlan 100 200
[PE2-Ten-GigabitEthernet1/1/2] qinq ethernet-type service-tag 8200
[PE2-Ten-GigabitEthernet1/1/2] quit
# Configure Ten-GigabitEthernet 1/1/3 as a trunk port, and assign it to VLAN 100.
[PE2] interface ten-gigabitethernet 1/1/3
[PE2-Ten-GigabitEthernet1/1/3] port link-type trunk
[PE2-Ten-GigabitEthernet1/1/3] port trunk permit vlan 100
# Set the PVID of Ten-GigabitEthernet 1/1/3 to VLAN 100.
[PE2-Ten-GigabitEthernet1/1/3] port trunk pvid vlan 100
[PE2-Ten-GigabitEthernet1/1/3] qinq enable
[PE2-Ten-GigabitEthernet1/1/3] quit
3.     Configure the devices between PE 1 and PE 2:
# Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. (Details not shown.)
# Configure all ports on the forwarding path to allow frames from VLANs 100 and 200 to pass through without removing the VLAN tag. (Details not shown.)
VLAN transparent transmission configuration example
As shown in Figure 4:
·     The service provider assigns VLAN 100 to a company's VLANs 10 through 50.
·     VLAN 3000 is the dedicated VLAN of the company on the service provider network.
Configure QinQ on PE 1 and PE 2 to provide Layer 2 connectivity for CVLANs 10 through 50 over the service provider network.
Configure VLAN transparent transmission for VLAN 3000 on PE 1 and PE 2 to enable the hosts in VLAN 3000 to communicate without using an SVLAN.
Figure 4 Network diagram
1.     Configure PE 1:
# Configure Ten-GigabitEthernet 1/1/1 as a trunk port, and assign it to VLANs 100 and 3000.
<PE1> system-view
[PE1-Ten-GigabitEthernet1/1/1] port trunk permit vlan 100 3000
# Enable transparent transmission for VLAN 3000 on Ten-GigabitEthernet 1/1/1.
[PE1-Ten-GigabitEthernet1/1/1] qinq transparent-vlan 3000
# Configure Ten-GigabitEthernet 1/1/2 as a trunk port, and assign it to VLANs 100 and 3000.
[PE1-Ten-GigabitEthernet1/1/2] port trunk permit vlan 100 3000
2.     Configure PE 2:
<PE2> system-view
[PE2-Ten-GigabitEthernet1/1/1] port trunk permit vlan 100 3000
[PE2-Ten-GigabitEthernet1/1/1] qinq transparent-vlan 3000
[PE2-Ten-GigabitEthernet1/1/2] port trunk permit vlan 100 3000
# Configure all ports on the forwarding path to allow frames from VLANs 100 and 3000 to pass through without removing the VLAN tag. (Details not shown.)
